2018 Tundra evo install tutorial
Discussion in '3rd Gen Tundras (2014+)' started by coreman23, Jan 20, 2018.
  1. Jan 20, 2018 at 9:40 AM
    coreman23
    coreman23 [OP] New Member
    Cory
    2018 4wd Crewmax Tundra
    I just got finished installing an aftermarket remote start with MyCar app on my 2018 Tundra. I’m attaching some pics that should help others if anybody wants to do this install.
    I've done minimal work with wiring, so if I can do it, anybody can. A quick disclaimer, I am not a professional, if you use my advise, it is at your own risk. I can not be responsible for any damage caused by following my pics.
    There is a bunch of good information out there, how to take the panels off, where the bolts are, etc, so I won't go into much depth there. Before you kill power, take the 2 Phillips head screws out from behind the steering wheel. I took the negative off my battery, just in case.
    Mock up was the key to my success, I could have had it even more organized, but it's all hidden and away from any danger.
    The 1st pic is what you will receive. (For the 2018, you will not need the splitter in the middle) Also missing is the ignition adapter, but that was very easy to install.
    The hardest point for me was finding the TPMS wire. It is located behind the driver's side kick panel. It is a part of the bottom white plug. To remove the plug, take something small (I used a pick tool) into the drivers side of the plug. This will release the plug and it pulls toward you. I removed the one attached to the white plug to make it easier to work on. Remove the plug from the connector and this is what you should have. (2nd Picture is where the plug is. 3rd picture is the wire you need to cut and attach 2 wires from the evo box. It says red, but looked pink to me, maybe I'm a little color blind.)
    That is the tpms connection, only 2 wires go here. I also ran the ground from the evo box here as well. (I think it was yellow with red, but double check.)
    The connection for the ODB port was really easy as well. To release the ODB port, just squeeze the outside and it will slide back to pull out a little further.
    The most connections go to the connector shown in pic 4. Run all the wires needed here in one run if possible. I rushed my job, if I had it to do over again, I would have organized my wires a little better and brought them all together. Overall, it would have been a much cleaner install. I also soldered all my connections. I used a razor blade to peel back the insulation (be very careful, these wires are very small.) I then used a pick tool to poke a hole in the wires and ran my new wires through the hole and tied them around before soldering. I tested everything before a final solder, it's up to you if you want to do this.
    I didn't take any pics of the ignition connector, it was really easy, remove the plug, plug it into the adapter, plug the adapter back into the ignition, then run the ground. I ran both grounds from the ignition and the evo box to the same bolt in the driver's side kick panel.
    After dry connecting all my connections and covering them all with electrical tape temporarily, just in case. I tested the remote. I did triple check my wiring, and did make a mistake, so double check your wires and runs.
    Programming went smoothly, I did mess up the first time, but just disconnected and tried again. The 2nd time, it went flawlessly.
    After testing, I pulled the negative cable from the battery and soldered all my connections, verifying each connection. Then I put tape on them and tied them up as best as I could. I left the evo box out for now, because I got the MyCar app to hook up.
    MyCar info:
    Per the instructions, don't install the MyCar until you have it working with the stock remotes. Mine worked and I took it for a quick test drive. The TPMS light does stay lit until you put the key in, turn it on and hit the brake.
    The MyCar stuff is attached in pic 5. You will NOT use the top splitter. I had a tough time finding how to connect the MyCar to the Evo box. You hook the blue cable of the splitter in the middle to the cable from the MyCar black box. (Blue to blue connection). The small black cable on this splitter goes to the Evo box. It doesn't feel like it connects and it doesn't really click until you push very hard into it. It felt like I was going to break it, but I did attach a picture, so you can see the way the plug goes in. (The red wire from the MyCar plug faces the cut yellow cable from the Evo box) Like I said, it doesn't feel like it fits, but you have to really press it in.
    After you get it installed, program it with the instructions in the email you get. Then, go get the app, register and install it, and it should work.
    Again, I am a novice at this stuff, if I can do it, trust me, you can too. I will put up a video later tonight of it starting. I just think they look better starting at night, but trust me, the 2018 works just fine and it's pretty easy to install.
