2018 Tundra LED headlight wiring info with diagrams
Discussion in 'Lighting' started by thomasbus337, Sep 6, 2017.
  1. Dec 15, 2017 at 12:52 PM
    #751
    dakient
    dakient New Member
    Thanks iHacker, I did try that but couldn't find anything. Also, there is a DRL fuse under the hood but it isn't used on the SR5/Pro, I assume it's for the Platinums with the OEM LED DRL.
    That might be worth trying just to see what happens, but several guys have left purple wire taped up and had the Amber DRL work fine (using Leo's harness). Here is post #269 from the Eledobleu's harness thread:
    But here is an option for you that wasn't clear in the instructions for me. I actually LIKE the AMBER DRLs on bright during the day. So...I unpinned the purple wire in the amber drl connector but NEVER cut the gray wire inside and it works just how I like it. Similar to our old headlights....when I turn on my car, the amber DRLs become bright ALONG with the LED DRL strip. (this is with or without the parking lights turned on). Only with the headlights turned on does the amber DRL turn off and is only lit when the blinker is used. TBH....its pretty striking during the day or in the evenings when you don't need the headlights yet and both the bright amber and bright LED drls are on together. (PS....it's an SR5....so the LEDs are bight all the time) Ill post pics.
  2. Dec 16, 2017 at 6:32 PM
    #752
    Hookee
    Hookee New Member
    2016 Toyota Tundra
    Been lurking this thread for some time now. I am going to be buying the LED lights after seeing such great pictures and results. The one thing I don't like about the tundra is the headlights, they suck IMO. Couple of questions -- The stock headlight leveling switch will no longer work after installing the 2018 LED's correct? Who can create a plug and play harness for a 2016 Tundra Platinum to 2018 LED's?
  3. Dec 16, 2017 at 7:18 PM
    #753
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Headlights Leveling still work in the 2018 LEDs same way as your old halogens, the connector is the same 3 way Plug, nothing changed on this function.
    darkknight2014 likes this.
  4. Dec 20, 2017 at 5:29 AM
    #754
    Triton19X2
    Triton19X2 New Member
    2021 Silver 1794 Crewmax 4X4
    Hope someone can help me here. I have Leo's harness but I am trying to wrap my head around what wires attach to what. Do the labled wires on the Moto attach directly to the headlights or to the original headlight wires coming from the truck?
  5. Dec 20, 2017 at 6:21 AM
    #755
    iHacker
    iHacker SW TRD PRO
    Mario
    The 3 prong conector in th Motocontrol connects to the OEM H4 connector, there are 2 leads in the motocontrol one labeled “Ballast” and this will power your Lo Beam in the harness and the other labeled as “High Beam” is for the high beam,
    The remaining connector in the harness will plug to the LED DRL harness
  6. Dec 20, 2017 at 9:53 AM
    #756
    Triton19X2
    Thank you sir! So the OEM H4 connector is the wire that currently plugs into the stock light right? So the Mto only has 1 of those so what happens to the OEM H4 from the passanger side light...tape it up?
    Sorry for all the questions ...just need to understand it all before I start tearing it apparto_O
  7. Dec 20, 2017 at 9:58 AM
    #757
    iHacker
    iHacker SW TRD PRO
    Mario
    Yeah is the connector you currently using in your stock headlights, the one in passenger side must covered I first use a coat of painters tape and then electrical tape to weatherproof it, this will never be used unless you go back to stock headlights
  8. Dec 20, 2017 at 10:01 AM
    #758
    Triton19X2
    :thumbsup::thumbsup: iHacker, you are the MAN! That makes better since now....thanks for the help!:hattip:
    iHacker likes this.
  9. Dec 20, 2017 at 10:11 AM
    #759
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    picture of the plug? going to install mine this weekend and want it to be as straight forward as possible :)
  10. Dec 20, 2017 at 10:23 AM
    #760
    iHacker
    iHacker SW TRD PRO
    Mario
    Is the brown plug in picture, you go to use the driver side only
    Passenger side must be like this covered in tape
    Triton19X2 likes this.
  11. Dec 20, 2017 at 10:27 AM
    #761
    fisherman951
    Tony
    2017 crewmax 4x4
    Thank u sir. Always helping us out. Cant wait tonget my lights on this weekend
    iHacker[QUOTED] likes this.
  12. Dec 21, 2017 at 1:03 PM
    #762
    Triton19X2
    got them hooked up but i have a fast blink on blinkers. I de pinned the purple wires and taped them and swapped the other two...mine is a 2016
    I do have LED bulbs in my fog lights but that should not matter right?
