2016 Tundra Strange Knock in Engine Compartment After Startup
Discussion in '2.5 Gen Tundras (2014-2021)' started by plumber802, Nov 17, 2019.
  1. Nov 18, 2019 at 10:46 AM
    shakezoola
    shakezoola Not a new member
    Kansas City
    2019 Tundra TRD Sport MGM
    N-Fab MRDS Bfront Bumper w/ Rigid Industries Radiance PODS and Curved LED Light Bar TRD Skid plate Victory 4x4 Roof rack and hood mounts with Rigid industries Midnight PODS Alpine Halo9 ILX-F309TND Alpine PDR-V75 5-Channel amp powering 4x Image Dynamics component speakers Alpine S-A60M powering 1x 12" sub Fortin Remote Start with MyCar App Switch Pros SP-9100 Pop-and-Lock tailgate lock vLeds front turn signals w/switchback Center Console Safe Pedal Commander Diamond Back HD bed cover Swing Cases Driver/Passenger Katzkin Leather seats w/ heated front seats Bilstein B8 5100's Front and rear AMP Research PowerSteps Toyota TSS wheels w/ DuraTracs Toyota bed mat Bed light (LEDs) Blacked out badges Sport Antenna
    I had something similar on a Dodge Dakota (4.7L) I used to own. Turned out to be the head gasket. As it was explained to me... exhaust was leaking through the gasket until the engine warmed up. After the engine was warm, the gasket would expand with heat to seal the leak temporarily. Gasket was replaced, noise went away, truck was traded shortly after.
  2. Nov 18, 2019 at 10:49 AM
    plumber802
    plumber802 [OP] New Member
    Andy
    Florida/Vermont
    2018 White Platinum CM
    LOL:rofl:
  3. Nov 18, 2019 at 12:26 PM
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    Here’s ours. Been happening off and on for about a year and a half maybe? I first noticed it on a significantly colder morning than usual at T2S 2018, so April 2018.
    it became more prominent when we moved to Ohio last winter and had much colder morning temps than in Phoenix.
    Sounds like lifter noise to me, but I’m open to speculation. Truck will be going to the dealer next week most likely. I’m traveling for work this week.
    https://youtu.be/2eGs9Aw1Ucw
    yoshi82 and Sunnier like this.
  4. Nov 18, 2019 at 12:28 PM
    KevinK
    Tundras to Sedona
    also notice how it will suddenly stop making the noise and start again. It’s also different sound from the passenger and driver sides.
  5. Nov 18, 2019 at 12:41 PM
    Sunnier
    Sunny
    San Diego, CA
    Sounds do weird things within a space. To me it sounds like probably the same source, something more drivers side than passenger, and the sound difference on the passenger side may be due to reverberation within the space. I’m sorry I haven’t a clue what the cause is, but maybe the guys who’ve chimed in already will do again. I sure hope an answer surfaces or that the few ideas on this thread narrow it down when you take it the dealer.
    JohnLakeman likes this.
  6. Nov 18, 2019 at 1:43 PM
    Warreng
    Warreng New Member
    I mentioned earlier my 02 chevy 4.8 had the same knocking sound when cold. I had done research at the time and there was tons of info about it. There was TSB’s regarding the issue and it seemed to be a very normal thing and not to worry. TSB’s cited piston and cylinder wall interaction. https://www.silveradosierra.com/vortec-5-3l-v8/knocking-noise-when-cold-t18979.html
    My 2013 does the knocking thing from time to time, 60k miles with a Supercharger. Dont think Im going to worry about it despite it sounding kinda concerning.
  7. Nov 18, 2019 at 2:22 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Agree with @Sunnier, noise source is on the driver side, and maybe "telegraphing" to the passenger side. Sounds like valve noise to me. As for it coming and going, it's hard to judge that from a video because if the camera is turned just slightly, the audio seems to go away. Coming and going would also indicate valve noise in my opinion; e.g. lifter rotates slightly in the bore, and it could be a whole new set of conditions for 20-30 seconds.
    Use a stethoscope and see if you can isolate a location. I doubt the dealer guys will be able to help you (give it a try)...unless...you want to spend a lot of money ($$$$). Again, I would experiment with different brands and grades of motor oil...I know it's a tired mantra, but the alternative could be very expensive and may not last a year. In the long run, the presence or absence of that noise will have very little impact on engine longevity in my opinion. It's a Toyota...quit worryin'. :D
    How many miles? Good maintenance history?
    Sunnier likes this.
  8. Nov 18, 2019 at 3:13 PM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    I cant tell for sure by listening to it on my phone, but on my old 08 I narrowed a noise just like that down to the vvti cam gears. It would happen after 3k on the oil and if it sat for longer than 6 hours and was below 40F.
    I was finally able to get it to go away by redlining it for a sec on my way home where it was going to sit all night.
