2014-2021 Front/Rear Anytime Camera Mod - FRAC Harness
Discussion in 'Audio & Video' started by TundraTex, Jun 1, 2017.
  1. Jul 16, 2021 at 8:22 AM
    #1621
    okcowboy
    okcowboy New Member
    No Mans Land (Tulsa, OK)
    2021 Tundra 4x4 1794 Edition Wind Chill Pearl
    I looked at this but since it was unavailable, I chose the fuse tap route. It was super easy to stuff the cable into the edge of the headliner. One bolt to take the pillar cover off and run it down (careful to avoid the airbag stuff) and use two fuse taps to get anytime power (for park recording) and power with ignition for automatic camera startup with engine on.
  2. Jul 17, 2021 at 9:44 PM
    #1622
    AZTundra
    Paul
    Phoenix, AZ
    Anyone have a good recommendation for a front mount camera for a 2017 TRD Pro grille to use with the FRAC Harness? Thanks in advance.
    TundraTex[OP] likes this.
  3. Jul 18, 2021 at 7:42 AM
    #1623
    TundraTex
    TundraTex [OP] FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Natika is a pretty good option. They have at least three different configurations for mounting.
    AZTundra[QUOTED] likes this.
  4. Jul 18, 2021 at 9:06 AM
    #1624
    AZTundra
    Paul
    Phoenix, AZ
    Thanks Lou!
    TundraTex[QUOTED][OP] likes this.
  5. Aug 1, 2021 at 8:37 AM
    #1625
    Tundrafan23
    Tundrafan23 New Member
    What is the easiest way to mount the Natika camera to a Platinum honeycomb grille?
  6. Aug 1, 2021 at 8:39 AM
    #1626
    @COMiamiFan
  7. Aug 1, 2021 at 8:45 AM
    #1627
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    :notsure:
    Would it come up via the search bar? Guessing since I don't have this camera LOL
  8. Aug 1, 2021 at 9:56 AM
    #1628
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
  9. Aug 1, 2021 at 10:37 AM
    #1629
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Not sure about easiest, but this is not difficult. Search for @ElNopal 's post on how he did it. I modified his method for my 1794 grill. It makes for a sturdy support for the camera.
    ElNopal likes this.
  10. Aug 24, 2021 at 2:49 PM
    #1630
    Ajalmazan1
    Ajalmazan1 Actually likes chrome
    Lincoln, NE
    2016 DC Limited
    What switch is that for your cameras? Is that one you purchased separately? thanks
    Beesta and ElNopal[QUOTED] like this.
  11. Aug 24, 2021 at 4:39 PM
    #1631
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
  12. Sep 4, 2021 at 10:52 PM
    #1632
    SAGE63
    San Diego County
    Can the FRAC be wired into a switchpro sp9100?
  13. Sep 5, 2021 at 6:35 AM
    #1633
    3rdTundra
    Central Texas
    The instructions that came with my FRAC harness included a section "Optional FRAC Harness Installation with a Switch-Pro Panel Power System". Obviously, additional parts/wiring would be required.
    bulldog93, TundraTex[OP] and SAGE63 like this.
  14. Sep 5, 2021 at 9:44 AM
    #1634
    SAGE63
    San Diego County
    Thank you for the info...
  15. Sep 14, 2021 at 8:07 AM
    #1635
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    Has anyone installed multiple cameras with this system? I think I saw a reference to this but can’t find it again.
    For my application I “need” a camera that will allow me to check on my cargo and/or trailer. I “want” to also add a front camera because why not. So I’d have the factory backup camera, a front camera and a third camera that I’ll put somewhere tbd.
    thanks in advance for your ideas!
  16. Sep 14, 2021 at 8:10 AM
    #1636
    SchnauzerMan
    SchnauzerMan New Member
    Southern New Mexico
    2019 SR5 CM 4x4
    Sumo Struts, Tiger Steps, Bed Rug, Undercover Flex Hard Folding Tonneau Cover
    https://www.tundras.com/threads/wha...d-gen-tundra-today.713/page-2053#post-2353597
  17. Sep 14, 2021 at 8:25 AM
    #1637
    jeffw6236
    Jeff
    San Antonio
  18. Sep 14, 2021 at 8:29 AM
    #1638
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    2019 Pro Midnight Black Metallic
    I have the same one and it came with the kit
  19. Sep 14, 2021 at 8:30 AM
    #1639
    SchnauzerMan
    Southern New Mexico
    2019 SR5 CM 4x4
    No, but the wires all all labeled except for the most important one. The red wire from the longest rca (the one that plugs into the HU) is the reverse trigger for the HU. The other red wires supply power for the individual cameras, if needed. You can set it up to trigger off of backup and blinkers, or use it manually, as i do - just push the button for whatever camera you want, the press the middle button to turn it off when you are done.
  20. Sep 14, 2021 at 8:34 AM
    #1640
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    I like how you did yours, its centered. Mine is on the side. F44D686A-C698-46ED-91B6-D9A8B168655B.jpg
  21. Sep 14, 2021 at 7:23 PM
    #1641
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    This can easily be accomplished with the FRAC harness. By adding a video switcher in line with the FRAC rear camera input port you can use the switcher to select your active rear or alternate camera. Then all functions such as selecting reverse on your shifter or selecting the anytime rear cam function will display the selected camera video on your head unit. A lot of guys use this with an RV trailer to monitor blind spot traffic or assist with parking the trailer in a tight spot. You have lots of options.
    bulldog93 and jeffw6236[QUOTED] like this.
  22. Sep 24, 2021 at 9:34 AM
    #1642
    AZTundra
    Paul
    Phoenix, AZ
    This is not my picture (I copied it from another post), but does anyone know or has anyone tried mounting the two frac switches in this location? Curious if there is enough room to fit them here or not.
  23. Sep 24, 2021 at 10:14 AM
    #1643
    French Avocado
    Utah / Wyo
    Plenty of room. I am mounting mine there but using different switches.
  24. Sep 24, 2021 at 10:16 AM
    #1644
    Legend33
    Legend33 New Member
    Middlesex Massachusetts
    Is the wire long enough to reach that area? Planning to mount it there as well.
  25. Sep 24, 2021 at 10:46 AM
    #1645
    AZTundra
    Paul
    Phoenix, AZ
    Nice. I feel like that is the perfect placement for the switches. With your arm resting on the console lid you can easily just flip the switches by touch. I assumed that part of the console was hollow, just haven't taken it apart or looked at it to see how much room is in there for the depth of the switch. I plan to do the install next weekend.
  26. Sep 24, 2021 at 10:47 AM
    #1646
    AZTundra
    Paul
    Phoenix, AZ
    Not sure, I haven't started the install. I'd guess that the wires are not long enough to run there, but they can easily be extended.
    Legend33[QUOTED] likes this.
  27. Sep 24, 2021 at 11:05 AM
    #1647
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    The switch wires are 36 inches so they don't quite reach the center console, but as you said you can add extensions and they'll work just fine.
  28. Sep 24, 2021 at 11:15 AM
    #1648
    Legend33
    Legend33 New Member
    I don't know if it already asked, but what size is the wires? Thanks in advance
  29. Sep 24, 2021 at 11:25 AM
    #1649
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    The switch wires are 20 AWG.
  30. Sep 24, 2021 at 9:30 PM
    #1650
    French Avocado
    Utah / Wyo
    Have not yet got it done but easy to extend if they do not.
    EDIT - I see Lou responded. He is the expert and knows more than anybody.
    AZTundra likes this.
