2018 Tundra evo install tutorial
Discussion in '2.5 Gen Tundras (2014-2021)' started by coreman23, Jan 20, 2018.
  1. Jun 11, 2018 at 8:21 PM
    Hoologan
    Hoologan New Member
    California
    18 Cement Limited Crewmax TRD
    I tried it slower after work and it functioned just fine. Thanks @itsdchz and @Dmas
    itsdchz likes this.
  2. Jun 12, 2018 at 7:31 AM
    Dmas
    Dmas New Member
    FTL, FL
    2018 SR5 Tundra DC TRD Off Road 4x4
    glad we could help
  3. Jun 27, 2018 at 5:09 PM
    Heatonrx
    Heatonrx New Member
    Nice write up. Where did you end up putting the two modules? Near the plug where most the the tapped wires are or zipped tied under the dash? Also did you program the Evo-One for the MyCar unit with the USB before the install but then hook it up after the starter was working? Thanks.
  4. Jul 4, 2018 at 7:51 PM
    sprtbkr
    sprtbkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 4x4 Double Cab - Inferno
    TRD Wheels & Tires, Double Cab Fold-down Back Seat mod, LED Interior Lighting, Turned Off Seat Belt Chime, Franken-key (Flip Key), Duraliner Bed Liner, Bed Rails, Hood Wind Deflector, Console Gun Safe, iBoard 5" Running Boards, TRD Sport Bed Vinyl, Fortin Evo One Remote Start with Mycar Cellular Module, Plasti-dipped Badges and Bumper End Caps, Tinted front windows, Extang Solid Fold 2.0, Pop-N-Lock, TUNDRA tailgate inserts, RCI Powder Coated Skid Plate - coming soon - 12” android radio, oemaudio+ Reference 500Q, under dash/seat lighting.
    I just installed this same setup in my 2018 as well. Also installed the mycar cellular module. Pretty straightforward. Took me about 2.5 hours trying to make sure everything looked good.
    I had the same problem with the connection not seeming right from the mycar module to the Evo, so I removed the tape from the mycar harness and found that the white connector that was taped up had the same pinouts and fits well and clips into place in the blue socket on the Evo.
  5. Jul 5, 2018 at 3:19 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    And have you tested it since you hooked it up?
  6. Jul 5, 2018 at 3:34 PM
    sprtbkr
    Scott
    Denver, CO
    Yep, working perfectly!
    Tundra Fan[QUOTED] likes this.
  7. Aug 26, 2018 at 5:51 PM
    Heatonrx
    Heatonrx New Member
  8. Aug 26, 2018 at 5:54 PM
    Heatonrx
    Heatonrx New Member
    I got the EVO-ONE hooked up ok but any info on the MyCar programing? I gave up for tonight but I couldn't get it to program. The instructions talk about flashing it with the software to Fortin 2 but I didn't see that option. Anyone got any info on this? Thanks.
  9. Oct 6, 2018 at 7:27 PM
    zeekworld
    zeekworld New Member
    Which harness did you guys get for the H key Tundra 2018.
    The Fortin site recommends the Evo One with a THAR-ONE-TOY10 part which is impossible to find.
    Per my research, the harness part above includes THAR-ONE TOY2 and THAR-TY20.
    Also, would you guys recommend a US seller?
    Thanks in advance!
    Zeek
  10. Oct 6, 2018 at 8:10 PM
    sprtbkr
    Scott
    Denver, CO
    Tech12volts.com sells it. That’s where I got mine.
    https://www.shop.tech12volts.com/product.sc?productId=353&categoryId=59
  11. Oct 6, 2018 at 8:21 PM
    zeekworld
  12. Oct 7, 2018 at 3:00 PM
    Dmas
    Dmas New Member
    FTL, FL
    Tech12volts.com makes its own harness, it’s not the TOY10 , that one just came out last week I think, just give it a few weeks and ask the eBay seller most people uses on here. Look for other Evo -one install thread and you will find him.
  13. Oct 7, 2018 at 9:42 PM
    zeekworld
    Do you know the eBay seller's name?
  14. Oct 8, 2018 at 6:33 AM
    Heatonrx
    Heatonrx New Member
    I got my Evo-one on Ebay for $72 I just checked and the seller wants $109 now. They didn't have a TOY10 a couple months ago. I had to use just the TOY2. Not too bad but I would have liked to avoid cutting wires. Check out the Crimestopper Tele-Connect add on module for $110. Plugs into the Evo-One and lets you start the truck with a cell app.
  15. Oct 8, 2018 at 7:10 AM
    bfd300
    bfd300 New Member
    So the $199 option with no 2 way remote and no mycar phone module, what do you use to start the truck?
    Most of this is plug and play?
    Thanks
  16. Oct 8, 2018 at 8:01 AM
    Dmas
    Dmas New Member
    FTL, FL
    anderson_electronics_inc...I bought my evo one from him, he can check if fortin is already selling the TOY10, send him a message on ebay.
  17. Oct 8, 2018 at 9:08 AM
    sprtbkr
    Scott
    Denver, CO
    You would use your own remote by hitting Lock 3x. I have it with the MyCar phone module. It has about 9 well documented wires you have to tap into. Most are in the same harness. You’re looking at about a 3 hour install if you know your way around automotive wiring.
    bfd300[QUOTED] likes this.
  18. Jan 15, 2019 at 5:07 PM
    blizz86
    blizz86 New Member
    Has anyone run into their cruise control not working after the install? I called in and the customer service rep was worse than useless.