    There are other toyota motors that have this same issue which how I found out about the redline(using vvti) trick. My scion had the vvti gears replaced on warranty for this same issue, but it had been doing it at any temp after sitting for 3 hours.
  9. Nov 19, 2019 at 6:17 AM
    JohnLakeman
    I like the sentiment that led to that discovery..."If I can't figure out how to fix this bastich, then I'll beat TELH out of it until it finally breaks for real!" :rofl:
  10. Nov 19, 2019 at 7:27 AM
    MT1794PRO
    MT1794PRO New Member
    Paul
    2014 MGM 1794 CM
    Debadge, Dechrome, TRD Pro Grille, 2018 Headlights, Amber Grill Lights, Carbon Wrapped Wood Trim, Pace Edwards Switchblade Tonneau....
    Mine is making the same intermittent sounds on cold idle. I also get a metallic thrap, thrap, thrap, on start up right after an oil change. My guess was timing chain tensioner failing.
    Let me know what you find out. I’ve struggled to get much traction with local mechanic due to being difficult to replicate.
  11. Nov 19, 2019 at 10:25 AM
    KevinK
    Tundras to Sedona
    Yeah I agree, I don't think there are two different noises, I think it's one noise that just sounds differently from side to side due to sound propagation through the engine and bay.I'll grab a stethoscope and try to isolate it. I used to do that years ago, but don't have any of my tools with me here since I don't have a garage to work on the truck in.
    We have a good relationship with our dealer and factory extended warranty, so I'll bring it to them next week. I just want to be able let them know what I've seen or heard so far.
    85k miles and religious maintenance record. We drive the truck hard, so we treat it well with fluid and filter changes regularly. We probably have 7 trips back and forth across the country non-stop where Lisa and I take turns driving, for 36-48 hours, only stopping for gas (constantly, LoL) and food/potty breaks. Plus all the abuse we put it through off road. We definitely buy Toyota for a reason. ;)
    Our only break/fix item was the starter after one of our drives from AZ to OH. The next morning the truck wouldn't start (25 degrees F), so we took it in (magically, it did start in the afternoon when it warmed up to the low 40s). The tech, who I'm not sure if he's still there or not, noted extended start, so he replaced the starter, flashed the ECU (persistent high alc% on ffv without E85 in the tank), and replaced the battery for some reason. We work with a different tech at that dealer now, who talks to us about his plans before doing stuff, and he asks us a lot of troubleshooting questions - great guy.
    Interestingly, and probably completely unrelated, our alc% reads 0% and has since he flashed our ECU. We should show _some_ amount of ethanol in the gas since it's added to all the stations here. Dunno what's up with that, but I assume we're running a tiny bit on the lean side as a result.
    TL;DR it's a Toyota, no worries. (but the sound is irritating ;) )
    Sunnier likes this.
  12. Dec 1, 2019 at 9:49 AM
    Bif
    Bif New Member
    Bif
    2014-1794 Edition
    Stock
    Well? so what happened with this? Was anything determined because I have the same problem with a 2014. My truck does this only cold and after a few minutes of idling it produces a knock. Not a loud knock but it is kind of a deep knock maybe like piston slap wrist pins is my best guess. It is not as loud as the truck in the video but it is bad enough to make me concerned! I'm running Mobil 1 0-20 and thinking of going to 10-30 maybe? Heck I don't know but one thing for sure I'm not taking it to the stealership we have the worst one in the nation >>> Northcut Toyota sorry sorry sorry no good %^$^%&(^&^*
  13. Dec 1, 2019 at 12:54 PM
    plumber802
    Andy
    Florida/Vermont
    I saw my son over Thanksgiving and asked him about the knock. He said it hasn't done it in a while. It would be a waste of time bringing the truck to the dealership unless the knock is present for a technician to hear and diagnose. Strange.
  14. Jan 1, 2020 at 10:40 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    My '16 is doing this, too, & definitely from driver side. I started noticing it for the first time recently when the weather started getting colder. Only when starting, and it's fine once warmed up.
    I've been using Mobil 1 0W-20 from Costco for the past 2 or 3 oil changes. Going to try Extended Performance next oil change as recommended above...see if that helps.
    Also gonna check exhaust manifold for leaks, too.
    plumber802[OP] likes this.
  15. Jan 2, 2020 at 4:17 AM
    patek
    patek New Member
    2019 trd sport
    possible fuel injector noisy but its fine
  16. Mar 4, 2020 at 11:12 AM
    Uhhhh....
    Dave
    7” BDS, 37s
    Update for those interested. Took mine into Toyota yesterday to have them take a look. They said it was coming from under the valve cover & definitely wasn't an exhaust manifold leak (though it does sound similar). They're going to replace all lifters and cam gears on driver's side & said it's covered under the powertrain warranty. Fingers crossed that it fixes the issue...and doesn't cause additional issues. The service manager said he's never seen this be the cause of the noise before. They have to order the parts & it'll be done next week. Stuck driving the go-kart till then ('03 Solara).
