2014-2021 Front/Rear Anytime Camera Mod - FRAC Harness
Discussion in 'Audio & Video' started by TundraTex, Jun 1, 2017.
  1. Apr 27, 2021 at 1:41 PM
    #1591
    nlaroy
    nlaroy New Member
    Nick
    So Cal
    2017 Inferno Crewmax
    LED bulbs, RCI Underwear, WKOR Sliders, Fox 2.5 w/ resi Front and back, Deaver leaf springs,
    @TundraTex Thanks for your product!!! Received it quick, installation was simple and straight forward! My Brother (Jeep Owner), was instantly Jealous, and was wanting this for his JK. Can't wait to use this on the trail this weekend!! Thanks! !
    TundraTex[OP] likes this.
  2. Apr 27, 2021 at 7:04 PM
    #1592
    TundraTex
    TundraTex [OP] FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Great report. Glad to hear the installation went smoothly. I love it when a plan comes together!
    nlaroy[QUOTED] likes this.
  3. Apr 29, 2021 at 7:21 AM
    #1593
    coTony
    Tony
    Montrose, CO
    Are there 4Runner forums that are good reference like this forum? Want to check out ideas and see where others have placed their cameras on the 4Runner
  4. Apr 29, 2021 at 7:35 AM
    #1594
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I had a 4runner before my tundra and that was my go to resource for information.....and their classifieds section usually has some pretty good deals too.
    okcowboy and coTony like this.
  5. Apr 29, 2021 at 10:55 AM
    #1595
    coTony
    Tony
    Montrose, CO
    Awesome! Much appreciated!
    shawn474[QUOTED] likes this.
  6. May 13, 2021 at 3:04 PM
    #1596
    SSPey
    SSPey .
    Oregon
    2021 DinoSR5
    Can the FRAC be changed so that a second rear camera replaces the front camera? I will be getting a bed canopy and ideally would like to mount a second rear-facing camera atop it, so my boat is visible while driving. I expect it is mostly a question of how to run wiring from the canopy to the bed (quick release?) and then underneath into the cab.
  7. May 13, 2021 at 4:15 PM
    #1597
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    @SSPey
    I don't see why not. The cameras that most of the FRAC harness users purchased are configurable for either front or rear use. The FRAC harness does not care. It just has two camera inputs: the OEM rear and whatever you connect to the other RCA connector.
    TundraTex[OP], mountainpete and SSPey like this.
  8. May 14, 2021 at 5:06 AM
    #1598
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    There are no limitations. I installed my "front" camera on the passenger side mirror to see cars better when towing my enclosed.
    As stated in the previous comment. Wire routing will be the only "Challenge"
    Extending the yellow co-axial and the 12V power should be the only differences.
  9. May 14, 2021 at 6:44 AM
    #1599
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Your biggest challenge might be finding a switch that says "Rear 1" and "Rear 2". :D
  10. May 15, 2021 at 7:55 PM
    #1600
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    The FRAC Harness is designed to provide a lot of flexibility in connecting cameras. It breaks out the Factory Tailcam video to an RCA connection as well as providing an RCA for a Front camera. If a second rear cam for a trailer is desired, the best way to do it is to connect the two rear cam inputs to a video switch then route the video switch output to the rear input of the FRAC Harness. Then you can select which one you want displayed when rear view is selected via the FRAC Cam select switch or by shifting into reverse.
    bulldog93 and SSPey[QUOTED] like this.
  11. May 16, 2021 at 9:48 PM
    #1601
    paulbk
    paulbk New Member
    How would one go about mounting the camera in this location?
    Are there any additonal pieces/hardware required?
    Thanks in advance!
    Beesta likes this.
  12. May 17, 2021 at 2:10 AM
    #1602
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    You should be able to screw it to the “fin” or horizontal plastic in between the, Y-O.
  13. May 17, 2021 at 1:38 PM
    #1603
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    There are 54 pages so I did not read them all so if my question has been asked Sorry.
    I don’t have the need for a front camera but would like the anytime rear.
    Does the original audio source continue to play when switched to the front camera input?
    I’d like to add a video source (streaming player) so was thinking of plugging the video into the FRAC front camera input and the audio to the Aux input.
    Would this setup work?
  14. May 17, 2021 at 8:21 PM
    #1604
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Yes, though I cannot guaranty the audio and video would be perfectly synced.
  15. May 18, 2021 at 3:42 AM
    #1605
    Black
    Bummer
  16. May 18, 2021 at 4:53 AM
    #1606
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    The FRAC Harness utilizes the same video mode that the OEM Camera uses. Audio will continue to play at all times just as it does if you shift into reverse and see the backup camera video. The volume control also continues to work. A number of my customers have used the FRAC Harness for this and nobody has reported any issues with it.
    French Avocado likes this.
  17. May 18, 2021 at 4:59 AM
    #1607
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I didn't mean to completely burst your bubble - I think it would be worth a try.
  18. Jun 4, 2021 at 7:33 PM
    #1608
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    @TundraTex or anyone else with experience - I know it is in the 54 pages of this thread but I cannot seem to find it. How do I use the Anytime switch for the cameras? I assume two wires are for the switch illumination and three are for the front/rear cameras with common ground but the Anytime switch has six wires. Thanks.
