2018 LED Headlight PNP Wire Harness Sales Thread (eledobleu)
Discussion in 'EleDobleU's Retrofits' started by eledobleu, Sep 29, 2017.
  1. Oct 9, 2017 at 7:46 PM
    Tophergt99
    Tophergt99 Back in black
    Weston, Wisconsin
    2015 SR5 Black TRD Crewmax
    In progress....
    Any pics?
  2. Oct 10, 2017 at 4:10 AM
    BigTimber
    BigTimber New Member
    Ben
    Casper, WY
    2016 TRD Pro
    email sent:)
  3. Oct 10, 2017 at 5:38 AM
    eledobleu
    eledobleu [OP] retrofitwholesale.com
    Orlando, FL
    Koito Bi-LED Retrofit
    Pics will be posted once I complete testing
    LKSR5-14 likes this.
  4. Oct 10, 2017 at 4:05 PM
    Sevi_86
    Sevi_86 New Member
    Edel
    '14 Platinum Tundra
    Fox Shox 2.5 Factory Series coilovers with DSC ICON UCAs 35x12.5 R18 BFG KO2 on Mayhem wheels AFE CAI and Throttle spacer AFE catback exhaust Nitro Gears 4.88 front and back differential gears BullyDog GT Tuner
    Will these be a completely PnP harness?
    By completely I mean, just the need of basic tools, no cutting, striping or running wires?
  5. Oct 10, 2017 at 6:20 PM
    eledobleu
    Orlando, FL
    100% PNP with the exception of the stock turn signal re-pin. Please see first post
  6. Oct 10, 2017 at 6:24 PM
    eledobleu
    Orlando, FL
    **UPDATE**
    After playing with the test harnesses, it seems as though toyota set the dim mode for LED's on these lights differently than the previous models. The dim wire does not switch off the bright wire when dim is activated like previous models. Instead Toyota must use a relay to shut off bright LED's when headlights are on. The relay must be on the stock harness for the 2018 as its not attached to the headlights.
    DUE TO THIS, ALL LED"S WILL BE BRIGHT MODE ALL THE TIME.
    Below are pictures of dim and bright modes. I think most people will prefer the bright mode 100% of the time.
  7. Oct 10, 2017 at 6:29 PM
    inferno_pro_satx
    inferno_pro_satx New Member
    Roger
    2016 Tundra TRD Pro
    With you’re harness will the customer be able to easily add the relay down the line for Hi’s and wire up the low’s if they wanted to? Or are you not adding the lows at all?
  8. Oct 10, 2017 at 6:32 PM
    eledobleu
    Orlando, FL
    Lows wire can be connected if requested. Not everyone will try to add relay so if special requested I will add the low/dim wire to the connected but it will be unplugged.
  9. Oct 10, 2017 at 6:33 PM
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Awesome
  10. Oct 10, 2017 at 9:55 PM
    Sevi_86
    Sevi_86 New Member
    Edel
    '14 Platinum Tundra
    Does this mean that the lights will be dimmed down if they're on "low beam"? Or am I missunderstanding this?
    But Yes, I would prefer bright LEDs on both Low and High beams...
  11. Oct 10, 2017 at 10:23 PM
    texbambam
    texbambam New Member
    Tundra TRD PRO sand
    Yes bright for me too
  12. Oct 11, 2017 at 8:52 AM
    eledobleu
    Orlando, FL
    No. The way the PNP harness is setup, theres no way to have the lights DIM when low beams are on due to Toyotas relay system. The PNP harness gets power directly from the ignition fuse. The only way to have the DRL's dim and function like factory is to connect them to the stock factory turn signal harness. Unfortunately no PNP harness can be made for this.
  13. Oct 11, 2017 at 8:59 AM
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Also the hi drl must be added with a relay and wired to the drl control unit inside the vehicle so pnp is not possible without cutting and adding some wires.
  14. Oct 11, 2017 at 9:00 AM
    Sevi_86
    Sevi_86 New Member
    Edel
    '14 Platinum Tundra
    Oh ok...
    That works for me... I was misunderstanding what you were saying there... Thanks.
  15. Oct 11, 2017 at 11:00 AM
    eledobleu
    Orlando, FL
    Yes thanks for mentioning that!
  16. Oct 11, 2017 at 11:05 AM
    bigoltater
    bigoltater New Member
    KC
    2005 Tundra DblCab4x4
    Leveling Kit,33'BFG
    So how much are these headlights from Roman cost ?
