2017 Tundra SR5 Sound system upgrade (proposed)
Discussion in 'Audio & Video' started by brownsno, Feb 16, 2018.
  1. Mar 9, 2023 at 6:55 PM
    #331
    RotorSlapX71
    RotorSlapX71 New Member
    2018 Trd Tundra
    Ok that makes sense….. I bought that before I knew about the harness….. I think I got like 10’ of that….. do you have any pictures of the connections?
  2. Mar 9, 2023 at 7:20 PM
    #332
    FirstTruck
    FirstTruck New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
    I did not use the 12 pos. I run my own wire from the batt to run the amps. Make sure to use one ground point to avoid loops which can cause white noise.
    RotorSlapX71 likes this.
  3. Mar 9, 2023 at 7:23 PM
    #333
    RotorSlapX71
    2018 Trd Tundra
    yea I got 2 wires from the battery for the amps… No idea what your talking about with the loops….. Am I supposed to add in a ground other than what is going to the LC7i?
  4. Mar 9, 2023 at 7:37 PM
    #334
    FirstTruck
    Stock, for now
    Ground loops is when u hear the alternator through the speakers. Its annoying. They just recommend using one point for all grounds.
    You will need a ground for the amp and another one for the LC7. Depending on the wattage of your amp will be the wire gauge. On the amp, try to make positive and negative the same gauge. The LC7 takes a small wire.
  5. Mar 9, 2023 at 7:38 PM
    #335
    RotorSlapX71
    2018 Trd Tundra
    power & grounds are 4ga….
  6. Mar 9, 2023 at 7:41 PM
    #336
    FirstTruck
    Stock, for now
  7. Mar 10, 2023 at 4:08 AM
    #337
    RotorSlapX71
    2018 Trd Tundra
  8. Mar 10, 2023 at 4:47 AM
    #338
    RotorSlapX71
    2018 Trd Tundra
  9. Mar 10, 2023 at 10:24 AM
    #339
    FirstTruck
    Stock, for now
    Don’t think you need it. You will have yr own ground.
    RotorSlapX71[QUOTED] likes this.
  10. Mar 10, 2023 at 1:28 PM
    #340
    RotorSlapX71
    2018 Trd Tundra
    Ok awesome, should I have both amps on the same ground to avoid engine noise?
  11. Mar 10, 2023 at 3:03 PM
    #341
    FirstTruck
    Stock, for now
  12. Mar 10, 2023 at 4:08 PM
    #342
    RotorSlapX71
    2018 Trd Tundra
    Ok, everything is connected. Harness to LC7 to 4 channel amp to sub amp…. Everything is turning on but nothing from the subs. Sounds like the subs want to fire off but no music coming from them.
    RCA’s from the 4 channel go to the sub amp, power is good and I believe the ground is solid. Remote wire running from the 4 channel to the sub amp as well…. The remote wire isn’t secured fully…. RCA’s are going in to the “input”…. Any idea?
  13. Mar 10, 2023 at 4:10 PM
    #343
    FirstTruck
    Stock, for now
  14. Mar 10, 2023 at 4:12 PM
    #344
    FirstTruck
    Stock, for now
    Post some pics. Are the amps turning on? Verify inputs and outputs
  15. Mar 10, 2023 at 4:18 PM
    #345
    RotorSlapX71
    2018 Trd Tundra
  16. Mar 10, 2023 at 8:04 PM
    #346
    FirstTruck
    Stock, for now
    Can u connect a speaker to the wire just before going into the LC7. This way we can know if the audio is getting there.
    You should have the switch to 4 channel on the RF amp
    Are the inout level to 50%
  17. Mar 10, 2023 at 8:09 PM
    #347
    RotorSlapX71
    2018 Trd Tundra
    figured out what it was. Needed 4 wires to run from the sub amp to the LC7i 3rd channel input… I switched channel 2 RCA’s to channel 3 and the subs started to work…. Tomm I’ll have to find that connector and run new wires then figure out how to adjust all the knobs….. car audio world is so vague….. thank God for YouTube and folks like yourself in this forum otherwise I’d say ffff it like last year.
