2017 Tundra SR5 Sound system upgrade (proposed)
Discussion in 'Audio & Video' started by brownsno, Feb 16, 2018.
  1. Mar 3, 2019 at 9:10 AM
    #91
    CaptSpaulding
    CaptSpaulding ...ain't nothin but nothin
    Jake
    2010 White DC 4x4
    Awesome! I'll do the same, thanks man. Have you dug into the wiring yet? I havent looked into the process yet
  2. Mar 3, 2019 at 2:20 PM
    #92
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    Not yet. Starting research now. But I have opened my doors up for new oem towing mirror install. So I saw the wires.
    My goal here will be passenger side first. and rear passenger side for guests.
    If all works ordering 3 more for drivers side behind drivers and rear window.
  3. Mar 3, 2019 at 9:57 PM
    #93
    SiberianTundra
    Greg
    War Machine
  4. Mar 3, 2019 at 10:04 PM
    #94
    CaptSpaulding
    Jake
    2010 White DC 4x4
    So that device adds noise filtering or prevents ground hum? I haven't seen these before
  5. Mar 3, 2019 at 10:20 PM
    #95
    SiberianTundra
    Greg
    War Machine
    it says - when adding an amplifier to a factory radio to convert the radio's speaker level output to the lower amplifier (RCA) level input
    So I think it just gives you flat signal.
    It also does mention - Utilize Audio Transformer for Noise Isolation
    So I assume they want you to noise filter with another device.
    I guess I am looking to flatten the sound before the alpine amp.
  6. Mar 4, 2019 at 7:25 PM
    #96
    Finch
    Finch New Member
    Donnie
    '16 Inferno CM 5.7L TRD Off-Road
    So I just ordered the Alpine unit and wiring harness. I'll be joining the club soon enough.
    SiberianTundra likes this.
  7. Mar 4, 2019 at 7:43 PM
    #97
    SiberianTundra
    Greg
    War Machine
    Your going to like it man. Take time to adjust gain when all is running.
  8. Mar 4, 2019 at 7:52 PM
    #98
    Finch
    Finch New Member
    Donnie
    Will do. I'm sure I'll be asking you a question or two. I am almost ashamed to say that because I had one helluva system that I put together and wired in my first vehicle. That was about 18 years ago though. :(
  9. Mar 4, 2019 at 7:56 PM
    #99
    SiberianTundra
    Greg
    War Machine
    Same story here. I have not done this in a long time. I got help here as well. But after soldering all the wires and wrapping it up in electrical tape. Everything worked just fine. It will make sense after you connect using the Pin numbers per text file
    Finch[QUOTED] likes this.
  10. Mar 5, 2019 at 2:06 PM
    #100
    SiberianTundra
    Greg
    War Machine
  11. Mar 5, 2019 at 2:41 PM
    #101
    Finch
    Finch New Member
    Donnie
  12. Mar 5, 2019 at 3:55 PM
    #102
    fulanoderock
    fulanoderock New Member
    Ventura County
    2018 Toyota Tundra TRD Sport
    So I've read through the entire threat and just a bit confused. Let me know if I am correct - I can add the amplifier that OP recommended with the harness from autoharness.com and not have to splice anything, correct? I really don't want to cut up any wires and mess anything up. Thanks for any clarification you can provide.
  13. Mar 5, 2019 at 4:03 PM
    #103
    SiberianTundra
    Greg
    War Machine
    Yes. But you still have to solder the autoharness harness to the alpine harness. Yes if you follow post #11 it should all work. Like it did for me.
    fulanoderock[QUOTED] likes this.
  14. Mar 5, 2019 at 4:04 PM
    #104
    fulanoderock
    Ventura County
    So it's not just plug n play? Soldering is required? Darn. Don't have soldering equipment.
  15. Mar 5, 2019 at 4:47 PM
    #105
    Finch
    Finch New Member
    Donnie
    A soldering iron isn't much and will come in handy for other things down the road. I've yet to do this yet (my amp is en route to me) but I'd imagine you could use those crimp splices but soldering prevents any loose connections.
