2017 Tundra SR5 Sound system upgrade (proposed)
Discussion in 'Audio & Video' started by brownsno, Feb 16, 2018.
  1. Apr 14, 2018 at 12:46 PM
    Dmas
    Dmas New Member
    FTL, FL
    2018 SR5 Tundra DC TRD Off Road 4x4
    Yeah I did, thanks...what fixed the issue on my truck was disconnecting the blue wire, read on the manual that it not necessary when you use the speakers level input.
  2. Apr 14, 2018 at 3:31 PM
    brownsno
    brownsno [OP] New Member
    2017 Tundra SR5
    that's awesome. Did you see an improvement in the stock sound?
  3. Apr 14, 2018 at 3:39 PM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    I have a 2017. I have the brown and blue left over. I connected the blue but when I turned the truck off the radio stayed on. Disconnected it and it seems to work normal. Thank you for getting back
  4. Apr 14, 2018 at 6:40 PM
    Dmas
    Dmas New Member
    FTL, FL
    Oh yeah it sounds better, no doubt, thanks for the write up!
  5. Apr 15, 2018 at 1:04 PM
    Mickleford
    Mickleford New Member
    2016 SR5
    No dynamat yet. It's on the list though!
  6. Apr 25, 2018 at 10:46 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I have decided to start with just putting some good component speakers in the front doors. I never have passengers so not even sure if I will ever change out the rears. I am going to see what the speaker change out sounds like and then at later point will probably add an amp and sub. May never change the rear speakers.
  7. May 3, 2018 at 10:50 AM
    johnxmccoy
    johnxmccoy New Member
    Grove City, Ohio
    2019 Crew Max
    Thinking of upgrading my system.
    Will you please explain the processor?
    Thanks.
    Tundyfundy likes this.
  8. May 4, 2018 at 6:05 AM
    smooosh
    smooosh This place costs me too much $
    2018 TRD Offroad Limited Crewmax.
    Ongoing project
    If you keep the factory head unit you want a processor in between the factory head unit and your new amps to flatten the signal and re eq it. If you dont you are just amplifying the crappy sound coming out of the factory head unit.
    Beerdude77 likes this.
  9. May 5, 2018 at 7:46 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    I plan on doing the same thing you did based on the results. Do you need the male or female connector from the website you listed above?
  10. May 5, 2018 at 8:11 PM
    Beerdude77
    Beerdude77 New Member
    2018 Silver Sky Tundra Limited TRD CM
    Linex bed, "Toyota" Console Safe
    As someone that currently only has the speaker level input harness going into the amp I can confirm this. I still haven't put in my new door speakers but so far the new subs I have put in sound so bad I keep the bass knob nearly completely turned off. I will be replacing my head unit ASAP because I can't believe I spent what I spent and it sounds this bad...
  11. Aug 16, 2018 at 11:45 AM
    turiha
    turiha New Member
    Tried to connect the alpine amp, no sound on 2 channels, went back to connect original amp and no sound on the speakers only on tweeters.
    need help to have sound
  12. Feb 11, 2019 at 11:35 AM
    CaptSpaulding
    CaptSpaulding ...ain't nothin but nothin
    Jake
    2010 White DC 4x4
    Adding to this outdated post. My fancy Kenwood head unit took a dump recently, so I put the stock radio back, and purchased the KTP-445U based on this post. However, I have a 2nd gen, non-JBL (without the amp). I believe the 2nd gens have wiring under passenger seat for the amp? Ideally, that would have been a much better location in retrospect. That said, I went to town decoding, soldering and heat shrinking all the connections, the power pack attached to the back of the head unit, with a peice of rubber in between for vibration. I wrote out my connectors, pins, and what color goes where, I'll attach that tonight when I get home. It differs from the info listed here.
    I have decent Polk speakers all around, nothing else. With the KTP-445U installed, it made a huge difference. Previous volume at 35 is now 13, with lots more power and range. I'm not at all informed on audio, but know it made a worthwhile difference for minimal cost and effort. I'm still working with 1 arm for the most part as I recover, yet still very doable. 2 arms should make it much easier. Cheap add-on for a better Tundra experience 20190210_101907.jpg 20190210_161615.jpg 20190210_162208.jpg 20190210_164413.jpg
    TX_ToyTundra likes this.
  13. Feb 11, 2019 at 11:43 AM
    Twinky
    07 double cab work horse
    Good info. Ty
  14. Feb 13, 2019 at 4:08 PM
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
  15. Feb 13, 2019 at 4:15 PM
    CaptSpaulding
    Jake
    2010 White DC 4x4
    You'll love it, and a super easy install with an existing Alpine head unit
    SiberianTundra likes this.