  18. Mar 10, 2023 at 8:12 PM
    #348
    RotorSlapX71
    2018 Trd Tundra
    the connector with 4 wires…. I think it’s missing from my amp box…..
  19. Mar 10, 2023 at 8:37 PM
    #349
    FirstTruck
    Stock, for now
    Great, I understood that you were not getting any audio. Sorry I went back and its just the sub. Glad you figure it out.
    Tip: most of the times channel 1 from the radio is stronger than channel 2, so they recommended to use channel one to get the signal to the sub. On the LCi flip flop channel 1 and 2 as yr inputs.
    Dont understand were will those wires / connectors go.
    Did you switch the dip switch inside the LC7? This will give u audio to the 3 rd channel output. Channel 3 is the sub. You are needing 3 channels from 2. The third one is a copy of channel 2 but you need to move the dip switch inside the LCi.
    check minute 3:30 on the first video I sent you.
  20. Mar 11, 2023 at 4:06 AM
    #350
    RotorSlapX71
    2018 Trd Tundra
    the 3rd channel….. isn’t for the sub? I was on the equalizer portion in the head unit where it breaks down front/rear, left / right. When I move it to the rear no sound, odd but not a big deal.
  21. Mar 11, 2023 at 5:49 AM
    #351
    FirstTruck
    Stock, for now
    Correct 3rd channel output. You dont have input for the 3rd channel. Can u post a pic of the LC7?
    You should have chanel 1 n 2 input, dip switch (Auto mode) on channel 2 to feed channel 3 (inside LC7), the cannel 1,2 n 3 from yr outputs to the two amps.
  22. Mar 11, 2023 at 7:41 AM
    #352
    RotorSlapX71
    2018 Trd Tundra
    Here are the default settings… I ran wires from channel 3 to speaker in on the amp… no subs…. But probably relates to what settings I need to change inside the lc7i?
  23. Mar 11, 2023 at 7:45 AM
    #353
    FirstTruck
    Stock, for now
    If Im not wrong the Auto mode needs to be “on”. This way the 2nd channel will feed the third. The GTO is good because you have a remote from the LOC to the amps. No summing is good.
  24. Mar 11, 2023 at 7:50 AM
    #354
    RotorSlapX71
    2018 Trd Tundra
    Yep. Switching to auto turned the subs on….. now how to adjust sub amp haha
  25. Mar 11, 2023 at 8:05 AM
    #355
    FirstTruck
    Stock, for now
    So now you have all 4 speakers and sub with audio, correct?
    The bass can be controlled with a bass control knob that you ca; connect to the LC7
    Gains are on the LC7.
    Start with all output level to zero
    DISCONNECT RCA OUT!!! A must
    Play music and start rotating each output level knob clockwise. Gentle here until the Max light turn on and then go back a midget.
  26. Mar 11, 2023 at 8:10 AM
    #356
    RotorSlapX71
    2018 Trd Tundra
    disconnect RCA’s to what? To the subs?
  27. Mar 11, 2023 at 8:23 AM
    #357
    FirstTruck
    Stock, for now
    Before we move on…what do you have connected where I circled?
    To set the gains:
    Play pink noise. If you don't have then play some music. You need to disconnect all RCAs to the amps. Start adjusting the gains one channel at a time. Start with channel one. Move the dial clockwise. Once you see that the Max led turns on, stop and go back a midget. Do the same with the other 2.
    Then connect the 3 pairs of RCA ro the amps.
    Finally zip tie all wires.
  28. Mar 11, 2023 at 9:51 AM
    #358
    RotorSlapX71
    2018 Trd Tundra
    the circled part goes to the sub amp.
  29. Mar 11, 2023 at 12:34 PM
    #359
    FirstTruck
    Stock, for now
    Im confused now. The screw side are inputs. The RCA are outputs. How come you have n input for the 3rd channel?
    also is that ground wire as thick as the positive? They should be the same gauge.
  30. Mar 11, 2023 at 4:09 PM
    #360
    RotorSlapX71
    2018 Trd Tundra
    Now that you mention it…. This picture was prior to getting inside the LC7i….So I won’t put those input wires back in. Positive & negative wires are straight from the stock harness…. Should be same diameter…
