2018 OEM LED Headlights
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Aug 21, 2017.
  1. Nov 25, 2018 at 2:10 PM
    #631
    TundraATX512
    TundraATX512 New Member
    Round Rock, Tx
    2023 Toyota Tundra Platinum Hybrid
    @Headlight Revolution
    Thanks! I have a 2017 Tundra Limited with the Non-DRL halogen and will I need to re-pin anything?
    I’ve notifed people commenting on your videos about the turn signal and any input would be appreciated.
  2. Nov 26, 2018 at 6:18 AM
    #632
    Headlight Revolution New Member Vendor
    Atlanta, GA
    Though the harness itself is completely plug n play, due to the fact that the new headlights use a 7443 front turn signal bulb inside the lights versus the original 3157/4157 - you will just need to re-pin the connector coming from your truck in order to make the blinker work properly. Simply swap the purple & black wire and good to go. :)
  3. Nov 27, 2018 at 6:38 AM
    #633
    douginBend
    douginBend New Member
    Doug
    I recently installed the OEM Tundra Sport LED headlights in my 2016 Tundra, using the iHacker harness. Although they seem to be working and look good, I am disappointed with the light output. Particularly in dawn / dusk times, the output is substandard. We have two other vehicles in the home ( one with OEM projector xenon - Porsche / one with OEM LED - Subaru ), and the Tundra lights are about half as bright as either. Does anyone else have this issue? Could it be a wiring issue? I have the dimming DRL harness.
  4. Nov 27, 2018 at 8:19 AM
    #634
    Tundracollector
    Tundracollector New Member
    16 Dc trd pro, 04 Dc, 08 rcsb
    The output on the tundra’s LED’s are better than the stock halogens it once had, but at the end of the day the output is just ok not phenomenal. They are still reflector housings and not projectors.
    I’m pretty sure the Porsche blows it out the water, so does my wife’s BMW X3 but those aren’t really fair comparisons because they are more expensive vehicles.
  5. Nov 27, 2018 at 8:28 AM
    #635
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Yeah, I felt this when I switched from retrofitted headlights to the new LEDs, took me about a week to get used to the new output which is not that bright compared to either HID or LED projector based headlights, unfortunately there’s nothing we can do to fix this.
    LED boards can be modified but that’s another story I don’t want to step in, this involve bake your headlights and take them apart to modify everything possible
    Give them a while and like happened to me I barely notice the difference nowadays. They only thing I’m pretty sure is I hated that ugly yellowish stock headlights and did everything possible to get rid of them on day one after delivery of my truck.
    I also have a Acura MDX with LED projectors and there’s a huge difference in output if I compare them.
  6. Nov 27, 2018 at 8:41 AM
    #636
    douginBend
    Doug
    Thanks for the confirmation with my experience. I would likely have gone the projector route if I had known the output was substandard. Given the cost, I am disappointed for sure. Anyone looking to do this conversion should realize that the look is far superior, but the function is marginally better than stock.
    Watt maker and iHacker like this.
  7. Nov 27, 2018 at 9:20 AM
    #637
    iHacker
    iHacker SW TRD PRO
    Mario
    If you doing the conversion the LED fogs is a must to complement the setup and compensate the weak output
    You have many choices OEM, Morimoto XB, RIGID OEM, RIGID SAE D2s etc...
    Watt maker likes this.
  8. Nov 27, 2018 at 9:31 AM
    #638
    Tundracollector
    I agree with you, but one thing the aftermarket projectors is not going to give you is oem quality and reliability.
    Look into getting Baja designs squadron sports in clear cornering Lens for your fogs, they will make up and then some for the headlights short coming.
  9. Nov 27, 2018 at 2:18 PM
    #639
    Roman
    Roman [OP] Toyota Parts Master Vendor
    Roman
    Franklin, TN
    As of right now, our back order report is showing us to be getting a large shipment of them on 12/8. Most of them are sold already, though.
  10. Nov 27, 2018 at 3:44 PM
    #640
    FoghornTX
    FoghornTX Proud American and Infidel since 1968
    Ft Worth, Texas
    2022 Camry XSE (Black w/blackout package)
    2018 SR5 with halogen headlights. Per the pictures below, do I need the non-LED DRL adapter or not when I upgrade to the LED headlights?
    Is the DRL in the headlight shown below an LED DRL?
    Thanks.
  11. Nov 27, 2018 at 5:37 PM
    #641
    austintxoutboards
    austintxoutboards New Member
    Travis County, Texas
    2019 Cement 4X4 Crewmax
    @FoghornTX it’s built in to the headlight the lower LED DRL.. you’ll need to get with @iHacker to get your order in for the plug n play harness adapter..
    Are these the headlights on your truck now?
  12. Nov 27, 2018 at 5:56 PM
    #642
    FoghornTX
    Ft Worth, Texas
    Yeah, the ones in the picture are OEM when I purchased it and they are on my truck right now. The OEM LED headlights are showing up tomorrow.
