2018 LED Headlight PNP Wire Harness Sales Thread (eledobleu)
Discussion in 'EleDobleU's Retrofits' started by eledobleu, Sep 29, 2017.
  1. Oct 24, 2017 at 10:17 AM
    #121
    bluecrush
    bluecrush New Member
    Are they really blue? I notice they are 6000K....I haven't put on my LED headlamps yet, but you are saying it is pretty close?
  2. Oct 24, 2017 at 10:21 AM
    #122
    zwillz
    zwillz New Member
    2015 sr5 Crewmax
    I think there more white ish than blue. I'm pretty particular, and there are very close. If it was noticeably different I woulda yanked them out quick lol.
    Bable985 and X09 like this.
  3. Oct 24, 2017 at 11:41 AM
    #123
    X09
    X09 New Member
    San luis obispo ca
    2017 Tundra Crewmax Limited
    @zwillz, did u install the headlights yourself? About how long did it take? Im still waiting for elebodleu's reply to get my harness.
  4. Oct 24, 2017 at 11:46 AM
    #124
    zwillz
    zwillz New Member
    2015 sr5 Crewmax
    I did... Took about 1.5-2 hours or so. But i took my time and im not an installer by any means lol. But I also did the DRL delete and pin swap for the stock turn signal. Wasnt too bad at all. Hopefully you hear from him soon!
    slide187 and ncmtnman like this.
  5. Oct 24, 2017 at 3:34 PM
    #125
    slide187
    slide187 New Member
    Boston, MA
    2015 Silver Sky Metallic DC Limited Tundra
    Console Cavern Organizer Mod, Driver's Forward Assist Handle Tonno Pro Hardfold, Body Colored Door Handles, Body Colored Mirror Caps, MBRP Stainless XP Series Dual Exhaust, OEM Bed Extender
    Man there's so much good info in this thread I'm starting to lose some of it. I know the stock DRL delete, but what does the turn signal pin swap do again?
  6. Oct 24, 2017 at 3:41 PM
    #126
    KAM392
    KAM392 New Member
    2017 Silver Sky Metallic Platinum
    Has anyone received their Harness yet????
  7. Oct 24, 2017 at 3:43 PM
    #127
    inferno_pro_satx
    inferno_pro_satx New Member
    Roger
    2016 Tundra TRD Pro
    Toyota changed the ground location on the pins this year so they need to be swapped in order for the bulb to operate correctly
    slide187[QUOTED] likes this.
  8. Oct 24, 2017 at 3:54 PM
    #128
    slide187
    slide187 New Member
    Boston, MA
    As a directional/parking light again, after the 2018 upgrade, right?
  9. Oct 24, 2017 at 3:54 PM
    #129
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Yes
  10. Oct 24, 2017 at 4:04 PM
    #130
    slide187
    slide187 New Member
    Boston, MA
    Ha got it. Thanks!
  11. Oct 24, 2017 at 7:36 PM
    #131
    zwillz
    zwillz New Member
    2015 sr5 Crewmax
    Sry, just seeing this.... But yes what inferno said. Just swap the purple wire and white/blk wire and you're good to go!
  12. Oct 24, 2017 at 8:22 PM
    #132
    5skware
    5skware New Member
    2017 Tundra
    Payment sent! Lights came in the other day, can't wait to install.
  13. Oct 24, 2017 at 9:23 PM
    #133
    Sevi_86
    Sevi_86 New Member
    Edel
    '14 Platinum Tundra
    Fox Shox 2.5 Factory Series coilovers with DSC ICON UCAs 35x12.5 R18 BFG KO2 on Mayhem wheels AFE CAI and Throttle spacer AFE catback exhaust Nitro Gears 4.88 front and back differential gears BullyDog GT Tuner
    I'm still waiting mine too...
  14. Oct 26, 2017 at 2:33 PM
    #134
    konzz77
    konzz77 New Member
    buddy
    2015 Black Tundra
    I want to order a set for a 2015 SR5 please. I sent you an email. Just tell me how to pay you and I will send the money. Thanks.
