2018 Lights and NSV Hood Bulge Light Bar
Discussion in 'Lighting' started by Sting Ray, Dec 23, 2017.
  1. Mar 26, 2018 at 5:45 AM
    #61
    Devildawg712
    Devildawg712 New Member
    Union City, Ca
    2020 Marine Corps Green Sequoia. (SEQUNDRA) Past~~ 17' Cement TRD PRO (FUNDRA)
    sorry, just saw this. No I did not remove the headlight. It was a PITA tho. I was too lazy. I have bolt on fender flares I didnt want to take off. You can do it without taking em out but I would recommend just removing them if you have time
  2. Mar 26, 2018 at 5:46 AM
    #62
    Devildawg712
    Union City, Ca
    has anybody experienced moisture/ condensation in their lightbar? I've had it installed for maybe 2 months and there's already moisture inside?!?! Kinda at a loss for words for a lightbar thats almost 1k. I've already contacted the cust. service and warrant dept. Surely hope they have some answers. I live in Northern California and its rained a little bit, but nothing that would warrant condensation in a product that supposedly rock solid.
    Wes0804 likes this.
  3. Mar 26, 2018 at 7:44 AM
    #63
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    No issues on mine. Id contact them on that.
  4. Apr 13, 2018 at 12:14 PM
    #64
    Lurchdubious
    Lurchdubious New Member
    East TX
    Black 2017 Platinum
    Hey guys so I have the NSV bar and I’m excited to install, but I’m confused on the wiring. I have a 2017 Platinum, but I have the 2018 headlights installed via a harness I got from EledobleU. Do I still need the jumper wire? Or do I just need to switch two pins on the NSV wiring?
    Thanks for any help!!
  5. Apr 13, 2018 at 1:09 PM
    #65
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    swap the pins like you did on the headlight / wire harness.
    Just need them to line up don't forget to do both sides of NSV harnesses (I made that mistake and only did one).
    I have the jumper wire, that tells the bar when to dim the marker lights.
    let me know if you run into trouble, I could try to take some photos of my setup if you need.
    There is already a bunch on info in this thread and 1UPPER and gregfocker have done a couple good write ups too
    https://www.tundras.com/threads/nsv-light-bar-install.22495/#post-538949
    https://www.tundras.com/threads/i-got-my-nsv-led-hood-bulge-in-today.11042/#post-188592
    Lurchdubious and darkknight2014 like this.
  6. Apr 14, 2018 at 12:02 PM
    #66
    Lurchdubious
    East TX
    Black 2017 Platinum
    Thanks Matt!
    I read through those threads and tackled the install last night. The bar is awesome! I do have a problem though, for some reason the yellow running light on the driver side headlight is illuminated. It’s never been lit up before, as I have the ‘18 DRL’s. Any ideas? The only other problem is I can’t get the NSV DRL’s to turn off, which is what I thought the 2nd gen was supposed to do? I push the strobe switch to turn off DRL and nothing happens, except the switch lights up.
    Pic:
  7. Apr 14, 2018 at 12:04 PM
    #67
    Lurchdubious
    East TX
    Black 2017 Platinum
    My 12 pin plug didn’t have a #3 pin but it had a #8. I think it was focker who mentioned that Jensen told him to just leave 3 empty and put the #8 pin in the 8 slot...so that’s what I did. Is that the issue?
  8. Apr 14, 2018 at 12:10 PM
    #68
    gregfocker77520
    gregfocker77520 New Member
    luis
    2018 Graphie tundra crewmax sr5
    none yet!!
    The drl part of nsv can only be turned off when headlights are off, they stay on when headlights are on. As for the turn signals I had same issue so I got the switch backs from trs and I jumpered the drivers side just like the passenger side. So light is white when headlight are on not orange.
  9. Apr 14, 2018 at 12:11 PM
    #69
    gregfocker77520
    luis
    none yet!!
    I got the jumper wire for passenger side from ihacker. You have to pin it in the middle empty slot of the turn signal plug and ttap it to purple wire on the light leveling switch.
  10. Apr 14, 2018 at 1:04 PM
    #70
    Lurchdubious
    East TX
    Black 2017 Platinum
    THANKS, FOCKER!
    LoL. That’s just fun to say.
    Ok, I’ll contact hacker and jump the passenger wire. I don’t mind the orange light, just want it to be balanced.
    Would this have anything to do with my NSV DRL’s not dimming with the headlights? And I’ll check again, but I tried turning off the NSV DRL while headlights were off, with no change.
  11. Apr 14, 2018 at 2:04 PM
    #71
    mtTundra
    mtTundra New Member
    Bozeman MT
    you need to de pin a wire going into the headlight. the factory connector doesn't have it but the nsv does. this is because the non platinum/ 1794s don't use the turn signal as marker lights. the jumper wire is to allow the nsv to properly dim with your factory drl. check your wire harness going into the headlight and check your jumper wire connecton.
    I pulled the battery to make it easier to get to.
  12. Apr 14, 2018 at 2:14 PM
    #72
    gregfocker77520
    luis
    none yet!!
    I have the 1794 wiring so not sure what issue is with drls not turning off on your nsv
  13. Apr 14, 2018 at 3:21 PM
    #73
    Lurchdubious
    East TX
    Black 2017 Platinum
    Thanks! iHacker just got back to me and said the same thing. I should have realized that was what’s going on.
  14. Apr 14, 2018 at 3:24 PM
    #74
    Lurchdubious
    East TX
    Black 2017 Platinum
    I played around some more, if I switch to “off” on the headlight switch then I can retain the 2018 LED DRL’s and switch off the NSV running lights, so I guess it just doesn’t work when set to the parking lights setting, which is what I run 90% of the time so that my dash gauges are illuminated.