    Wynnded likes this.
  17. Aug 3, 2020 at 1:37 PM
    travis05
    travis05 New Member
    Tbock
    2015 Tundra Limited
    None
    Did that fix the issue? My 2015 sounds identical!
  18. Aug 3, 2020 at 1:43 PM
    travis05
    travis05 New Member
    Tbock
    2015 Tundra Limited
    None
  19. Aug 3, 2020 at 1:55 PM
    #49
    Uhhhh....
    Dave
    7” BDS, 37s
    Yes, that & a lot more. No more knocking since they fixed it in April.
    Here’s everything they did (all covered under powertrain):
    Their 1st attempt:
    - Replace all lifters and cam gears on driver's side.
    - Replace both timing chain tensioners & cam shaft pulley assembly.
    - Replace valve adjusters
    - Replace cylinder head gaskets
    - Replace valve arm sub assembly
    2nd attempt (still made the noise):
    - Replace the head on driver's side
    3rd attempt (noise on driver side gone - now noise on passenger side):
    - Replace the head on passenger’s side
    Fixed.
    Diagnosis: the valves weren't getting oil like they should to top of engine.
    It was a $12,000 warranty job billed to Toyota (would have cost me much more if it was a non-warranty job).
    It’s pretty much a rebuilt engine. Crazy.
  20. Aug 3, 2020 at 8:38 PM
    #50
    travis05
    travis05 New Member
    Tbock
    2015 Tundra Limited
    None
    Wow that’s impressive. Mine is going in this week. Last time I had it in they didn’t hear it. I’ve had a rough stretch here with mine. Recently had the 3rd member replaced in the diff and a rear wheel bearing. Now need to get this issue resolved. Appreciate the info!
    Uhhhh.... likes this.
  21. Aug 4, 2020 at 6:26 AM
    #51
    Uhhhh....
    Dave
    7” BDS, 37s
    No prob - good luck to ya. If it helps (and if it's the same issue), the sound only happens when the engine is started cold. Once warmed up, it goes away & you have to wait till it's cold again.
    Yeah I had my water pump seal go out shortly after this got fixed - replaced under powertrain, too. Very common for them to go - even at low mileage. They don't make anything like they used to - even Toyota. Cheap junk.
    Dubbled842 and KevinK like this.
  22. Aug 31, 2020 at 4:38 PM
    #52
    KevinK
    Tundras to Sedona
    Ours has been fixed.
    This was caused by a small leak in the timing chain tensioner on the driver side. Your dealer or other service tech can validate the cause on the driver side by observation through the oil filler location if they remove the filler tube and run the engine to see the tensioner action. This has to be done on a stone-cold engine. Letting it sit for a couple hours after running is not cold enough. Plan on dropping it off at the dealer the evening before, and have them pull the filler neck before starting it for the first time in the morning.
    The reason the sound comes and goes is due to fluctuations in oil pressure - higher pressure pushes the tensioner hard enough to prevent the chain slap (functioning as designed). As soon as oil pressure goes down a little bit, the tensioner allows slack in the chain guide and causes slap (the tick noise). Ours was covered under warranty for both sides: tensioners, chain guides, chains, and whatever else is in there. When they opened it up, they found cam tower leaks starting so they covered that as well as a coolant diverter leak in the valley of the engine with a slow weep.
    It was basically a top end rebuild.
    We opted to have them replace the water pump and radiator hoses on our dime while they were in there, at the cost of parts and a little water pump labor.
    Purrs like a kitten all over again.
    If you have this noise, take it to the dealer and ask them to observe the tensioner through the filler (neck removed) on a stone-cold start up. I may see if my tech is on the forum so he can post pictures and video of the repair. Here are a few he sent me.
    D04B83FE-853F-42FF-9AE3-7E5B10B05C01.jpg 325CE204-EF29-4922-88FE-6490571CE53E.jpg B5503BAE-480D-45C7-86FB-258145447270.jpg
    Sumo91 likes this.
  23. Sep 1, 2020 at 6:22 AM
    #53
    travis05
    travis05 New Member
    Tbock
    2015 Tundra Limited
    None
    I just got my truck back last week from the dealer after over 3 weeks in the shop for this. They replaced all the mentioned items and put it back together with the timing off and bent several valves which resulted In them taking it all back apart to put in new heads and valves. Also did the cam tower seals. I hope this thing is good to go for a while.
  24. Sep 1, 2020 at 9:41 AM
    #54
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    @KevinK do you know how they fixed the coolant diverter leak? That would be good info for someone who may have a leak they cant trace and this ends up being the culprit, and I'd like to know so I can fix it if it ever happens to my truck in the future.
  25. Sep 1, 2020 at 3:44 PM
    #55
    plumber802
    Andy
    Florida/Vermont
    Great info in this thread. I hope this doesn't become more widespread.