  15. Oct 26, 2017 at 3:37 PM
    #135
    bluecrush
    Check out the posts....they have all of the instruction.
  16. Oct 26, 2017 at 9:47 PM
    #136
    X09
    X09 New Member
    San luis obispo ca
    Have you done this with the wiring harness? Can you pls explain how i can do this with the wiring harness from eledobleu. Thanks
  17. Oct 26, 2017 at 9:56 PM
    #137
    X09
    X09 New Member
    San luis obispo ca
    So the dash dims if i leave the parking lights wire plugged?
  18. Oct 26, 2017 at 10:04 PM
    #138
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    You will have to add pins to the low side drl in the 8 pin harness since Leo doesn’t use and tap into the parking light wire along with adding a 5 pin relay
  19. Oct 27, 2017 at 12:59 AM
    #139
    X09
    X09 New Member
    San luis obispo ca
    So for these new headlight? Does any1 know what bulbs i need to buy for both the hi and low? Any suggestions? Thanks
  20. Oct 27, 2017 at 4:45 AM
    #140
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    They are a sealed unit non serviceable led bulbs so when they go out the headlight assembly will need to be replaced
    geno0506 likes this.
  21. Oct 27, 2017 at 10:32 AM
    #141
    eledobleu
    eledobleu [OP] retrofitwholesale.com
    Orlando, FL
    Koito Bi-LED Retrofit
    **UPDATE**
    For those who have placed an order, all orders will be completed and shipped next week. Keep a watch on your email for shipment details.
    For those who want to place an order, email me at eledobleuretrofits@gmail.com
    Buildn, lutznutz and ncmtnman like this.
  22. Oct 27, 2017 at 9:20 PM
    #142
    boloson
    boloson New Member
    Ok so my lights & my harness are shipped. Just wanted to be clear here....on my 2014 platinum oem harness i would have to swap the directional & the ground wires in order for my directionals to work on the new 2018 lights correct? And i wont need to do the fuse tap for my platinum correct?
    Wasnt expecting to do any wire swaps till i reread the install instruction. Thanks
  23. Oct 27, 2017 at 9:26 PM
    #143
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Yes that's the only thing you have to do in your platinum in the turn signal socket move the white/black stripped wire from center which is pin #2 to the pin #1 in both driver and passenger side
  24. Oct 27, 2017 at 9:31 PM
    #144
    boloson
    boloson New Member
    Thanks dude!
    iHacker[QUOTED] likes this.
  25. Oct 28, 2017 at 3:47 PM
    #145
    TrdPro86
    TrdPro86 New Member
    Cheng thao
    2016 Toyota Tundra TRD PRO
    Does this look right to you guy? It seen like the amber/turn signal light are brighter. I follow the step to repin it.
    Prerunnertundra15 and X09 like this.
  26. Oct 28, 2017 at 3:49 PM
    #146
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Did you do the drl delete inside ?
    You gotta depin or cut the thin gray wire inside at the flasher relay.
    X09 and TrdPro86[QUOTED] like this.
  27. Oct 28, 2017 at 3:53 PM
    #147
    TrdPro86
    TrdPro86 New Member
    Cheng thao
    I guess I haven’t cut the gray wire. Thanks!
  28. Oct 28, 2017 at 8:40 PM
    #148
    X09
    X09 New Member
    San luis obispo ca
    Did your dash/nav dim after installing the headlights? Someone here mentioned that it happened to them. Im trying to figure out if that only happens if you dont cut the gray wire/do the drl delete.
  29. Oct 28, 2017 at 8:57 PM
    #149
    TrdPro86
    TrdPro86 New Member
    Cheng thao
  30. Oct 30, 2017 at 5:00 PM
    #150
    eledobleu
    Orlando, FL
    Dash/Nav only dims when headlights are on. There may be some confusion with that but headlights wont effect the rest of the trucks lighting system.
    Mw4904 likes this.