  15. Apr 14, 2018 at 3:26 PM
    #75
    mtTundra
    mtTundra New Member
    Bozeman MT
    yeah i can't help you here I have the v1 with the strobe function. my nsv marker lights are always on
    Lurchdubious likes this.
  16. Apr 14, 2018 at 6:45 PM
    #76
    Lurchdubious
    East TX
    Black 2017 Platinum
    Ok I depinned the middle wire and taped it off, took care of the amber light. I’m afraid something’s up with my jumper wire though, the NSV DRL’s don’t seem to dim at all when the headlights are on.
  17. Apr 14, 2018 at 8:55 PM
    #77
    mtTundra
    mtTundra New Member
    Bozeman MT
    probably something to do with your jumper wire. it should dim when your market lights dim/ turn on your interior lights.
  18. Apr 17, 2018 at 1:17 PM
    #78
    inferno_pro_satx
    inferno_pro_satx New Member
    Roger
    2016 Tundra TRD Pro
    If you guys wanna kill the nsv drl's just put the red/blk you t-tapped at the trailer harness on a toggle switch, that will kill the drl's and you can turn back on whenever.
  19. Apr 17, 2018 at 2:46 PM
    #79
    gregfocker77520
    luis
    none yet!!
    Any one figure out how to get the strobe back on the gen 2s?
  20. Apr 22, 2018 at 8:49 AM
    #80
    Alptbird
    Alptbird SR5, Limited, TRD, Mutt.
    Glen
    Houston Tx
    2016 crew max SR5
    Too many to list, I actually have an excel spread sheet!
    On my V2 bar I noticed that all instructions said no pin 8 but on mine it was no pin 3. I suspect if you re pin 8 to 3the strobe function may come back? I haven’t had a chance to test it, but it is still my list of things to do.
  21. May 2, 2018 at 4:12 PM
    #81
    tinyt1553
    tinyt1553 New Member
    Tom
    Cypress, TX
    2017 1794 CM - Magnetic Gray
    Exterior: POP & Lock Power Tailgate lock BakFlip MX4 Tonneau Cover Rhino Bed Liner Swapped OEM Halogen Fogs with Formula-J87 LED 6000k bulbs Rough Country 60" Tailgate LED lightbar 6" rubber stub antenna Interior: Front Emblem Camera with anytime backup cam, Crux Vimty-05 for Vehicle in Motion Override Center console wireless charging Verizon Hotspot in center console Chromecast to OEM head-unit display ESP Rear Seat 3 Compartment Storage 5% Ceramic tint on rear window and rear doors 18% Ceramic tint on front doors Weathertech rear seat cover (try to take Hank (boxer/pointer mix) with me everywhere I can) In The Works: Upgrade to 2018 OEM LED Headlights VLEDs throughout the rear (turns, brakes, highmount 3rd brake and cargo) GRT Lighting LED's to replace all interior bulbs Future Wishlist: Swap OEM Head-unit with Kenwood DNX994S and use iDataLink Maestro RR to integrate OEM backup cam, OEM USBs, OEM Aux input, etc AMP-Research Power Sidesteps Train (air) horn
    I can confirm if you take pin 8 and put in pin 3 hole on the 2nd gen NSV light bar, you will have the strobe feature back. It will disable the DRLs on the lightbar (only for DRLs, the end lights still come on in dim mode when headlights are on), it also gives you a nice extra feature... If you flip your headlight switch to the off position and hit the lightbar button switch for the NSV you get the lightbar on full by it'self without having to kick on your brights. I don't know if this shortens the life of the bar or causes other issues. I am running it on a '17 1794 with the 2018 LED headlights and have had no issues. Do this at your own risk.
    Alptbird likes this.
  22. May 4, 2018 at 6:37 PM
    #82
    925tundra
    925tundra New Member
    adrian
    san ramon,ca
    I have a 2018 and I just installed mine today what a cluster. I connected to the trailer brake and I am getting the trailer brake error and the only thing that works are the drl's on the nsv. None of the buttons do anything....
  23. May 10, 2018 at 2:44 PM
    #83
    Alptbird
    Glen
    Houston Tx
    2016 crew max SR5
    Don’t mean to insult you but it doesn’t sound like you got the correct two wires that connect behind the brake. if the buttons don’t work then you aren’t getting the power from the trailer brakes like you are supposed to be. At least that is what it sounds like
  24. May 10, 2018 at 3:34 PM
    #84
    925tundra
    adrian
    san ramon,ca
    Thanks all, I called Jensen from NSV and got it figured out..
    darkknight2014 likes this.
  25. May 10, 2018 at 4:15 PM
    #85
    Alptbird
    Glen
    Houston Tx
    2016 crew max SR5
    Glad you got it squared away. It is a great light. I get complements all the time.
  26. May 10, 2018 at 4:18 PM
    #86
    Fuckin bad ass!!!
  27. May 20, 2018 at 8:05 PM
    #87
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    Is the corners of ur nsv amber or just look like they are in pic? Was wondering if that was an option? Tia
  28. May 21, 2018 at 4:32 AM
    #88
    Alptbird
    Glen
    Houston Tx
    2016 crew max SR5
    All clear. My guess is he tinted his
  29. May 21, 2018 at 5:10 AM
    #89
    mgm16trdpro
    Northern NJ
    Tnx that's what I thought.
  30. Jun 28, 2018 at 4:34 PM
    #90
    Ntmid8r
    Ntmid8r New Member
    2018 Tundra TRD Sport
    TBA
    Will this NSV bar fit in a 2018, and how does it wire in?
