2018 Tundra LED headlight wiring info with diagrams
Discussion in 'Lighting' started by thomasbus337, Sep 6, 2017.
  1. Oct 3, 2017 at 10:32 PM
    #451
    Cyrus
    Cyrus New Member
    Cyrus
    Maryland, USA
    2014 Tundra 1794 Edition TRD Supercharged
    Thanks for the quick reply bro. Mine is a 1794 model, do I still need to switch them? Since @thomasbus337 only included the signal/parking light adapters for the non Platinum/1794 models. I assumed I did not have to do this on mine. Can you confirm @thomasbus337?
  2. Oct 3, 2017 at 10:48 PM
    #452
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Yes you have to but you only have 2 wires in that 3 pin connector you have the parking light purple wire already in your DRLs you only have to move your ground to pin 1 as you can see in the diagram we have the ground in pin 2 mine is a 16 Pro so should be the same in yours
  3. Oct 4, 2017 at 12:07 AM
    #453
    Cyrus
    Cyrus New Member
    Cyrus
    Maryland, USA
    Thanks iHacker. I should have read through all the posts in this thread. Now it's clear that there lies the issue. @thomasbus337 even posted a pic of it in post #42 :frusty: I will do that first thing in the AM. Thanks again to both of you!
    iHacker[QUOTED] likes this.
  4. Oct 4, 2017 at 12:46 AM
    #454
    sano502
    sano502 New Member
    17 Tundra TRD Pro Cement
    @eledobleu does the DRL dim when the lights are on normally on 2018 OEM? Is that the factory way?
  5. Oct 4, 2017 at 8:35 AM
    #455
    Redlineaz
    Redlineaz New Member
    Haha, you're out of luck Pal!!!! But @BlueBottle just posted a video for you!!!!
    But here are some pics for motivation!! IMG_8356.jpgIMG_8357.jpg IMG_8369.jpg
  6. Oct 4, 2017 at 8:40 AM
    #456
    mcoyken
    mcoyken New Member
    2017 Platinum Tundra
    I have not installed his harness on my 17 platinum yet but I was under the impression that the pin out change was only required on models other than the 1974 and Platinum edition. @thomasbus337 could you please comment on that?
  7. Oct 4, 2017 at 8:56 AM
    #457
    jdm ctr '00
    jdm ctr '00 New Member
    los Angeles, CA
    2016 Tundra TRD PRO
    lol Looks awesome. :thumbsup:
  8. Oct 4, 2017 at 12:39 PM
    #458
    inferno_pro_satx
    inferno_pro_satx New Member
    Roger
    2016 Tundra TRD Pro
    The pins still need to be swapped on the platinum/1794 for the ground.
    BlueBottle and iHacker like this.
  9. Oct 4, 2017 at 1:33 PM
    #459
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    At @thomasbus337 or anyone that can help.. just got done with my harness. Does this look right for my platinum guys? Wanna make sure before I intstall. Can’t wait!
  10. Oct 4, 2017 at 2:06 PM
    #460
    thomasbus337
    thomasbus337 [OP] New Member
    2020 TRD Sport DC
    Looks 100% correct from here.
  11. Oct 4, 2017 at 2:18 PM
    #461
    thomasbus337
    2020 TRD Sport DC
    All models will have to move the ground pin for the directional to function properly. If you don't switch the pins you'll still have a turn signal but it will be dim and hyperflash because the stock wiring will be illuminating the 8w "parking light" 7444NA filament and not pulling the 28w signal.
    However if you are running VLEDS V3 or V6 units you can avoid this because you will be able to fit the V3 or V6 LED bulb into the new 2018 housings while still using your stock bulb sockets outside of the headlight unit
    inferno_pro_satx likes this.
  12. Oct 4, 2017 at 2:38 PM
    #462
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
  13. Oct 4, 2017 at 6:20 PM
    #463
    Cyrus
    Cyrus New Member
    Cyrus
    Maryland, USA
    Sure enough it functions as it should after switching the ground. Now onto the next issue... the DRL stays dim when you turn on parking lights only. Can someone confirm if this is the OEM functionality because I could swear in 'parking light' mode, the DRLs were bright before.
