2018 OEM LED Headlights
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Aug 21, 2017.
  1. Jan 23, 2018 at 3:56 PM
    #481
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    I didnt get hyperflash.
  2. Jan 26, 2018 at 5:52 AM
    #482
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    You dont order any, they come with. The headlights from toyota
  3. Feb 12, 2018 at 6:44 PM
    #483
    METRO32168
    METRO32168 New Member
    2016 CM PLATINUM SILVER
    DECKED STORAGE UNIT,BACKFLIP G2 COVER,THULE ROOF RACKS, AMP RESEARCH POWERSTEP, TRD BILSTEINS COIL OVER SHOCKS (3" LIFT), TRD BILSTEINS SHOCKS REAR, SETINA BUMPER GUARD
    Parts list when available please. Tia
  4. Feb 15, 2018 at 3:26 PM
    #484
    wes77
    wes77 New Member
    Does anyone have a links to videos of the DIY for the harness and motocontrol?
    I saw the one for under the dash relay, but is there any for the Morimoto, fuse wire and wire harness to the led lights...
    How does one connect the fuse wire?
  5. Feb 15, 2018 at 3:45 PM
    #485
    @iHacker send PM
  6. Feb 24, 2018 at 8:19 AM
    #486
    manofsteele2003
    manofsteele2003 New Member
    Grant
    24 Sequoia TRD Pro
    Westcott designs 3"/1" lift 295/70/18 Falken Wildpeak RTs Canvasback cargo liner aFe Tow hooks
    I'm about to ditch my retrofits for these but I'm kinda confused about the different harnesses. The one above is only $90 and it sounds like that's all you need but all others are about $175 plus you need to use the Morimoto relay in conjunction. Can anyone clarify?
  7. Feb 24, 2018 at 8:26 AM
    #487
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    If you use the one from TRS you WILL NOT need any additional relays or the Morimoto control relay.
  8. Feb 24, 2018 at 8:27 AM
    #488
    manofsteele2003
    Grant
    24 Sequoia TRD Pro
    That's what I was thinking but was thrown off by the lower cost than the others. Thanks for clarifying
  9. Feb 24, 2018 at 8:48 AM
    #489
    thomasbus337
    2020 TRD Sport DC
    Just checked and when added to the cart they show up as "sold out". I wonder how many they had to begin with?
  10. Feb 24, 2018 at 9:20 AM
    #490
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Either that or it didn’t work properly :notsure:
  11. Feb 24, 2018 at 11:07 AM
    #491
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    They tested the harness just with the headlights but not in the actual truck so I guess didn’t work that way and took the posting down :notsure: who knows, the harness they sell is perfect only for Platinum/1794 only, for non LED models the DRL will use the fuse tap style only they just power the DRLs to any 12V switched power and not keep the factory style and dimming function, I like the idea to ditch the Motocontrol but not how the DRL work with their harness
  12. Feb 24, 2018 at 11:13 AM
    #492
    manofsteele2003
    Grant
    24 Sequoia TRD Pro
    Hmm, it let me place an order. Wonder how long it'll take to get it.
  13. Feb 24, 2018 at 11:14 AM
    #493
    manofsteele2003
    Grant
    24 Sequoia TRD Pro
    Ha, just noticed that our signatures are almost identical.
    iHacker[QUOTED] likes this.
  14. Feb 24, 2018 at 11:14 AM
    #494
    iHacker
    iHacker SW TRD PRO
    Mario
    Not sure they said “SOLD OUT”
  15. Feb 24, 2018 at 11:17 AM
    #495
    iHacker
    iHacker SW TRD PRO
    Mario
    The only thing I cannot understand is how to choose color they said offer both Chrome and Black Chrome Headlights but there’s no option to select this, maybe if you leave a message when placing your order
  16. Feb 24, 2018 at 11:24 AM
    #496
    iHacker
    iHacker SW TRD PRO
    Mario
    :thumbsup::thumbsup: Yeah I had retros before, blacked out TRD PRO headlights with LED strip and Panamera LED shrouds same like you D2S 4.0 projectors
  17. Feb 24, 2018 at 11:25 AM
    #497
    OceanSkyWolf
    OceanSkyWolf New Member
    2017 MGM CM
    So from which person did you order the harness from???
