2018 LED Headlight PNP Wire Harness Sales Thread (eledobleu)
Discussion in 'EleDobleU's Retrofits' started by eledobleu, Sep 29, 2017.
  1. Oct 31, 2017 at 7:15 AM
    #151
    bluecrush
    bluecrush New Member
    Can you post pictures of what it looked like after you cut the gray wire?
  2. Oct 31, 2017 at 7:38 AM
    #152
    inferno_pro_satx
    inferno_pro_satx New Member
    Roger
    2016 Tundra TRD Pro
    The gray wire has nothing to do with the brightness of the Amber bulb. It’s just a ground signal wire
  3. Oct 31, 2017 at 11:39 AM
    #153
    texbambam
    texbambam New Member
    Tundra TRD PRO sand
    OK i just installed my harnes and did the repin. I am getting a fast blink turning signal at idle and when I turn on the headlights i hear the fast blink but the turning signals dont do anything. Any ideas??? I did not do the DRL wire cut.
  4. Oct 31, 2017 at 12:09 PM
    #154
    BayRunner
    2017 Tundra Platinum
    Ok, got my harness in and prepping for the install. I'm a little confused about the purpose of the DRL Delete Mod. What is this for and is it required for all trim models?
  5. Oct 31, 2017 at 12:15 PM
    #155
    eledobleu
    eledobleu [OP] retrofitwholesale.com
    Orlando, FL
    Koito Bi-LED Retrofit
    You may have repined it wrong. DRL delete mod has nothing to do with fast blink.
  6. Oct 31, 2017 at 12:30 PM
    #156
    X09
    X09 New Member
    San luis obispo ca
    2017 Tundra Crewmax Limited
    Is the DRL mod required? What happens if i decide to not cut the gray wire? Thanks
  7. Oct 31, 2017 at 1:18 PM
    #157
    brickee
    brickee New Member
    jay
    silver sr5
    1794 rims ,platinum front grill, 2018 headlights
    if you don't cut it your amber drl will stay on with the leds
  8. Oct 31, 2017 at 1:27 PM
    #158
    texbambam
    Tundra TRD PRO sand
    OK I got it fixed...just was looking at the turn signal re-pin from the wrong end.
    inferno_pro_satx likes this.
  9. Oct 31, 2017 at 2:03 PM
    #159
    Retched1
    Retched1 New Member
    Aaron
    2017 Tundra Sr5 CrewMax
    Email sent.
    I'd like to order one for my 17 Sr5
  10. Oct 31, 2017 at 4:14 PM
    #160
    eledobleu
    Orlando, FL
    Lots of harnesses going out this week!
  11. Oct 31, 2017 at 5:52 PM
    #161
    BayRunner
    Does this only affect the SR, SR5 and Limited version or does the Platinum/1794 version also have to cut the grey wire?
  12. Oct 31, 2017 at 5:53 PM
    #162
    eledobleu
    Orlando, FL
    No wire cutting for Platinum/1794
    allstar617 likes this.
  13. Oct 31, 2017 at 7:30 PM
    #163
    BayRunner
    Roger that.... Thanks!
  14. Nov 1, 2017 at 12:01 AM
    #164
    verticaltrig
    verticaltrig New Member
    Big thanks to @eledobleu and @thomasbus337 ! Got the harness in this afternoon and did the install tonight. Now I just need the V6 Tritons and I'll be 100% LED all the way around.
  15. Nov 2, 2017 at 6:52 AM
    #165
    lutznutz
    lutznutz New Member
    Plant City, FL
    2016 Tundra SR5
    Can we get an update on shipping? My headlights got here a couple of days ago, and I'm getting antsy...
    5skware likes this.
  16. Nov 2, 2017 at 7:07 AM
    #166
    Retched1
    Retched1 New Member
    Aaron
    Looks good!
    Those V6's are spendy, but will compliment it nicely.
  17. Nov 2, 2017 at 11:51 AM
    #167
    X09
    X09 New Member
    San luis obispo ca
    Looks really good. Is it possible to add the dim option for the DRL?
  18. Nov 2, 2017 at 11:54 AM
    #168
    Retched1
    Retched1 New Member
    Aaron
    I'm looking at how-to modify the harness with a relay to turn the LED off when the blinker circuit is active... I know it will require a few runs from before the flasher, but can be done.
    I ordered my harness for my 17 Sr5 yesterday.
  19. Nov 2, 2017 at 12:00 PM
    #169
    X09
    X09 New Member
    San luis obispo ca
    Let me know how if your successful that will be great to have. Im reading another trend on how to add the dim function for the DRL's
    Retched1[QUOTED] likes this.
  20. Nov 2, 2017 at 12:02 PM
    #170
    Retched1
    Retched1 New Member
    Aaron
    Will do.
    It will be a low priority, someone may beat me to it.
  21. Nov 2, 2017 at 1:52 PM
    #171
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    Now I know what my next project is going to be!
    X09 and brickee like this.
  22. Nov 2, 2017 at 2:17 PM
    #172
    boloson
    boloson New Member
    @eledobleu
    Well this just happened. Wire came out of the low beam harness. How we can we rectify this? Im down 1 headlight now & cant finish the install. Doubt i can drive with 1 light on without blowing a fuse
  23. Nov 2, 2017 at 2:20 PM
    #173
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    You can pull the pin out now for temporary and recrimp the wire
  24. Nov 2, 2017 at 2:25 PM
    #174
    boloson
    boloson New Member
    No crimping tools or remotely close to being electrically inclined. Thats why i bought the retro harness. Am i able to drive eith only 1 hamead light installed? I doubt it since everything is connected tothe moto relay
  25. Nov 2, 2017 at 5:43 PM
    #175
    TrdPro86
    TrdPro86 New Member
    Cheng thao
    2016 Toyota Tundra TRD PRO
    My ground came off when I was installing I used a plier to put it back together with no iusse.
  26. Nov 2, 2017 at 5:46 PM
    #176
    boloson
    boloson New Member
    My wires completely slipped off the crimp. No way i can fix this
  27. Nov 2, 2017 at 6:18 PM
    #177
    eledobleu
    Orlando, FL
    Open up crimp with flathead screwdriver. Slide wire in and crimp. Pliers will crimp just fine. Should take you only a few minutes If you still can't get it, email me and i'll take care if it.
  28. Nov 2, 2017 at 6:21 PM
    #178
    boloson
    boloson New Member
    Ok ill give it a shot tomorrow
  29. Nov 2, 2017 at 6:24 PM
    #179
    eledobleu
    Orlando, FL
    Ok let me know!
  30. Nov 2, 2017 at 6:25 PM
    #180
    boloson
    boloson New Member
    Will do thanks
