2018 OEM LED Headlights
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Aug 21, 2017.
  1. Mar 2, 2018 at 5:09 PM
    #511
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    I ordered a pair of the harnesses from TRS just to see how they compare to the ones I made from scratch. All in all, not bad.
    TRS harness Pros:
    Motocontrol Relay Harness not needed
    Simplified wiring
    TRS harness Cons:
    18 awg wiring (I used 16awg)
    wiring terminal seals fit poorly, terminals have too much wiggle/play in 8pin connector
    unused spots on plugs do not come with rubber hole plugs to help seal out moisture
    If you're going the TRS harness route I would recommend ordering 10 Sumitomo MT/TS/HX/SL cavity plugs (CONN-100550) to fill in the blank spots
    BlueBottle likes this.
  2. Mar 2, 2018 at 5:17 PM
    #512
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Do the lows stay on w the highs? All switching is seemless? Flash to pass works low + high?
  3. Mar 2, 2018 at 5:22 PM
    #513
    thomasbus337
    2020 TRD Sport DC
    I only bench tested the harness with the extra headlight I had in storage. The lows do stay on with the highs. I'll try testing the other features again tomorrow using the new harness with the unused passenger side 3 prong plug on the truck
    DaBoro54 and BlueBottle like this.
  4. Mar 2, 2018 at 7:10 PM
    #514
    OceanSkyWolf
    OceanSkyWolf New Member
    2017 MGM CM
    So is it better to order the harness from retrofit or ihacker?
  5. Mar 2, 2018 at 7:15 PM
    #515
    Kwikfish
    Kwikfish Get your poop in a group!
    Tri cities,WA
    16 CM SSM
    Or retrofitwholesale?
  6. Mar 3, 2018 at 9:48 AM
    #516
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    I cant see how you dont need a motocontrol. As that harness sends the power for the low/high beams.
  7. Mar 3, 2018 at 9:57 AM
    #517
    Kwikfish
    Tri cities,WA
    16 CM SSM
    Ya im a bit lost on this as well lol...
  8. Mar 3, 2018 at 10:00 AM
    #518
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    I bout my harness which retains the dim feature, then ordered the motocontrol for the headlights. Mine works flawless plus i did the drl delete so it looks even more oem. I actually inspired a toyota tech to do his tundra when i was there the other day getting it serviced.
    Kwikfish likes this.
  9. Mar 3, 2018 at 11:05 AM
    #519
    Kwikfish
    Tri cities,WA
    16 CM SSM
    Where did you get your harness from if you domt mind me asking
  10. Mar 3, 2018 at 11:26 AM
    #520
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    The only thing that I can come up with is a jumper wire from hi beam to lo beam with a diode to isolate them. When the lo beam is on, the diode keeps power from going to the hi beam, but when you turn on hi beams, it allows power to go to the lo beam also keeping the lo beam on.
  11. Mar 3, 2018 at 11:27 AM
    #521
    Cuzican
    Cuzican New Member
    Louisiana
    @iHacker
  12. Mar 3, 2018 at 1:42 PM
    #522
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    This is called “bridge rectification” in the electronics world
  13. Mar 3, 2018 at 2:02 PM
    #523
    thomasbus337
    2020 TRD Sport DC
    I just tested the TRS harness against my original design on the truck. The TRS harness does keep the low beam on with the high beam, so it does work without the Morimoto relay harness. The flash to pass works exactly the same as it does on the original setup. The only other difference is with the TRS harness, the slight delay upon shutting the lights off is gone, they shut off instantly.
  14. Mar 3, 2018 at 2:07 PM
    #524
    iHacker
    iHacker SW TRD PRO
    Mario
    Do you noticed any slightly voltage drop in the Lo Beam wire? I’m waiting a few Schottky diodes to make my own test
  15. Mar 3, 2018 at 2:20 PM
    #525
    Kwikfish
    Tri cities,WA
    16 CM SSM
    Its confusing to me lol...
