2018 OEM LED Headlights
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Aug 21, 2017.
  1. Sep 9, 2017 at 6:35 AM
    #151
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    On the 2nd page of this thread, 1st post has a link from Roman for it.
  2. Sep 9, 2017 at 7:35 AM
    #152
    havasubud
    havasubud Owner ESP Truck Accessories Vendor
    Earl
    Corona, California
    2022 Tundra CrewMax Limited TRD OR 4x4
    Factory Tube Steps, TraiFX tri fold tonneau cover
    Here are the wiring diagrams if anyone wants them
    Quebec likes this.
  3. Sep 9, 2017 at 8:12 AM
    #153
    TuffTundra
    TuffTundra New Member
    Missouri
    2016 MGM SR5
    4" Rough Country Lift - Fuel Assault 20x10 - Nitto Ridge Grapplers 33x12.5x20 - 2018 LED Headlights - LED Lights all around - No Chrome - Tinted Windows & Tail Lights
    Thanks for posting all the information guys but I'm sure a lot of guys are still confused as I am with all of this. From what I gathered reading over the posts so far is that I will need to order obviously the 2018 LED headlights and the connector on page 2 to make these lights work. I'm I understanding this correctly?
    What I would like on my truck once the lights are installed is that when the truck is running the DRL are on much like they are on the new Sierras and Silverados. Right now on my 2016 the lights that come on are on the inner orange lights and I am not a big fan of that look.
    I truly hope that one of you guys will either give instructions or provide a video of how to get this look on my truck. I know if I would post information to help everyone out if I knew what it took to achieve this look. But when it comes to this stuff I rely on you experts out there.
    Hope one of you guys out there can help us all.
    Thanks so much!
    Berdine likes this.
  4. Sep 9, 2017 at 8:33 AM
    #154
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    With the new headlights you'd get exactly what you're talking about. The wires for the amber drl are used to power the white drl strip in the 2018 headlight.
  5. Sep 9, 2017 at 8:39 AM
    #155
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    That is incorrect. That same wire is for your front signals. To get a drl in an sr5 you would have to tap off an ignition source and use a relay. If you want to disable the amber drl you can cut the grey wire under the dash. But it will still act as a signal.
  6. Sep 9, 2017 at 10:29 AM
    #156
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thanks for the correction. I've got a limited. On my retros I cut the pinkish wire to disable the amber drl. I assumed that wire would provide power for the drl in the 2018 headlight.
  7. Sep 9, 2017 at 10:36 AM
    #157
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Wasn't sure on the color. I think you are right if you done it already.
    I sent you a text last night. Hit me up regarding your UCA's.
  8. Sep 9, 2017 at 1:28 PM
    #158
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Anyone upgrading to 2018 headlights that are replacing retrofits? I'd be interested in buying your used retros, especially if they have the platinum style led DRL
  9. Sep 9, 2017 at 6:31 PM
    #159
    jdm ctr '00
    jdm ctr '00 New Member
    los Angeles, CA
    2016 Tundra TRD PRO
    Sorry I'm a bit confused. On my 2016 Pro my DRL's/turn signals are a switchback style factory set up. When driving the ambers light up as the DRL's. When I activate the turn signal it switches to the amber turn signal in that same bulb. My turn signals and my DRL's are the same bulbs/plugs, how would that work with the new 2018 LED headlights(DRL's & Turn signals)?
    I want to order these A.S.A.P. if they work.
    Thank you
  10. Sep 9, 2017 at 7:34 PM
    #160
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    As @BlueBottle pointed out, I could be wrong but, I looked at this schematic https://www.tundras.com/threads/201...-wiring-info-with-diagrams.16225/#post-347440
    The pinkish wire would provide power to the DRL just as it does with your present lights. But it would be the strip and not the amber. The other 2 are the turn signal and ground. Someone please correct me if I'm wrong. On my lights (I have retros) I've cut the pinkish wire and disabled the amber DRL. My DRL is powered like bluebottle said, from the fuse box and not using the pinkish wire, but I don't see why I couldn't have used the pink wire. The above wiring diagram utilizes factory plugs that use the pink wire.
  11. Sep 10, 2017 at 3:58 PM
    #161
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    So good news and bad news. I put together a PnP harness according to my diagrams and for the most part it worked, until it was time to flip on the high beams. The way our trucks are wired the low beams shut off when the hi beams are turned on. The 2018 LED headlights keep the low beams on with the high beams, so simply wiring it up the way I had it shown (like a traditional H4 bulb) won’t work.
    I’ve come up with plan B. I’ve made revised diagrams with an updated parts list and tried it out and it works. Now I’ll be using the wiring from a Morimoto motocontrol H4/9003 Bi-Xenon HID relay harness. It will be hooked up just as it would if you were doing a HID retrofit. With this relay harness the headlights will keep the low beams on with the high beams just like the 2018’s. I’ve updated my thread with the new info.
  12. Sep 10, 2017 at 6:29 PM
    #162
    Tophergt99
    Tophergt99 Back in black
    Weston, Wisconsin
    2015 SR5 Black TRD Crewmax
    In progress....
    Do you need to modify the Motocontrol? Because I have a H4 Morimoto HID kit in my truck now.
