2018+ LED HEADLIGHTS PLUG N PLAY HARNESS FOR 2014-2020 MODELS [V 2.0]
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by iHacker, Apr 21, 2018.
  1. Apr 21, 2018 at 9:28 AM
    iHacker
    iHacker [OP] SW TRD PRO
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Wiring Harness for the 2018+ LED Headlights conversion on 2014-2020 models.
    NO HOLDS.
    I CAN PROVIDE INSTRUCTIONS FOR PAYMENT ONLY IF YOU ARE READY TO PLACE YOUR ORDER AND HARNESS WILL BE SHIPPED ON A FIRST COME FIRST SERVE BASIS TO KEEP ALL ORDERS FLOWING IN A TIMELY MANNER AND AVOID DELAYS.
    Disclaimer
    Please you have to understand if you are doing this modification is completely at your own risk and I have no liability for any damage you could cause to your truck if you don’t follow the directions correctly for this installation. No issues reported but this warning is just in case.
    If you are interested in a harness please PMe to confirm availability, this will take a while to produce due to lots of soldering required specially for truck with Amber DRL but I do my best to ship in 1-2 day after payment most of the time.
    Installation for the 2014-2017 1794/Platinum/2018-2021 SR/SR5 models 100% Plug N Play, for TRD PRO/SR5/Limited Models a few connections under dash and Amber DRL delete MOD are required to power LED DRLs and have them working with factory DRL system but nothing too complicated to worry about. NO WIRE CUTTING IS REQUIRED zero permanent damage to factory wiring is done so this is totally reversible to factory halogen headlights just in case you sell or trade in your truck.
    Warranty
    All my harnesses come with a 1 Year warranty replacement for any issue as a result of manufacturing or any malfunction, If a issue is detected please contact me as soon as possible I can help to do some quick troubleshooting at first, and if necessary, I can send a replacement.
    ATTN:
    Payments methods accepted Venmo, PayPal, Zelle or CashApp Friends and Family type of payments only for all platforms.
    All my harness sets are made using Toyota Genuine connectors, seals, cavity plugs and terminals, I prefer to never use generic parts to ensure quality. My first choice is Toyota connectors but if they become unavailable or back ordered I will use the cross compatible part form Japanese OEM manufacturer Yazaki which is the connectors supplier for the 2018-19 Toyota lineup. I use 16 gauge TXL automotive wire 100% made in USA not cheap wire from China.
    Check the available options depending on the type of headlights your truck came out equipped from factory:
    2014-2017 1794/Platinum/2018-2021 SR/SR5 (Trucks with single LED DRL and halogen headlights) $100 +shipping
    If your truck came out from factory equipped with halogen headlights and single LED DRL strip you definitely need this option. Check picture below
    This option is 100% PNP including turn signals no pins rewire required.
    The Turn Signal Adapters are intended to make your turn signals plug and play and avoid hyper flashing due to differences in the 7444 bulb used in this new headlights so you don’t have to move or cut a single wire as other harnesses from TRS or HR are required to do.
    If your truck came out from factory equipped with Amber DRL SR5/LIMITED/PRO) I can make two harness variants you can choose one between the two that is better for your wiring skills.
    2014-17 TRD PRO/SR5/LIMITED with factory LED DRL dimming $130 +shipping
    This Harness have full factory functionality (this is how 2018+ trucks normally work), the LED DRL is controlled by ECU, And also have a LED DRL auto dimming function, when headlight is turned ON LED DRL brightness is reduced to 60% to avoid blind or distract oncoming traffic at night, this option requires a bit of extra work (run a wire through firewall grommet and a simple wiring job under dash) but the end result is totally worth. By far this is the most popular option. Price for this option is $130 +shipping
    2014-17 TRD PRO/SR5/LIMITED Non-Dimming LED DRLs (Bright mode all the time) $110 +shipping
    Non-Dimming Harness (Bright DRL All The Time), This option is 100% Plug n Play no wires to splice or mess with, no firewall wire or any sort of wiring under dash besides the Amber DRL Delete (optional) but the LED DRL turns ON/OFF with ignition and stay at full brightness all the time (not like factory functionality which dims the LED DRL). To power the LED DRL in this option we go to use a fuse tap to replace the 10A IGN fuse in the hood fuses box. Price for this option is $110 +shipping.
