2018 LED Headlight PNP Wire Harness Sales Thread (eledobleu)
Discussion in 'EleDobleU's Retrofits' started by eledobleu, Sep 29, 2017.
  1. Apr 1, 2018 at 11:00 AM
    #481
    LKSR5-14
    LKSR5-14 New Member
    Chicago Northwest suburbs, Illinois
    2016 Tundra SR5 DC
    Tundra SR5 DC 2016 Upgrade: pro wheels, headlights retrofit, head unit Kenwood 694s, bed cover, lineX, Viper security and starter system, pro grille, tinted windows, LED lighting, black wrap on all end chrome corners, ceramic coating
    Currently I have retrofit and waiting for new headlights to arrive so I can swap them out.
    Currently with my setup I have just pulled out my gray wire under the dash and didn't cut any wires.
    I have SR5 truck. I have retrofit that has led strip and halo as a switchbacks and both as a DRL but amber is only works when turn signal working. So I'm not sure what you referring white/black exchange.
  2. Apr 1, 2018 at 11:10 AM
    #482
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    This, that white/black wire used to be in the middle stock:
    LKSR5-14[QUOTED] likes this.
  3. Apr 11, 2018 at 2:59 PM
    #483
    LMG
    LMG New Member
    2014 Tundra SR5
    Question:
    What happens if I cut the grey wire and then also disconnect the purple? I'm hoping this will make the amber be only blinker and not DRL, regardless of beam position.
    Thanks!
  4. Apr 11, 2018 at 3:32 PM
    #484
    eledobleu
    eledobleu [OP] retrofitwholesale.com
    Orlando, FL
    Koito Bi-LED Retrofit
    Purple wire is parking lights so if you cut that the amber bulb will not turn on when your headlights are on. Cutting the gray wire will disable the amber drl.
    LMG[QUOTED] likes this.
  5. Apr 11, 2018 at 4:23 PM
    #485
    eledobleu
    Orlando, FL
  6. Apr 16, 2018 at 7:18 PM
    #486
    Ossurvivor06
    Ossurvivor06 New Member
    Jeff
    2017 Limited Crewmax
    May be a stupid question, but is there anyway to disable the Amber completely besides turn/hazards? I installed everything today and left the purple wire out the Amber seems to be disabled for everything except when I turn the parking lights on... I am doing the anytime fog light mod tomorrow and would really like to run the led DRL with the fogs without the Amber light. Am I missing something? I have not cut the grey wire yet, didn’t think I had to leaving the purple wire out.
  7. Apr 18, 2018 at 12:09 PM
    #487
    fullofbs
    fullofbs Project SnowFlake
    any additional instructions out there? I installed the moritmoto battery and grounded but not sure what else?
  8. Apr 18, 2018 at 9:37 PM
    #488
    OceanSkyWolf
    OceanSkyWolf New Member
    2017 MGM CM
    Connect the cables as stated on 1st page and the rest is history, let me know if you still need help. I was also confused at the beginning. @JoshuaA was a champ and helped me out during the install process
    JoshuaA likes this.
  9. Apr 19, 2018 at 4:31 AM
    #489
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    The gray wire is what you want. I just put a switch on the drl’s and cut the gray wire and wired it up. When the switch is off, the drl’s are off. Never messed with the purple wire. Hope this helps
  10. Apr 19, 2018 at 9:00 AM
    #490
    fullofbs
    Thanks all. I got everything to work except for the headlights. Any idea of whats causing that? I didnt do the DRL delete mod.
  11. Apr 19, 2018 at 3:19 PM
    #491
    OceanSkyWolf
    2017 MGM CM
    Do DRLs work? Turn signal? Sidemarkers? Did you make sure to plug in one of plugs from the truck old headlights to the relay?
  12. Apr 19, 2018 at 3:33 PM
    #492
    fullofbs
    Everything works now. I was a bone head and didn’t pay attention to the terminals.
  13. Apr 19, 2018 at 3:39 PM
    #493
    OceanSkyWolf
    2017 MGM CM
    Nice, post pics!!!
  14. Apr 19, 2018 at 5:08 PM
    #494
    fullofbs
  15. May 6, 2018 at 5:13 AM
    #495
    jfox
    jfox New Member
    Richmond VA
    2015 MGM Limited
    Hi all, is there new installation instructions for the harness from Leo? Looks as if the new ones don't require the re-pin and don't include the Motocontrol relay. Thanks for the help!
