2018 Tundra LED headlight wiring info with diagrams
Discussion in 'Lighting' started by thomasbus337, Sep 6, 2017.
  1. Sep 28, 2017 at 2:12 PM
    #361
    Steve Tundra
    Steve Tundra New Member
    Steven
    2022 4x4 platinum
    Dang it.....I swear every time I log into this site I spend money. Must order my v6's....:)
    BlueBottle and Tundracollector like this.
  2. Sep 28, 2017 at 3:04 PM
    #362
    be77solo
    be77solo New Member
    2017 Silver Crewmax 4x4 5.7L
    KO2's on ENKEI ST6's, BakFlip MX4
    Look like cool bulbs.
    So, dumb question as I might just order a set, do we need the "load resistor" add on for our trucks? I hate bulbs that flash too fast ha
  3. Sep 28, 2017 at 3:20 PM
    #363
    thomasbus337
    thomasbus337 [OP] New Member
    2020 TRD Sport DC
    BlueBottle and be77solo like this.
  4. Sep 28, 2017 at 3:33 PM
    #364
    Judd1980
    Judd1980 New Member
    Judd
    2014 Tundra Platinum
    Those are some pretty pricey bulbs
  5. Sep 28, 2017 at 3:39 PM
    #365
    uaeboy
    uaeboy New Member
    mubarak
    2017 Toyota Tundra
    no need to order any bulbs or load resister ,,, When I finished installing the lights I had issue withe flash lights is to fast pumping like crazy
    after that I change the pin form conector and now run normal
    only change pin positon
    passenger side
    driver side
  6. Sep 28, 2017 at 3:40 PM
    #366
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
  7. Sep 28, 2017 at 3:42 PM
    #367
    MMichaelJJ
    MMichaelJJ New Member
    14 Platinum CM
    Always works that way. I just ordered all the parts last night. I'm guessing it might be a little cheaper for me to make them myself.
    Good info for others.
    Roman[QUOTED] likes this.
  8. Sep 28, 2017 at 3:45 PM
    #368
    thomasbus337
    2020 TRD Sport DC
    I mounted them on the black metal cross member above the bumper. You can kind of see them laying flat in this pic.
    BlueBottle[QUOTED] likes this.
  9. Sep 28, 2017 at 4:04 PM
    #369
    MMichaelJJ
    14 Platinum CM
    I mounted mine behind the tail lights. There's a lot of room back there. I don't think it matters where it's mounted as long as it's connected to the turn signal wires.
    Someone might want to confirm that.
  10. Sep 28, 2017 at 4:11 PM
    #370
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Sweet. I see them. Good to know the cables are long enough to reach.
  11. Sep 28, 2017 at 5:32 PM
    #371
    Tophergt99
    Tophergt99 Back in black
    Weston, Wisconsin
    2015 SR5 Black TRD Crewmax
    In progress....
    Will this harness still use the motocontroller? :)
  12. Sep 28, 2017 at 11:52 PM
    #372
    Tundracollector
    Tundracollector New Member
    16 Dc trd pro, 04 Dc, 08 rcsb
    Ordered all my connectors, way more expensive than I thought.....
  13. Sep 29, 2017 at 5:13 AM
    #373
    BRTundra
    BRTundra New Member
    Tony
    Baton Rouge, LA.
    2017 Tundra Platinum 5.7L CM
    I didn't know we had to order a supercharger also to get this 2018 lights to work lol.
  14. Sep 29, 2017 at 7:21 AM
    #374
    Tundracollector
    It’s a must lol i heard it raises light beam slightly for a few seconds by just giving it gas lol
    be77solo and BRTundra like this.
  15. Sep 29, 2017 at 7:24 AM
    #375
    Supercharged1254
    Supercharged1254 New Member
    Brandon
    Kalispell MT
    2014 Platinum Tundra, Supercharged
    LED interior, exterior, 2018 Fog lamps, TRD dual exhaust, TRD rear sway bar, TRD supercharger
    You will not be disappointed. But you'll never be able to go back either haha
    Tundracollector likes this.
  16. Sep 29, 2017 at 7:41 AM
    #376
    Cyrus
    Cyrus New Member
    Cyrus
    Maryland, USA
    2014 Tundra 1794 Edition TRD Supercharged
    4.7 seconds to be exact :)
  17. Sep 29, 2017 at 9:56 AM
    #377
    eledobleu
    eledobleu retrofitwholesale.com
    Orlando, FL
    Koito Bi-LED Retrofit
    After tons of research, It seems that @thomasbus337 method is the only way to get High/Low beams to work together via Relay Harness. I will begin to produce these harnesses beginning next week or so once parts arrive. Harnesses will include the Morimoto H4 harness.