  16. Mar 5, 2019 at 4:53 PM
    #106
    SiberianTundra
    Greg
    War Machine
    Yes you can always use quick splice https://www.amazon.com/Ginsco-Terminals-Self-stripping-Insulated-Disconnects/dp/B01CDWC60Y/
    fulanoderock likes this.
  17. Mar 9, 2019 at 2:09 PM
    #107
    Finch
    Finch New Member
    Donnie
    Shit cant ever be easy. Started on my install today but a mounting screw on each side of the amp will not come out. I hit it with some Kroil oil but they are stuck in there good and the heads are stripped. Thinking about either velcroing to factory amp cover or using 3M tape. Should still be fine but was hoping to screw it down.
  18. Mar 10, 2019 at 8:53 AM
    #108
    SiberianTundra
    Greg
    War Machine
    I never took my amp out. I just pulled the wires out. And plugged em into new wires. Did not even take the seat out.
  19. Mar 10, 2019 at 9:02 AM
    #109
    CaptSpaulding
    Jake
    2010 White DC 4x4
    That's a $500 bill sittin under your seat man! Ahahah
  20. Mar 10, 2019 at 11:48 AM
    #110
    Finch
    Finch New Member
    Donnie
    Sorry, I meant the new amp as it came with mounting brackets in which two screws have to be removed on each end of the amp so you can attach the bracket so it can then be screwed down. It's not an issue now- I've got an alternate method.
  21. Mar 10, 2019 at 2:58 PM
    #111
    SiberianTundra
    Greg
    War Machine
    Cool beans!
    Im sure its going to be good!
  22. Mar 13, 2019 at 10:20 PM
    #112
    SiberianTundra
    Greg
    War Machine
    Infinity Reference REF-3032CFX 3-1/2" 2-way Car Speakers should be here tomorrow for my dash speakers.
    They are 4 ohms and are 1 ohm more over OEM. But should work just fine.
  23. Mar 16, 2019 at 7:57 PM
    #113
    SiberianTundra
    Greg
    War Machine
    Got component 6X9 and rear components designed for Toyota oem fit
    So far fronts fit perfectly and sound amazing w alpine
    1EB93D76-2108-4ED0-AFF3-DA7B5D76653A.jpg 910B55EC-D622-4883-A38A-D2728112313F.jpg
    CaptSpaulding likes this.
  24. Mar 16, 2019 at 9:07 PM
    #114
    SiberianTundra
    Greg
    War Machine
  25. Mar 17, 2019 at 10:29 AM
    #115
    SiberianTundra
    Greg
    War Machine
  26. Mar 17, 2019 at 10:30 AM
    #116
    SiberianTundra
    Greg
    War Machine
    Only left tweeters I kept oem for now wires do not match
  27. Mar 17, 2019 at 10:58 AM
    #117
    CaptSpaulding
    Jake
    2010 White DC 4x4
    Great job! Fun project overall too
  28. Mar 17, 2019 at 5:59 PM
    #118
    SiberianTundra
    Greg
    War Machine
    What is interesting is that front dash speakers left and right are 6 ohms
    Front 6x9 2ohm
    Rear 6.5 are 2ohm
    Rear Tweets are 4 ohm... Little bit of a head scratcher. Why are the tweets more ohm vs mids for OEM.
    Current setup is 4 ohm for all Mids front and rear with OEM rear tweets and OEM front dash speakers. I have 4 tweeters but I think They will not be same as the cross over for oem is different. More tests are needed. I might do infinity front dash. More tests.
    Anyways. Drove around today and stereo sounds amazing.
  29. Mar 17, 2019 at 7:34 PM
    #119
    CaptSpaulding
    Jake
    2010 White DC 4x4
    Very weird! I guess as long as it sounds great while you're cruisin, we don't need to understand right? Ahaha
  30. Mar 17, 2019 at 7:45 PM
    #120
    hey smell this
    hey smell this New Member
    Houston
    2016 Tundra TSS
    I was thinking about simply changing out the crummy stock speakers with some good ones. Would that alone make a big difference?