  19. Jun 4, 2021 at 8:01 PM
    #1609
    3rdTundra
    Central Texas
    Check these posts. The last one has pictures. The others are a more recent request and a reminder to clip the diode.
    https://www.tundras.com/threads/201...a-mod-frac-harness.13633/page-49#post-1840637
    https://www.tundras.com/threads/201...a-mod-frac-harness.13633/page-49#post-1840697
    https://www.tundras.com/threads/201...a-mod-frac-harness.13633/page-49#post-1840782
    https://www.tundras.com/threads/combining-frac2harness-with-anytimecamera-switch.59099/#post-1549576
    I do not have this switch myself.
    ToyoD and TundraTex[OP] like this.
  20. Jun 4, 2021 at 8:28 PM
    #1610
    French Avocado
    Utah / Wyo
    Thanks @3rdTundra. This is why I love this Forum - people helping people
  21. Jun 5, 2021 at 7:27 AM
    #1611
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Yes! This is the THE BEST Tundra Forum on the Planet!
  22. Jun 5, 2021 at 8:45 PM
    #1612
    French Avocado
    Utah / Wyo
    And to clarify, Anytime did not have the package marked or any instructions as to the wiring of the switch. Seeing the prior package was a major help. Thanks to @3rdTundra and I can't imagine why you do not have one yet! This makes garage parking much simpler!
  23. Jun 5, 2021 at 9:00 PM
    #1613
    3rdTundra
    Central Texas
    I have the FRAC harness and a front camera, I just used the switch provided with the harness instead of the Anytime switch
    https://www.tundras.com/threads/201...a-mod-frac-harness.13633/page-53#post-2210938
  24. Jul 15, 2021 at 8:02 PM
    #1614
    cohoch
    cohoch New Member
    My apologies if I missed any updates on a separate thread, but very interested in hearing from somebody who has already done this setup. It looks pretty straightforward, just a couple of questions:
    1) Would it make more sense to install the camera towards the top of the windshield rather than the grill if I'm more interested in using this soluion as a 'dash cam' rather than off-road driving assistance?
    2) Any recommendations for a decent quality mobile DVR that works well? The choices on Amazon are few with limited reviews - maybe due to the ongoing chip availability issues?
    Any feedback is appreciated!
  25. Jul 16, 2021 at 6:30 AM
    #1615
    3rdTundra
    Central Texas
    Most people who have mounted them high end up moving them lower. The cameras have such a wide field of view that mounting higher just gives more sky. You probably should get a camera that is adjustable rather than one that does not tilt.
    I used this one: https://www.amazon.com/dp/B07JCSYPPS?ie=UTF8
    This is another good choice: https://www.amazon.com/dp/B07HNRYHZ6
    Mine is located on the bumper here:
    Here is the image with the camera horizontal (poor image quality is a photo artifact. it is clear on screen):
    This is the DVR that most seem to have used in this one mounted in the glove box:
    https://www.amazon.com/dp/B00A0JMY8C
    Here are several useful posts:
    https://www.tundras.com/threads/201...a-mod-frac-harness.13633/page-48#post-1817031
    https://www.tundras.com/threads/201...a-mod-frac-harness.13633/page-48#post-1817397
    https://www.tundras.com/threads/201...a-mod-frac-harness.13633/page-48#post-1811413
    bulldog93, BLONGTX and TundraTex[OP] like this.
  26. Jul 16, 2021 at 6:49 AM
    #1616
    okcowboy
    okcowboy New Member
    No Mans Land (Tulsa, OK)
    2021 Tundra 4x4 1794 Edition Wind Chill Pearl
    If you are wanting a dash cam, I would just purchase that instead. It will be easier to install (no going through firewall) and has more functionality than the backup cams that most seem to be using on the front. I just installed this relatively inexpensive camera and am happy with it.
    VIOFO A119 V3
    https://smile.amazon.com/gp/product/B07SRQH4R7?ie=UTF8
    VIOFO HK3 ACC Hardwire Kit
    https://smile.amazon.com/gp/product/B07B984HJ5?ie=UTF8
    VIOFO 4pcs Circuit Fuse Tap (2)
    https://smile.amazon.com/gp/product/B07K866RPR?ie=UTF8
    Samsung PRO Endurance 128GB MicroSDXC memory card
    My off-roading does not require a front cam but I still highly recommend (and own 2 of) TunraTex's FRAC harness (and a front camera) for the parking assistance it provides.
    CGP likes this.
  27. Jul 16, 2021 at 7:47 AM
    #1617
    cohoch
    cohoch New Member
    Thanks for the quick feedback guys!
    @okcowboy I should have known this was the type of forum where somebody would help me realize my problem - I was mistakenly approaching this as an "either/or" solution rather than realizing I would end up "needing" both :)
  28. Jul 16, 2021 at 7:47 AM
    #1618
    3rdTundra
    Central Texas
    Good point. Here is a simple way to get power for the dashcam without tapping:
    https://www.dongartechnologies.com/product/12pin/
    For Tacoma, but also lists 17+ Tundra
    Used to be on Amazon, but says currently unavailable.
    https://www.amazon.com/dp/B07DMW3DML?ref=ppx_yo2_dt_b_product_details
  29. Jul 16, 2021 at 7:55 AM
    #1619
    GWill
    GWill gods gift to the internet
    Willis
    Don’t know what you’re talking about
    2020 MGM TRD Pro
    If going with the DVR option, does the DvR keep recording both cameras if you don’t have the cameras activated in your dash?
  30. Jul 16, 2021 at 8:05 AM
    #1620
    cohoch
    cohoch New Member
    @TundraTex explains this with the options very succinctly. I haven't come across any posts from somebody who actually installed the front cam and DVR connected directly to the battery with a switch yet...
    TundraTex[QUOTED][OP] likes this.
