2018 OEM LED Sequoia headlights
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Sep 21, 2017.
  1. Sep 23, 2019 at 6:52 AM
    #91
    Roman
    Roman [OP] Toyota Parts Master Vendor
    Roman
    Franklin, TN
    The catalog is not showing a different part number for the Pros.
    Wynnded likes this.
  2. Jan 4, 2020 at 4:50 AM
    #92
    Xtruck008
    Xtruck008 New Member
    Is there any difference non-visually? My 2013 Tundra Platinum headlights adjust from inside the cab, do any of the '18 sequoia lights do that? I like the all black headlight rather than the platinum edition.
  3. Jan 4, 2020 at 6:49 AM
    #93
    Ericsopa
    Ericsopa Old man and the sea
    No leveling adjustment on the Sequoia headlights, even if you have the dashboard control. I did the conversion on my '13 Limited.
    And no other differences other than the black vs. silver side trim.
  4. Jan 4, 2020 at 7:12 AM
    #94
    Xtruck008
    Thank you! I guess that'll give me an extra spot for an aux switch in the existing spot. :D
  5. Jan 4, 2020 at 11:17 AM
    #95
    Ericsopa
    When I instralled the lights, I went to Lowe's and bought a long phillips screwdriver. The shank is about a foot long, probably more like 10". Anyway, it makes the adjustment very easy. Don't get one with a square shank (my first attempt with one purchased at Home Depot), as it probaby won't fit in the groove that guides the driver to the adjusting screw.
    Adjustments are vertical only. No horizontal adjustment, nor is it necessary.
    Trusty Rusty likes this.
  6. Jan 20, 2020 at 8:13 AM
    #96
    Roman
    Roman
    Franklin, TN
  7. Jan 20, 2020 at 10:17 AM
    #97
    Roman
    Roman
    Franklin, TN
    Yes, on the 2014 model you can use the Tundra accessory fog lights, and they will be plug and play.
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-fog-lights-black-led-pt41342191
    #97
  8. Jan 25, 2020 at 11:07 AM
    #98
    uzzyjr
    uzzyjr New Member
    hello airfish
    i guess you i asked the wrong question.
    how can i lay my hands on this headlight washers
    please advice.
    how much did you pay meso customs?
  9. Feb 2, 2020 at 8:09 PM
    #99
    Showtz
    Showtz New Member
    MESO customs charged me $40shipped. They are printed from Nylon Carbon Fiber.
  10. Feb 15, 2020 at 4:13 PM
    #100
    yeeyo
    yeeyo New Member
    Rodrigo
    11' Limited Sequoia
    OVtune
    Ordered the Headlights, panels and PNP harness. New to the forum, ready to go on this bad boy. IMG_1387.jpg
    Beau, omgboost and TheBeast like this.
  11. Feb 17, 2020 at 6:27 PM
    #101
    Mattyc
    Mattyc <insert custom title>
    Matthew
    NY
    2008 Limited Rock Warrior
    Not stock
    Which side of the headlight is the adjustment screw? Do you have any pics? There is very little information on how to level 2018+ Sequoia lights. My DS is slightly high
  12. Feb 17, 2020 at 7:12 PM
    #102
    Ericsopa
    I think it was toward the inside end of the lights. I'll take a picture in the morning and post it here for you. I think you'll be able to figure it out best with the picture.
    Mattyc[QUOTED] likes this.
  13. Feb 18, 2020 at 6:02 AM
    #103
    Ericsopa
    Well, I was mistaken about the location of the adjusting screw. It's toward the outside of the assembly, near the inner fender. Here's the screwdriver I bought.
    Here's the adjusting screw location for the passenger side headlight. The green arrow points to the slot that positions and holds the screwdriver shank in place. The red arrow points to the actual adjusting screw. That's the washer fluid reservoir on the right.
    And lastly, here's the screwdriver in position.
    Unfortunately, I don't remember which direction to turn the screwdriver to either raise or lower the beam. :D
  14. Feb 18, 2020 at 6:39 AM
    #104
    Mattyc
    Matthew
    NY
    Not stock
    Thanks man. That helps!
    Ericsopa likes this.
  15. Mar 29, 2020 at 6:50 PM
    #105
    Fotoshark
    Fotoshark New Member
    @Showtz do you happen to have the link to the 3d model he used to attach the washers to the new lights?
