2018 OEM LED Sequoia headlights
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Sep 21, 2017.
  1. Sep 21, 2017 at 8:59 AM
    Roman
    Roman [OP] Toyota Parts Master Vendor
    Roman
    Franklin, TN
    For all you second gen owners out there looking to swap headlights from the 2018 Sequoia onto your 2007-13 Tundra, here's a thread for you.
    Below are the two options for headlights. One is from the Platinum model, and the other is from the rest of the model options. The only difference is in the outside, top corner of the headlight. On the Platinum, it is chrome. On the others, it is black. Here's some pictures:
    2018 Platinum Sequoia LED headlamp
    2018 Sequoia (Limited, SR5, etc.) LED Headlamp
    Barely any difference between the two visually. Only the outside, top corner above the yellow reflector is different.
    Here are a few links to them in the store:
    2018 Sequoia Platinum LED Headlamps
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-headlamp-assy-rh-811100c190
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-headlamp-assy-lh-811500c150
    2018 Sequoia (Limited, SR5, etc.) LED Headlamps
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-headlamp-assy-rh-811100c200
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-headlamp-assy-lh-811500c160
    Headlamp filler panel (small panel under the headlights)
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-panel-fr-end-lh-l-539320c904
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-panel-fr-end-rh-l-539310c904
    These are not plug and play. You will have to come up with a wiring solution for them, similar to the 2018 Tundra LED headlights. Also, I am unsure what other parts you will need. There are a few that are obvious, but I will wait to update this until someone has completed the swap and we can confirm all parts needed.
    Trusty Rusty, Skew12, YTIT and 2 others like this.
  2. Sep 21, 2017 at 8:22 PM
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    When are these available for purchase? Also, I'm wondering if they are height adjustable? TIA
  3. Sep 22, 2017 at 6:31 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    There's a 2018 Sequoia Platinum on the lot here in town, sticker $69K :eek:. And other than the headlights it looks the same as all the other ones since 2008 unless they changed the interior.
  4. Sep 22, 2017 at 6:37 AM
    Bulldog_tundra
    Bulldog_tundra New Member
    USA
    2006 Double Cab
    Bilstein 5100 (Top Notch Front) 1” Rear Block Flowmaster 40 w/ 3” Tip Bumperplugs Front Plate Delete
    Interior is “upgraded” to match the current 3rd gen Tundra. Pretty sad “refresh” IMO for an almost 10 year old model. Crazy to me that you can spend $65K+ on an SUV that looks identical to the model released 9 years ago.
    TheBeast and tomsinamerica like this.
  5. Sep 22, 2017 at 4:15 PM
    Quebec
    Quebec New Member
    Tag.
    I hope someone develops a harness (and quickly); these are a must for me.
    myt1 likes this.
  6. Sep 22, 2017 at 7:48 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Am I missing something? Our headlights aren't shaped like that, they're flat across the bottom.
    joonbug likes this.
  7. Sep 22, 2017 at 7:50 PM
    Tundra Fan
    Toby
    Early 2nd Gen..........
    Later 2nd Gen........judging by the grill, not sure what year it changed.
    2010-2013-Toyota-Tundra-CrewMax-Platinum_997b7dc6ddb50a380e820f908acb8ba26a6315a5.jpg
    Do we change the plastic piece below it as well?
    Bulldog_tundra likes this.
  8. Sep 22, 2017 at 7:52 PM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    I thought the same thing... At some point I need to replace wife's 4r. Not a fan of the new 4r either, prefer my 2004... For 70k there are much nicer options
  9. Sep 22, 2017 at 8:01 PM
    Bulldog_tundra
    USA
    2006 Double Cab
    Yes, you’d have to change the plastics beneath the headlamps. They’re about $50 each and come unpainted from what Roman said on another post. He also can’t guarantee they’ll fit until someone tries it.
    Tundra Fan[QUOTED] likes this.
  10. Sep 22, 2017 at 8:03 PM
    Tundra Fan
    Toby
    Aaahhh, okay, that makes more sense. Thanks :thumbsup:
  11. Sep 22, 2017 at 8:04 PM
    Bulldog_tundra
    USA
    2006 Double Cab
    Exactly. I don’t understand how the Lexus LX can be so light years ahead of the Sequoia. I get that it has to be nicer, it’s a Lexus, that’s a given. But they clearly have the ability to upgrade at least the interior.
    I also checked and the Sequoia’s still only have a 26 gallon tank which blows my mind, it needs that bigger 36-38 gallon tank the new Tundra’s have.
    Just an all around disappointment for me. Been holding out, my wife’s 2006 4Runner only has 100K miles so we’ll be waiting for them to completely redesign it. With 2 kiddos it’s getting tight though...
    tomsinamerica[QUOTED] likes this.
