2014-2021 Front/Rear Anytime Camera Mod - FRAC Harness
Discussion in 'Audio & Video' started by TundraTex, Jun 1, 2017.
  1. Jun 26, 2020 at 8:08 AM
    #1411
    57scottw
    57scottw New Member
    Hi, thanks for input. My camera is different than one in schematic you sent. Here is my “trigger” wire I don’t know what to do with...upload_2020-6-26_10-8-2.jpg
  2. Jun 26, 2020 at 8:31 AM
    #1412
    TundraTex
    TundraTex [OP] FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Scott. I called and left a message. Get back with me if you're still having camera issues. It's much easier to diagnose by voice than text.
    Based on your diagram. You should connect the FRAC power line to the Red "B" tigger wire then cap off the red wire on the red/black pair and connect the black wire to ground.
    Does the screen go black when you select the front cam? And does the rear cam work when you shift into reverse as well as when you select it on the FRAC switch?
    EDIT: The red wire in the red/black pair SHOULD be internally the same as the red wire at "B". But I would connect the "B" red wire to the FRAC power wire just to be safe. You should have 12 volts on both of those wires if one is connected to the FRAC Harness power line and the Head Unit is on.
    Thanks, Lou
    Tchase likes this.
  3. Jun 26, 2020 at 8:48 AM
    #1413
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    @Tchase once again proving how awesome the members are on this forum. Always looking to help others. :thumbsup::thumbsup:
    Tchase[QUOTED] likes this.
  4. Jun 26, 2020 at 4:17 PM
    #1414
    57scottw
    57scottw New Member
    Ummm... Gotta suggestion... Read instructions. My Pro is a 2020... new instructions.
    Thank you LG for the prompt and patient phone call. Yer a good guy and business owner...
    TundraTex[OP] likes this.
  5. Jun 27, 2020 at 9:05 AM
    #1415
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Happy to assist. I never like to hear someone is having difficulties with the installation, but I thoroughly test every FRAC Harness before it leaves the shop, so it's usually easy to solve. Great work on your installation, too!
  6. Jun 27, 2020 at 9:52 AM
    #1416
    freeflyer454
    freeflyer454 New Member
    2019 Quicksand Tundra SR5 4.6L
    I have the same camera. I have not installed it yet, but I did do a quick continuity test with a multimeter. I got tone with the red wire in the red/black pair and the "B" trigger wire - which it states underneath the diagram: "If your head unit without A trigger wire, then no need to use B trigger wire". So, I take it, that means either red wire could be used for the 12v power supply.
    Thanks for this awesome mod, Tex. Just got the notice my FRAC harness is shipping! Looking forward to installing it.
    TundraTex[QUOTED][OP] likes this.
  7. Jun 27, 2020 at 10:21 AM
    #1417
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    You are correct, Jason. Either Red wire may be connected to the FRAC Harness power lead for front camera power. Just make sure the other one is capped off since it will have 12 volts on it whenever the head unit has power.
    Welcome to Tundras.com! Glad you're officially a member now and honored that you chose the FRAC harness as your first mod!
  8. Jun 27, 2020 at 3:54 PM
    #1418
    57scottw
    57scottw New Member
    How do you watch video on DVR shown below?
  9. Jun 27, 2020 at 4:13 PM
    #1419
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    I haven't personally used this DVR, but others in the thread have. So my assumption is that you would select the camera position that is being recorded and activate the DVR playback function if you want to watch it on the Head Unit display. Otherwise, you remove the SD Ram card and play back the file of interest on your computer. I believe every power cycle creates a new AVI file.
    rothmigo and HulkSmurf14 like this.
  10. Jul 1, 2020 at 6:30 PM
    #1420
    102dalz
    102dalz New Member
    Andy
    2017 Tundra CrewMax White
    None
    Lou,
    Thanks for all your help with the FRAC & a Pyle video switching unit (needed 2 inputs for rear cams) install. I have to do this to carry motorcycles in the bed. Also helps when carrying bikes with a bed pad covering the OEM rear cam.
    I mounted a Pyle 4way video switch (PLVSPLT41)in the glovebox to allow a license plate camera for running tailgate down. This switch has a remote, but must have line of sight for it to work. So, I decided to mount it in the glovebox & run inputs/output wires there. FRAC included plenty of length, but made "splitter" for power wire to power front & 2nd rear cam. After 3 weeks, it's running perfectly & switches at the touch of a button (once glovebox is opened). It even allows viewing of multiple cameras at the same time via split screen (up to 4 ways).
    Running the front cable was more "fun" than the YouTube video showed, but once I took out the glovebox parts (again) it went smoothly.