    This option is highly recommended if wiring projects are not your thing (better safe than sorry) or if you definitely need a quick PNP solution.
    INSTALLATION GUIDES
    STEPS 1-4 Required For All Models
    Step 1:
    Set your headlights leveling system to 0, and then mark your headlights hot spots against a wall with your truck at at least 25FT from the wall in a level surface. This will help you to aim your headlights correctly at a later point.
    Warning: Before preceding to next step battery must be disconnected prior installation, remove negative terminal and cover it with a rag to keep it safe.
    Step 2:
    Remove Grill and Headlights
    https://youtu.be/gSeb4T7WP5M
    Step 3:
    With your headlights removed proceed to install your main harness
    For security I recommend you to zip tie the Headlights Plugs
    Make sure to plug back all the remaining connectors (Auto leveling system and Side corner makers are Plug N play and nothing involving my harness)
    Step 4:
    For Platinum/1794/18SR5 and DRL Bright All the time harness only:
    To use the turn signal adapters follow the instructions in next picture
    This complete the installation for Platinum/1794 and the new 2018 SR5 with LED strip from factory.
    ATTN: Follow next steps only for trucks with Amber DRL to install the LED DRL wiring.
    Bright mode all the time harness only (Fuse tap to IGN Fuse)
    TRD PRO/SR5/LIMITED
    The LED DRL harness have 2 sides (longer side with single wire is for passenger side, fuse tap side must be used in driver side) one for driver and the other for passenger side and a wire lead with a fuse tap containing one 10A and 7.5A fuses.
    Start installing the driver side harness and then to route the passenger side harness you can locate and follow the stock wiring harness in the radiator area (front of the radiator) and zip tie to it to secure it or you can also use this other option as I did mine:
    Now you have both ends in the respective place ready to plug to the designated connector.
    For turn signal adapters use the same instructions mentioned before
    Now we need to use the end of the harness containing a fuse tap to power the LED DRL. This option is completely Plug N Play and after plugin DRL connector on each side (Driver and Passenger) all you have to do is open the fuses box and replace the 10A IGN fuse with the fuse tap in the LED DRL harness.
    After this steps try to find a secure way to close the Fuses box lid cover over the wire without damaging the wire or cover
    Please make sure the lid cover make a good seal to avoid water intrusion and that finalize your installation.
    Harness with dimming only
    TRD PRO/SR5/LIMITED LED DRL WIRING
    The LED DRL harness have 2 sides one for driver and the other for passenger side respectively
    Driver side harness have 3 wires and turn signal adapter
    Passenger side only have 2 wires and the turn signal adapter
    Now we have a wire lead in the driver side LED DRL harness and this have to be routed into cab through the firewall grommet.
    NOTE:
    Please keep the wire lead with metal terminal only until you finally have the wire in the other side of firewall grommet, only after this you can insert the metal terminal into the connector until you feel or hear it clicking that means is inserted correctly and locked in place, give a gentle tug to make sure wire is secured.
    Complete this only if the wire is in the other side of firewall
    Zip tie to secure the harness to stock wiring alongside fender wall to reach firewall grommet.
    Insert wire into the nipple and gently pull the wire from the inside of cab
    Secure wire and use tape on nipple and complete stock harness to keep it safe and weatherproof.
    To continue with DRL Delete Mod and Relay installation watch the following pictures and videos
    DRL Relay Installation
    This is the process you have to follow for the relay connections under dash.
    Gray wire (AKA Amber DRL Delete Mod)
    ATTN: Before starting this step if you are planing to keep your amber DRL alongside with the new LED DRL do not depin/cut gray wire, you only need to splice the black wire from my relay to gray wire using either a positap or regular t-tap (RED) as shown in next picture.
    Highly recommended to buy a special terminal extractor tool but if not available a thumbtack can be used for this
    https://www.ebay.com/itm/353270127256
    Video
    https://youtu.be/5Vp4wjDK19I
    Depin or in the last case cut gray wire in pictures
    Once gray wire is out white connector insert the metal pin crimped in my relay black wire into the female metal terminal in the gray wire
    3
    Nothing have to be attached in the place where gray wire was removed.