  13. Sep 11, 2017 at 12:49 PM
    #163
    Roman
    Roman [OP] Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Hey fellas, been on vacation this past week. It's going to take me a minute to go through everything. :)
  14. Sep 11, 2017 at 12:50 PM
    #164
    Darth Tundra
    Curt
    17 CM TRD Black
    X100
  15. Sep 11, 2017 at 12:51 PM
    #165
    Darth Tundra
    Curt
    17 CM TRD Black
    :wave:
    BlueBottle likes this.
  16. Sep 11, 2017 at 2:56 PM
    #166
    BlueBottle
    '16 Platinum 4x4
    See fine print
    '18 headlights became the new TRd pro grill lol. Good luck keeping these bad boys on the shelves!
    *waiting patiently for mines haha.
  17. Sep 11, 2017 at 4:10 PM
    #167
    be77solo
    be77solo New Member
    2017 Silver Crewmax 4x4 5.7L
    KO2's on ENKEI ST6's, BakFlip MX4
    Thanks Roman! Just ordered a set from you, excited to get these mounted. Will hide the box from the wife while waiting for the wiring to be figured out ha....
  18. Sep 11, 2017 at 4:48 PM
    #168
    thomasbus337
    2020 TRD Sport DC
    Nope, no mods to the relay harness. I also already have one installed, that's where the thought to use it came from. I'm going to add the male connectors to my Pnp harness so I can simply unplug from hid components then plug into the LED harness for an easy changeover
  19. Sep 11, 2017 at 5:01 PM
    #169
    Berdine
    Binghamton, NY
    Yep, this is awesome!
  20. Sep 11, 2017 at 6:28 PM
    #170
    Lanceb83
    Lanceb83 New Member
    Lance
    Valliant, OK
    2014 Tundra Crewmax
    RC leveling kit RC fender flares 305/55/20 Mickey Thompson ATZ P3 Fuel Maverick 20x10 -12 offset Body chop mount modification
    Is there a promo code?
  21. Sep 11, 2017 at 9:46 PM
    #171
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Roman, do you have the link or part number for the new led fog light. Thanks!
  22. Sep 12, 2017 at 3:11 AM
    #172
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Scribed.
  23. Sep 12, 2017 at 6:57 AM
    #173
    David P
    David P New Member
    David
    Alabama
    2016 Toyota Tundra 4x4 CM Platinum
    BDS 7" lift with Fox coil overs and 2.5s in the rear, CB shackles w/ poly bushings, CB steering kit, CB poly rack bushings, Dakar rear leaf pack w/ CB poly bushings, Bushwacker paint to match fender flares,, Fab Fours premium bumpers font + rear, Fab Fours modular roof rack with lights all around, ARE Z series shell, BDS Traction control bars, Fuel Nutz 2 piece 22x10 wheels, Toyo MT 37X13.5, Spod overhead lighting control unit, Kenwood/JL Audio, Dynamat sound deadening throughout the cab, Morimoto 40" LED light bar hood bulge, Viper remote start alarm, Bully Dog tuner, S+B CAI, Retro'd HID Headlights, Morimoto 2-Stroke LED Fogs, Undercover tool boxes.
    These look extremely tempting, beautiful craftsmanship on the design. What is needed to wire these to a 2016 Platinum? How is the light output compared to HIDs? If I order these, I'll likely have a very nice set of retros for sale soon.
    TRD15559 and iHacker like this.
  24. Sep 12, 2017 at 10:23 AM
    #174
    Roman
    Roman
    Franklin, TN
  25. Sep 12, 2017 at 4:29 PM
    #175
    Judd1980
    Judd1980 New Member
    Judd
    2014 Tundra Platinum
    This is awesome @Roman. I'll be placing an order for these as my 2014 platinums tend to build up condensation. I see the fogs are also available. I wish I didn't just install the mori LED fogs because I certainly would get these too. I dislike the fitment of the mori's. I hope someone makes a nice PnP harness soon for the 14' Platinum.
    Roman[OP] likes this.
  26. Sep 12, 2017 at 4:54 PM
    #176
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Thanks Roman! Just order a pair for my 2015 Platinums! I hope someone figured out harness too.
  27. Sep 12, 2017 at 6:24 PM
    #177
    MMichaelJJ
    MMichaelJJ New Member
    14 Platinum CM
    Just like that, $700 spent. Figured while I was ordering the lights I could pick up some other stuff to save on shipping.
    Roman[OP], Tophergt99 and 757TUNDRA like this.
  28. Sep 12, 2017 at 8:23 PM
    #178
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    X2, I'll stick with my retrofit. Thanks for the link@Roman
  29. Sep 13, 2017 at 6:36 AM
    #179
    Judd1980
    Judd1980 New Member
    Judd
    @Roman I didn't see that I needed to purchase two harnesses until after I paid for the headlights. Can I add them to my order? If so, just send me your Paypal address and I'll send the funds. My order for the headlights is: 20773
    Thanks!
    Judd
  30. Sep 13, 2017 at 7:20 AM
    #180
    Roman
    Roman
    Franklin, TN
    Are you talking about the connectors? I don't have any conversion harnesses. I would think someone should be coming up with them and selling them soon, hopefully. Speaking of which...
    If you have developed a good quality harness for sale for the community, let me know and I will update the OP with your information on where/how to buy them.
    Berdine and 757TUNDRA like this.
