2014-2021 Front/Rear Anytime Camera Mod - FRAC Harness
Discussion in 'Audio & Video' started by TundraTex, Jun 1, 2017.
  1. Oct 10, 2017 at 3:13 PM
    #631
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    :thumbsup: Good to hear.
  2. Oct 10, 2017 at 4:45 PM
    #632
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
  3. Oct 12, 2017 at 3:09 PM
    #633
    SapperTRDPro
    SapperTRDPro New Member
    2017 White Tundra TRD Pro
    N-Fab steps, LineX, Bakflip cover
    I am very interested in purchasing this but had a few questions. Does this plug an play also allow DVDs to be played on the factory head unit? I know the purpose is to switch between front and rear camera but was curious if this also allows DVDs to be played? Thanks in advance!
  4. Oct 12, 2017 at 4:26 PM
    #634
    TundraTex
    TundraTex [OP] FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Thanks for your interest and your question, @SapperTRDPro. The FRAC harness provides Front/Rear Anytime Cam selection and VIM enable for factory Nav functions while in motion. It does not provide for any AV functions.
    4x4_Angel likes this.
  5. Oct 12, 2017 at 4:43 PM
    #635
    SapperTRDPro
    This is exactly what I want to do, the FRAC harness as well has the AV mirroring at once and it looks like you have definitely considered selling this but if you don't mind me asking, what were some of the problems/reasons why you decided not to offer the AV feature?
  6. Oct 12, 2017 at 5:36 PM
    #636
    SapperTRDPro
    So I found your initial posting referring to the AV addition titled "
    COMPLETED!! 2016 CrewMax - FRAC-AV; Front/Rear Anytime Cams and Audio/Video"
    and from what it looks like, it looks like you stopped with the AV mod and solely focused on prefecting the FRAC system which many before have mentioned was a success. (Took a while to read thru all 22 pages but worth it) so i guess my question is, how do I add in the AV, I got the grasp of installing the FRAC but wasn't able to see your YouTube videos showing the FRAC-AV cuz they may have been deleted. Do you by chance sell this set up or would you suggest that I just buy the FRAC and then the lighting cable/HDMI cord/ converter and seeing how it goes into the FRAC? Sorry for all the questions, I just want to see if I can knock out two birds with one stone by buying your FRAC and still easily setting up the mirroring option.
    From the start of your thread, it looks way more simple than this video https://youtu.be/UH0yhrRWWOo which involves splicing factory wires and what not which I do not want to do, so maybe the mod you had going doesn't involve that.
  7. Oct 12, 2017 at 6:14 PM
    #637
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    As indicated, I did figure out the way to get AV mirroring working, and it was a lot simpler to install, than the video you referenced. It worked OK, although I wasn't happy with the HU display resolution. It also added a lot of extra build time and cost to the harness. So when I started building harnesses for sale, I decided that it was not something I wanted to include. I decided that If I'm going to watch something, I'll just view it directly from my iPad or phone and get a better picture.
    If AV is something you really want, there are solutions and methods available online as you found. However, the FRAC harness, as sold, does not include any AV capability or any provisions for connecting HDMI or lightning cables. I do not recommend or support modifying the FRAC harness for an AV function. If it is done, it's at your own risk.
  8. Oct 12, 2017 at 6:22 PM
    #638
    SapperTRDPro
    Thank you for your quick response, and that makes sense as to why you stopped that mod. And I totally agree and I won't be messing with the FRAC harness risking the chance of ruining it and or factory parts all for a mirroring option.
  9. Oct 13, 2017 at 2:03 PM
    #639
    SapperTRDPro
    I'd like to purchase one if you have the parts. I sent you an email with the information you requested. Hopefully you received it, if not let me know and I'll resend it! Thanks
  10. Oct 13, 2017 at 4:20 PM
    #640
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    @SapperTRDPro, Got your order and everything is good. I'll be shipping yours out tomorrow morning with a few others.
  11. Oct 13, 2017 at 6:09 PM
    #641
    TRD_femi
    TRD_femi New Member
    2015 TRD Pro
    I hope mine is one of them!!
  12. Oct 13, 2017 at 7:15 PM
    #642
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    As a matter of fact, there is one with your name on it.
  13. Oct 13, 2017 at 7:31 PM
    #643
    TRD_femi
    TRD_femi New Member
    2015 TRD Pro
    Thanks.
    Looking fwd to installing that gizmo!
  14. Oct 15, 2017 at 4:11 PM
    #644
    TRON
    TRON Is LIVE on the GRID.
