2018 LED Headlight PNP Wire Harness Sales Thread (eledobleu)
Discussion in 'EleDobleU's Retrofits' started by eledobleu, Sep 29, 2017.
  1. Nov 4, 2017 at 11:24 AM
    #241
    BayRunner
    2017 Tundra Platinum
    Absolutely.... @inferno_pro_satx is a huge help and sent me a video on how to properly remove the pins from the turn signal plug. Back on track! Thanks,
    ncmtnman and inferno_pro_satx like this.
  2. Nov 4, 2017 at 11:35 AM
    #242
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    Just so you all know Eledobleu (Leo)
    Is in contact with me even on a Saturday. He is sending me a new harness and being a true professional.
    He is holding up to what he said when you order from him. Even answering me on his day off.
    Thanks Leo!
  3. Nov 4, 2017 at 2:49 PM
    #243
    Sevi_86
    Sevi_86 New Member
    Edel
    '14 Platinum Tundra
    Fox Shox 2.5 Factory Series coilovers with DSC ICON UCAs 35x12.5 R18 BFG KO2 on Mayhem wheels AFE CAI and Throttle spacer AFE catback exhaust Nitro Gears 4.88 front and back differential gears BullyDog GT Tuner
    Is the harness supposed to come with only one of these plugs...?
    My passenger side low beam is not turning on. What am I doing wrong?
    I got ordered the harness for platinum...
  4. Nov 4, 2017 at 2:51 PM
    #244
    inferno_pro_satx
    inferno_pro_satx New Member
    Roger
    2016 Tundra TRD Pro
    Yes the moto only has 1 input and uses the drivers side factory bulb connector. The passenger isn’t used.
  5. Nov 4, 2017 at 2:58 PM
    #245
    Sevi_86
    Sevi_86 New Member
    Edel
    '14 Platinum Tundra
    Ok, got it running, it was just one wire that came loose off of the harness on the passenger side...
    Now the only thing is that the turn signals flash really fast. Could that be cause cause I dont have a good ground connection? I only did a quick ground connection just to test it out.
  6. Nov 4, 2017 at 3:00 PM
    #246
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Did you swap the wht/blk wire & purple at the turn signal bulb on both sides.
    Sevi_86[QUOTED] likes this.
  7. Nov 4, 2017 at 3:03 PM
    #247
    Sevi_86
    Sevi_86 New Member
    Edel
    '14 Platinum Tundra
    Oh, that must be it. I didn't do that. Missed a step I guess
  8. Nov 4, 2017 at 3:46 PM
    #248
    BayRunner
    Also clarifying on the Platinum / 1794 trucks, there is no purple wire. You simply move the black/white wire from the center pin to the outside empty pin hole.
  9. Nov 4, 2017 at 3:48 PM
    #249
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Correct
    Sevi_86 likes this.
  10. Nov 4, 2017 at 5:33 PM
    #250
    Sevi_86
    Sevi_86 New Member
    Edel
    '14 Platinum Tundra
    20171104_171649.jpg 20171104_171755.jpg Thanks @eledobleu and @inferno_pro_satx for the harness, the help and/or advise to install my lights.
    Everything is up and running as it should. Loving my new lights!
  11. Nov 4, 2017 at 6:03 PM
    #251
    bluecrush
    bluecrush New Member
    Hey guys....im running into a problem. Everything on the new headlights work fine except an issue in running into with the blinker. (Yes...i did the repin correctly)
    Car is running, headlights ON: blinker works fine.
    Car is running, headlights OFF: blinker and taillights both sides flash, interior accessry lights flash, and front headlight amber sidemarker flash.
    Car is off, headlights off, key turned in ignition: blinker work fine.
    Car is off, headlights off, key turned in ignition to accessory power: emergency flashers flash all blinkers and ttaillights.
    Car is off: I use my key fob to unlock or lock the car...both blinkers and taillghts flash, and front amber sidemarker flash along with accessory lights inside.
    I will post videos. Amy clue what could be causing this?
  12. Nov 4, 2017 at 6:12 PM
    #252
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    You need to tell us what exactly did you do? Just headlights and harness? What trim is your truck? Did you do any other mods At same time? Anytime fog lights? Drl delete? If I were to guess you did one of the last two mods and did it wrong.
  13. Nov 4, 2017 at 6:15 PM
    #253
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Yea I’m lost at what the problem is.
