2016 tundra - bad gas mileage
Discussion in '2.5 Gen Tundras (2014-2021)' started by sqa4life, Apr 27, 2016.
  1. Jul 7, 2016 at 5:00 PM
    #61
    LTD15
    LTD15 New Member
    2015 Limited
    What should we be running our tire pressures at? I have a 2015 dblcab with 7500mi and my mpg says 12.7. I've never hand calculated it yet.
  2. Jul 7, 2016 at 5:54 PM
    #62
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    That depends on your tire/wheel combination. NOT what it says the max is on the side of your tires. It should be listed in the owners manual or the inside of the door.
  3. Jul 7, 2016 at 6:26 PM
    #63
    bigsapz
    bigsapz New Member
    Beast
  4. Jul 7, 2016 at 7:00 PM
    #64
    LTD15
    LTD15 New Member
    2015 Limited
    Hahah idc about the mpg that much. It just caught my attention when someone said setting factory 30/33psi will kill your mpg. Just wondering what it should be at if factory recommends kills our mpg?
  5. Jul 7, 2016 at 8:11 PM
    #65
    I would run 38 psi in all four tires if you have the factory P-Metric craptastic tires.
    zcarpenter92 likes this.
  6. Jul 8, 2016 at 5:17 AM
    #66
    LTD15
    LTD15 New Member
    2015 Limited
    Cool thanks I'll give that a try
  7. Jul 8, 2016 at 6:34 AM
    #67
    NJMIke
    NJMIke New Member
    2016 Tundra Double Cab SR5
    Rial cast wheels. Looking for TRD Pro grill with chrome surround
    I've also been running 38-40 psi. The Toyota dealer suggested it. My 1st & last 6 miles each day to & from work is a twisty road and I did notice the extra tire pressure reduces handling through the bends & curves in the road a little so, at best, it's a trade off I've accepted. My tires are the Michelin LTX/MS2. Over the last 9 months I've owned the truck, I've driven 21,590 miles at an average fuel cost of $1.75 and an average mpg of 18.2 (I use fuelly.com and they keep track of the stats). If I would get 2 mpg less with the lower tire pressure (that's probably stretching the gain) it would have only cost an additional $256 for the 21,590 miles or 1.2 cents per mile more. Unless you're really into squeezing the best mileage possible from your truck, it's not worth the performance drop. My Tundra is a commuter vehicle and I'm amused by getting better milage even though the savings is quite minimal.
  8. Jul 8, 2016 at 8:08 AM
    #68
    SuperSilverTundra
    SuperSilverTundra i didnt pull up i Landed
    Nick
    Los Angeles California
    16 TUNDRA 5.7 PLATINUM-PRO
    3"/1" TOYTEC 18x9 XD818 Heist 295/70r18 COOPER XLT DirtyDeeds BAMuffler 2018 LEDs KatzKin Leather S&B CAI
    i just hit 400 miles on my stock 2016 5.7 cm first 2 days I was at about 10.3 it keeps climbing up now one week later I am at 15.0 im happy with that coming from my 4.0 Tacoma I averaged about 16.0 mpg with lift and 33s intake/exhaust only loss of 1 or 2 mpg with all that extra power its well worth it although im sure once I put wheels and lift I should drop a few mpgs but wont mind :D
  9. Jul 14, 2016 at 3:51 PM
    #69
    bandit
    bandit New Member
    2011 Supercharged Mazzulla Long Travel Rock Warrior
    Duh Tundra
    I can only dream of these numbers you guys speak of.:help:
    Ancient1 likes this.