    MotoTundra, rocky_mtn_trd and JH5370 like this.
  2. Jan 20, 2018 at 9:47 AM
    TP30
    TP30 New Member
    Trey
    2018 Super White Tundra TSS 4x4
    Great write-up, I have been on the fence about this product but may go ahead and pull the trigger now. Where did you purchase your system?
  3. Jan 20, 2018 at 10:03 AM
    coreman23
    Cory
    I got mine from a vendor on All Out Tundras on Facebook. I’m new here and don’t know the rules, if it’s ok, I’ll post the link. Remove if not cool.
    http://shop.tech12volts.com/product.sc?productId=353&categoryId=59
  4. Jan 20, 2018 at 10:52 AM
    Berdine
    Berdine New Member
    Binghamton, NY
    2016 MGM Crewmax TRD
    Great write up! I did it on my '16, and love it! Best mod I did soo far!
  5. Jan 20, 2018 at 11:04 AM
    coreman23
    Cory
    Thank you!
  6. Jan 20, 2018 at 2:54 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Great write-up!
  7. Jan 21, 2018 at 6:04 PM
    Dmas
    Dmas New Member
    FTL, FL
    2018 SR5 Tundra DC TRD Off Road 4x4
    Great write up thanks...planning on doing this soon.
  8. Jan 23, 2018 at 7:45 AM
    blizz86
    blizz86 New Member
    Did you install the 2way option as well? I knew fortin had the remote start but just found out about the 2way feature and mycar... definitely on the priority list to install. Had a local shop quote me over $1000 for a viper 2way and remote start no gps
  9. Jan 23, 2018 at 8:39 AM
    Tundra Fan
    Tundra Fan Cotton Member
    Toby
    Nor Cal (Placer Co.)
    2013 Platinum, Silver Sky Metallic
    I had the exact same issue. I was worried I was going to break it.
  10. Jan 23, 2018 at 10:09 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Congratulations on your first time success!
    I'll take another stab at it probably this coming weekend. I know you don't need it but somebody else may......attached is a pretty good wiring diagram (for lack of better terms) I downloaded from wirecolor.com, it might be helpful for other brand of remote start units as well.
    Dmas likes this.
  11. Jan 23, 2018 at 10:42 AM
    Berdine
    Berdine New Member
    Binghamton, NY
    No,not yet. Right now I get good distance, but I am planning to do soo. Check out bluebottle's thread on his install. He did the 2 way. You can get them off of eBay for $89
    blizz86 likes this.
  12. Jan 23, 2018 at 2:06 PM
    blizz86
    blizz86 New Member
    I mainly wanted to see testimonials on the feature of how it lets you know if the car is locked vs not, etc. WIll do
  13. Jan 23, 2018 at 5:54 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I got the 2 way. It’s nice that I can check status now. Only drawback is it has a slight delay when you press a button. It’s about 2 seconds. If you can live with that get it! So worth it.
    blizz86 likes this.
  14. Jan 24, 2018 at 2:01 PM
    coreman23
    Cory
    I have the two way. On iPhones it’s a little buggy still. It shows unlocked when I know the doors are locked. The countdown timer sometimes works. If you exit the app by going to the home screen, then back to the app, all the options work. The gps is awesome as well.
  15. Jan 24, 2018 at 2:09 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    The two way doesn’t use a phone. It has its own remote that gives feedback etc. it’s called RF kit.
  16. Jan 24, 2018 at 2:23 PM
    coreman23
    Cory
    Oh my mistake, there was an option to do an extended remote. I think up to 3000 ft and it has led notification.
  17. Jan 24, 2018 at 3:03 PM
    DexterL
    DexterL New Member
    16 crewmax platinum
    Sweet I have the same set up, now i just need the new truck to arrive!
    With the my car gps app, can you really unlock and lock it from anywhere? Like miles away, same with the remote start? What if you dont have service?
  18. Jan 24, 2018 at 3:16 PM
    coreman23
    Cory
    From my understanding, the MyCar attachment uses Verizon cell towers. So if the truck does not have Verizon service, then it would not work.