  16. Mar 29, 2020 at 10:12 PM
    #106
    Showtz
    Showtz New Member
    You can buy the sequoia headlight washer block from MESO customs. They are 3D printed from Nylon Carbon Fiber. $40shipped
    Kimo and Toy2008 like this.
  17. Apr 2, 2020 at 8:05 PM
    #107
    yeeyo
    yeeyo New Member
    Rodrigo
    11' Limited Sequoia
    OVtune
    @Fotoshark
    Toy2008 likes this.
  18. Apr 2, 2020 at 8:06 PM
    #108
    yeeyo
    yeeyo New Member
    Rodrigo
    11' Limited Sequoia
    OVtune
    @Fotoshark
  19. Apr 2, 2020 at 8:06 PM
    #109
    yeeyo
    yeeyo New Member
    Rodrigo
    11' Limited Sequoia
    OVtune
    @Fotoshark
  20. May 1, 2020 at 10:39 PM
    #110
    Toy2008
    Toy2008 New Member
    2008 white Toyota Sequoia
    Hi me again, I also have these washer on my platinum so it just drill and that’s it or do we need that squared part? For the new 2019 headlights?
    thanks again
  21. May 2, 2020 at 8:16 AM
    #111
    xrunnerdude67
    xrunnerdude67 New Member
    I believe it’s rectangular shaped
  22. Jun 3, 2020 at 7:42 PM
    #112
    Toy2008
    Toy2008 New Member
    Hello have you bought the part for the washers?
    If you did , how do you install it correctly to point the correct way
  23. Jun 5, 2020 at 9:15 AM
    #113
    yeeyo
    yeeyo New Member
    Rodrigo
    11' Limited Sequoia
    OVtune
    I did. If you purchase the brackets, they only attach one way. Use plastic JBweld to attach them to the headlights.
  24. Jun 15, 2020 at 5:20 PM
    #114
    Toy2008
    Toy2008 New Member
    Can some one help me please I bought the cable I’m installing it right now and I’m confused there are 3 connections on the new harness but from the headlight there are 4 cables which one is the one that doesn’t connect ? And what do you yo with that one ?
  25. Jan 7, 2021 at 7:33 PM
    #115
    yeeyo
    yeeyo New Member
    Rodrigo
    11' Limited Sequoia
    OVtune
    @Trdwillie14 you can get the headlights and grill from him. He works for a Toyota dealership, he’s legit
  26. Jan 7, 2021 at 8:32 PM
    #116
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    2010 Pyrite Mica Limited CM
    Pretty sure the 4th connector is for your headlight levelers, which the 2018+ sequoia headlights do not have. It’s the only one that doesn’t match a connector on the new harness. Just secure it out of the way.
  27. Mar 27, 2021 at 6:21 PM
    #117
    Dontgoleft
    Dontgoleft New Member
    I’m totally new here. Been browsing around for a few days. Y’all’s done up Sequoia’s are so sick! I have an 08 Limited Sequoia and would love to start some of these mods. It’s confusing to me though reading some of these threads on what will fit. I want to do a headlight upgrade, Grill for sure to start. Can anyone point me where to go?
    I’m also not gifted working on cars. I’m in Dallas Fort Worth if anyone knows where I can take it to install these things. Thanks fellas and love the forum!
    hunterk2 and aggiepablo like this.
  28. May 7, 2022 at 9:20 PM
    #118
    Kimo
    Kimo New Member
    2010 Sequoia Platinum
    Hey, I'm new to the group but I have been following for a little while now, getting ideas here and there. I have been trying to print these washer adapters for about 2 months now and I would rather pay someone and have then sent to me. Who do I contact the person that is selling them for $40Shipped?
    Thanks
  29. May 7, 2022 at 9:52 PM
    #119
    Showtz
    Showtz New Member
    https://mesocustoms.com/
    go to the contact page and let them know you want the 3d printed headlight washers for the sequoia headlights.
    Kimo[QUOTED] likes this.
  30. May 24, 2022 at 3:24 AM
    #120
    Kimo
    Kimo New Member
    Thanks, I did exactly what you said buy it has been almost two weeks and I have not heard anything. How long did it take them to respond to you?