  18. Feb 24, 2018 at 11:37 AM
    #498
    NickyF25
    NickyF25 New Member
    Nick
    SE Pa
    2017 Platinum 4x4 Silver Sky-Sold
    I agree it is confusing. I noticed in the product specs under compatibility it lists the part numbers for the black ones only, which is what I want but hesitant to order until it is made more clear. Also odd the harness is advertised but is immediately out of stock.
  19. Feb 24, 2018 at 11:51 AM
    #499
    iHacker
    iHacker SW TRD PRO
    Mario
    I used the diode method in my old 2000 Honda Civic Si to keep LO Beam with HI beam and it worked but I remember I had a weird thing when pulling the stalk to flash with headlights, this work but isn’t reliable mine lasted for about 2 years until the diode blew out I guess this is if you use HI Beam for long period of time. The diode help to block current passing to the other side when using LO beam but when using the HI beam it allows current going to the LO beam wire
  20. Feb 24, 2018 at 11:58 AM
    #500
    iHacker
    iHacker SW TRD PRO
    Mario
    I made my own harness with parts list in thomasbuss377 thread
  21. Feb 24, 2018 at 3:36 PM
    #501
    Kwikfish
    Kwikfish Get your poop in a group!
    Tri cities,WA
    16 CM SSM
    I want to get the harness already done so i can do this mod
  22. Feb 26, 2018 at 7:56 AM
    #502
    manofsteele2003
    Grant
    24 Sequoia TRD Pro
    Ordered the one from Retrofit Source, says on back order so I called to find out the ETA and they said it should ship today or tomorrow. I asked about the harness itself on how it worked and the way it's wired, the guy couldn't give me any info on it.
    Anyone have one of these installed?
  23. Feb 26, 2018 at 8:24 AM
    #503
    BlueBottle
    '16 Platinum 4x4
    See fine print
    You might be the first one! Let us know how it works and all functions work.
  24. Feb 27, 2018 at 5:15 AM
    #504
    manofsteele2003
    Grant
    24 Sequoia TRD Pro
    Ha great, I love being the guinea pig.
    BlueBottle[QUOTED] likes this.
  25. Mar 2, 2018 at 11:26 AM
    #505
    VAQuicksand
    VAQuicksand New Member
    @manofsteele2003 - ever get your 2018 oem light installed on your limited tundra?
  26. Mar 2, 2018 at 12:28 PM
    #506
    manofsteele2003
    Grant
    24 Sequoia TRD Pro
    Not yet . I got the headlights in the other day and I just got the harness this afternoon. The weather is shit today but I'm hoping to have them in by Monday. I have to say that pics do not do the 2018 headlights justice, they look pretty badass in person.
  27. Mar 2, 2018 at 4:07 PM
    #507
    lbcdan
    lbcdan Zip it up and zip it out
    Daniel
    Long Beach, CA
    2018 Toyota Tundra CrewMax 4x4
    Toytec Boss Coilovers, Total Chaos UCA, Icon 57720P Shocks, Toytec Shackles, TRD Off-Road Wheels, SpiderTrax Spacers, BakFlip MX4, Clazzio Seat Covers, Rough Country Light Bar, BajaDesigns Foglights
    I have been reading all of these threads but I am still confused on what harness I need. I have a 2018 SR5 (w/ LED DTRL strip). What do I need to get the 2018 full LED headlights to work?
  28. Mar 2, 2018 at 4:28 PM
    #508
    iHacker
    iHacker SW TRD PRO
    Mario
    You will need a harness same as current Platinum/1794 since you already have LED DRL
  29. Mar 2, 2018 at 4:31 PM
    #509
    lbcdan
    Daniel
    Long Beach, CA
    It looks like there are a few out there. Are there any that are 100% plug-n-play? I would rather not mess with pins, wiring etc. Thanks for the help.
  30. Mar 2, 2018 at 4:56 PM
    #510
    Kwikfish
    Tri cities,WA
    16 CM SSM
    They are from what ive read,on mine i will pron leave the marker wire so there on as well,seen a pic of ot done on here somewhere and like the look.
