2018 LED Headlight PNP Wire Harness Sales Thread (eledobleu)
Discussion in 'EleDobleU's Retrofits' started by eledobleu, Sep 29, 2017.
  1. Nov 2, 2017 at 6:27 PM
    #181
    inferno_pro_satx
    inferno_pro_satx New Member
    Roger
    2016 Tundra TRD Pro
    You can remove the pin from the connector and recrimp it with some pliers
  2. Nov 2, 2017 at 6:33 PM
    #182
    KAM392
    KAM392 New Member
    2017 Silver Sky Metallic Platinum
    Will more harnesses be sent out????
  3. Nov 2, 2017 at 7:01 PM
    #183
    boloson
    boloson New Member
    Any advice on how to open the adaptor?
  4. Nov 2, 2017 at 7:53 PM
    #184
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    It’s hard to explain but the pin has a locking tab, that needs to be pushed down and the pin will come out.
  5. Nov 2, 2017 at 8:15 PM
    #185
    boloson
    boloson New Member
    Ok just like the turn signals got it. Took a quick look & thought i had to take apart the actual adaptor. Thanks again bro
  6. Nov 3, 2017 at 6:52 AM
    #186
    trdlife
    trdlife Toyota Master Technician
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    Are these the platinum headlights but blacked out? similar to the 2018 sr5, they are still halogen and that's ok, I just really want the led running light in my pro. What harness did you get for it to work?
  7. Nov 3, 2017 at 12:46 PM
    #187
    boloson
    boloson New Member
    @eledobleu ,
    I attempted to put the wire back in & made it more secure but it slipped out twice. The 3rd time i pushed it in further & crimped it harder & it stayed in. Hope it stays in place. Not sure how it'll hold up in the long run with vibrations & road bumps, etc but everything worked as normal.
    @inferno_pro_satx couldn't have done it without u brother thanks again
    eledobleu[OP] likes this.
  8. Nov 3, 2017 at 12:49 PM
    #188
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Glad you got it going
  9. Nov 3, 2017 at 3:13 PM
    #189
    boloson
    boloson New Member
    Obligatory light pics with morimoto fogs. Now wondering how much brigther those baja design fogs are compared to these?
    Prerunnertundra15 and Milkman like this.
  10. Nov 3, 2017 at 4:53 PM
    #190
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I came from Morimoto fogs then to he squadron pocket kit. The bd blows the Morimoto away. But I don’t run them on the streets because it doesn’t have a sharp cutoff like the Morimoto.
  11. Nov 3, 2017 at 6:43 PM
    #191
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    Question
    How do you remove the white terminal lock from the turn signal connector?
  12. Nov 3, 2017 at 6:44 PM
    #192
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Put a screwdriver halfway and pull up and it will pop up
    Prerunnertundra15 likes this.
  13. Nov 3, 2017 at 6:46 PM
    #193
    boloson
    boloson New Member
    Underneath the lock theres a tuny indentation. Just stick a tiny flathead screw driver underneath that & itll pop out
  14. Nov 3, 2017 at 6:51 PM
    #194
    Buildn
    Medina, Ohio
    On my moto control is ballast my low beam connection?
  15. Nov 3, 2017 at 6:52 PM
    #195
    boloson
    boloson New Member
    Yes
  16. Nov 3, 2017 at 6:52 PM
    #196
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Yes
  17. Nov 3, 2017 at 6:56 PM
    #197
    Buildn
    Medina, Ohio
    Boloson thanks! Got that part
    How hard do I have to push for tab on terminal?
  18. Nov 3, 2017 at 6:57 PM
    #198
    boloson
    boloson New Member
    Not hard at all . They all alhave a positive click when they connect so just make sure they click
  19. Nov 3, 2017 at 6:57 PM
    #199
    Buildn
    Medina, Ohio
    Thanks inferno, also am I plugging in the 3 prong connector from the moto control to the drivers side brown connector from factory harness?
    inferno_pro_satx likes this.
  20. Nov 3, 2017 at 6:58 PM
    #200
    Buildn
    Medina, Ohio
    Ok thanks boloson
  21. Nov 3, 2017 at 6:58 PM
    #201
    boloson
    boloson New Member
    Yes. Inferno helped me alot with my install. Just finished today as a matter of fact
  22. Nov 3, 2017 at 7:04 PM
    #202
    Buildn
    Medina, Ohio
    Having a hard time with terminal any trick? Using an eye glass flat head
  23. Nov 3, 2017 at 7:05 PM
    #203
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Yes moto only uses 1 input, drivers side.
  24. Nov 3, 2017 at 7:05 PM
    #204
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Just pry up and it will pop up
  25. Nov 3, 2017 at 7:08 PM
    #205
    Buildn
    Medina, Ohio
    Am I just flip flopping the red and white wires?
  26. Nov 3, 2017 at 7:09 PM
    #206
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    No wht/blk & purple
  27. Nov 3, 2017 at 7:10 PM
    #207
    Buildn
    Medina, Ohio
    Inferno I got the white lock off but having trouble with popping out the terminals
  28. Nov 3, 2017 at 7:16 PM
    #208
    Buildn
    Medina, Ohio
    Don’t want to break the inner terminal guts
  29. Nov 3, 2017 at 7:17 PM
    #209
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    There’s a locking tab looking on the inside on each wire, you need to pull that back and pull the wire out.
  30. Nov 3, 2017 at 7:18 PM
    #210
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