    I have not tested the range, but have seen others say they have started it hours away. I don’t know why you would need to do this, but I guess you could. I’ve had no issues starting it 1/4 a mile away. It works with the oem remote as well, if I’m close, I just use that.
  19. Jan 24, 2018 at 3:40 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Yes that’s the one I have.
  20. Jan 28, 2018 at 4:14 PM
    rodm1
    rodm1 New Member
    To anyone that attempts this could you post the part numbers stamped on the connectors if visible? I would like to make my install plug and play as possible. When I get to this point I would rather have some of the connectors on hand before starting.
  21. Jan 28, 2018 at 8:36 PM
    Tundra Fan
    Toby
    Not according to their website FAQ's. I have AT&T, but I'm having issues with the 2 way communication on mine. It works, but the app says it failed.
  22. Mar 3, 2018 at 5:11 PM
    blizz86
    blizz86 New Member
    i just installed the EVO one with the rf kit. it does give me the green led and beep when successfully locked and unlocked but i went ahead and tried to trigger the alarm and the remote doesn't give any notification.. does yours?
  23. Mar 3, 2018 at 6:59 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Yes mine gives me the confirmation. What do you mean tie trigger? I just plugged in the Rf kit and that’s it.
  24. Mar 3, 2018 at 9:44 PM
    blizz86
    blizz86 New Member
    i mean if your alarm goes off, does your remote give you any indication?
    mine gives me the green dot and beep with lock/unlock.. but nothing if the alarm goes off
  25. Mar 3, 2018 at 9:49 PM
    TheBeast The Beach
    FYI there is a new harness available looks like. the TOY7. plug and play from what I read.
    BlueBottle likes this.
  26. Mar 3, 2018 at 9:54 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I actually never tried that. Not sure if it is supposed to. It’s not an alarm but a keyless entry unit.
    blizz86 likes this.
  27. Jun 10, 2018 at 9:32 PM
    Hoologan
    Hoologan New Member
    California
    18 Cement Limited Crewmax TRD
    I just installed the evo one on my ‘18 today and it went very smooth, however, I seem to be having one problem. Granted, I’ve only tried this a few times since installing, but sometimes it will just simply not work unless I unlock the vehicle, relook, then 3x the lock button. Anyone had this happen? I wonder if my button press timing is off or something?
    Wiring money shot. Wound up pink wire is for the hood switch, which I skipped today but left for future.
  28. Jun 11, 2018 at 5:49 AM
    sprtbkr
    sprtbkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 4x4 Double Cab - Inferno
    TRD Wheels & Tires, Double Cab Fold-down Back Seat mod, LED Interior Lighting, Turned Off Seat Belt Chime, Franken-key (Flip Key), Duraliner Bed Liner, Bed Rails, Hood Wind Deflector, Console Gun Safe, iBoard 5" Running Boards, TRD Sport Bed Vinyl, Fortin Evo One Remote Start with Mycar Cellular Module, Plasti-dipped Badges and Bumper End Caps, Tinted front windows, Extang Solid Fold 2.0, Pop-N-Lock, TUNDRA tailgate inserts, RCI Powder Coated Skid Plate - coming soon - 12” android radio, oemaudio+ Reference 500Q, under dash/seat lighting.
    You convinced me. Ordered it today for my 2018. Can't wait to install it. I had an Evo One from Fortin that I installed in my 2014 Tacoma. I also have the usb programming module for it if I want to change any settings. :)
  29. Jun 11, 2018 at 8:39 AM
    Dmas
    Dmas New Member
    FTL, FL
    You may be doing it too fast, try waiting 2-3 seconds between each time you press the lock button.
  30. Jun 11, 2018 at 8:48 AM
    itsdchz
    itsdchz 50statesoverland
    Clovis, CA
    2018 SR5 CM Cement 4x4
    Icon Stage 3, UCAs, SCS SR8 Bronze, SSO, VOODOO
    Many times it is too fast. Simply adding one lock click if it doesnt respond immediately will prompt it for me...
