FRAC Harness Experience, with Pictures/Measurements!
Discussion in 'General Tundra Discussion' started by 57scottw, Jun 27, 2020.
  1. Jun 27, 2020 at 8:45 AM
    57scottw
    57scottw [OP] New Member
    CAN ABSOLUTELY RECOMMEND FRAC BY LG TECHNOLOGY!!! I have a 2020 TRD PRO with 2 inches of lift, (not leveled as I like the raked/lower front end and slightly better mileage). Toyo AT open country extreme tires 295/70 18 at 45 psi. Running boards (not recommended for this truck) APS inboard 6” Aluminum Black... I think they look awesome and are functional for 5’ 3” wife. Extreme rear of running board is not supported. So, I installed a “No Step” decal, until I fab a rear support.upload_2020-6-27_10-24-29.jpg
    Camera wire placement below. At this location looks great. But camera bolt has no more than 1/2 of the nut threaded on it. BUT!!! A 13mm nut is WAY over kill to hold little camera.upload_2020-6-27_10-26-58.jpg
    Other threads talk about the poor camera to extension cable connection. See pic below showing connection made BUT alignment arrows are NOT aligned.upload_2020-6-27_10-34-27.jpg
    Next two photos show the TRUE alignment “V” shaped alignment slots inside female extension, then male camera connections.upload_2020-6-27_10-36-58.jpg
    upload_2020-6-27_10-37-28.jpgWire in sleeve and route indicated by blue tape...upload_2020-6-27_10-31-12.jpg
    Alignment set up. Tapes are 5’ long and in line with outside edges of truck. The top of the yellow balls are 20” elevation.upload_2020-6-27_10-38-56.jpgCamera view... yes, I did try at highest elevation on grill and you loose NO visual information mounting camera low.upload_2020-6-27_10-44-11.jpg
    The line is an easy to remember 18” from front bumper.upload_2020-6-27_10-44-30.jpg
    Gig em!!!
    TundraTex likes this.
  2. Jun 27, 2020 at 8:55 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Great looking install and write-up @57scottw. I'm liking the low-side camera installation.
  3. Jun 28, 2020 at 10:52 AM
    TR15UCK
    TR15UCK New Member
    2020 Cement Limited
    Can you link your FRAC harness?
  4. Jun 28, 2020 at 11:03 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
  5. Jun 28, 2020 at 12:21 PM
    BRP479
    BRP479 New Member
    Ricky
    Rogers,AR
    I just ordered the Phoenix Tesla style radio. Any idea if a FRAC is needed for it?
