2016 tundra - bad gas mileage
Discussion in '2.5 Gen Tundras (2014-2021)' started by sqa4life, Apr 27, 2016.
  1. Apr 27, 2016 at 5:53 PM
    sqa4life
    sqa4life [OP] New Member
    Hi all
    I am getting only 10.8 MPG average on my 2016 tundra DC 5.7L. Combined 50/50 local and freeway and I drive very gentle.
    Truck is stock. No lift and factory wheels/tires
    Truck only has approximately 1500 miles.
    Should I take it to the dealership to have it check out or wait until first oil change? That will be awhile until first oil change. I work from home so I don't drive much.
    Thanks.
  2. Apr 27, 2016 at 6:05 PM
    Bobgav
    Bobgav New Member
    2014 Tundra Crewmax
    I would reset the mpg and give it another try. That's really low.
    Do you let it idle alot?
  3. Apr 27, 2016 at 6:08 PM
    cfdfireman90
    cfdfireman90 New Member
    Cory
    Southern NH
    2015 Tundra Limited/TRD Double cab
    It will get better as it "breaks in" also.
  4. Apr 27, 2016 at 6:17 PM
    sqa4life
    I reset a few times, no help.
    No, I normally start driving within seconds after I started the engine.
  5. Apr 27, 2016 at 6:59 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I think it will improve a bit as you put on more miles.
    monaco730 and 040Tundra like this.
  6. Apr 27, 2016 at 7:09 PM
    jlee
    jlee New Member Vendor
    jerry
    Bay area CA
    2016 TRD Off Road on 35's supercharged and Kings and A 2002 SAS'ed supercharged Tacoma on 37's Linked front and rear
    Oh one or two.
    Have you calculated the milage yourself?
    waj30, Tracker and 15whtrd like this.
  7. Apr 27, 2016 at 7:18 PM
    Yep ^^
    And this^^
    Also, any long periods of idling?
    zcarpenter92 likes this.
  8. Apr 27, 2016 at 7:51 PM
    Wow, I got 10.3 mpg the last time I pulled my camper.
    There are several threads on here about what you can do to improve mpg.
    Tire pressure, fuel octane rating, alignment, is where I would start. Running 30 front/33 rear tire pressure as the factory recommends will straight up kill your fuel economy.
    15whtrd and T-Rex266 like this.
  9. Apr 27, 2016 at 7:55 PM
    I'm averaging now at 11.1 and I'm happy.
    jlee likes this.
  10. Apr 27, 2016 at 8:04 PM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    I don't trust digital read out, I always calculate my mpg when I fill up. I drive a stock 14 with 90% city driving with a light foot and am getting 15.2 to 15.8 mph. That's me dividing miles driven by gallons put in the tank.
    Jsena and waj30 like this.
  11. Apr 27, 2016 at 8:06 PM
    flynbyu2
    flynbyu2 I'm your huckleberry...
    NorCal
    2015 SR5 CrewMax 2WD
    Flowmaster Super 50 / Dual In - Dual Out Exhaust BakFlipG2 Tonneau Cover TRD Rear Sway Bar
    I drive my 5.7 with the "Mileage Nanny" bar graph showing on my display at all times. I always try to keep the bar above the middle mark which is 15 MPG. My truck is all stock except for a Flowmaster dual in/dual out muffler, however I was getting very similar numbers before I had the muffler installed. The last two fill-ups I've gotten 16.6 and 16.3 MPG with most of my driving on surface streets and an occasional jaunt on the freeway.
    The best mileage I see on the graph is between 45-55 mph, which conveniently is the average speed on our surface streets here.
    There are times when I flip back to the MPG setting and I'm averaging over 18 MPG! It's tough to drive like an old lady over an entire tank of gas, but it shows you that it is possible.
    I'm actually pretty happy with the mileage. My Tacoma 4.0L got 18 MPG no matter how I drove it; freeway, surface streets.....didn't matter.
    {EDIT} My SC is 2WD, so that makes a wee difference also.
    040Tundra and scurdyness like this.
  12. Apr 27, 2016 at 8:06 PM
    My 11.1 is hand averaged over the last 400+ miles. Mostly city. I'll be going on VACA soon. Mostly hiway. Should get 14 to 16 if lucky. (Not even remotely stock)
  13. Apr 27, 2016 at 8:21 PM
    1G3-TRD
    1G3-TRD New Member
    Aaron
    2014 double cab TRD off road
    I don't care about gas milage, if I did I wouldn't drive a truck or put heavy mud tires on it or an after market rear bumper that weighs over 100 lbs more than the stock bumper. But that's just me...
  14. Apr 27, 2016 at 8:33 PM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Make sure the units selected are in MPG and not the crazy metric units (Liters per kilometer, or some crap like that).
    If they are in MPG then I'd take it back to the dealer. My 2011 is in the shop right now and I have a 2016 Tundra rental and I'm averaging 18mpg and getting 20mpg easy on the highway.
  15. Apr 27, 2016 at 9:30 PM
    The rental has been broken in, I'm sure. His only has 1600 miles on it..
    monaco730 likes this.
  16. Apr 27, 2016 at 10:42 PM
    Nor7
    How many does it take to break in? My rental only has 9,700 miles on it.
  17. Apr 28, 2016 at 2:39 AM
    Ubc2361
    Ubc2361 New Member
    Tony
    Los Angeles
    Tundra crewmax 5.7 4x4
    My 15 crewmax has 6,000 miles and only getting 11.5 mpgs. I don't think it's going to get any better. Tundras arnt know for their fuel economy, sucks but I knew that going in so I can't complain much.
