2013 Sequoia Limited to TRD FAUX build now with BOOST!
Discussion in 'Sequoia Builds' started by e30cabrio, Apr 19, 2021.
  1. Mar 11, 2024 at 12:37 PM
    #1351
    e30cabrio
    e30cabrio [OP] I'm e30cabrio, I'm a modaholic
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
  2. Mar 13, 2024 at 8:39 AM
    #1352
    farnsrocket
    farnsrocket New Member
    Sounds sinister.....we need to see some highway runs!!!!!!!
    e30cabrio[OP] likes this.
  3. Mar 22, 2024 at 4:56 PM
    #1353
    e30cabrio
    M3Tundra-JK likes this.
  4. Mar 23, 2024 at 8:32 PM
    #1354
    e30cabrio
  5. Mar 27, 2024 at 8:16 PM
    #1355
    e30cabrio
    This happened today.
    M3Tundra-JK and armyoffoo like this.
  6. Mar 27, 2024 at 8:37 PM
    #1356
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    How's she runnin?
  7. Mar 27, 2024 at 8:41 PM
    #1357
    e30cabrio
    Great, 400 miles more before the oil change & I can really find out, that was less than 5k RPMs.
    armyoffoo likes this.
  8. Mar 28, 2024 at 1:06 PM
    #1358
    e30cabrio
  9. Mar 29, 2024 at 3:12 PM
    #1359
    e30cabrio
    Drove the BMW a bit over 40 miles round trip on the freeway. It's a freaking blast!
  10. Mar 30, 2024 at 11:05 AM
    #1360
    e30cabrio
    The bung is in!
    AZTundra likes this.
  11. Mar 31, 2024 at 7:41 AM
    #1361
    e30cabrio
    Car running just in time for over 85 temps & of course it is raining!
    0&I washed the Sequoia yesterday wheeeeeeee
    It is huge, tall & a pita to wash.
  12. Apr 2, 2024 at 9:51 AM
    #1362
    e30cabrio
    Meanwhile back at the Tree.....
    Last Saturday I went to replace my spark plugs, the first plug I pulled front of the engine, driver side had a huge amount of oil in it.
    Auto Nation Tempe, did the Cam Tower repair 4/6/23. I called to make an appointment to get it fixed under their 12 month, 12k warranty, (it is under 7k miles) they hemmed & hawed about paying for a loaner. I said the spark plug tubes were not leaking when I gave it to them ergo they messed it up.
    The manager called back, said I have to get it in by Saturday, there is no "grandfathering" from making the appointment last month. I said I have an appointment Saturday, now I have to change my alignment appointment Saturday at 9am to bring this in at 7am.
    Wheee!
  13. Apr 2, 2024 at 12:25 PM
    #1363
    e30cabrio
    The sensor for the AFR/boost gauge is defective. Reads 22.4 when revved and 7.4 at idle.
    Searched forums, found it's a known issue if the gauge does not like the ground.
    Opened the pita to open center console ran the ground to a bolt holding the gas pedal assy on the car, no change. As I bought the PSB1 direct, called Innovate. After some drama, they are sending another O2 sensor.
    I have one I bought for the Sequoia that disappeared, searched and searched, then it occurred to me I put the new one in the box the gauge came in.
    Mystery solved!
  14. Apr 2, 2024 at 7:13 PM
    #1364
    e30cabrio
  15. Apr 2, 2024 at 8:41 PM
    #1365
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I hope that's wrong...What does the stock sensor say?
  16. Apr 3, 2024 at 8:19 AM
    #1366
    e30cabrio
    Don't know, there have been O2 error codes so I ordered 2 new ones, Rock Auto sent the wrong ones, waiting for new ones Friday.
  17. Apr 5, 2024 at 7:33 PM
    #1367
    e30cabrio
    The M master cylinder & master vac came with a check valve, I put the valve in, brakes are back. New valve is coming tomorrow.
  18. Apr 6, 2024 at 8:58 AM
    #1368
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Well, you're making me want to put some mods into the M3! I have an oil leak to sort out once it finally gets down to Dallas. And I need to find a good BMW shop around here
  19. Apr 6, 2024 at 11:49 AM
    #1369
    e30cabrio
    Took the Tree to Toyota, I get they have to verify themselves but (A) who makes up a spark plug tube full of oil & (B) who opens a valve cover to damage the gasket?
    They determined it needs to be replaced & gave me a '24 Highlander loaner. (last year it was a '23 Tacoma)
    On the way home I called Firestone. They got me in, I dropped the Z off on the way to the airport to drop my Daughter and it was ready when I got home.
    It feels amazing!
    BiggHertz and M3Tundra-JK like this.
  20. Apr 8, 2024 at 1:30 PM
    #1370
    e30cabrio
    Got a text from Toyota, bad picture of some dirt under the passenger side valve cover, message says valve cover leak/from the advisor. I call to ask is that the passenger side & am told she is off. I asked to speak to someone else & am dumped into her VM.
    Another reason I hate taking my car for service.
  21. Apr 8, 2024 at 1:37 PM
    #1371
    e30cabrio
    I got 20mm spacers for the rear & moved the 15mm to the front.
  22. Apr 9, 2024 at 9:46 AM
    #1372
    e30cabrio
    Autonation Tempe are thieves, they say the Valve cover gasket on the passenger side is bad as is the front passenger LCA, they did the driver LCA last year, I did not think it made sense not doing both then (they did not do them last year) Makes no sense in under 6k miles they magically went bad. They want 2k to do both, I ordered the gaskets for 40 & am looking for the LCA.
  23. Apr 9, 2024 at 11:52 AM
    #1373
    e30cabrio
    Ordered the control arm from Serra Toyota. 290.08 shipped, no tax, free shipping.
    Watched this video:
    https://youtu.be/oUpTxegQ89Y?feature=shared
    How is that 1200+ in labor???
    Hardest part is taking off the tire, even on that totally rusted suspension.
  24. Apr 11, 2024 at 8:37 AM
    #1374
    e30cabrio
    Felt a bit more in back was warranted, got 25mm, it's perfect!
    Sitting a bit high as it has not been moved since jacking it up.
  25. Apr 11, 2024 at 4:57 PM
    #1375
    e30cabrio
  26. Apr 12, 2024 at 8:09 PM
    #1376
    e30cabrio
  27. Apr 13, 2024 at 6:51 AM
    #1377
    e30cabrio
    First oil change, magnetic drain plug did a good job, surprisingly clean considering it's a new motor.
    I know it is a waste but sending a sample to Blackstone.
  28. Apr 13, 2024 at 9:47 AM
    #1378
    e30cabrio
    Motor is "done" all is well & it is amazing!
    AZTundra and M3Tundra-JK like this.
  29. Apr 13, 2024 at 1:43 PM
    #1379
    e30cabrio
    First real wash in months.
    Black@Blue19 and SnrDisregardo like this.
  30. Apr 15, 2024 at 11:07 AM
    #1380
    M3Tundra-JK
    Scott
    2005 GX470
    looks amazing!
    e30cabrio[QUOTED][OP] likes this.