  14. Nov 4, 2017 at 6:16 PM
    #254
    BlueBottle
    '16 Platinum 4x4
    See fine print
    @bluecrush also did you make the harness or did you buy it from someone? More info needed on what you did.
  15. Nov 4, 2017 at 6:20 PM
    #255
    bluecrush
    2015 SR5. Only did new headlights and harness. Did not do DRL delete. Did not do anytime fog lights. I installed new LED fogs, at the same time, but that was just a bulb replacement. I have the same rear blinkers you use that do not require the resistors. I also have some LED tails. Everything worked fine last night.
  16. Nov 4, 2017 at 6:21 PM
    #256
    bluecrush
    Bought the harness from Lou.
  17. Nov 4, 2017 at 6:28 PM
    #257
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Did you move the correct pin on the signal? Double check that. If it’s correct, unplug the headlamp harnesses from the truck side. If it goes away when you unplug the headlamp harnessss the problem has something to do with the harness or headlights.
  18. Nov 4, 2017 at 6:31 PM
    #258
    bluecrush
    Yes....I swapped 1 and 2. Ill try what you mentioned.
  19. Nov 4, 2017 at 6:33 PM
    #259
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Yea seems something is back feeding
  20. Nov 4, 2017 at 6:34 PM
    #260
    iHacker
    iHacker SW TRD PRO
    Mario
    AR
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    What you did with the purple wire in the turn signals?
    BlueBottle likes this.
  21. Nov 4, 2017 at 6:35 PM
    #261
    iHacker
    iHacker SW TRD PRO
    Mario
    AR
    I think there is your problem
  22. Nov 4, 2017 at 6:35 PM
    #262
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Purple should be in the middle on both left and right turn signal bulbs.
  23. Nov 4, 2017 at 6:41 PM
    #263
    iHacker
    iHacker SW TRD PRO
    Mario
    AR
    This is how they look after pin reconfigured
    The purple is optional and goes in the center, but I recommend you to tape it away to kill the amber parking lights
    Prerunnertundra15 likes this.
  24. Nov 4, 2017 at 6:45 PM
    #264
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Yes I have my purple out taped up.
    iHacker[QUOTED] likes this.
  25. Nov 4, 2017 at 6:59 PM
    #265
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    He still has the drl gray wire connected, I’m pretty positive the repin it back feeding through the bulb filament to the flasher relay causing the issues.
    iHacker and BlueBottle[QUOTED] like this.
  26. Nov 4, 2017 at 7:41 PM
    #266
    bluecrush
    Okay....blinker issue is FIXED! whew....thanks to Bluebottle and Inferno....they helped walk me through it.
    But here is an option for you that wasn't clear in the instructions for me. I actually LIKE the AMBER DRLs on bright during the day. So...I unpinned the purple wire in the amber drl connector but NEVER cut the gray wire inside and it works just how I like it. Similar to our old headlights....when I turn on my car, the amber DRLs become bright ALONG with the LED DRL strip. (this is with or without the parking lights turned on). Only with the headlights turned on does the amber DRL turn off and is only lit when the blinker is used. TBH....its pretty striking during the day or in the evenings when you don't need the headlights yet and both the bright amber and bright LED drls are on together. (PS....it's an SR5....so the LEDs are bight all the time) Ill post pics.
    Anyway...I found this out only through trial and error with inferno and bluebottles help. Just on option out there for you guys.
  27. Nov 4, 2017 at 7:47 PM
    #267
    bluecrush
    Maybe you all already knew what I mentioned above...but it wasn' clear to me with the instructions. Here is with the headlights off....and on. Ignore the dirt....shes getting a bath tomorrow :)
    BigTimber likes this.
  28. Nov 5, 2017 at 1:17 PM
    #268
    brickee
    brickee New Member
    jay
    silver sr5
    1794 rims ,platinum front grill, 2018 headlights
    do you know if those amber 7444 bulbs in the light are standard base or ck type?
  29. Nov 5, 2017 at 4:49 PM
    #269
    BigTimber
    BigTimber New Member
    Ben
    Casper, WY
    2016 TRD Pro
    does the headlight angle adjust knob on the dash need to be on any specific setting before changing out the headlights and wiring harness? I usually run it on a 3. Just wondering before I do the 2018 headlight change out if I need to adjust all the way one way or another or leave it in the middle or it doesn't matter?
  30. Nov 5, 2017 at 4:52 PM
    #270
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    No