  10. Jul 19, 2016 at 7:45 PM
    #70
    astro-jason
    astro-jason New Member
    2022 CHEVROLET 3500 CC L/B Duramax 10spd
    Reset your average mpg after every fill up you will see a difference in mpg according to that average. Just remember everyone drives different! your easy may not be easy compared to someone else's
    -Jason
  11. Jul 19, 2016 at 7:50 PM
    #71
    frogger
    frogger just boost it
    Stephen
    Louisville Ky
    2008 S/C Tim Mica SR5 5.7L DC 4X4
    too much to list
    Mine has always been 12.6 has only dropped to 12.4 once lmao luckily it isn't as bad as it used to be. The days of filing up the tundy when it was over 4 phew
  12. Jul 19, 2016 at 9:47 PM
    #72
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    I sit around 13.2 with hand calculations but the mpg reading is 12.9
  13. Jul 20, 2016 at 7:21 AM
    #73
    NJMIke
    NJMIke New Member
    Noticed for the 1st 18-20 thousand miles the truck milage estimate was always over reported by up to .5 MPG. Now it usually under reports by as much a .3 MPH.
  14. Jul 20, 2016 at 9:17 AM
    #74
    TheBeast The Beach
    hand calculations: 15 mpg for today's fill up with 33" O/R tires. Only thing that sucks is the smaller gas tank on pre 2016 models.
  15. Jul 20, 2016 at 10:15 AM
    #75
    Nookster
    Nookster New Member
    Las Vegas
    2016 TRD SR5 4x4 White
    I have 2016 DC 5.7 4x4 that has 600 miles on it and my average is 13.5 so far. All my driving has been in town, stop light to stop light so far. Haven't done a pencil calculation yet.
  16. Jul 20, 2016 at 2:33 PM
    #76
    robie56
    robie56 New Member
    Steven
    New Hampshire
    2011 white cm rock warrior
    mbrp exhaust, afe dropin filter, stubby antenna, Readylift leveling kit, ICI magnum RT sidesteps, weather techs front & rear
    New truck, new engine, it takes 5000-15000 miles to break everything in, maybe more now that everyone uses synthetic oils, so I wouldnt judge your mileage just yet! Give it some time, it should improve some. And I would hand calculate my mileage each week, rather than rely on the trip computer
  17. Jul 21, 2016 at 3:58 AM
    #77
    BC.Austex
    BC.Austex New Member
    2014 Tundra Limited - Texas Edition
    My 2014 5.7 started out getting around 12.9, slowly increased to 15. When I baby it, I get 16 around town. Did a 2500 mile road trip last year, and barely eeked 21. I measured this myself, and now that I know. I can drive more realistically.
    dino112265 likes this.
  18. Aug 7, 2016 at 2:57 PM
    #78
    SOCO Tundra
    SOCO Tundra When do you stop being the FNG?
    bsr
    SOCO
    '16 SR5 TRD Off Road, DBL Cab, Super White
    Leer topper, MagnaFlow, TRD CAI, TRD Hvy skid plate, and I want less chrome!
    My '16 TRD Off, DC started off getting almost 21 at times. Pueblo to Gunnison (Monarch pass) to Clear Lake, Taylor Res, 4 HI at times and speeding to smooth out the ATV dirt chatter on the road, over Cottonwood to Buena Vista, back to Pueblo and it averaged almost 21. Now that includes some very long down hills from the passes. Put on my leer topper, and MF exhaust and it's hovering around 18, when it used to get almost 20. I don't hammer it as a norm, and try to use terrain to my best advantage...speed up on the down and easy on the up. I would think that guys in the flats would get great mileage with the cruise control.
  19. Aug 8, 2016 at 10:01 AM
    #79
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    I've been averaging 16.2 (hand calculated), and I drive in Houston rush hour every week day. Two things I recommend, 1) slow acceleration. I try not to bust 1500 rpm EVER...if I have people tailgating at a stop, I'll sometimes be nice and push it to 2000 rpms...but nothing over. You burn a lot of gas getting up to speed...I also figure less wear and tear on the engine/tranny over time. 2) drive the speed limit. yeah it's boring, but it really does save gas.
  20. Aug 9, 2016 at 9:06 PM
    #80
    Tundra280AI
    Tundra280AI New Member
    COS
    '17 Tacoma TRD OR
    My worst tank was 15.9 and best 21.7 and average 18.8. That's about 3/4 highway but did have a bit of city stop and go. Yes I try to be easy on the gas. Averaging 67 according to the truck from Boise to Salt Lake I averaged 20.5 (hand calculated) but admittedly was with a 15ish mph tailwind at least half the way. Truck always says about 1mpg better than hand calculating/phone app
    2cID likes this.
