2018 Tundra LED headlight wiring info with diagrams
Discussion in 'Lighting' started by thomasbus337, Sep 6, 2017.
  1. Nov 18, 2017 at 8:35 AM
    #721
    thomasbus337
    thomasbus337 [OP] New Member
    2020 TRD Sport DC
    I missed a wire input in the last post. Here's the info copied and pasted from another source
    There are three input wires: black, yellow, and white.
    • Black is GROUND, and should be connected to a constant chassis ground.
    • White is STATIC, or running light input.
    • Yellow is TURN signal input. This will also shut off the static output, so it could be treated as a "shutoff" wire for DRL applications.
    The output wires are:
    • White: static output. When power is applied to STATIC, and turn signal is not activated, it will output 12V power. For example, you might connect this to a white light to act as a running light.
    • Yellow: Turn signal output. You might connect to an amber or red LED, to become a turn signal. The static output will shut off, "switchback" style, while the turn signal is running. If you are using the TURN as a "shutoff" wire, just leave this wire disconnected.
    • Black: extra ground output. This does not need to be connected- it is an extra ground point. You can connect LEDs to ground here, or anywhere on the chassis.
    Input wires are male spade connectors, with T-taps for installation. Output wires are bare leads, for connection to LEDs.
    Gee Dub likes this.
  2. Nov 20, 2017 at 8:01 PM
    #722
    TuffTundra
    TuffTundra New Member
    Missouri
    2016 MGM SR5
    4" Rough Country Lift - Fuel Assault 20x10 - Nitto Ridge Grapplers 33x12.5x20 - 2018 LED Headlights - LED Lights all around - No Chrome - Tinted Windows & Tail Lights
    @thomasbus337 Could you please post a photo of this switchback module installed on your truck? I got my 2018 headlights to work with your help as well as some other guys but just want to make sure I install this module correctly without screwing up my harness but cutting the wrong wires. Thanks again for your help!
    Oh and I'm guessing you installed this module because this is how they work on 2018 trucks?
  3. Nov 21, 2017 at 5:41 PM
    #723
    Azblue
    The Dirty T ( ^_^)_且
    OK, couple of stupid questions for all of you that have done the swap in preparation of doing mine.
    Do the new headlights ship in a "standard" position relative to the height adjustment knob? In other words, should I set the adjuster, say to the middle setting, before swapping headlights or does it not matter?
    Are most just using the stock turn signal bulb, or has anyone switched to an LED? Are the 7443 bulbs "CK" like the old 3157's?
  4. Nov 21, 2017 at 6:14 PM
    #724
    inferno_pro_satx
    inferno_pro_satx New Member
    Roger
    2016 Tundra TRD Pro
    They come shipped in the middle , the new 7444 is a weird looking bulb. I haven’t tried but pretty positive the 3157 won’t fit.
    mesaboogieman likes this.
  5. Nov 21, 2017 at 6:29 PM
    #725
    Azblue
    Thanks for the info on position. On the bulbs, the reason I ask is that I already had LEDs front and rear for my turn signals, so I have 1 3ohm Vled resistor mounted per side. If I use the standard bulb that ships with the 2018 headlights for the turn signals then I would need to either change my resistors to 6ohm or remove the resistors and change back to standard bulbs in the rear turns. I'd like to keep 3 ohm resistors and my rear LED turn bulbs and upgrade the new 2018 headlights to LED turn signal bulbs. I just need to know if the new front bulbs are 7443 or 7443CK. None of the online parts sites has the info for 2018's yet.
  6. Nov 21, 2017 at 6:32 PM
    #726
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    I’m using the bulbs that shipped with the headlights and didn’t remove the resistors. Seen no impact leaving them on, it’s been 6-7weeks no issues.
    Azblue[QUOTED] and mesaboogieman like this.
  7. Nov 27, 2017 at 6:26 PM
    #727
    geno0506
    geno0506 New Member
    Michael
    What is the difference between the black housing and the chrome housing
    Are the lens on both clear or is the black housing a smoked lens
  8. Nov 27, 2017 at 7:29 PM
    #728
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    The lenses are the same, just the inside bezel are lightly blacked out.
    geno0506[QUOTED] likes this.
  9. Nov 29, 2017 at 2:37 PM
    #729
    StevenH1
    StevenH1 New Member
    steven
    Hey guys!
    So I would like to switch my factory Headlights on my 2017 SR5,
    I found this Harness kit on internet: https://www.bmotorsports.com/shop/p...X7xZAmrnSY3cHioFtUpZnS6WGatFWMbIaApifEALw_wcB
    For what I can read in the description I will need to buy x2 of those and also 2 Relay kits: http://www.morimotohid.com/motocontrol-bi-xenon-h4-9003.html
    Could anyone tell me if im on the right thing? also which bulbs should I buy for the new head lights?
    having the harness and the relay kits will be just matter of plug n play or ill need to do any further modifications?
    Any further instructions - guidance from those who have already done the conversion will be highly appreciated!!
    Thx.
  10. Nov 29, 2017 at 6:13 PM
    #730
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    The harness you see is for the platinum/1794 trim so it won’t work on SR5. And only 1 motocontrol will be needed, get with @iHacker he’s selling complete harness kits for your trim all plug & play.
    geno0506 likes this.
