2017 Tundra SR5 Sound system upgrade (proposed)
Discussion in 'Audio & Video' started by brownsno, Feb 16, 2018.
  1. Sep 10, 2019 at 9:02 AM
    #151
    TysToy
    TysToy New Member
    2019 Gray Tundra Dbl SR5 TSS
    After reading many many threads, I have decided to attempt the following upgrade.
    2019 Tundra SR5 TSS Dbl Cab w/o JBL audio. At this time I am going to use the factor HU.
    Alpine KTP-445U Amp
    PowerBass OE69C-TY 6x9" Speakers
    PowerBass OE65C-TY 6.5" Speakers
    AutoHarnessHouse 4438 Harness
    I was also thinking of adding the below Interface to add a powered subwoofer (already owned)
    Would it be possible to add the interface near the underseat amp instead of at the back of the HU. It sure would make the install much easier.
  2. Sep 10, 2019 at 10:35 AM
    #152
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    @Hunterdan and @TysToy
    I honestly cannot help you, since its different than my setup. Hopefully someone will pop in who can help you both.
    TysToy likes this.
  3. Sep 10, 2019 at 11:19 AM
    #153
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    I have that setup but no amp. However I feel that you should be able. The amp you getting has an extra switch lead wire for amp as well
    Since it is Amazon you can always return it ;)
    TysToy likes this.
  4. Sep 10, 2019 at 11:44 AM
    #154
    TysToy
    TysToy New Member
    I thought you added that same amp? It was your back and forth of questions and answers with the Capt that helped me towards this project.
    @CaptSpaulding Please jump on in as your input would be appreciated. TIA
  5. Sep 10, 2019 at 12:56 PM
    #155
    SiberianTundra
    Greg
    War Machine
    My bad “no sub”
    but yes that is the amp I have with same speakers. Wonderful sound. Lots of base for my taste without subwoofer
  6. Sep 10, 2019 at 1:03 PM
    #156
    TysToy
    TysToy New Member
    I am new to this so please keep that in mind. Actually 25 years ago, I added a super nice system to my first new car. But technology has changed and my memory is starting to fail this old man.
    I am not looking to build some crazy expensive unbelievable system. I just want to improve the crappy factory system for a reasonable cost.
    I keep reading about dsp units. What is your opinion? If I read the thread correctly, using the above mentioned setup, I would not need to add this item.
  7. Sep 10, 2019 at 1:25 PM
    #157
    SiberianTundra
    Greg
    War Machine
    Same here! I just wanted a good sound. Alpine and plug and play powerbass speakers worked great.
    TysToy[QUOTED] likes this.
  8. Sep 11, 2019 at 1:00 AM
    #158
    Hunterdan
    Hunterdan New Member
    2017 Inferno DC SR5
    OEM TRD led lights, TRD exhaust, s&b intake
    I did some research, taco tunes makes an inline plug that originally plugged into the factory amp with leads to go to a line level input for a sub amp. That same harness can be plugged inline between the factory harness and new Alpine amp harness to give me line level input leads to feed to a sub. I'm looking at a small 10" powered sub that will fit under the front seat with the Alpine amp and allow the door speakers to run just mids and highs (120 hz and higher) and the sub to run anything under 120 hz. Should clean up the sound a little more. Other than running an 8ga power wire, this would still be basically plug and play and easily removed/bypassed should I have to.
    SiberianTundra and TysToy like this.
  9. Sep 11, 2019 at 3:14 AM
    #159
    cslax35
    cslax35 New Member
    Liverpool, NY
    2018 Super White CrewMax TRD
    I installed one of those cheap Rockville 10” powered subs in my CM and mounted it to the rear wall behind the seat (didn’t want driver seat to vibrate all the time).
    I ran 4 gauge power wire from the battery for power. Spliced in a PAC SNI-35 line out converter under the front passenger seat and ran RCA cables for the signal input to the powered sub.
    To be honest, I like having the extra bass when I want it and I turn it down when I don’t (at the HU and/or on the remote bass knob) I do think that I will be looking to put in a different amp to replace the factory at some point like the OP, but right now, I can live without it.
    Because of the unknown with this brand, I bought a 3-yr warranty for 20 bucks on the powered sub. I paid just under $200 and am happy with the extra bass and so far, it’s worked great since April when I installed.
  10. Sep 11, 2019 at 3:14 AM
    #160
    yamabob
    yamabob New Member
    Chicagoland
    2018 Limited
    Following this thread. This might be the route I go too. How do you like the new dash speakers?
  11. Sep 11, 2019 at 10:35 AM
    #161
    TysToy
    TysToy New Member
    Great question.
    So, ST what are your thoughts on these dash speakers? My truck is only a month old and it seems like the dash speakers are already sounding scratchy.
    SiberianTundra likes this.
  12. Sep 11, 2019 at 6:04 PM
    #162
    SiberianTundra
    Greg
    War Machine
    Yea I would go with https://www.amazon.com/Infinity-REF3022CFX-Reference-Speakers-Edge-driven/dp/B01E4JWG6I
    Infinity 3022 I have them on both sides and it sounds amazing.
    You can start there actually before you swap everything out. It might be enough for you to be happy.
