2018 Lights and NSV Hood Bulge Light Bar
Discussion in 'Lighting' started by Sting Ray, Dec 23, 2017.
  1. Oct 9, 2018 at 1:35 PM
    #91
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    Hey guys I have the same setup, but my fog lights won’t come on any thoughts ? I’ve checked the fog light relay it’s fine , so is the fuse....
  2. Oct 9, 2018 at 1:47 PM
    #92
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    YES it does
  3. Jan 23, 2019 at 8:55 AM
    #93
    rjl82
    rjl82 New Member
    Rj
    I’m wanting help on bypassing the high beam switch to turn on light bar any help ?
    4077th likes this.
  4. Feb 5, 2019 at 5:55 AM
    #94
    Xray09
    Xray09 New Member
    Phenix City, Al
    2014 White Tundra Platinum Crewmax 4x4
    2.5/1 lift 275/65r20 BFG ko2 TRD rear sway bar Spray in bed liner Sprayed tow hooks red
    How can I get the DRL’s to turn off when headlights are on , got pulled over today and was told they were not legal, (to bright and to high). And yes they dim correctly when headlights come on, it’s probably related to the fact my truck is lifted so they seem brighter wheel you look up into them.
  5. Feb 14, 2019 at 12:03 PM
    #95
    BlackdOutTundra
    BlackdOutTundra New Member
    2019 Black Tundra Limited TRD
    @Xray09 Did you figure out a solution to this? I want to do the same thing because I know I will get pulled over as well for running Aux lights not attached to the high beam. I think as a quick solution it has to be as easy as pulling one of the 11 pins to the light bar. The more viable option I would like to do is have the dimmed drls come on when the truck is in the auto setting and you turn on the high beams. This is simply wishful thinking.
  6. Feb 14, 2019 at 1:17 PM
    #96
    Xray09
    Xray09 New Member
    Phenix City, Al
    Pin#9. Yes, I hate having to do this but I don’t want a ticket, even though all the other cops I talk with say it’s fine, but the one that pulled me over said different. I wished the switch in the truck had 3 settings, low, high, off. Pulling the pin was a little challenging, be sure to remove the orange piece inside the harness, then you will need a small screw driver or nail to reach in and depin it. I just taped it once removed Incase I ever want to repin it later.
  7. Feb 14, 2019 at 1:20 PM
    #97
    BlackdOutTundra
    You are a life saver! Thank you so much and for the tips on removal.
    I agree I wish there was a setting for those three. Does your drls still work when the headlights are not on?
  8. Feb 14, 2019 at 1:23 PM
    #98
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    I just push the button to turn mine off at night, but you may want to look at putting tint on them so they're not so bright. I've done that and it helped.
  9. Feb 14, 2019 at 1:24 PM
    #99
    Xray09
    Xray09 New Member
    Phenix City, Al
    When you turn switch on, the DRLs will be in bright mode. The good is that you can turn them on anytime you turn switch on, whether headlights are on, off, or bright. The bad is, you will lose the dim mode all together.
  10. Feb 14, 2019 at 1:43 PM
    #100
    BlackdOutTundra
    The bar sounds better when you take pin 9 out. I’d be happy to be able to turn the drls on with the push of a button! Thanks for the info
  11. Feb 14, 2019 at 2:57 PM
    #101
    Xray09
    Xray09 New Member
    Phenix City, Al
    I like being able to control them too, just wished I still had the dim mode
  12. Apr 6, 2020 at 6:34 AM
    #102
    Wes0804
    Wes0804 New Member
    2018 Tundra
  13. Apr 6, 2020 at 6:35 AM
    #103
    Wes0804
    Wes0804 New Member
    2018 Tundra
    I am experiencing the same issue. How did you resolve the problem??
  14. Apr 6, 2020 at 6:36 AM
    #104
    Wes0804
    Wes0804 New Member
    2018 Tundra
  15. Apr 6, 2020 at 4:12 PM
    #105
    Devildawg712
    Devildawg712 New Member
    Union City, Ca
    2020 Marine Corps Green Sequoia. (SEQUNDRA) Past~~ 17' Cement TRD PRO (FUNDRA)
    Contact the vendor you bought it from. I can't speak for anyone else, but my POC was Jensen at TORC auto. 1000% satisfied. Sent me a replacement via FedEx and a prepaid label to send the defective one back. GL