  11. Nov 30, 2017 at 3:58 PM
    #731
    slide187
    slide187 New Member
    Boston, MA
    2015 Silver Sky Metallic DC Limited Tundra
    Console Cavern Organizer Mod, Driver's Forward Assist Handle Tonno Pro Hardfold, Body Colored Door Handles, Body Colored Mirror Caps, MBRP Stainless XP Series Dual Exhaust, OEM Bed Extender
    So wait... then does the position of the lights when they ship matter then? Like when you install them won’t they just go to the dial’s setting? Or is it not controlled by the computer and more like a direct connection between the dash dial and the leveler motors themselves?
  12. Nov 30, 2017 at 4:44 PM
    #732
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Before removing your old headlights level them in 0, then mark your hotspots against a wall at at least 25ft when install your LEDs check the aiming to see if they match with the markings in your wall if not you have to aim them using those marks
    Exile86 and slide187[QUOTED] like this.
  13. Dec 1, 2017 at 12:42 PM
    #733
    iHacker
    iHacker SW TRD PRO
    Mario
    Same process for fog lights
  14. Dec 1, 2017 at 2:09 PM
    #734
    slide187
    slide187 New Member
    Boston, MA
    Really? I didn’t think the fog lights were aimable?
  15. Dec 1, 2017 at 3:32 PM
    #735
    iHacker
    iHacker SW TRD PRO
    Mario
    Yes the have a bolt to aim them, not sure in the 2018 LEDs but my Morimoto XB Fogs has a bolt and I aimed with the same marks as my OEM halogens
    Sent from my iPhone
  16. Dec 2, 2017 at 9:43 AM
    #736
    slide187
    slide187 New Member
    Boston, MA
    Weird. I’m on the fence between just a bulb for the fogs or the morimoto’s. How hard is it to match the color temp of the headlights and LED strips? I haven’t seen any values for those so it seems like it’s trial and error. Which could get pricey.
  17. Dec 2, 2017 at 9:43 AM
    #737
    slide187
    slide187 New Member
    Boston, MA
    Either way I’m not getting the OEM 2018 fogs, it’s way too pricey after this mod. Haha
  18. Dec 2, 2017 at 11:28 AM
    #738
    vila251
    vila251 New Member
    I have the morimoto's. They are off a little bit.
  19. Dec 2, 2017 at 2:43 PM
    #739
    geno0506
    geno0506 New Member
    Michael
    PM'd you
  20. Dec 8, 2017 at 9:58 PM
    #740
    ht808c
    ht808c New Member
    2015 TUNDRA SR5 4x4 CREWMAX
    Hi all. Can somebody please show me the site to order the 2018 LED Headlights? Thanks
  21. Dec 8, 2017 at 11:29 PM
    #741
    geno0506
    geno0506 New Member
    Michael
  22. Dec 15, 2017 at 8:36 AM
    #742
    dakient
    dakient New Member
    Guys, I'm writing with a question that I can't solve. Any help would be very much appreciated.
    I wired in my 2018 LEDs on my '16 Pro using Eledobleu's harness. I re-pinned the turn signal as outlined, leaving the parking light (purple wire) out and taping it up. Turn signals work correctly (flashing ambers). I have not cut the grey wire inside the cab.
    Everything functions as it should, except my Amber DRLs do not come on at all--as a DRL or with the headlights on. They do function correctly for turn signals, hazards, and flash when locking/unlocking, so it's not the bulbs. How can this be happening? Basically, it's as if I did the Amber DRL Delete Mod (cut grey wire) but I have not. I actually want the Amber DRL on. They did work fine before the mod.
  23. Dec 15, 2017 at 9:02 AM
    #743
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Did you connect the purple wire to the LED DRL signal? I'm not familiar with the harness you used, but if you tie that purple wire into the signal running the LED DRL's you should have amber DRL's provided you tapped into the gray wire under the dash, rather than cutting it. I used the iHacker harness and all I did was tap the purple into his leads provided on his harness, and tapped the gray under the dash instead of cutting it.
  24. Dec 15, 2017 at 9:18 AM
    #744
    dakient
    dakient New Member
    Really appreciate the quick feedback. I think that Leo's setup is different than iHackers, the LED DRLs are powered by a fuse tap to the fuse box with no in-cab mods required. Amber DRLs should stay on without any in-cab mods. Some have chosen to cut the grey wire to disable them (which I have not). There are others using his harness that did the exact same thing I did and have the Amber DRLs functioning. I guess I'm trying to figure out the signal path for the amber DRLs...like, could a connection be loose somewhere that would cause neither side's amber DRL to function?
  25. Dec 15, 2017 at 9:45 AM
    #745
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Do you have hyper flash on your turn signals?
  26. Dec 15, 2017 at 9:53 AM
    #746
    dakient
    dakient New Member
    Negative, they work perfectly. (Adds to the confusion for me).
  27. Dec 15, 2017 at 10:00 AM
    #747
    iHacker
    iHacker SW TRD PRO
    Mario
    Check for any blown fuse, not sure if Amber DRL has one but just in case, that purple wire might touched something before you used tape on it
  28. Dec 15, 2017 at 10:08 AM
    #748
    SilverRider
    SilverRider New Member
    Las Vegas
    2015 Silver Crewmax Limited 4x4 TRD Off Road
    Doesn't the purple wire control the Amber drl?
    If your led drl are high all the time and you're not using the purple wire, I would put the purple wire back on the Amber connector.
  29. Dec 15, 2017 at 11:19 AM
    #749
    iHacker
    iHacker SW TRD PRO
    Mario
    No the purple wire only is the parking light option same as your corner marker light
  30. Dec 15, 2017 at 12:01 PM
    #750
    SilverRider
    Las Vegas
    I stand corrected. :hattip:I don't know why I keep confusing what the purple wire does.