  16. Feb 13, 2019 at 4:44 PM
    SiberianTundra
    Greg
    War Machine
    I dont have Alpine headunit. Just the OEM tundra headunit. But should still sound better then Toyota factory amp
  17. Feb 13, 2019 at 5:01 PM
    CaptSpaulding
    Jake
    2010 White DC 4x4
    I think the only difference between 445U and 445A are the included wires. The unit itself should be the same. Worth checking though
    445A: specific to Alpine head units. Harness attaches direct to the head unit via connector, same for the speaker side.
    445U: universal for all other brands. Harness has no connectors, you splice it into your existing system.
    Either way, good luck and ask for help before smashing the unit. Ahaha
  18. Feb 13, 2019 at 5:04 PM
    SiberianTundra
    Greg
    War Machine
    Oh yea I updated my post it is U I am getting. not A. So yea should be good. Thanks man
    CaptSpaulding[QUOTED] likes this.
  19. Feb 13, 2019 at 5:37 PM
    #49
    CaptSpaulding
    Jake
    2010 White DC 4x4
  20. Feb 13, 2019 at 8:29 PM
    #50
    SiberianTundra
    Greg
    War Machine
  21. Feb 13, 2019 at 9:03 PM
    #51
    CaptSpaulding
    Jake
    2010 White DC 4x4
    Great find! Specific to the non-JBL systems, which is me. Would have saved me a ton of time.
    For reference, here are the colors/speakers for each connector in a 2nd Gen Non-JBL setup at the dash.
    Small connector with 5 wires:
    Rear Right + : Red
    Rear Right - : White
    Rear Left + : Yellow
    Rear Left - : Black
    Tan-ish color (illumination?) Not needed, don't cut
    Large connector with 8 wires:
    Front Right + : Green
    Front Right - : Blue
    Front Left + : Yellow
    Front Left - : White
    White/Black = Ground
    Blue = 12 Accessory
    Gray = Battery (constant power)
    Light Blue = Not sure, not needed. Dont cut
  22. Feb 21, 2019 at 6:44 AM
    #52
    socal147
    socal147 None Specified
    Patrick
    Oak Hills Commiefornia
    2019 Tundra Tonka
    Stock is so temporary
    Op
    Added to favorites
    Thank you
  23. Feb 26, 2019 at 7:44 PM
    #53
    SiberianTundra
    Greg
    War Machine
    Ok I got my harness and my Alpine 445 U today
    About to splice wires together
    Wonder if anyone has a map 1 to 1 for harness
    Factory Amp Upgrade Harness AHH-4438
    https://www.amazon.com/gp/product/B01BSEGCQW/ref=ppx_yo_dt_b_asin_title_o01_s00
    to Alpine 445 U harness that comes with it
  24. Feb 26, 2019 at 7:52 PM
    #54
    CaptSpaulding
    Jake
    2010 White DC 4x4
    Nice!
    That link shows 10 and 12 pin connectors, which didn't apply to my non-JBL set up. Mine was 5 and 8 pin. The Metra connectors may help?
    Metra 70-1761 Radio Wiring Harness For Toyota 87-Up Power 4 Speaker https://www.amazon.com/dp/B0002BEQJ8/ref=cm_sw_r_cp_apa_i_lLGDCb5J2HP2E
    That said, you got it! I can help you identify colors if needed, what year Tundra and do you have an amp under your passenger seat?
  25. Feb 26, 2019 at 8:03 PM
    #55
    SiberianTundra
    Greg
    War Machine
    2018 Tundra Crewmax SR5. NON Jbl entune Plus Apps but no GPS. Yes I have a amp under my seat. SO I got wrong harness then?
    cause it says for Non JBL
  26. Feb 26, 2019 at 8:12 PM
    #56
    CaptSpaulding
    Jake
    2010 White DC 4x4
    I think you're ok, once you get to the amp under the seat it'll all make sense. All of my stuff is a gen 2 without amp, the initial @brownsno write up and post #8 apply to your setup directly I believe
  27. Feb 27, 2019 at 7:31 PM
    #57
    SiberianTundra
    Greg
    War Machine
    Thank you very much. I have SR5 2018 with same under seat amp. Hope 2017 and 2018 sr5 colors are same
    Ill just connect wires based on what you explained in the text file and just go to car and plug it in.
    CaptSpaulding likes this.
  28. Feb 28, 2019 at 6:41 PM
    #58
    SiberianTundra
    Greg
    War Machine
    oh so the color combo is not based on the Factory Amp Upgrade Harness AHH-4438 but on the actual OEM wire harness going to and from the amp. I just need to translate it based on pins
  29. Mar 1, 2019 at 2:28 PM
    #59
    SiberianTundra
    Greg
    War Machine
    Ok it is same harness for colors thats good Next question is. Will I need to flip any dip switches in the alpine unit it self?
  30. Mar 1, 2019 at 2:41 PM
    #60
    CaptSpaulding
    Jake
    2010 White DC 4x4
    Nice. You'll be bumpin in no time!
    Mine was set to RCA by default, adjusted it to speaker level output. Didn't change anything else and threw a peice of electrical tape over the rubber cover for peace of mind