  13. Nov 27, 2018 at 6:31 PM
    #643
    TundraATX512
    Round Rock, Tx
    I have a black ‘17 CrewMax LTD and wondering what color housing to go with.
    I know the TRD Pros look to be the preferred choice but per @Roman look to be out of stock.
    I’m more of a chrome guy anyways so trying to decide between smoked or regular chrome.
    Any feedback or even pictures would be appreciated.
    Roman[OP] likes this.
  14. Nov 27, 2018 at 6:34 PM
    #644
    FoghornTX
    Ft Worth, Texas
    I went with regular chrome.
  15. Nov 28, 2018 at 12:29 PM
    #645
    TundraATX512
    Round Rock, Tx
    Hey @FoghornTX
    I was thinking about the regular chrome ones as well. Do you by chance have any pics of them on the truck?
  16. Nov 28, 2018 at 12:42 PM
    #646
    FoghornTX
    Ft Worth, Texas
    Not yet. Wife just texted me and said that a whole bunch of boxes showed up at the house. They must be the LED headlights, Morimoto LED fogs, and boxes of AR15 parts.
  17. Nov 28, 2018 at 1:08 PM
    #647
    TundraATX512
    Round Rock, Tx
  18. Nov 28, 2018 at 1:13 PM
    #648
    Azblue
    The Dirty T ( ^_^)_且
    I just happened to be standing by my truck when I read this. Here you go, chrome ones.
    trddriver and iHacker like this.
  19. Nov 28, 2018 at 1:14 PM
    #649
    TundraATX512
    Round Rock, Tx
    Man those are nice! Appreciate the picture!
  20. Dec 16, 2018 at 11:16 PM
    #650
    Dual Rider
    Dual Rider New Member
    Ken
    Portland, OR
    2014 MGM Limited Crew Max
    Bilstein 6112 2" level in the front, black Fuel wheels, 285/70R 18 Nitto Exo Grappler tires, BakFlip Tonneau cover, N-Fab nerf steps, Undercover Swing Case, Line-X bed liner, console safe, 2018 TRD Sport grill with color matched MGM surround and hood bulge, and more...
    I ordered mine on 11/23 and still don't have them... Trying to remain patient, but not easy...
    Blackrr likes this.
  21. Dec 16, 2018 at 11:22 PM
    #651
    Atlanta, GA
    Backorders hit everyone this time of year, it's tough to keep up sometimes. We have had ours sold out pretty quick as well, but I believe we are getting more in soon.
    Roman[OP] and JustinTheHeathen like this.
  22. Dec 17, 2018 at 7:13 AM
    #652
    TundraATX512
    Round Rock, Tx
    @Roman
    Is there a particular housing that is more readily available than the other? Or are all of the headlights in general back ordered?
    Appreciate any insight you may have.
  23. Dec 17, 2018 at 8:47 AM
    #653
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    has anyone retro'd these yet?
  24. Dec 17, 2018 at 9:17 AM
    #654
    Atlanta, GA
    That would be interesting. :drool: The performance of them already is great though, and I personally love the look of them stock. It would be neat to see what people would come up with!
  25. Dec 17, 2018 at 12:21 PM
    #655
    Roman
    Roman
    Franklin, TN
    The chrome and black housing headlights (0C140's and 0C210's) are more readily available than the TRD Pro headlights (0C211's). That tee tiny bit of extra black is costing people weeks of wait times. :D
  26. Dec 17, 2018 at 12:32 PM
    #656
    TundraATX512
    Round Rock, Tx
    Thanks for the update Roman!
  27. Dec 17, 2018 at 3:41 PM
    #657
    Jamen800x
    Jamen800x New Member
    Jamen
    Ogdensburg, NY
    2016 Tundra Crewmax TRD
    TRD PRO suspension with Coachbuilder TRD PRO lift kit. 2019 TRD PRO black led headlights with IHacker wiring harness. TRD duals. TRD PRO grille. ARE Z series matching topper. SCS Ray 10’s. General Tire X3’s 295/70r18 tires. Spray in bed liner.
    I am one of them fools waiting (backordered) for that extra black in the pro headlights. I have a service this Saturday at the stealership. Who knows, they might have a 19 PRO there waiting for me.
  28. Dec 26, 2018 at 6:10 AM
    #658
    TundraATX512
    Round Rock, Tx
    Hope everyone had a great Christmas!
    I have a 17 Black Limited CM. I’m trying to decide between the TRD Pro headlights or the chrome ones.
    I don’t plan to dechrome my truck and needing feedback on which would look best.
  29. Dec 26, 2018 at 8:36 AM
    #659
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    In your case, chrome.
  30. Dec 26, 2018 at 8:43 AM
    #660
    TundraATX512
    Round Rock, Tx
    Thanks @TundraMcGov.
    I think I’m going this route as it would probably match best. Appreciate the feedback.