  13. Dec 21, 2017 at 2:05 PM
    #763
    Triton19X2
    figured it out....thought I had to swap the red and the white but the red had to be moved to the #3 location in the plug
    iHacker likes this.
  14. Dec 22, 2017 at 7:22 AM
    #764
    Triton19X2
    Thanks iHacker for the help with this eventhough I had bought another harness before realizing you had one as well. For now I like the ambers and DRL staying bright all the time.....Thanks Again!:cheers:
    iHacker likes this.
  15. Dec 22, 2017 at 10:26 AM
    #765
    iHacker
    iHacker SW TRD PRO
    Mario
    Really nice setup :thumbsup::thumbsup::thumbsup:
    tgun likes this.
  16. Dec 24, 2017 at 12:32 AM
    #766
    inferno_pro_satx
    inferno_pro_satx New Member
    Roger
    2016 Tundra TRD Pro
    Sorry been busy the last few weeks, with Toyota’s wiring at the flasher relay the purple wire controls both the parking light & amber drl.
  17. Dec 24, 2017 at 12:39 AM
    #767
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    The lights are flashing with the locking & unlocking because of the red or pink wire depending on sides. The amber or parking lights aren’t gonna Work because you have the purple removed
  18. Dec 26, 2017 at 8:08 PM
    #768
    looks_smart
    looks_smart New Member
    KIM
    Seoul, Korea
    2017 WHITE TRD PRO
    2018 LED HEADLIGHT&FOG, BAK Flip MX4
    Exactly same situation for me. Did u solve it?
  19. Dec 28, 2017 at 10:25 PM
    #769
    u2asian
    u2asian New Member
    Not sure if this has been discussed on any of the threads regarding the switch backs for the 2018 LED headlights but I received my VLEDs Triton V6 3157CK kits the other day and attempted to install them. Found the 2018 LED headlight assembles have 7444NA instead of the 4157NAK bulbs so my adapters that came with the kit did not fit. Had to order the correct adapter kits:
    http://www.vleds.com/v6-base-7443.html?___store=default
    Here is what is show in the 2018 manual:
  20. Dec 28, 2017 at 10:33 PM
    #770
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    What you can do is pull your signal socket from your pre 2018 lights and it will fit.
  21. Dec 28, 2017 at 11:06 PM
    #771
    u2asian
    u2asian New Member
    Didn't think of that! Thank you for the info. Sold my lights though so good tip for others.
    BlueBottle[QUOTED] likes this.
  22. Dec 28, 2017 at 11:09 PM
    #772
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Also if you revert back to the old sockets you need to repin it again. Since you ordered he correct adapter you don’t need repin.
  23. Dec 30, 2017 at 1:52 PM
    #773
    slide187
    slide187 New Member
    Boston, MA
    2015 Silver Sky Metallic DC Limited Tundra
    Console Cavern Organizer Mod, Driver's Forward Assist Handle Tonno Pro Hardfold, Body Colored Door Handles, Body Colored Mirror Caps, MBRP Stainless XP Series Dual Exhaust, OEM Bed Extender
    Finished my install today! too damn cold to get more pics right now tho!! (like 6 deg.) Thanks to everyone for all the help, especially @iHacker!! His harness really is top notch!! And he helped me with a few questions i had during the install. Worth every penny! Fogs are next on the list!
    inferno_pro_satx and iHacker like this.
  24. Jan 4, 2018 at 7:15 PM
    #774
    nucmedcurtis
    nucmedcurtis New Member
    Curtis
    2016 Balzing Blue Pearl TSS
    TRD PRO Grille TRD PRO Air Box
    Did you ever get your harness built and tested?
  25. Jan 11, 2018 at 7:28 PM
    #775
    PTO22
    PTO22 New Member
    Paul
    2015 1794 metallic ribbon blue
    TRD suspension and intake
  26. Jan 12, 2018 at 6:29 PM
    #776
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    How are yo uguys getting the drl to switch off with the turn signal?
  27. Jan 12, 2018 at 6:38 PM
    #777
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Diode Dynamics switchbacks
  28. Jan 12, 2018 at 6:38 PM
    #778
    BlueBottle
    '16 Platinum 4x4
    See fine print
    iHacker likes this.
  29. Jan 12, 2018 at 6:40 PM
    #779
    xtyfighterx
    Ty
    North Idaho
  30. Jan 12, 2018 at 7:04 PM
    #780
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Yes correct. That does that.