  21. Aug 9, 2016 at 9:58 PM
    #81
    Maddog94
    Maddog94 New Member
    2 thoughts.
    I'm getting 15 mpg combined
    And I've checked the mpg manually and the trucks readout has been spot on to withing a tenth of a mpg
  22. Aug 10, 2016 at 4:15 AM
    #82
    Island woody
    Island woody New Member
    Scott
    2016 crew max 4x4
    Lift kit, Borla exhaust, 35 inch tires
    11.6 here
  23. Aug 10, 2016 at 5:27 AM
    #83
    RussellVaughan
    Houston
    that's really good. you have the 4.6 or the 5.7?
  24. Aug 10, 2016 at 2:54 PM
    #84
    Tundra280AI
    COS
    '17 Tacoma TRD OR
    5.7 4x4
    Two more fill ups, not completely empty though.
    Salt Lake to Vernal, UT 19.7 claimed 18.80 actual
    Vernal to Colorado Springs 20.5 claimed 19.79 actual
    I don't use CC unless it's completely flat. Will get a run downhill to help it get up the next hill when in rolling hill areas. Cruise at 65 highway or 70 freeway and not much faster unless downhill. Will let the truck drop a gear and slow 2-3mph rather have have it drop down 2 gears going uphill. Seems to work.
  25. Aug 10, 2016 at 4:12 PM
    #85
    Island woody
    Scott
    2016 crew max 4x4
    5.7 but the 35 inch tires are hurting me the most, but I live on a little island and don't leave for the mainland often so mileage is low. Price of fun!
  26. Aug 10, 2016 at 8:54 PM
    #86
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    5.7 4x4 33" Coops can't get it over 13.3
  27. Aug 11, 2016 at 6:24 PM
    #87
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    :annoyed:So you are the guy going so slow holding up traffic just to save a few bucks. Seriously, 1500 rpm is LAME!
  28. Aug 12, 2016 at 6:23 AM
    #88
    LM_Tundra
    LM_Tundra New Member
    Richard
    Southern California
    Tundra 1794
    I get about 12.4 towing my Lance TT. It's very low.
  29. Aug 14, 2016 at 5:38 AM
    #89
    Lee's rig
    Lee's rig Party naked
    Lee
    North nj
    2014 DC and 2014 single cab both 8' bed with 5.7
    To many
    2014 sr 4x4 with 5.7 work tow package,. 3/2 lift with nitto trail grappler 295/70r18. System on ladder rack with parts inside. Average mpg in Bergen county nj mixed driving. 80% local 20% high way. I get 12.5 according to computer. The computer has not been recalibrated. My single cab has a 2 inch lift in front and stock tires. My employee gets 11.5 according to the computer. I told him to stop beating on the truck. Both are 2014 ,same set up , except for the cab and tires. I should add that it is very easy to get down to 10.5 if you have a heavy foot and brake late coming to lights instead of coasting to them. From reading most of the replies it comes down to how you drive. I did see some high numbers due to different vehicle set ups. My buddy has a 4.6 and can average 17 mixed driving
    Black Wolf likes this.
  30. Aug 14, 2016 at 8:11 AM
    #90
    bj46-taco-tundra
    bj46-taco-tundra New Member
    Mark
    Bj46 taco and now a tundra
    Just came back from our first camping trip pulling with my new 15 tundra.
    Our trailer is a 3340 lbs dry skyline Eco camp 20bh. I didn't put it on a scale before we left but I'd assume loaded it was 4000lbs
    We traveled just over 2300km through the mountains in British Columbia Canada (1400 miles) and averaged 10.8 mpg on the truck computer, but through my road trip app I was seeing 20.41 L per 100 km or 11.52 mpg.
    Wvmoonshiner, Black Wolf and aperezsh like this.
