2017 Tundra SR5 Sound system upgrade (proposed)
Discussion in 'Audio & Video' started by brownsno, Feb 16, 2018.
  1. Mar 1, 2019 at 2:45 PM
    #61
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    Here is the picture of the amp out and what the harness look like
    It is Fujitsu!
    CaptSpaulding likes this.
  2. Mar 1, 2019 at 2:45 PM
    #62
    CaptSpaulding
    CaptSpaulding ...ain't nothin but nothin
    Jake
    2010 White DC 4x4
    Attached the settings for reference. The gain levels I set at 50%, or vertical.
    betotundra and SiberianTundra like this.
  3. Mar 1, 2019 at 2:47 PM
    #63
    SiberianTundra
    Greg
    War Machine
    Thanks for all your Help Capt. !
  4. Mar 1, 2019 at 2:48 PM
    #64
    CaptSpaulding
    Jake
    2010 White DC 4x4
    Happy to help! Excited to hear how much your sound improves
  5. Mar 1, 2019 at 2:50 PM
    #65
    SiberianTundra
    Greg
    War Machine
  6. Mar 1, 2019 at 2:54 PM
    #66
    CaptSpaulding
    Jake
    2010 White DC 4x4
    "What's the matter kid....dont ya like clowns?"
    So good!
  7. Mar 1, 2019 at 3:00 PM
    #67
    YsoSeRiouS!
    YsoSeRiouS! A good day...for a good day
    NorCaL
    2019 White Platinum CM
  8. Mar 1, 2019 at 4:12 PM
    #68
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Awesome!
  9. Mar 1, 2019 at 9:56 PM
    #69
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Rancho Cordova, aka....."the cho"
    YsoSeRiouS![QUOTED] likes this.
  10. Mar 2, 2019 at 8:19 AM
    #70
    Finch
    Finch New Member
    Donnie
    '16 Inferno CM 5.7L TRD Off-Road
    Glad I came across this thread as it'll save me some coin. I have a '16 Tundra CM with the non-JBL system. I found an open box Alpine KTP-445U but it doesn't include the harnesses that it originally came with. Would I even need those if I were to buy the harness at https://www.autoharnesshouse.com/41112.html
  11. Mar 2, 2019 at 9:15 AM
    #71
    SiberianTundra
    Greg
    War Machine
  12. Mar 2, 2019 at 9:25 AM
    #72
    Finch
    Finch New Member
    Donnie
    Ok, thanks. Disregard the PM I sent you BTW. How are you liking it since you installed the amp? Would the Alpine be good if paired with some aftermarket component door speakers? I've been out of the sound system game too long.
  13. Mar 2, 2019 at 9:59 AM
    #73
    CaptSpaulding
    Jake
    2010 White DC 4x4
    I have decent Polk speakers all around, Alpine power pack, and stock Non-JBL head unit. From jazz-fusion to death metal....fom Kool Keith to Sinatra, it all sounds amazing
  14. Mar 2, 2019 at 10:14 AM
    #74
    Finch
    Finch New Member
    Donnie
    Great, that's what I'm hoping for! Thanks again.
  15. Mar 2, 2019 at 10:25 AM
    #75
    CaptSpaulding
    Jake
    2010 White DC 4x4
    @SiberianTundra should have his installed today I believe, anxious to hear his feedback
    SiberianTundra and Finch like this.
  16. Mar 2, 2019 at 10:57 AM
    #76
    SiberianTundra
    Greg
    War Machine
    Ok Just finished putting together the harness. Getting ready to go outside and plug it in. Kind of moment of truth. @CaptSpaulding and @Finch I will let you know how it goes Right after. Took a little while to solder it all together and then I used electrical tape. After that I added all the tags to it left, right front and rear all that jazz.
    CaptSpaulding and Berdine like this.
  17. Mar 2, 2019 at 10:57 AM
    #77
    SiberianTundra
    Greg
    War Machine
    This is going to be on OEM speakers
    Finch and Berdine like this.
  18. Mar 2, 2019 at 11:45 AM
    #78
    SiberianTundra
    Greg
    War Machine
    It works great nice sound. I turned gain all down. Front hpf 120mz rear hpf 120mz dip switches on 4 channel and spkr dip switch. Sounds so much better. W gain even a little I get some sort of shhhh static. But it sounds so much better over stock.
    Thank you for all the help !
  19. Mar 2, 2019 at 11:49 AM
    #79
    CaptSpaulding
    Jake
    2010 White DC 4x4
    Awesome! Glad it worked out and worth the minor headaches involved
    SiberianTundra likes this.
  20. Mar 2, 2019 at 11:55 AM
    #80
    Finch
    Finch New Member
    Donnie
    Awesome! I assume it gave you a little more bass from the stock speakers? I'm probably going to order everything here soon.
  21. Mar 2, 2019 at 11:58 AM
    #81
    SiberianTundra
    Greg
    War Machine
    Thank you for all the help!
    I had to turn on dip switches for 120 MHz too much base.
    But tested both. Cleaner sound from alpine. Oem amp muffled the base and mids
    Alpine gives me cleaner sound w oem speakers
    Finch and CaptSpaulding[QUOTED] like this.
  22. Mar 2, 2019 at 3:35 PM
    #82
    SiberianTundra
    Greg
    War Machine
  23. Mar 2, 2019 at 3:43 PM
    #83
    CaptSpaulding
    Jake
    2010 White DC 4x4
    Nice work! Labelled and all. It's rewarding
  24. Mar 2, 2019 at 4:08 PM
    #84
    Finch
    Finch New Member
    Donnie
    Nice! So you just mounted on top of your existing amp? I like that idea. Also, the connector that you ordered...is that it at the top of the middle pic? That's the only other thing you had to order besides the amp, right?
  25. Mar 2, 2019 at 7:51 PM
    #85
    SiberianTundra
    Greg
    War Machine
    Yes use post #11 for all details.
    Download and print both images and the text file.
    Use pin numbers to make it easier to identify wires.
    Most colors will match the Amazon adapter https://www.amazon.com/gp/product/B01BSEGCQW
    Here is the Alpine Amp I purchased
    https://www.amazon.com/Alpine-KTP-445U-4-channel-Power-Amplifier/dp/B003VVYL46/
    Also yes I decided to mount it on top of my old amp shroud. If something goes wrong with alpine and I need sound while waiting to replace.
    This should be a sticky!
  26. Mar 2, 2019 at 7:53 PM
    #86
    CaptSpaulding
    Jake
    2010 White DC 4x4
    Professional!
  27. Mar 2, 2019 at 7:57 PM
    #87
    SiberianTundra
    Greg
    War Machine
    Well thanks to your input this was easy. Support is important.
    This took too long to install. But only because I took my time cranking my brain to make sure it is done the right way.
    But damn. Drove today and my girl thinks sounds is so much better. We cruised all day listening to everything and tuning the radio.
    Next: Auto Power up/down window switch per girls request. On her side.
    Soon after some Speaker upgrades.
  28. Mar 2, 2019 at 8:04 PM
    #88
    CaptSpaulding
    Jake
    2010 White DC 4x4
    I'd love to install the auto switches, maybe you can help me on that one? Or we'll tackle it together, but I'm definitely interested
  29. Mar 2, 2019 at 9:19 PM
    #89
    SiberianTundra
    Greg
    War Machine
    You are on my bud! Lets get the switches done next.
    I will start research with a new post.
  30. Mar 3, 2019 at 8:34 AM
    #90
    SiberianTundra
    Greg
    War Machine