    Blue Positap Wire (Inline fused red wire to ECU harness black wire)
    Black wire on the right side of flasher is used for the inline fused wire (12V supply), splice to this using the provided blue positap
    3
    5
    The following video show all this steps in action, video could be a bit outdated using older parts but still helpful.
    Installation Video
    https://youtu.be/6BG2MIlR8is
    Once you have done all this steps, connect your negative battery terminal, check for correct functionality and only if everything works now is time to put everything back in place you are all set, and it is time to enjoy your new headlights.
    One more thing...
    Some users noticed their headlights arrived aimed incorrectly, compare your new headlights heigh with the marks we placed in the wall in step 1, keep your leveling system in 0 and do the required adjustments,
    Each headlight have a channel reaching the leveling system motor gears, and you can rotate the gears as needed UP/DOWN just turning gears with a long Phillips screw driver.
    If for any reason you forgot to mark your stock headlights heigh follow this video to correctly AIM your headlights from scratch.
    https://youtu.be/GWvSWBlAwnI
    I hope this guide help you out.
    Thank you for your support guys.
    To order headlights here is the info:
    Seems like Toyota of Cool Springs online store is down and @Roman is no longer a active member here :(
    Contact @Roman at Toyota Of Cool Springs he is a tundras.com member and his thread have all the links with parts needed at great prices.
    https://www.tundras.com/threads/2018-oem-led-headlights.15733/
    Toyota Cool Springs use code FORUM20 for 20% off in shipping costs
    Check the Genuine Toyota Parts online store @ SPARKS Parts, if you end buying from them don’t forget to use the coupon code TUNDRAS.COM or TUNDRADUDE34 to get 5% OFF your total purchase.
    Headlights are available in 3 options here the links to them in their store:
    2019 TRD PRO Gloss Black housing
    Right Hand Side
    - Headlamp Assembly Right-Hand - Toyota (81110-0C211)
    Left Hand Side
    - Headlamp Assembly Left-Hand - Toyota (81150-0C211)
    2018 LED Headlights
    Smoked chrome housing
    Right Hand Side
    - Headlamp Assembly RH (LED - Black housing) - Toyota (81110-0C210)
    Left Hand Side
    - Headlamp Assembly LH (LED - Black housing) - Toyota (81150-0C210)
    Chrome housing
    Right Hand Side
    - Headlamp Assembly RH (LED - Chrome housing) - Toyota (81110-0C140)
    Left Hand Side
    - Headlamp Assembly LH (LED - Chrome housing) - Toyota (81150-0C140)
    And if needed here the link for the OEM LED Fog lights
    2018+ OEM LED Fog lights
    The 2018+ LED fog lights are completely plug n play, identical to the 2014-17 halogen fog lights. Simply remove the old ones, and pop in these in their place no harness needed.
    Right Hand Side
    - LED Fog Lamp Assembly (Right Side) - Toyota (81210-48051)
    Left Hand Side
    - LED Fog Lamp Assembly (Left Side) - Toyota (81220-48051)
    2019 TRD Pro Rigid LED Fog Lights
    Before starting this I highly recommend you to check this 2 threads, you can buy Rigid SAE D2 Pods or any of your choice buy the OEM bezels, Deutsch to H8 harness and build or buy the brackets showed in this threads and you can have Rigid LED fogs with 2X light output of OEMs for half of the price
    Original DIY
    https://www.tundras.com/threads/diy-trd-pro-rigid-fog-lights.34224/#post-855868
    Bracket and harness for sale at
    https://www.tundras.com/threads/diy-rigid-trd-pro-fog-lights-brackets.37902/#post-960860
    ... But if money isn’t a problem for you and want the real thing here you go
    Here are links to them in the store:
    Complete Kit
    https://www.sparksparts.com/p-tundra-trd-pro-rigid-fog-light-kit-pktunprofog
    Right Hand Side
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-fog-lamp-right-hand-tundra-trd-pro-pt22834190ac?c=az0x
    RH Bezel
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-fog-light-bezel-right-hand-tundra-trd-pro-pt22834190aa?c=az0x
    Left Hand Side
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-fog-lamp-left-hand-tundra-trd-pro-pt22834190ad?c=az0x
    LH Bezel
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-fog-light-bezel-left-hand-tundra-trd-pro-pt22834190ab?c=az0x
    You will need all four parts if you are adding
    The OEM Rigid fog lights to your Tundra. They use the same style plug so they are 100% plug and play no harness required.
