2018 Tundra LED headlight wiring info with diagrams
Discussion in 'Lighting' started by thomasbus337, Sep 6, 2017.
  1. Oct 10, 2017 at 1:08 PM
    #571
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Yes they both move. How do you manually adjust it?
  2. Oct 10, 2017 at 1:25 PM
    #572
    Sevi_86
    Sevi_86 New Member
    Edel
    '14 Platinum Tundra
    Fox Shox 2.5 Factory Series coilovers with DSC ICON UCAs 35x12.5 R18 BFG KO2 on Mayhem wheels AFE CAI and Throttle spacer AFE catback exhaust Nitro Gears 4.88 front and back differential gears BullyDog GT Tuner
    They have a white knob on the back of the headlight housing, just turn thay with a socket, make sure you unplug the leveling motor first. 20170821_113219.jpg
  3. Oct 10, 2017 at 1:35 PM
    #573
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Oh ok.. so just need to turn clockwise to move the beam up right? Thanks again!
  4. Oct 10, 2017 at 1:52 PM
    #574
    Rowens88
    Rowens88 New Member
    Randy
    2015 tundra limited 4x4 bronze
    Level kit, 275/65/20 trail grapplers paint matched all chrome custom headlights audio
    Thanks man loving them
  5. Oct 10, 2017 at 1:54 PM
    #575
    Rowens88
    Rowens88 New Member
    Randy
    You can also adjust them while mounted in the truck with a long Phillips screw driver by inserting it in the funnel looking thing that leads to the adjustment screw
  6. Oct 10, 2017 at 1:55 PM
    #576
    inferno_pro_satx
    inferno_pro_satx New Member
    Roger
    2016 Tundra TRD Pro
    Yes don’t adjust at the leveling motor, the motor can only go so much before it strips.
  7. Oct 10, 2017 at 2:06 PM
    #577
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Oh ok I’ll try it out tonight..thanks guys!
  8. Oct 10, 2017 at 4:15 PM
    #578
    TuffTundra
    TuffTundra New Member
    Missouri
    2016 MGM SR5
    4" Rough Country Lift - Fuel Assault 20x10 - Nitto Ridge Grapplers 33x12.5x20 - 2018 LED Headlights - LED Lights all around - No Chrome - Tinted Windows & Tail Lights
    Hey guys attempting to assemble everything but need someone to look over my crimp. Keep in mind this is the first time I have ever done this and don't want to do anymore unless I'm doing it correctly. Does this look like a good crimp? Is the exposed wire too long in the terminal? Do I need to crimp more of the pin? Also the slant piece (closest to the pin) does that need to be pushed down?
  9. Oct 10, 2017 at 4:18 PM
    #579
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Looks good, on the next one cut back 1mm on the exposed wire. Other than that not bad for a first timer. Crimp the seal alittle more tad
  10. Oct 10, 2017 at 4:21 PM
    #580
    TuffTundra
    Missouri
    2016 MGM SR5
    Should I try to dig out the extra and cut it? Also I guess there is no need to crimp more closer to the pin and push down the slant metal?
  11. Oct 10, 2017 at 4:26 PM
    #581
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Nah you’ll be ok
  12. Oct 10, 2017 at 4:38 PM
    #582
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Just leave it alone and don’t push down on that slant. It needs to be where it’s at. Also give it a good tug to make sure your crimp is secure.
  13. Oct 10, 2017 at 7:07 PM
    #583
    sano502
    sano502 New Member
    17 Tundra TRD Pro Cement
    @iHacker are those the OEM LED Fogs?
    LKSR5-14 likes this.
  14. Oct 10, 2017 at 8:42 PM
    #584
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Morimoto XB LED Fogs
  15. Oct 11, 2017 at 6:44 AM
    #585
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    :help:Hi guys.. have anyone order the new led fog light? Was thinking about ordering the new led fogs or the vleds.but don’t know if the vleds 6k would match up with the headlight color.
