2016 tundra - bad gas mileage
Discussion in '2.5 Gen Tundras (2014-2021)' started by sqa4life, Apr 27, 2016.
  1. Nov 4, 2017 at 3:56 PM
    #211
    silly
    silly New Member
    sam
    What you set your tire presure at then?
  2. Dec 11, 2018 at 3:45 PM
    #212
    wishiwasoutside
    wishiwasoutside New Member
    2011 Tundra Platinum 4WD
    New to the forum here and read this thread when my Platinum 4x4 went down with the 10.8 MPG malaise and solved the issue for $22.00. If you take your truck to a local oil change shop or local mechanic who uses non-oem air filters, you might have had an air filter installed that fits perfectly and looks just like a Toyota OEM air filter, but it isn't. The filter that was installed on my truck looked right but was different. When I held them both up to the light, the non-oem filter was opaque and very dense and the OEM filter was light and translucent (relatively speaking). If light won't go through it, air won't either. It was the equivalent of having an extremely dirty air filter installed. My gas mileage went right back up when I put the OEM filter on. If someone runs across this issue and an after market filter has been installed, it might be in their best interest to get a Toyota OEM filter.
    OR18TRD likes this.
  3. Dec 11, 2018 at 7:03 PM
    #213
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    Many many tanks down...33k miles. Have had the 6” PC and 35’s for almost 2 years.
    Hyper tech installed as well, with calibrated numbers. Still avg 18.1mpg.
    I’ll take that all day
  4. Dec 11, 2018 at 7:08 PM
    #214
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    18.1 mpg on 35s??o_O
    I think I will stay depressed for rest of my life now..
    JH5370 and Bear[QUOTED] like this.
  5. Dec 11, 2018 at 7:18 PM
    #215
    Bear
    Bear
    Custer, SD
    I drive ‘er nice and easy. Light to moderate accel, cruise control damn near always, psi at 48 empty. Long as I keep the crusing speeds under 65 its all good. Had some couple hour drives (back country roads, light traffic, varying terrain) where the trip avg was 20.9 and 21.2
    To turn that around and go tow 10k lb of trailer and equipment? And still get 10.1mpg. Pretty happy with the ol’ girl
    Mwray8909 likes this.
