2018 LED Headlight PNP Wire Harness Sales Thread (eledobleu)
Discussion in 'EleDobleU's Retrofits' started by eledobleu, Sep 29, 2017.
  1. Mar 20, 2018 at 4:01 PM
    #451
    Rolandonieto67
    Rolandonieto67 New Member
    Rolando
    2016 Toyota Tundra Limited
    Hi, I just ordered the harness at the name of Rolando Nieto. In PayPal it said that something went wrong so I just wanted to know if you got the order because I don’t want to buy it twice?
  2. Mar 21, 2018 at 8:28 AM
    #452
    eledobleu
    eledobleu [OP] retrofitwholesale.com
    Orlando, FL
    Koito Bi-LED Retrofit
    For some reason your order was canceled. You was not charged. You can re-order
  3. Mar 23, 2018 at 6:47 AM
    #453
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    The pic of the tiny flat screwdriver and this vid should be in post 1, essential to switching the pins.
  4. Mar 23, 2018 at 6:51 AM
    #454
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    So I taped the purple wire and didn't cut the gray, like a previous poster I like the look of DRL ambers, matches my 3 hood lights.
    Kwikfish likes this.
  5. Mar 23, 2018 at 7:01 AM
    #455
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    And lastly, if you don't mind ordering from EB in North Attleboro, they were $52 less than the popular option, tracking and shipped in 5d, well packaged.
    Input your zip to compare. From my bill:
    Edit: Can't forget to thank OP for the harness!
  6. Mar 23, 2018 at 7:06 AM
    #456
    Shaggypeach
    Shaggypeach New Member
    Can someone please make a short video of how the lights function? Drl, lows highs signals etc. I know there is one from iHacker but I would like to see one with this harness. I am curious about DRL on high all the time.
  7. Mar 23, 2018 at 7:44 AM
    #457
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Don't have a vid but assuming you switch the pins and cut the gray to do the DRL amber delete mod, there are 4 settings (I've ignored the fog lights), refer to my headlight pic above:
    1. Lights OFF, LED C bars are ON (truck running)
    2. Switch turned to DRL, LED C bars are ON, same as 1 no change
    3. Switch turned to Low Beams, LED C bars are ON and main lights inside the C are ON
    4. Pushing lever to High Beams, LED C bars are ON, main lights ON, small high beam lights beside the grill above the large ambers are ON
    Lock/unlock/hazard/turn signals will flash the large amber lights beside the grill. If you leave the purple wire out, tape it off, and don't cut the gray wire in post 1 like me, the larger ambers are ON in 2, and turn OFF in 3 and 4.
    If I'm understanding correctly, the "DRL on high all the time" refers to the LED C bar which is at full brightness and ON from 1 to 4, and also when turning. If you look at modern vehicles, most DRL LED's go off or dim on the side that is signalling a turn. I am unclear what the stock 2018 does with its LED C bars, but what I described is the behaviour I'm getting after install.
  8. Mar 23, 2018 at 8:09 AM
    #458
    NY98M3
    NY98M3 New Member
    There was a promo code for $5 off shipping :)
  9. Mar 23, 2018 at 8:10 AM
    #459
    Shaggypeach
    Thank you for the input. As far as I know, led drl bar should dim or go off when signaling and dim when the beams are on.
  10. Mar 23, 2018 at 8:22 AM
    #460
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
  11. Mar 23, 2018 at 8:55 AM
    #461
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    That would be ideal to oncoming traffic and what I would prefer safety-wise but I don't think any PNP harness does that.
    ihacker's only does the 2nd part according to his vid, dims C bar when beams on, no change when signalling.
    Personal preference I guess, I like the C's bright with beam on using eledobleu's harness. They're not blindingly bright like in the vid you pm'd, whatever recording device most people use do not exposure compensate. In real life, the C bars at full brightness are quite nice day or night.
  12. Mar 23, 2018 at 12:29 PM
    #462
    Kwikfish
    Kwikfish Get your poop in a group!
    Tri cities,WA
    16 CM SSM
    Got my front end remodel donr yesterday and i love it
    JoshuaA likes this.
  13. Mar 23, 2018 at 5:23 PM
    #463
    OceanSkyWolf
    OceanSkyWolf New Member
    2017 MGM CM
    Anybody want to help me get started not exactly sure where to start plugging stuff at..07EFA277-6EAC-4333-A147-4EBED7B2A0B7.jpg
  14. Mar 23, 2018 at 6:03 PM
    #464
    Kwikfish
    Tri cities,WA
    16 CM SSM
    Once you get your old headlights out it will make more sense,do the pin swaps and the drl mod if you choose to then start by routing all the new wiring to each side
  15. Mar 23, 2018 at 7:11 PM
    #465
    OceanSkyWolf
    2017 MGM CM
    Where did you put the ground from the relay? Also where did you mount it at?