    As for DRL's, (NONE PLATINUM Trims) It will use my PNP harness for retrofit LED's that will be powered by the Ignition fuse via fuse tap. The brightness will remain on High even with headlights are on. If you want the DRL to dim when lights are on please request it.
    LKSR5-14, BRTundra, zwillz and 2 others like this.
  18. Sep 29, 2017 at 10:03 AM
    Redlineaz
    Redlineaz New Member
    So are you saying to get the high and low beams on a 1794/platinum to work at the same time the additional relay @thomasbus337 posted is a must? Or is that just for the SR5/limited/TRD Pros? We can't just use the morimoto safely? Several members on here are running the high and low beams at the same time with just the morimoto, and not the additional relays.
  19. Sep 29, 2017 at 10:07 AM
    #379
    eledobleu
    Orlando, FL
    Yes for both low and high beams to work at the same time the Relay harness is a must. The morimoto relays is the most efficient.
  20. Sep 29, 2017 at 10:09 AM
    #380
    Redlineaz
    Ok so just to clarify we need to create this in the post below using the Hella Relays?
    Or just the morimoto itself is sufficient?
  21. Sep 29, 2017 at 10:11 AM
    #381
    kkim124
    kkim124 New Member
    Torrance, CA
    2016 Tundra Platunum 4x4
    I got an email from them today. They say they are about a month or two out with the harnesses. That is why I had to order the the connectors after my initial order. Either way, I just got my headlights delivered and harness making parts are on their way. Soon enough, I will have the new headlights on.
  22. Sep 29, 2017 at 10:14 AM
    #382
    eledobleu
    Orlando, FL
    Once I receive the parts and test, I will let you know for sure.
    757TUNDRA likes this.
  23. Sep 29, 2017 at 12:00 PM
    #383
    thomasbus337
    2020 TRD Sport DC
    The extra Hella relay is only needed if you wanted to upgrade the wiring for the high beam circuit. I used 16 gauge wire throughout the harnesses that I put together. The high beam wiring on the H4 Morimoto harness is 20 gauge. TRS said it would be sufficient to operate the High beams since they have a low amperage draw. I used the high beam power and ground outputs on the Moto harness to trigger a relay and ran 16 awg from the relay to the high beam circuit.
  24. Sep 29, 2017 at 12:23 PM
    #384
    TuffTundra
    TuffTundra New Member
    Missouri
    2016 MGM SR5
    4" Rough Country Lift - Fuel Assault 20x10 - Nitto Ridge Grapplers 33x12.5x20 - 2018 LED Headlights - LED Lights all around - No Chrome - Tinted Windows & Tail Lights
    Anyone willing to make a video of putting this harness together yet? Got all my parts just need to see how everything goes together now :)
  25. Sep 29, 2017 at 12:25 PM
    #385
    Redlineaz
    OK, sorry for the noob questions just want to make sure I understand this fully. So if the lighting harness is made using 16 gauge wire, is that hella relay an extra precaution, or is it now actually necessary since the entire headlight harness will be made out of 16g wire?
  26. Sep 29, 2017 at 12:31 PM
    #386
    thomasbus337
    2020 TRD Sport DC
    I basically did it as an extra precaution and to try out/test my wiring layout
    Redlineaz likes this.
  27. Sep 29, 2017 at 12:33 PM
    #387
    Redlineaz
    Awesome thanks so much @thomasbus337!! Should have all my parts this weekend hopefully to put this together :)
  28. Sep 29, 2017 at 1:05 PM
    #388
    Cyrus
    Cyrus New Member
    Cyrus
    Maryland, USA
    Just a quick shout-out to @Roman and crew. Ordered my 2018 headlights on Tuesday (3 days ago) and just received the tracking info. Great, responsive customer service as well. Excited to have the new headlights on early next week :bananadance:
    iHacker and Roman like this.
  29. Sep 29, 2017 at 1:31 PM
    #389
    sano502
    sano502 New Member
    17 Tundra TRD Pro Cement
    @thomasbus337 do you have to switch any pins around with the harness you made on a 14-17 Pro?
  30. Sep 29, 2017 at 1:34 PM
    #390
    steadfast
    steadfast New Member
    Harness from @thomasbus337 are in! And they look good
    Also got my tracking number for my headlights today as well. Ordered them on the 21st.
    I'm real pumped now!