  16. Oct 11, 2017 at 7:06 AM
    #586
    Lanceb83
    Lanceb83 New Member
    Lance
    Valliant, OK
    2014 Tundra Crewmax
    RC leveling kit RC fender flares 305/55/20 Mickey Thompson ATZ P3 Fuel Maverick 20x10 -12 offset Body chop mount modification
    @iHacker what size braided sleave did you have to go with?
  17. Oct 11, 2017 at 1:07 PM
    #587
    iHacker
    iHacker SW TRD PRO
    Mario
    3/8. 25ft, for my harness design I used about 18ft
  18. Oct 11, 2017 at 1:23 PM
    #588
    Lanceb83
    Lanceb83 New Member
    Lance
    Valliant, OK
    2014 Tundra Crewmax
    Thanks
  19. Oct 12, 2017 at 12:52 PM
    #589
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Any picture of the new fog light guys?
  20. Oct 12, 2017 at 3:28 PM
    #590
    TuffTundra
    Missouri
    2016 MGM SR5
    @thomasbus337 sent you a message. Please respond when you get a chance. Thank you!
  21. Oct 12, 2017 at 5:39 PM
    #591
    35chaser
    35chaser New Member
    Kenny
    Central Massachusetts
    2019 Super White Platinum
    Color match mirrors and door handles RetraxOne MX Tonneau cover WeatherTech Visors Ionic Gladiators Running Board White LED lights
    2018 LED fog lights. Don’t mind the halogen yellows, I got the 2018 too but parts for my harness didn’t come in yet. Will install that soon.
    C9F2B7F9-1CB6-4E30-9470-5C78A4B2E81B.jpg FF9FBA01-BC7A-4FBD-9757-1B04111A34F7.jpg E3A41476-B426-4ECD-9CEA-D5721BFE5AF6.jpg
    geno0506, Ben_onewise and iHacker like this.
  22. Oct 12, 2017 at 8:06 PM
    #592
    Silverbullet
    Silverbullet New Member
    Long Travel Toyota Tundra
    Who wants to make a harness for my 08 sr5 to use these lights?
  23. Oct 13, 2017 at 3:59 AM
    #593
    Scarabmike
    Scarabmike New Member
    2017 Tundra Platinum
    Are the foglights plug and play?
    35chaser likes this.
  24. Oct 13, 2017 at 7:09 AM
    #594
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Nice.. thank you!
  25. Oct 13, 2017 at 9:24 AM
    #595
    35chaser
    35chaser New Member
    Kenny
    Yes they were plug and play. very easy to access, i took one panel off in wheel well. 1 screw holding it in. its actually more white, the picture show more of a tint of blue.
    Scarabmike[QUOTED] and 757TUNDRA like this.
  26. Oct 13, 2017 at 2:03 PM
    #596
    zwillz
    zwillz New Member
    2015 sr5 Crewmax
    HELP
    Trying to do the first part of my headlight install and do the DRL delete mod. I'm having a hard time getting the flasher relay module out, any secrets besides pushing the little tab in? I planned on unpinning it and electrical taping it just in case I want to go back to stock. But at this point I might just cut the wire LOL. Can anyone confirm which wire it is on the left column? There's a couple of wires in there that look white. I think the gray one might be the fifth wire down on the 1st or left column? Can anyone help me out real quick or confirm which wire is the correct one. Any help would be great thanks fellas.
  27. Oct 13, 2017 at 2:05 PM
    #597
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Newm and iHacker like this.
  28. Oct 13, 2017 at 2:06 PM
    #598
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Don’t mind the arrow on the pick it was for someone else
  29. Oct 13, 2017 at 2:10 PM
    #599
    zwillz
    zwillz New Member
    2015 sr5 Crewmax
    Ok thanks! That's the one I thought it was. I really wana unpin it, but I can't get the bastard out lol. Did yours come out easy? Tried everything to get it out. Thx man
  30. Oct 13, 2017 at 7:21 PM
    #600
    35chaser
    35chaser New Member
    Kenny