  12. Sep 24, 2017 at 4:48 PM
    Rngr188
    Chad
    Harrison AR
    I went again today and looked through the window of the 18 Sequoia, the steering wheel is the same as a 3rd Gen Tundra and some changes have been made but it's definitely not identical interior to my 17 Tundra.
  13. Sep 24, 2017 at 5:05 PM
    TheBeast The Beach
    tag. I wish they went with the gen3 tundra front end on the sequoia
  14. Sep 24, 2017 at 5:55 PM
    Bulldog_tundra
    USA
    2006 Double Cab
    There’s already some guys that have done the front end swap, I thought I’d like it but it looks funny. I guess if they redid the body lines on the rear it might look better.
  15. Sep 24, 2017 at 6:23 PM
    TheBeast The Beach
    jonnyjo, Gibo244, 1UPPER and 2 others like this.
  16. Sep 24, 2017 at 6:23 PM
    Quebec
    Quebec New Member
    3rd gen is hideous. 2nd Gen is what peak performance looks like.
    Smiley likes this.
  17. Sep 25, 2017 at 1:56 PM
    Roman
    Roman
    Franklin, TN
    You can place an order now. There is no manual height adjustment like on the Tundras.
  18. Sep 25, 2017 at 5:05 PM
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    Damn that might be a deal killer For that much, you can't even adjust the height
    Wynnded likes this.
  19. Sep 25, 2017 at 7:13 PM
    cheehab
    cheehab Fan Boy
    Southern Maine
    2015 TRD Pro CrewMax
    @Roman, you're going to sell a shit ton of these!
  20. Sep 25, 2017 at 7:34 PM
    Bulldog_tundra
    USA
    2006 Double Cab
    At $1,600 for the complete swap? I must’ve picked the wrong career path...
    Krezz likes this.
  21. Sep 25, 2017 at 7:42 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    For that price, I won't give them a second glance. They're simply too much.
  22. Sep 25, 2017 at 10:01 PM
    Tundra Fan
    Toby
    Yeah , that's crazy out of my budget. Plus I'm kinda not feeling them. The smaller light looks weird IMO.
  23. Sep 26, 2017 at 7:26 AM
    Roman
    Roman
    Franklin, TN
    I love the look of them in person, but I wouldn't spend that much on them. If they were closer to the price of the new Tundra headlights, I could see me selling a lot of them.
    Bulldog_tundra and Wynnded like this.
  24. Sep 26, 2017 at 11:35 AM
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    I don't get why they cost that much
    duece292 and Bulldog_tundra like this.
  25. Sep 26, 2017 at 1:33 PM
    Roman
    Roman
    Franklin, TN
    Big bro Toyota says they want that much for them. I couldn't tell you why prices are what they are. ¯\_(ツ)_/¯
    Krezz likes this.
  26. Sep 26, 2017 at 2:18 PM
    Rngr188
    Chad
    Harrison AR
    I'd love to have the woodgrain steering wheel in my Tundra Limited, looks like it would match the wood dash trim perfect.
  27. Oct 11, 2017 at 4:31 PM
    Sequoiarider09
    Sequoiarider09 New Member
    Hey Roman. Do you have any updates on the headlights wiring because I want to do this swap to my 2013 Sequoia Limited with the 2018 Limited headlights. How much does it cost for the Limited or Platinum Grille?
  28. Oct 12, 2017 at 2:13 PM
    Roman
    Roman
    Franklin, TN
    I do not. As far as I know, no one has been trying to build a harness adapter for these like with the new Tundra LED headlamps. I think it's because the cost is so high for the swap. Not many people are attempting it.
    Limited grille
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-grille-sub-assy-rad-531010c080
    Platinum grille
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-grille-sub-assy-rad-531010c090
    You'll also need the upper painted portion of this, which is separate. It comes in 8 different colors from Toyota, so hopefully one of those matches yours.
  29. Oct 12, 2017 at 2:40 PM
    Sequoiarider09
    Thanks for the info. I guess I’ll hold on the headlights swap for a while until someone’s project works out (Or a price drop). Do you happened to know if the grille is a plug-n-play kind of swap or do I need to modify a part? As for the upper painted portion, I’d need that piece in black.
  30. Oct 12, 2017 at 7:03 PM
    MookTastic
    MookTastic Because I was inverted!
    Trice
    Rapid City, SD
    2013 5.7L White D/C TSS Offroad Icon Stage 8
    Icon Stage 8 AlphaRex Headlights
    I like the idea of the new headlights and the led strips inside...but yeah there are way cooler things my money could goes towards