  13. Sep 12, 2019 at 4:06 AM
    #163
    TysToy
    TysToy New Member
    Did you just replace the corner dash speakers? Or, did you replace all 3 of the dash speakers? And if so, did you do anything different for the center speaker? Thanks again for all your info and help.
  14. Sep 17, 2019 at 2:15 PM
    #164
    SiberianTundra
    Greg
    War Machine
    just corner. I will replace center speaker eventually. But was happy with results of just corner.
    TysToy[QUOTED] and Brian0414 like this.
  15. Sep 17, 2019 at 3:29 PM
    #165
    SiberianTundra
    Greg
    War Machine
    I posted on page 3 but this will be your harness from OEM to alpine. Under the seat.
    TysToy likes this.
  16. Sep 18, 2019 at 5:31 PM
    #166
    TysToy
    TysToy New Member
    Trigger has been pulled.
    Amazon order placed. Looks like Sat will be spent in the garage.
    Alpine KTP-445U Amp
    PowerBass OE65C-TY6.5" Speakers
    I did install the infinity speakers in the dash corners this past wkend. Some improvement but not enough. That's why I decided to replace factory door speakers as well as the amp.
  17. Sep 18, 2019 at 7:55 PM
    #167
    SiberianTundra
    Greg
    War Machine
    Attached is the speaker diagram wiring for colors I got from this or some other thread.
    I used this and it worked great no issues at all. I think OP posted this on this here thread.
  18. Sep 18, 2019 at 8:03 PM
    #168
    SiberianTundra
    Greg
    War Machine
    No sound material yet. But it is coming and I will use full door skins they sell and back. But not the roof or floor.
  19. Sep 19, 2019 at 6:42 AM
    #169
    TysToy
    TysToy New Member
    That is one of the first things I printed when I started my research. Thanks.
  20. Sep 19, 2019 at 9:00 AM
    #170
    SiberianTundra
    Greg
    War Machine
    Also if you look at one of the pictures I posted above you will notice 1 wire dark blue with white is not connected to anything. That is normal.
  21. Sep 19, 2019 at 2:27 PM
    #171
    TysToy
    TysToy New Member
    Thanks for the info. With all the rain down here in Houston, I hope Amazon can still get my stuff delivered by tomorrow night. I am ready to dive in come Saturday.
  22. Sep 21, 2019 at 2:18 AM
    #172
    Hunterdan
    2017 Inferno DC SR5
    So, I ordered a small powered sub that will fit under the passenger seat with the Alpine amp. I tapped into the 4438 harness to grab high level inputs for the sub. Only thing left to do is run the power from the battery and plug it all in. Should be all done come Sunday morning.
    TysToy and SiberianTundra like this.
  23. Sep 21, 2019 at 6:05 AM
    #173
    SiberianTundra
    Greg
    War Machine
    What is the small power sub? Brand or link ? Thanks.
  24. Sep 21, 2019 at 6:32 AM
    #174
    TysToy
    TysToy New Member
    I got the front door panels off and added sound deading material. Also removed the speakers. Next I removed passenger seat and pulled old amp. Got one delivery from Amazon, the amp. Unfortunately the harness and speakers have been delayed. It shows a delivery from 21st-24th. So much for a perfect wkend to tackle my project. Gonna have to button it back up if they don't arrive by 9mp tonight. Ugh.
  25. Sep 21, 2019 at 6:35 AM
    #175
    TysToy
    TysToy New Member
    Which wires did you tap for the sub? I was thinking of doing same. I assume you did it on the input side "before the amp".
    Thanks in advance.
  26. Sep 21, 2019 at 7:13 AM
    #176
    SiberianTundra
    Greg
    War Machine
    Lately AMAZON has been on late on all shipping. Something changed or the folks working for them want to take their time.
  27. Sep 21, 2019 at 7:43 AM
    #177
    TysToy
    TysToy New Member
    True. But I think this lastest rain event kinda screwed up the airports and delivery. Fingers crossed it makes it here today.
  28. Sep 21, 2019 at 8:04 AM
    #178
    TysToy
    TysToy New Member
    Christmas came early. Amazon did not have app updated. My stuff just got delivered. Time to grab a beer and head to the garage.
    :yes::yes::yes:
  29. Sep 21, 2019 at 8:31 PM
    #179
    SiberianTundra
    Greg
    War Machine
    Oh man its a great way to spend a Saturday evening.
  30. Sep 22, 2019 at 6:28 AM
    #180
    TysToy
    TysToy New Member
    Install complete. It took a little longer than expected. I was concerned and a little worried about the wiring. Some of the colors on my 2019 Turndra were different. I added sound deadening to the doors. I also put the tweeters in the sail panels.
    WOW. What a difference. There is so much more fullness to the sound. I actually need to adjust the amp because it is a little too much bass. No doubt this was worth every penny. And I enjoyed doing the project.
    Thanks to all for the advice.
    I just need to address a slight interference noise with the AM stations. It was not there before or at least not noticeable. Any thought from the experts?
    Again, thanks to all.
    UPDATE: It turns out the interference noise with the AM was due to being parked in my garage while doing the install. After I pulled out, the static was gone. I adjusted the amp settings and I love the sound. For a small investment of time and money, the project was a huge success. Again thanks to all for the advice and help.
    betotundra likes this.