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    @TundraTex or anyone running this kit, I'm currently about to button everything up, all connections are complete and all I have left is to Mount the camera in a permanent spot.
    Question is, right now my camera selection switch seems to be the only thing working/turning on each camera or back to the home screen when switched to the middle. Now this is perfect and working as expected but what exactly does the VIM switch do? Is this switch only going to factor in when the truck starts to move down the road? I put the truck in reverse the rear works fine, and while in drive I can switch to either camera just fine, but all while the VIM switch doesn't seem to change anything.
    Probably thinking way too hard about this but thanks for any help:thumbsup:
  15. Oct 15, 2017 at 4:32 PM
    #645
    Cfincke
    San Antonio
    Easiest way to check if the VIM is working is to go to maps and try to input a destination or address while driving. If it is greyed out, flip the switch, mine has about a 2 second delay, then the destination input becomes available. You will also be able to access menu settings that typically require the truck to be stationary
  16. Oct 15, 2017 at 4:36 PM
    #646
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    The VIM (vehicle in motion) don't have nothing to do with cameras but it will help to deactivate the security future that won't let you do anything or limited use of the head unit while your vehicle is moving, for example if you are in the road you can't input any address in your GPS until your vehicle is stopped, some apps like Pandora or iheartradio are limited to use too, but the VIM switch give you full access to the headunit while your truck is moving
    TRON[QUOTED], Spook46 and 4x4_Angel like this.
  17. Oct 15, 2017 at 4:46 PM
    #647
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    This! And it's awesome!!! Mine is always on!
    Spook46 and iHacker[QUOTED] like this.
  18. Oct 15, 2017 at 4:55 PM
    #648
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    I finished the install this morning and this kicks ass.
    TundraTex[OP] and 4x4_Angel like this.
  19. Oct 15, 2017 at 4:57 PM
    #649
    4x4_Angel
    Bree
    Funky Town, Texas
    Right? I love it! Though I haven't been able to do many mods yet....out of all the ones I have done...this one is my favorite!
  20. Oct 15, 2017 at 5:07 PM
    #650
    Ely010606
    SPARKS, NV
    Same here, I totally agree. I took my kids for a ride to show off, lol and they loved it more than I do.
    4x4_Angel[QUOTED] likes this.
  21. Oct 15, 2017 at 5:24 PM
    #651
    TRON
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    Right on!! Thanks gents I knew I was overthinking it haha. Love this mod and thanks again @TundraTex :cheers:
  22. Oct 15, 2017 at 8:36 PM
    #652
    Tundra Fan
    Toby
    I thought if it was left on it didn't update your location on the map screen.
  23. Oct 15, 2017 at 8:38 PM
    #653
    4x4_Angel
    Bree
    Funky Town, Texas
    Mine does
  24. Oct 15, 2017 at 8:44 PM
    #654
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    FRAC users helping FRAC users. Now THAT's what I'm talking about!
    You guys are awesome!
    TundraTex
  25. Oct 15, 2017 at 8:45 PM
    #655
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Glad to hear it, @Ely010606!
  26. Oct 16, 2017 at 9:43 AM
    #656
    MMichaelJJ
    MMichaelJJ New Member
    14 Platinum CM
    I already have mine through, but I’m curious about the connectors. Are those just the ends and require soldering to reattach? When I search “phono connector” i get images of standard RCA ends and some that look a little different (non soldering)
    Tacogrande likes this.
  27. Oct 16, 2017 at 9:45 AM
    #657
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    I have the camera that runs the power along the phono cable, so there are 3 wires... signal (+), signal (-) and 12v (+) In the end, since mine had a disconnect plug at the camera end, I just cit the wire, passed it through the firewall, soldered it back together and used heat shrink...
  28. Oct 16, 2017 at 9:46 AM
    #658
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Wait, so you can just leave it on all the time? @TundraTex, what's the point of having a switch then?
  29. Oct 16, 2017 at 9:49 AM
    #659
    4x4_Angel
    Bree
    Funky Town, Texas
    I do.....but mostly because i forget to switch it off. I'm usually going 10000mph through life being a single mom
    joonbug[QUOTED] and iHacker like this.
  30. Oct 16, 2017 at 11:07 AM
    #660
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I understand it can be left on all the time, and I'm sure I'm going to forget and leave it on a few times, but like @Tundra Fan stated, the reason for the switch is because when it's left on, the truck thinks it's not moving and supposedly won't update the map. But if what you're saying is true that the map does update, I would just leave the switch on and not even mount it... maybe just stuff it behind the radio. Does anyone know if there are any drawbacks to just leaving the switch on? @TundraTex?