  16. Mar 23, 2018 at 7:16 PM
    #466
    OceanSkyWolf
    2017 MGM CM
    Also in my old setup I got switchback LEDs with quick splice resistors, anyway I can remove them smoothly? Or should I put in 7444NA LEDs?
  17. Mar 23, 2018 at 7:18 PM
    #467
    eledobleu
    Orlando, FL
    There are instructions including mounting locations on the first post in this thread
  18. Mar 23, 2018 at 7:21 PM
    #468
    OceanSkyWolf
    2017 MGM CM
    I must be over looking it but I didn’t see any. Also the fuse tap ends connect to the Green end from the headlight correct?
  19. Mar 23, 2018 at 7:26 PM
    #469
    eledobleu
    Orlando, FL
    Its the last two pictures on the first post. Yes the fuse goes with green
  20. Mar 23, 2018 at 7:29 PM
    #470
    OceanSkyWolf
    2017 MGM CM
    Bet, it’s clear now. I’ll try installation this weekend. Hopefully that quick splice doesn’t give me any issues.
  21. Mar 24, 2018 at 1:06 PM
    #471
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    It's pretty easy once you connect the OP's harness wires to the Motocontrol wires (clip them together as color coded and described in steps 1-3, double check), then lay it out:
    You have to re-pin the truck's stock signal harnesses on either side first before plugging them into the new headlights (the "REQUIRED" step in Post#1). Watch the YouTube vid above how to push down and pull out the ends. Basically white/black goes where purple was.
    Then exchange the 10A fuse with the fuse tap in the fuse box as shown in Post#1.
    Find the nearest ground spots for the ground wires, mount the orange Motocontrol vertically somewhere.
    The only step I missed was plugging together the OP's matching harness to the driver's side main light plug. The passenger side isn't plugged to anything, you can tape it covered if you want. This to this:
    And a further step is making sure your lights are pointed correctly, my left one was pointing high AFTER I put everything back together. So I used a Philips screwdriver through the funnel and turned it to the desired position, turning rotates that white knob on the bottom left:
    OceanSkyWolf[QUOTED] likes this.
  22. Mar 24, 2018 at 1:13 PM
    #472
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    OceanSkyWolf likes this.
  23. Mar 24, 2018 at 4:55 PM
    #473
    LMG
    LMG New Member
    2014 Tundra SR5
    JoshuaA[QUOTED] likes this.
  24. Mar 26, 2018 at 12:26 AM
    #474
    Kwikfish
    Tri cities,WA
    16 CM SSM
    I have my new lights in and i love them but now im curious if i get a set of VLED headlight bulbs if thwy will be even better,anyone upgrade the 2018 headlights to a aftermarket bulb yet??
  25. Mar 29, 2018 at 11:19 AM
    #475
    NY98M3
    NY98M3 New Member
    Question - Is this installed backwards? Isnt the wire supposed to be on the load size which is the right side of the fuse terminal?
  26. Mar 29, 2018 at 7:14 PM
    #476
    Rolandonieto67
    Rolando
    Hi, is there anyone or anyone that yall may mnow that can install the harness here in east texas? I would really appreciate it.
  27. Mar 29, 2018 at 7:15 PM
    #477
    Kwikfish
    Tri cities,WA
    16 CM SSM
    I put my fuse tap in the same as the pic and have no issues so far
  28. Mar 30, 2018 at 8:19 AM
    #478
    eledobleu
    Orlando, FL
  29. Apr 1, 2018 at 10:47 AM
    #479
    LKSR5-14
    LKSR5-14 New Member
    Chicago Northwest suburbs, Illinois
    2016 Tundra SR5 DC
    Tundra SR5 DC 2016 Upgrade: pro wheels, headlights retrofit, head unit Kenwood 694s, bed cover, lineX, Viper security and starter system, pro grille, tinted windows, LED lighting, black wrap on all end chrome corners, ceramic coating
    Looks great. Did you keep your led as a DRL on full brightness and not dimming when you turn your headlights on?
    I would like to keep amber as a DRL along with led strip.
    What purple wire do if you keep it vs removing? Where purple wire is located?
  30. Apr 1, 2018 at 10:54 AM
    #480
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    When you exchange the white/black pin where the purple was in the truck's signal harnesses, leave the purple out and tape it dead. Don't cut the gray wire inside the cab and the amber stays on in DRL mode. OP's harness has no option for DRL dimming when beams on (like iHacker's), but you can add a relay I think if you want it.