    Switch Status | DRL Function
    Off | Off
    Parking Light |Dim
    Headlights | Dim
    Auto (during day) | Bright
  14. Oct 4, 2017 at 6:22 PM
    #464
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    The factory function for the drl’s are bright during the day and switch to dim at night “parking light” mode
    What probably confused you is some people were wiring them on bright all the time
  15. Oct 4, 2017 at 6:24 PM
    #465
    Cyrus
    Cyrus New Member
    Cyrus
    Maryland, USA
    Okay then I might have killed something when I did not switch the ground wires because at full daylight, in parking light mode, it was still dim. I'll start by checking the fuses.
  16. Oct 4, 2017 at 6:26 PM
    #466
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Did you do the 1 relay for the red wire on the drl’s.
  17. Oct 4, 2017 at 6:31 PM
    #467
    iHacker
    iHacker SW TRD PRO
    Mario
    Looks good, but don't forget the cavity plugs into the unused pins to avoid any water getting into the connector
  18. Oct 4, 2017 at 6:36 PM
    #468
    Cyrus
    Cyrus New Member
    Cyrus
    Maryland, USA
  19. Oct 4, 2017 at 6:41 PM
    #469
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    How do you have the drl LED’s wired “ the red & purple wire at the 8 pin connector”?
  20. Oct 4, 2017 at 6:44 PM
    #470
    Cyrus
    Cyrus New Member
    Cyrus
    Maryland, USA
    Sorry I should have mentioned that the harness was purchased from the OP. I'm almost certain it's not the harness though because no one else has reported this issue. I might have messed something up. I'll check the fuses in the morning.
  21. Oct 4, 2017 at 6:46 PM
    #471
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Did you run 1 wire inside to the drl control unit and wire up a 4 pin relay?
  22. Oct 4, 2017 at 6:48 PM
    #472
    Cyrus
    Cyrus New Member
    Cyrus
    Maryland, USA
    Negative. The harness was pretty much PnP except for having to switch the ground on the turn signal plug.
  23. Oct 4, 2017 at 6:49 PM
    #473
    thomasbus337
    2020 TRD Sport DC
    Cyrus has a 1794 so he already has the factory DRL wiring. I can't answer the dimming question on a factory setup because I have an SR5.
  24. Oct 4, 2017 at 6:49 PM
    #474
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Krezz, steadfast and inferno_pro_satx like this.
  25. Oct 4, 2017 at 6:51 PM
    #475
    BlueBottle
    '16 Platinum 4x4
    See fine print
    @ 53 seconds is when I disengaged the parking brake
  26. Oct 4, 2017 at 6:56 PM
    #476
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    @thomasbus337...thank you almost forgot about the cavity plug..forgot to order the cavity plug for the high beam connector. Try to order some on Amazon but won’t be here till Monday.Does anyone in cali know where I can go buy some? Can’t wait any longer lol
  27. Oct 4, 2017 at 6:58 PM
    #477
    Cyrus
    Cyrus New Member
    Cyrus
    Maryland, USA
    Man can it be that simple?!!! I had never paid attention to the DRL functionality that closely. I will test and report back.
  28. Oct 4, 2017 at 6:59 PM
    #478
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Please test and report now I’m curious as well
  29. Oct 4, 2017 at 7:01 PM
    #479
    thomasbus337
    2020 TRD Sport DC
    I guess if you were in a hurry you could dab a little bit of silicone sealant in the unused spots to seal them off.
  30. Oct 4, 2017 at 7:08 PM
    #480
    Cyrus
    Cyrus New Member
    Cyrus
    Maryland, USA
    YOU ARE THE MAN @BlueBottle!!! I had never paid that much attention to the functionality of the DRLs and sure enough, I've always used the handbrake when I park the car. As soon as I disengage the handbrake it brightens. You just saved me hours of troubleshooting a non-issue. I owe you a beer man!
