2018 Tundra LED headlight wiring info with diagrams
Discussion in 'Lighting' started by thomasbus337, Sep 6, 2017.
  1. Sep 29, 2017 at 1:36 PM
    #391
    thomasbus337
    thomasbus337 [OP] New Member
    2020 TRD Sport DC
    Nope, on the signal adapters I made, the wire positions have already been switched around. For you it will be plug and play
  2. Sep 29, 2017 at 1:49 PM
    #392
    sano502
    sano502 New Member
    17 Tundra TRD Pro Cement
    @thomasbus337 thank you. I am so lost on the DRL portion of this setup. Is there any way you could make the DRL setup? I can pay you up front for parts and labor. I have the moto module I just don't know how to make the rest for the DRLs to work on a Pro
  3. Sep 29, 2017 at 1:58 PM
    #393
    sano502
    sano502 New Member
    @eledobleu can you please make me the LED DRL relay for my 17 Pro. I got the LED headlight harness from thomasbus337 but I am lost on how to make the LED DRL portion. Can I please order one or however you want to do it? I already have the moto control
  4. Sep 29, 2017 at 2:24 PM
    #394
    eledobleu
    eledobleu retrofitwholesale.com
    Orlando, FL
    Koito Bi-LED Retrofit
    Once parts arrive, I will make the harness for you.
  5. Sep 29, 2017 at 2:40 PM
    #395
    sartod01
    sartod01 New Member
    2017 Black 1794
    Let us know!!
  6. Sep 29, 2017 at 2:49 PM
    #396
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    I will see if it's possible to upgrade the wiring in the motocontrol to 16 gauge wire maybe is doable just wondering about that.
  7. Sep 29, 2017 at 3:03 PM
    #397
    thomasbus337
    2020 TRD Sport DC
    I looked at it on mine and I don't believe it's possible. They have the two 20awg wires twisted together and crimped on one small terminal on the plug that enters the gold relay. I doubt we'd be able to squeeze two 16awg wires together on that small of a pin.
    iHacker[QUOTED] likes this.
  8. Sep 29, 2017 at 3:11 PM
    #398
    sano502
    sano502 New Member
    @eledobleu thank you very much! Let me know if you need any other info from me
  9. Sep 29, 2017 at 3:22 PM
    #399
    iHacker
    iHacker SW TRD PRO
    Mario
    :( I'm getting my headlights this coming Monday to start making my harness, I'm still waiting for a few connectors to complete my harness
  10. Sep 30, 2017 at 12:00 PM
    #400
    guyp2k
    guyp2k New Member
    Can you please add me to the list as well for my 2016 Limited CM. I have the harness from Thomas, but as others lost on the DRL portion. Also, I have the motocontrol as well.
    Thanks!
  11. Sep 30, 2017 at 12:01 PM
    #401
    dakient
    dakient New Member
    Yep, me too!
  12. Sep 30, 2017 at 12:08 PM
    #402
    eledobleu
    Orlando, FL
    ncmtnman, sano502 and zwillz like this.
  13. Sep 30, 2017 at 9:00 PM
    #403
    sano502
    sano502 New Member
    @eledobleu I will also add my info to the email you provided for this
  14. Oct 1, 2017 at 12:39 PM
    #404
    Redlineaz
    Redlineaz New Member
    Hey guys how do you unlock the white connector to insert the new terminals?
  15. Oct 1, 2017 at 3:06 PM
    #405
    thomasbus337
    2020 TRD Sport DC
    Grab a small screwdriver and pry around the inside seam. The center section pops off the front. All of the Toyota connectors I have worked on for this project unlock from the front
  16. Oct 1, 2017 at 3:27 PM
    #406
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Use a small screw driver or pick. Pull the highlighted area out and it will come out.
    Redlineaz likes this.
  17. Oct 1, 2017 at 4:18 PM
    #407
    Redlineaz
    Hey guys!! I am having trouble here. No high or low beams, and DRLS aren't working. Turn signals and amber DRL work fine. @thomasbus337 @BlueBottle anyone have any ideas? :( Truck is a 1794.
  18. Oct 1, 2017 at 4:27 PM
    #408
    thomasbus337
    2020 TRD Sport DC
    Your pins in the eight pin connector and on the DRL 4 pin connectors are reversed
    Sunnier and Redlineaz like this.