  16. May 6, 2018 at 9:11 AM
    #496
    AndyCBR
    AndyCBR New Member
    Baton Rouge, LA
    Leo,
    How does one go about getting missing cavity plugs from you after purchase?
    The support after the sale has been underwhelming so far.
    Thank you,
    Andy Hall
  17. May 6, 2018 at 5:09 PM
    #497
    eledobleu
    Orlando, FL
    Sorry buddy! Ive been out of the country for the last two weeks. I'll send you the plugs. DM your name and address
  18. May 6, 2018 at 8:14 PM
    #498
    AndyCBR
    AndyCBR New Member
    Baton Rouge, LA
    Leo,
    You have my name as I have contacted you through the forum and via your website prior to your "vacation". There is no secret who I am or what I am asking you to provide.
    The ball is in your court to deliver a complete waterproof harness.
    Best,
    Andy Hall
  19. May 7, 2018 at 8:29 AM
    #499
    eledobleu
    Orlando, FL
    I recieve about 30 emails a day. Sometimes I forget and the emails get buried. I'll try to dig up your email and send the plugs out to you asap!
  20. May 7, 2018 at 8:43 AM
    #500
    AndyCBR
    AndyCBR New Member
    Baton Rouge, LA
    Leo,
    No problem.
    I ended up getting a newer harness from another vendor that doesn’t require motocontrol.
    If I get this one sealed up I may try and sell it on the forum.
    Any interest in a return with a restocking fee? Everything is in the package as it came from you.
    It’s the 1794 harness and motocontrol.
    Andy Hall
    17759 Glen Forest Ave
    Baton Rouge, LA 70817
  21. May 7, 2018 at 8:45 AM
    #501
    eledobleu
    Orlando, FL
    Unfortunately I cant accept returns as the harness now has been updated as well and no longer requires the motocontrol. And because my harnesses is now accepted at Toyota dealerships, I now have a new return policy.
  22. May 7, 2018 at 8:47 AM
    #502
    AndyCBR
    AndyCBR New Member
    Baton Rouge, LA
    Well then just get me the cavity plugs.
    I can’t sell it in the state it is in.
    You have my address above.
  23. May 7, 2018 at 8:48 AM
    #503
    eledobleu
    Orlando, FL
    I'll get the plugs shipped today.
  24. May 7, 2018 at 10:13 AM
    #504
    dugfur
    dugfur New Member
    doug
    2016 limited DC
    what about the people who have been trying to contact you about getting the adapters to upgrade the original version? Ive tried multiple times and get no response. I have to agree with what Andy says about your customer service.
  25. May 7, 2018 at 10:21 AM
    #505
    eledobleu
    Orlando, FL
    Again guys I was out of the country for 2 weeks. When I returned I had over 200 emails. Im trying to catch up on orders and emails. I responded in the other thread to PM for the adapters as they will not be available on the website. So if you want them PM.
  26. May 18, 2018 at 10:25 AM
    #506
    fundra_goes_west
    fundra_goes_west I’m just a guy with a girl
    Evan
    2022 SQ8
    So you didn't move any other wires just pulled the Purple and taped it? Is that correct?
  27. May 18, 2018 at 12:23 PM
    #507
    fundra_goes_west
    Evan
    2022 SQ8
    I’m sorry I’m not retarded, not a mechanic either but these are the worst instructions ever. Really disappointed honestly. Is there a video somewhere?
    OceanSkyWolf likes this.
  28. May 18, 2018 at 12:23 PM
    #508
    fundra_goes_west
    Evan
    2022 SQ8
    I’m right at the end. Where does the fuse tap plug into?
  29. May 24, 2018 at 9:03 PM
    #509
    maharaj1
    maharaj1 New Member
    Justin
    2014 Tundra 1794 2WD
    What are the updates to the new harness that allow it to function without the Motocontrol?
  30. Aug 11, 2018 at 4:04 PM
    #510
    DallasTundra
    DallasTundra New Member
    2014 Tundra CrewMax SR5 4X4 5.7L Silver Sky
    2" MotoFab leveling Kit, 2Crave NX-5 wheels(5X150 +15 offset to fill in fender flares space), 275/60R20XL Nitto Terra Grappler G2 Tires, VLEDs Triton V3 Switchbacks, TRS Morimoto XB LED Fog Lights, CCI Chrome Grille, 2019 LED Headlights, Extang Solid Fold, Texas Edition, Leather, Nav, JBL, OEM Flares, Husky WeatherBeaters.
    Don’t sell them anymore?
