2013 Sequoia Limited to TRD FAUX build now with BOOST!
Discussion in 'Sequoia Builds' started by e30cabrio, Apr 19, 2021.
  1. Feb 12, 2024 at 7:07 PM
    #1321
    e30cabrio
    e30cabrio [OP] I'm e30cabrio, I'm a modaholic
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
  2. Feb 13, 2024 at 6:31 PM
    #1322
    e30cabrio
    I need to do all the fluids and am doing the rear subframe bushings which requires removal of the rear end and brakes, I have to bleed the hydraulic system including the clutch slave so that's next. The rear shocks and springs will go in when it goes back together.
    Also. Mock up....
  3. Feb 13, 2024 at 6:40 PM
    #1323
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    Looking good!
    e30cabrio[OP] likes this.
  4. Feb 16, 2024 at 6:10 AM
    #1324
    e30cabrio
    Subframe out, nightmare is too small a word.
    Spring comparo.
    Also, fluids.
    Black@Blue19 likes this.
  5. Feb 16, 2024 at 3:28 PM
    #1325
    e30cabrio
    It runs! The DME needs to learn so it needs to warm up, & it's open headers so sounds like a P51 (which is pretty cool actually)
    Finally found blanks that fit the M console.
  6. Feb 17, 2024 at 11:24 AM
    #1326
    e30cabrio
    I paid 93 to get the differential seals TODAY. Wanted to finish and drive tomorrow. I'll be demanding my money back for the shipping.
  7. Feb 19, 2024 at 8:02 AM
    #1327
    e30cabrio
    Spoke to Bimmerworld, refund incoming. Thier CS is amazing!
    Black@Blue19 and M3Tundra-JK like this.
  8. Feb 19, 2024 at 4:52 PM
    #1328
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Fcp Euro is another great site. People have reported being able to return old oil to them for a refund! Lol
    e30cabrio[OP] and Black@Blue19 like this.
  9. Feb 19, 2024 at 6:04 PM
    #1329
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    DANG!!!!!!!!!!!!!!!!!:) :) :) manoman that is one heck of a setup!! Love the headers! Those are secure!! They look amazing!
    Hope we get to hear that! Unplugged :eek2:and plugged!:) Neighbor has a M6 he even wants to hear that beast!! Nice very nice indeed!
    e30cabrio[OP] and M3Tundra-JK like this.
  10. Feb 19, 2024 at 10:18 PM
    #1330
    M3Tundra-JK
    Scott
    2005 GX470
  11. Feb 20, 2024 at 5:49 AM
    #1331
    e30cabrio
    I have a SS & like it alot.
    Thanks, I need to replace the belt but will get a video of it unocorked.
    This happened.
    M3Tundra-JK likes this.
  12. Feb 20, 2024 at 4:12 PM
    #1332
    e30cabrio
    armyoffoo likes this.
  13. Feb 20, 2024 at 8:08 PM
    #1333
    M3Tundra-JK
    Scott
    2005 GX470
    Startup sounds great! When my Tundra was Starting but not maintaining idle, it was a bad fuel pump. Fingers crossed the tuner see something
  14. Feb 20, 2024 at 8:44 PM
    #1334
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Sounds great, good job getting it all back together! It doesn't sound like it's stumbling or anything...does it run for the same amount of time if you restart it? Seems like a sensor calibration/pairing issue or maybe some kind of anti-theft.
  15. Feb 21, 2024 at 7:09 AM
    #1335
    e30cabrio
    Yup, every time. I can keep it running with the gas pedal. No codes. It has no driver side suspension, driveshaft is not connected clutch & brakes need to be bled (once the driver side caliper is connected) etc so not like I'm not driving it due to this.
  16. Feb 21, 2024 at 7:14 AM
    #1336
    armyoffoo
    armyoffoo Member
    Cypress, TX
    If you can keep it running with throttle it's an air/fuel issue and your tuner can sort it out. Sounds like you're almost there!
  17. Feb 23, 2024 at 11:29 AM
    #1337
    e30cabrio
    27 year old MAFis the issue, verified by removing it & it idles. I had a cheap Amazon on hand & it runs fine. Ordered a new OEM.
    M3Tundra-JK and farnsrocket like this.
  18. Feb 25, 2024 at 6:45 AM
    #1338
    e30cabrio
    99% there! Should be driving today!
    I just put in the trans & differential fluids, all that's left is running the hoses from the PS pump/cooler to the reservoir & adding fluid. Taking a break & then I'm dropping it off the jackstands & going for a ride.
    https://jmp.sh/G3LKAL7z
    PolishedTRD and M3Tundra-JK like this.
  19. Feb 25, 2024 at 11:55 AM
    #1339
    e30cabrio
    It runs! Feels great!
    farnsrocket and M3Tundra-JK like this.
  20. Feb 26, 2024 at 7:13 PM
    #1340
    e30cabrio
    15mm spacer in. Except losing the short stud lock, I like it.
    armyoffoo and M3Tundra-JK like this.
  21. Feb 28, 2024 at 7:02 AM
    #1341
    e30cabrio
    Belt broke, took the AC belt out. New tensioner that came with the SC froze.
    Took all the other pulleys with it. The PS has chips. Water pump has a large crack.
    I ordered all aluminum pulleys.
    Before this happened I installed a big bore TB.
  22. Feb 28, 2024 at 7:27 PM
    #1342
    M3Tundra-JK
    Scott
    2005 GX470
    Too much belt tension, or just low quality pulley? The aluminum should do the trick though!
  23. Feb 28, 2024 at 7:34 PM
    #1343
    e30cabrio
    I think the pulley was defective.
  24. Mar 2, 2024 at 11:30 AM
    #1344
    e30cabrio
    Been wrestling the belt for 2 days.
  25. Mar 4, 2024 at 11:42 AM
    #1345
    e30cabrio
    So, thanks to the difference in the S54 oil cooler housing & M52, the power steering pump mount is different & the alignment is off so the belts don't run properly.
    The accident had nothing to do with the bungy, it was a pry bar to the radiator.
  26. Mar 4, 2024 at 4:59 PM
    #1346
    e30cabrio
    Oops, left out I ordered an S54 power steering pump lol
  27. Mar 6, 2024 at 3:47 PM
    #1347
    e30cabrio
  28. Mar 8, 2024 at 4:45 PM
    #1348
    e30cabrio
    Soooo the S54 hose is totally different & cannot fit. I called a hose repair place 32 miles away, they insisted they can swap the banjo the S54 pump needs to my hose, I drove there & (A) the woman at the counter acted like I was making up the call, the guy I spoke to came out and said oh sorry no.
    WTF????
    I went the the hole in the wall shop I found for the Sequoia & they did it in an hour, getting it in is an adventure, I'll start over tomorrow.
  29. Mar 10, 2024 at 7:34 AM
    #1349
    e30cabrio
    Got everything together, damn pump is defective (noisy) but works, took a drive, the car is pretty awesome!!!
    Ordered a reman ZF, supposed to come in Wednesday.
  30. Mar 10, 2024 at 9:04 AM
    #1350
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Perseverance pays off, way to go man! That was like one gut punch after another, good work seeing it through!