  16. Mar 3, 2018 at 4:35 PM
    #526
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    I got mine from a nonmember. The harness is legit and well built. I can pm u the info If Interested
  17. Mar 5, 2018 at 2:31 PM
    #527
    manofsteele2003
    manofsteele2003 New Member
    Grant
    24 Sequoia TRD Pro
    Westcott designs 3"/1" lift 295/70/18 Falken Wildpeak RTs Canvasback cargo liner aFe Tow hooks
    Need some help quickly if I can get it. I got the Retrofit Source harness and the headlights or the DRL do not work. I got power coming from the factory harness and power coming from the adapter but nothing. I also noticed that the separate harness for the DRL's don't have a ground wire which is I'm guessing why those don't work.
  18. Mar 5, 2018 at 3:39 PM
    #528
    iHacker
    iHacker SW TRD PRO
    Mario
    You will need to use a fuse tap for the LED DRL, no ground needed since this is shared for whole headlight
  19. Mar 5, 2018 at 3:47 PM
    #529
    iHacker
    iHacker SW TRD PRO
    Mario
    Not sure the colors they used but must add a fuse tap to the wire in the right side in the connector, in my case I use red wire for the DRL bright. Unless you create your own relay for HI and LO DRL, with their harness you only have HI DRL
  20. Mar 5, 2018 at 3:52 PM
    #530
    manofsteele2003
    Grant
    24 Sequoia TRD Pro
    They still do nothing even with the fuse tap. The headlights are still nada as well. I called the Retrofit Source and let them know the issues and I haven't heard back from them yet. I'm currently back to the crappy stock headlights since I didn't want to rerun the harness for my retrofits.
    Does anyone have the schematic for the 2018 headlight plug? I'm wondering if the wires are in the right spots.
  21. Mar 5, 2018 at 3:53 PM
    #531
    iHacker
    iHacker SW TRD PRO
    Mario
    Send me a Pm
  22. Mar 5, 2018 at 4:30 PM
    #532
    OceanSkyWolf
    2017 MGM CM
    So don’t get them from retro fit???
    fundra_goes_west likes this.
  23. Mar 5, 2018 at 4:32 PM
    #533
    thomasbus337
    2020 TRD Sport DC
    Never even thought to check it. I'm leaving my original wiring setup installed just in case I decide to reinstall my D2S retrofit headlights.
  24. Mar 5, 2018 at 4:34 PM
    #534
    iHacker
    iHacker SW TRD PRO
    Mario
    Using diodes as a circuit rectifier produce a drop in voltage for around 0.7V (Vf) not sure if this will affect brightness of headlights
  25. Mar 5, 2018 at 4:56 PM
    #535
    iHacker
    iHacker SW TRD PRO
    Mario
    I just prefer your harness design to be safe
  26. Mar 8, 2018 at 6:09 PM
    #536
    TundraCoast
    TundraCoast Member In Good Standing
    Ian
    California
    1794 4x4
    1794 on the inside - PRO on the outside
    Saw an oddity today, 2018 Tundra Platinum facing me at a stop light had no DRL's on. This was a bone stock truck with paper-plates so I doubt any mod's had been done. Is that something that Toyota is doing on the new trucks? Where you can override the DRL's.
    When he turned it was clearly a Platinum and not a lower model without the LED headlights, just curious as there would be situations where you would want the DRLS completely off (if this has been covered I apologize).
  27. Mar 8, 2018 at 10:14 PM
    #537
    iHacker
    iHacker SW TRD PRO
    Mario
    DRLs can be turned OFF in 2018 trucks they have that setting in the headlights/turn signals switch, I have seen a few at the dealership and isn’t nothing new I had that feature in my 2015 Tacoma not sure why didn’t include that option in the 2014-2017 Tundras
  28. Mar 8, 2018 at 10:18 PM
    #538
    iHacker
    iHacker SW TRD PRO
    Mario
    Easy fix if you want that, just add a dashboard switch to control your DRLs
  29. Mar 21, 2018 at 9:36 AM
    #539
    Ossifer_Evo
    Ossifer_Evo New Member
    Miguel
    2015 TRD Pro Tundra (supercharged)
    Are we still able to purchase the headlights through that link? A buddy of mine that works for a dealer was told they were unavailable for purchase unless they were actually working on the vehicle a their shop.
  30. Mar 21, 2018 at 9:39 AM
    #540
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I believe @Roman can still get them. Tbey may be on back order.
    Sounds like your buddies dealer wants people in the door , so they can charge more, and charge to install?
    Roman[OP] likes this.