    Lilly likes this.
  17. Oct 11, 2017 at 2:45 PM
    SuperSilverTundra
    SuperSilverTundra i didnt pull up i Landed
    Nick
    Los Angeles California
    16 TUNDRA 5.7 PLATINUM-PRO
    3"/1" TOYTEC 18x9 XD818 Heist 295/70r18 COOPER XLT DirtyDeeds BAMuffler 2018 LEDs KatzKin Leather S&B CAI
    @bigoltater they are bout $650 plus the harness so add another $200
    bigoltater likes this.
  18. Oct 11, 2017 at 4:19 PM
    bigoltater
    KC
    Leveling Kit,33'BFG
    Wow, thats Not bad at all, I've hear the guys with F-150's, that didn't pony up for LEDs are close to a couple grand for a conversion.
  19. Oct 11, 2017 at 4:52 PM
    #49
    eledobleu
    Orlando, FL
    **UPDATE**............***PICTURES***
    The first harness has been completed and will be shippped to the individual whom sent me their 2018 Headlights for testing.
    I made the harnesses as simple as possible.
    1 (white conversion) Harness for each Light (Driver/Passenger)
    1 DRL PNP Harness with fuse tap
    1 MotoControl Harness
    INSTALLATION INSTRUCTIONS:
    1. Low Beam> Ballast (On Relay Harness)
    2. High Beam> High Beam
    3. LED> DRL Harness (Driver/Passenger)
    4. Fuse Tap (DRL Harness)> Ignition Fuse in fuse box (Engine Bay). Remove Old Ignition fuse (IGN) and replace with fuse tap.
    5. Done.
    PLATINUM/1974 VERSION (RETAINS DIM OEM FUNCTIONS)
  20. Oct 11, 2017 at 5:10 PM
    #50
    JonSVSB
    JonSVSB New Member
    Jon
    Santa Barbara, CA
    2017 TRD OR Crew Max 5.7L 4x4
    @eledobleu I assume your instructions above will make total sense once I see the harness, remove the stock lights etc? I haven't played around with this truck since Ive only owned it 3 weeks. SO those familiar with the headlight swapping process seem like pros and it sounds like Chinese to me haha.
    bigoltater, 757TUNDRA and Bable985 like this.
  21. Oct 11, 2017 at 5:15 PM
    #51
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    Will there be a modified version for the Platinum and 1794 models with the mating four pin DRL plug to retain the oem DRL functions?
    Lilly likes this.
  22. Oct 11, 2017 at 6:28 PM
    #52
    eledobleu
    Orlando, FL
    Yes, picture has been added
  23. Oct 11, 2017 at 6:56 PM
    #53
    eledobleu
    Orlando, FL
    Here is a video of the headlight removal process. I will also update first post https://www.youtube.com/watch?v=qOgOFHcWYOk
    Bable985 likes this.
  24. Oct 11, 2017 at 10:47 PM
    #54
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Sent you a pm
  25. Oct 11, 2017 at 11:06 PM
    #55
    MMichaelJJ
    MMichaelJJ New Member
    14 Platinum CM
    Are you referring to non platinum / 1794 models? Right now my LED DRL dim when the low or high beams are on (I have a 14’ platinum). Is that what you’re referring to?
    I’m probably overthink this.
  26. Oct 11, 2017 at 11:29 PM
    #56
    bigoltater
    KC
    Leveling Kit,33'BFG
    For us who rode the short bus to school, any chance the instructions will have drawings, photos? ??? Maybe a short video, lol,
    Ben_onewise and 757TUNDRA like this.
  27. Oct 12, 2017 at 6:03 AM
    #57
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Yes if you have a factory platinum/1794 they will work as factory, just make sure to order the correct harness.
  28. Oct 12, 2017 at 8:46 AM
    #58
    victm4
    victm4 New Member
    Victor
    17 CEMENT TRD PRO
    I need a set for my pro
  29. Oct 12, 2017 at 9:49 AM
    #59
    eledobleu
    Orlando, FL
    If you have factory DRL, all oem functions will remain the same. As stated above, be sure to order the correct harness.
  30. Oct 12, 2017 at 9:50 AM
    #60
    eledobleu
    Orlando, FL
    Connectors are labeled. Just match up the correct labeled connector and thats it!
    Tundracollector and Bable985 like this.