    Thank you all for choosing me to help with your headlight conversion.
  2. Apr 21, 2018 at 9:41 AM
    HornFrog
    HornFrog Go Frogs!
    Fort Worth
    2016 MGM SR5 4x4 Crewmax
    TC UCA's, King 2.5, Ex-Pelf Bumpers and skids, TRD Pro Grill, 2018 Lights, BD Fogs, FRAC
    Hello. Do you have any harnesses for a 16' CM SR5? I like the dimming option. Thank you.
    iHacker[OP] likes this.
  3. Apr 21, 2018 at 9:55 AM
    Sting Ray
    Sting Ray New Member
    Ray
    Vegas
    2017 SR5 Crewmax
    Not enough space here...
    Awesome! For anyone thinking of purchasing from Ihacker, just do it! Not too many folks sell a product, that you can get a hold of at a moments notice if you have a question. HIGHLY RECOMMEND!
  4. Apr 21, 2018 at 10:01 AM
    iHacker
    I think I have 3 sets left, I shipped 13 already over the week.
    To produce this new harness is slow and tedious but I guess I can complete about 15-20 sets weekly
  5. Apr 21, 2018 at 10:08 AM
    OceanSkyWolf
    OceanSkyWolf New Member
    2017 MGM CM
    ihacker is the man! I didn’t order my harness from him but his support and guides are top notch and don’t leave anything to question.
  6. Apr 21, 2018 at 10:08 AM
    HornFrog
    HornFrog Go Frogs!
    Fort Worth
    I'll take one if you do.
    iHacker[QUOTED][OP] likes this.
  7. Apr 21, 2018 at 10:12 AM
    I'll be placing order soon!
  8. Apr 21, 2018 at 10:42 AM
    NickyF25
    NickyF25 New Member
    Nick
    SE Pa
    2017 Platinum 4x4 Silver Sky-Sold
    Just sent you a PM for my 2017 Platinum.
  9. Apr 21, 2018 at 10:42 AM
    iHacker
    PM
    hahahaha just on time Adam,
  10. Apr 21, 2018 at 10:49 AM
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    Freaking awesomeness!!!!!!! @iHacker :muscleflexing::muscleflexing:
    Bien echo vato!
  11. Apr 21, 2018 at 10:51 AM
    iHacker
    Gracias!!
  12. Apr 21, 2018 at 12:09 PM
    LKSR5-14
    LKSR5-14 New Member
    Chicago Northwest suburbs, Illinois
    2016 Tundra SR5 DC
    Tundra SR5 DC 2016 Upgrade: pro wheels, headlights retrofit, head unit Kenwood 694s, bed cover, lineX, Viper security and starter system, pro grille, tinted windows, LED lighting, black wrap on all end chrome corners, ceramic coating
    Great. I wish I knew it two weeks ago so I would go this route without motocontrol.
    Great job @iHacker
    Y0TA PR0 likes this.
  13. Apr 21, 2018 at 12:16 PM
    iHacker
    Sorry, I wasn’t sure if that was the way I want to go by that time, but I received too many email asking for this, this isn’t so easy to produce for me but I’m glad it will make everything truly plug n play for the end user.
    LKSR5-14[QUOTED] and Y0TA PR0 like this.
  14. Apr 21, 2018 at 5:35 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    You have the best looking harness by far! No competition. If I had to buy a harness I would so buy from you!
    So for anyone on the fence, do it!
    iHacker[OP] and LKSR5-14 like this.
  15. Apr 22, 2018 at 7:51 AM
    AndyCBR
    AndyCBR New Member
    Baton Rouge, LA
    So what changed that allowed motocontrol to be eliminated?
    I thought that box was the LED driver, but I guess the lights have an internal driver?
    So basically the only OEM harness difference from 2018 sr5 to 2018 limited & up is the connectors?
    Nice work ihacker!
    iHacker[OP] and Y0TA PR0 like this.
  16. Apr 24, 2018 at 6:34 AM
    Leg.20v
    Leg.20v New Member
    Randy
    2016 Blue Tundra SR5
    Don't see order page.