  19. Oct 1, 2017 at 4:31 PM
    #409
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Yup. That white connector needs to be rotated 180degrees.
    Sunnier likes this.
  20. Oct 1, 2017 at 4:40 PM
    #410
    thomasbus337
    2020 TRD Sport DC
    Don't pay any attention to my wire colors (this pic was taken from my first harness prototype) but with the squeeze tab is on the bottom of the plug you want the row right above the tab to be the Hi/Lo and ground and the top row is the LED DRL[GALLER
    Also, the red DRL wire needs to be in pin 1 and the violet is in pin 2
    BlueBottle likes this.
  21. Oct 1, 2017 at 4:44 PM
    #411
    Redlineaz
    OK thank you so so much for the quick response. I have corrected the white harness. My headlight functions perfectly now. The only thing it's not doing is dimming the white DRLS, which I preferred them to be on full brightness anyways. Would swapping the red and the purple on the black harness cause the DRL to Dim? Or have I found a weird way to keep it from Dimming without disconnecting the purple wire from the black harness
    EDIT: I've swapped the red and purple wires on the black harness and the white DRL stays dim constantly, whether headlights are on or not. If I switch them back to how o originally had them, they remain bright all the time and don't dim.
  22. Oct 1, 2017 at 4:55 PM
    #412
    Redlineaz
    Thank you so much for all your help bro, you guys have been so awesome and helpful. I really, really appreciate the time you guys are taking to help me. Thank you so much !!!!!
  23. Oct 1, 2017 at 4:56 PM
    #413
    thomasbus337
    2020 TRD Sport DC
    I'd double check that you have the red and violet wires in the correct spots and maybe even check the DRL fuse under the hood. Something might have blown when you had the wires crossed
  24. Oct 1, 2017 at 5:01 PM
    #414
    Redlineaz
    Would the wiring staying in this manner (red and purple reversed) cause any harm if it already blew the fuse? It's functioning as I originally wanted it to (DRLS on high all the time). Do you know which fuse is the DRL one by any chance? Thanks for all the help @thomasbus337
  25. Oct 1, 2017 at 5:36 PM
    #415
    thomasbus337
    2020 TRD Sport DC
    The fuse will be labeled LED DRL and is marked under the lid of the fuse box. I'd be afraid that having the LED strips on full brightness at night might make the Amber directionals less visible
  26. Oct 1, 2017 at 5:41 PM
    #416
    TuffTundra
    TuffTundra New Member
    Missouri
    2016 MGM SR5
    4" Rough Country Lift - Fuel Assault 20x10 - Nitto Ridge Grapplers 33x12.5x20 - 2018 LED Headlights - LED Lights all around - No Chrome - Tinted Windows & Tail Lights
    Anyone have a photo of all the plugs/lights into the back of the headlights? I see that the 8-pin goes into the back of it and the "park light" needs to be reconfigured per instructions on page 2 of this thread. What I am wanting to know/see is does all the other plug/lights remain the same with no re-wiring or re-configuring?
    Also @thomasbus337 did you get the messages I sent? Will my diagram work?
    LKSR5-14 likes this.
  27. Oct 1, 2017 at 5:50 PM
    #417
    Steve Tundra
    Steve Tundra New Member
    Steven
    2022 4x4 platinum
    I had the same issue. look at the respnsonses i got. all hi low should be connected to negative. I had to switch my wires and it worked perfectly
  28. Oct 1, 2017 at 6:05 PM
    #418
    Redlineaz
    Thanks so much Steve!!
    Did you ever figure out what to do with the brown connector on the passenger side?? The drivers side is the only one with one apparently, I can't find a place to plug it in on the passenger side. Did you just electrical tape it to cover it? @thomasbus337 @BlueBottle
  29. Oct 1, 2017 at 6:20 PM
    #419
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Take it well to one of the wire looms. Make sure it doesn't contact anything or you will blow a fuse.
    Redlineaz[QUOTED] likes this.
  30. Oct 1, 2017 at 6:23 PM
    #420
    Redlineaz
    Thank you so much for the fast response, you guys are so awesome !!!!!!!!