    My wife (who drives the truck most) LOVES having the extra cameras for parking. Looking forward to adding a 3rd (& maybe 4th) rear cam for towing.
    For those looking at buying a FRAC...Lou is a totally class act & provides the best customer service ever!!!
    Stay safe brother...& go JSF.
    TundraTex[OP] and WAtundra4x4 like this.
  11. Jul 1, 2020 at 6:38 PM
    #1421
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    @102dalz Do you have pictures of: (a) the wire connections between the FRAC and the Pyle unit and (b) the Pyle unit install? We do love pictures here!
    Tchase likes this.
  12. Jul 1, 2020 at 6:45 PM
    #1422
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    And links
  13. Jul 1, 2020 at 6:46 PM
    #1423
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    Btw now that I’m spoiled with the front camera, the rear needs an upgrade. Has anyone found one on Amazon the is a direct fit replacement?
    rockmup likes this.
  14. Jul 1, 2020 at 6:53 PM
    #1424
    102dalz
    102dalz New Member
    Andy
    None
    Links to what? Do an Amazon search for Pyle video switch...I also used a Pyle license plate mounted camera (PLCM18BC), easy search for model numbers.
  15. Jul 1, 2020 at 7:13 PM
    #1425
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    The video switch, it’s just nice to know exactly where it came from when reading about it. I did a search and got several hits , cameras... and in google the switch came up with several models.
    I was just tacking on the request for pics with a link. But adding the model number was helpful for the camera so thanks :) lots of switches..
  16. Jul 1, 2020 at 7:28 PM
    #1426
    French Avocado
    Utah / Wyo
  17. Jul 1, 2020 at 8:04 PM
    #1427
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Happy to help, Andy. Glad everything is working to your satisfaction... And glad that your wife approves!
  18. Jul 2, 2020 at 10:50 AM
    #1428
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Lou, got a question about the mini dvr at the bottom of page, it comes with a 120v adapter to 12v dc. Did you just cut out the adapter part and wire the cord up to 12v car battery?
  19. Jul 2, 2020 at 3:01 PM
    #1429
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Yes. The "Wall wart" adapter that comes with it has a 12VDC output. So you can cut it and connect it to any 12V source. I recommend not connecting it directly to the battery, as it will always be on and could drain your battery over time. You can connect the DVR power lead in parallel with the Front Cam power lead from the FRAC harness to get a good ignition-switch 12 Volts. If you do this check your FRAC harness fuse value. If it has a 2-Amp fuse, I would replace it with a 3-amp. I started using 3 Amp fuses about 2 years ago to account for extra connections to the power lead.
  20. Jul 2, 2020 at 9:50 PM
    #1430
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Thanks
  21. Jul 7, 2020 at 2:10 PM
    #1431
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
  22. Jul 7, 2020 at 2:22 PM
    #1432
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    They provide BNC Plugs and BNC-RCA adapters (at least they did with a couple of these that I bought) and a power adapter with the DVR. You can cut off the wall wart and use the provided adapter to connect the 12VDC power or you can buy the 5.5mm power pigtails online.
  23. Jul 7, 2020 at 2:41 PM
    #1433
    rockmup
    rockmup New Member
    Todd
    Understood, the white ones are the RCA's not the yellow. Just for future reference
  24. Jul 7, 2020 at 4:21 PM
    #1434
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Yes, and for additional reference the white RCAs are for Audio recording. The Yellow connectors are BNCs and they are for Video. The DVR comes with BNC to RCA adapters that you can use to connect the yellow BNCs to the FRAC Harness RCAs.
  25. Jul 7, 2020 at 4:45 PM
    #1435
    rockmup
    rockmup New Member
    Todd
    Mine only came as pictured, I'll go find the correct adapters tomorrow.
    Thanks
  26. Jul 7, 2020 at 5:42 PM
    #1436
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
  27. Jul 23, 2020 at 10:29 AM
    #1437
    kwebre
    kwebre New Member
    2020 Blck Tundra
    4" pro comp suspension lift
    Lou, are you still using the round switches in the kit?
  28. Jul 23, 2020 at 11:37 AM
    #1438
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Yes. However I am working on developing some OEM-like switches. Those won’t be ready for a while though.
  29. Jul 23, 2020 at 12:03 PM
    #1439
    kwebre
    kwebre New Member
    2020 Blck Tundra
    Anyone have pics of switch mounting locations for the FRAC install. I dont have any open OEM slots and dont want to put the switches in a bad location.
  30. Jul 23, 2020 at 1:23 PM
    #1440
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Check out post #1 of this thread. A lot of guys are putting the switches in the “ledge” area above the USB port panel.