  17. Apr 24, 2018 at 7:23 AM
    iHacker
    To order use the “Start a conversation” option under my user name to send me a Private message, I’m not a business and don’t have a website for the harness. This is only for Tundras.com members
    Thank you
    Deeptraxx, Bannock452 and Y0TA PR0 like this.
  18. Apr 24, 2018 at 9:08 AM
    dradd
    dradd Sometimes there is just us
    City of Champyinz
    '17 TRD Pro
    pending...
    Ohhhh... let me count the 130 ways I dislike you now.
    :p
  19. Apr 24, 2018 at 9:56 AM
    iHacker
    :D:D
    Y0TA PR0 and dradd[QUOTED] like this.
  20. Apr 24, 2018 at 10:13 PM
    iHacker
    After a few hours editing pictures, videos and text finally installation guide is complete, I hope this help.
    MDHinSD and dradd like this.
  21. Apr 25, 2018 at 5:44 AM
    SikYota
    SikYota New Member
    Northport, AL
    2014 Platinum
    7" bds suspension lift with fox coilovers 37/13.50r20 cooper discover stt pros 20x10 -24 fuel mavericks with machined faces Nitro 4.88 gears Ekstrom design tie rod ends Zone carrier bearing drop Amp research steps Retrax pro bed cover http://www.gearinstalls.com/Chris2014Tundra.htm http://www.gearinstalls.com/Chris2014Tundrafront9.htm https://youtu.be/2P3yKKwG1ig
    Just used this new harness to upgrade to the 2018 headlights. It was crazy easy and ihacker makes an oem quality harness(maybe even better than oem ).
  22. Apr 25, 2018 at 7:56 AM
    iHacker
    Not trying to compete with anyone, this is just for tundras.com members everyone is free to buy wherever they want.
    Bashing others threads isn’t allowed here if you read the site rules, if you have a good product (which I know it is) to sell I encourage you to create your own thread just read the market place rules.
  23. Apr 25, 2018 at 8:07 AM
    SikYota
    SikYota New Member
    Northport, AL
    2014 Platinum
    yeti23, Tundyfundy, harrydunn and 3 others like this.
  24. Apr 25, 2018 at 10:57 AM
    tundras00
    tundras00 New Member
    Well, I bought both, so I guess they will have one in stock pretty soon after I'm done returning mine.
    And there's a reason I didn't install them on my car first as that is what I received first, and didn't feel adequate. The connectors felt like connectors bought from dollar store if they would carry such products. Total shit.
    There is no comparison when iHacker uses OEM connectors.
  25. Apr 25, 2018 at 11:51 AM
    dugfur
    dugfur New Member
    doug
    2016 limited DC
    I'm confused on the dimming/ not dimming thing. Can you explain ihacker?
    New_DoorDing and BigE like this.
  26. Apr 25, 2018 at 12:09 PM
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    nice work @iHacker.
    I have the old version and can attest to the quality product he puts out. If I didn't already have a motocontrol i'd be all over this.
  27. Apr 25, 2018 at 12:32 PM
    iHacker
    In 2018 trucks with LED Headlights from factory the LED strip brightness is reduced to about 60% and this is a safety feature to be gentle with oncoming traffic, with LED strip at full brightness and headlights ON at night you gonna be out there blinding oncoming traffic, So the dimming function is activated when you use your headlights, this is hard to notice with a camera but I’ll try to upload a video I have in my phone
    New_DoorDing likes this.
  28. Apr 25, 2018 at 6:21 PM
    AndyCBR
    AndyCBR New Member
    Baton Rouge, LA
    So does a 2018 SR5 dim the LED strip when the Halogen light comes on from the factory?
  29. Apr 25, 2018 at 6:38 PM
    iHacker
    Yes they do
  30. Apr 25, 2018 at 6:49 PM
    AndyCBR
    AndyCBR New Member
    Baton Rouge, LA
    Just received my harness today. Quick shipping and a quality harness with any and all empty connector holes plugged with the proper cavity plug to prevent water intrusion.
    Looking forward to getting these installed sans Motocontrol.
    Excellent customer service from ihacker.
    4x4_Angel likes this.
