2018 Lights and NSV Hood Bulge Light Bar
Discussion in 'Lighting' started by Sting Ray, Dec 23, 2017.
  1. Dec 23, 2017 at 7:38 PM
    Sting Ray
    Sting Ray [OP] New Member
    Ray
    Vegas
    2017 SR5 Crewmax
    Not enough space here...
    Anyone running the 2018 led headlights and the NSV hood bulge light bar?
  2. Dec 23, 2017 at 8:37 PM
    Cfincke
    San Antonio
  3. Dec 24, 2017 at 12:17 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Yes I've been talking to him on Facebook. Trying to figure this out as I have ihacker harness and the 2018 lights. About to pull the trigger on the NSV but not if it doesn't work right...
    @iHacker he says he doesn't use the purple wire at all?? Hopefully he chimes in as I am definitely not the expert....
  4. Dec 24, 2017 at 12:18 AM
    inferno_pro_satx
    inferno_pro_satx New Member
    Roger
    2016 Tundra TRD Pro
    What problems were y’all having? I had no problems when I first started playing with it or dimming. I also switched the wires at the bulb connector. But did away with the purple wire completely cause I didn’t like the nsv drl’s with the headlight drl’s.
  5. Dec 24, 2017 at 7:22 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    NSV is 20% through TORC....good discount
    Watt maker likes this.
  6. Dec 24, 2017 at 7:39 AM
    TRDProCement
    TRDProCement New Member
    Joe
    2017 TRD Pro Cement
    I couldn’t get the drl in the lightbar to dim and it would blow my rear tail running lights fuse.
    I tried pulling the purple wire and the drls in the bar wouldn’t dim but no popped fuse.
    You got the drls in the bar to turn off just by deleting that wire?
    Thanks
    Joe
    Beesta likes this.
  7. Dec 24, 2017 at 7:43 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Yes I know that's a great deal. Waiting for confirmation of how it will work the led lights before I order.
  8. Dec 24, 2017 at 7:44 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Did you switch the wires at the bulb connector also with the purple wire removed like he said above?
  9. Dec 24, 2017 at 7:45 AM
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Did you reconfigure the nsv pins on both ends of the pigtail harness as you did on the factory harness? Remember you swapped the purple & white/blk wire on the factory harness so that also needs to be done on the nsv both ends. The blue pigtail they send if for the platinum/1794 only since they don’t have a purple wire at the 3 pin connector.
  10. Dec 24, 2017 at 8:06 AM
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    I have the nsv and am about to install the 18 headlights with the ihacker harness.
    are you saying there is no longer a wire to jump the marker lights? Or does the dimming function work differently?
  11. Dec 24, 2017 at 8:06 AM
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    This is how the pins should look on the nsv
    nucmedcurtis likes this.
  12. Dec 24, 2017 at 8:10 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    So are you saying they won't send this harness to me since mine is an SR5?
  13. Dec 24, 2017 at 8:20 AM
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    As long as you repin the the factory harness for the turn signal bulb and so the same on the nsv t harness it will function and dim as supposed.
  14. Dec 24, 2017 at 8:21 AM
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    The t harness comes with all nsv’s, this one I have is from another one I installed and guys wiring was way not factory so had to be hardwired.
  15. Dec 24, 2017 at 8:44 AM
    mtTundra
    mtTundra New Member
    Bozeman MT
    that makes sense thank you for clarifying
  16. Dec 24, 2017 at 8:50 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
  17. Dec 24, 2017 at 9:31 AM
    TRDProCement
    Joe
    2017 TRD Pro Cement
    I didn’t.
    I was only trying to remove the jumper wire to make it work.
    I did remove my purple wires to make the headlights work.
    Devildawg712 likes this.
  18. Dec 24, 2017 at 9:33 AM
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Don’t use the jumper wire it’s for platinums the pro/SR5 already have the purple wire
  19. Dec 24, 2017 at 9:34 AM
    TRDProCement
    Joe
    2017 TRD Pro Cement
    I’ll have to give this a shot.
    Probably not going to do it before someone else tries to install though. I’ve already installed and uninstalled these lights twice.
    Thanks
    Joe
  20. Dec 24, 2017 at 9:44 AM
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Give it another try, I assure you it will Work doing it my way.
  21. Dec 24, 2017 at 1:16 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Ok @inferno_pro_satx I'm gonna order my NSV light.
    Just to confirm the changes I need to make in order for it to work are:
    1.repin the factory turn signal harness from how I currently have it configured to make the 2018 lights work. ( currently have 1. White w/ black stripe, 2. empty, 3. pink or red depending on side) pics of how they are wired below.
    2. repin the NSV t harness to match this change
    3. Disconnect the purple wire that I currently have connected (not in the pics) and just tape it off.
    4. Don't use the jumper as it's for plat/1794 only.
    Does that all sound right? This will allow the drl's to still be bright and then dim when I turn the headlights on and will also allow the NSV light bar drl's to do the same, bright she headlights are off and then dim when the headlights come on.
  22. Dec 24, 2017 at 2:40 PM
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Yes you have it correct, you can repin the purple you currently have unpinned and remove the blue pin at the nsv bulb only bulb side leaving the other end in so the nsv drl’s dim. Because currently with the purple removed your amber parking lights are not on at night.
    Don’t use the jumper at all
    Devildawg712 and Sting Ray[OP] like this.
  23. Dec 24, 2017 at 3:06 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Got it! Light bar is on the way. Thanks man! Looking forward to the install.
  24. Dec 24, 2017 at 3:10 PM
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Nice, keep me updated
    Sting Ray[QUOTED][OP] likes this.
  25. Dec 29, 2017 at 7:17 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    NSV hood bulge lightbar installed. Pretty easy install, little tricky on the wiring due to having the 2018 lights and harness but @inferno_pro_satx helped me out tremendously. I'll post up some output shots later on.
    https://youtu.be/22qzDnA7lyY
    B737, Tierhog, mesaboogieman and 3 others like this.
  26. Dec 31, 2017 at 1:24 PM
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    I’m jealous....killer look but 1k for a light bar is out of my reach....anyone else make one for the bulge ? Did you look at others?
    Sting Ray[OP] likes this.
  27. Dec 31, 2017 at 1:32 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    You can put a single row light bar in there but you'll be cutting your hood bulge. Light output might not be as good. There's no cutting with the NSV and it comes with the replacement switch panel (looks OEM) and it has swipe and strobe functions. Well worth the money to have a factory fit and finish as well as cool features. Just like anything else, you get what you pay for.
  28. Dec 31, 2017 at 1:34 PM
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    Might have to be patient and catch the next discount...looks awesome
  29. Dec 31, 2017 at 1:36 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Thanks. It's still on sale I think until today
    Stulloh likes this.
  30. Dec 31, 2017 at 1:45 PM
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    Too close to Christmas....maybe he will drop a Valentines special ❤️