    Krezz likes this.
  18. Apr 28, 2016 at 6:36 AM
    I would say around 5k
    I'm around 17/18 mixed (not yet ready-calibrated).but I just got these tires on and haven't driven as much as usual this past week.
  19. Apr 28, 2016 at 7:40 AM
    tibadoe
    tibadoe New Member
    Joe
    Gladys
    2014 SR5 DC 4x4
    Dealer won't have a clue. May want to check tire air pressures and hand calculate your mileage. The computer is sometimes close and sometimes not.
  20. Apr 28, 2016 at 10:40 PM
    QSX15
    QSX15 New Member
    Oregon
    2016 Tundra 4X4 SR5 LB TRD
    Factory spray liner, bed rails, TRD sway bar, firestone airbags
    2016 DC longbed 4x4 5.7L
    Getting 15.5 average last 3 tanks just turned 2000 on odometer completly stock still
    Appears to get 18-20 below 65 mph on hwy 30 but 15 on I-5 at 75-80 mph
  21. Apr 29, 2016 at 8:46 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    It's discouraging getting worse fuel economy than what's advertised. In my last car I was getting 14 city/hwy when I lived in San Diego, I moved to Oregon and it improved to 18mpg, so it could be how crowded your city driving is with the more stop and go. Probably a long shot but maybe run a fuel treatment and engine treatment, something could be clogged. I've seen brand new vehicles be delivered with problems and had to order parts as soon as delivered.
  22. Apr 29, 2016 at 11:49 AM
    Ryan Mc.
    Ryan Mc. New Member
    Ryan
    Mission Viejo
    2015 Toyota Tundra SR5 Double Cab 5.7L
    Hand made bed divider, bed d-rings
    When I bought my Tun it came with 74 miles and was, at that time, running around 9 mpg. You got to admit when people take it for a test drive they stomp on the gas on fwy on ramps....I did when I drove it. Now as I continued to drive, yes the mpg really didnt change much. However over the course of several thousand miles it has. Mine just surpassed 11k, and what I have figured out is that once you reset the mpg it takes about 2k-3k miles to really find your average.
    You need to look at the amount of running time, and the activities, its been since resetting. If you reset it in a parking lot, then hit the fwy on ramp, then hit the streets and drag race all in a matter of minutes, your mpg will be low single digits. But if you wait, the average will show its true number. Just be patient my friend.
    My current MPG 14.4. Normal work week is 75% street, 25% fwy. No stop n' go traffic I might add.
    sqa4life[OP] likes this.
  23. Apr 29, 2016 at 1:22 PM
    Blacksmithdog
    Blacksmithdog New Member
    2016 4X4 Silver Crew
    My 16 Tundra 4X4 crew has about 1500 miles on it so far. In three fill-ups, the calculated MPG has been between 15 and 17.
  24. Apr 29, 2016 at 1:48 PM
    chphilo
    chphilo Tundra addict
    Western PA
    I think mixed mpg average is pretty much meaningless since there are too many variables especially if you do a lot of city driving. For instance, I live in a small city whose average block is only a few hundred feet. Added to that, there are either stop sign or a signal light every or every other block. I get city mpg that's substantially lower than 10 mpg. But that number is more of a indication of the driving condition than the truck.
    Perhaps a better item to compare is the highway mileage since it has fewer variables. What sort of highway mpg do you get?
    Black Wolf and sqa4life[OP] like this.
  25. Apr 29, 2016 at 6:44 PM
    sqa4life
    I calculated by hand :)
  26. Apr 29, 2016 at 6:48 PM
    sqa4life
    I think you hit the spot. There are a lot of traffic lights in the area where I live.
    However, I am hoping to get at least the advertised MPG after it broken in. after 5k miles?
  27. Apr 29, 2016 at 8:58 PM
    I'm just curious as to what car/truck of any make ever gets advertized MPGs??? Especially any 4X4 truck. Examples please?? Factual empirical data , not anecdotal opinions. (No junk science, just sayin....) By the way, FACT's always trump "truth". Ask any judge...........
    Note....pre "common core" math......Big truck with 5.7L that hasn't been improved since 2007 with not so great MPGs will still have in 2016..........let me guess.............not so great MPGs!! Discouraging??? Sheesh
    Definitely going to try to get a few more scratches on my truck this weekend. MPG's is the last thing I'm worried about. It's possible to spend a grand or more to gain pretty much nothing as far as better MPGs. It's all relative to driving habits and where you take your truck and your capabilities/experience. There is no real "factual" solution other than buying a Prius.
    Darth Tundra, 040Tundra and JAMES like this.
  28. Apr 29, 2016 at 9:42 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    I usually get better mpg than displayed on the dealer sticker so not as advertised. This is usually with me driving to get decent mpg. I took the Tundra (stock) on a road trip from OR down to SoCal and I was getting 17's cruising at 70-75 on the I-5. The best I've been able to get is 20.0 round trip, thats also with trying to get the best mpg's possible on the highway.
  29. Apr 29, 2016 at 9:47 PM
    sqa4life
    Do I see MPG somewhere in the specs?
  30. Apr 30, 2016 at 3:27 AM
    George14
    George14 New Member
    West Virginia
    2014 Tundra SR5 Dc TRD Off Road 5.7L with tow package
    None
    Mine is stock I get 14-17 mpg combined city and highway. Calculated by hand within 1 mpg got about 23000 miles on it
    too tall and Black Wolf like this.
