2013 Sequoia Limited to TRD FAUX build now with BOOST!
Discussion in 'Sequoia Builds' started by e30cabrio, Apr 19, 2021.
  1. Jan 6, 2024 at 6:59 PM
    #1261
    e30cabrio
    e30cabrio [OP] I'm e30cabrio, I'm a modaholic
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Comes with the territory.
    Thanks
  2. Jan 6, 2024 at 7:02 PM
    #1262
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    Damn, that was fast! My Condolences, hopefully the damage is only limited to the piston...maybe rings or ringlands and the block/crank are still good. Was this still 5.5PSI? Was it tuned for the SC, or still running stock tune?
  3. Jan 6, 2024 at 7:13 PM
    #1263
    e30cabrio
    It has a basic SC tune, I need to get logs to the tuner.
    The BMW world consensus is the issue is a valve or valve stem seal.
    M3Tundra-JK and armyoffoo like this.
  4. Jan 6, 2024 at 7:15 PM
    #1264
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Fingers crossed it's just a seal and you can do it with the head on.
    e30cabrio[OP] likes this.
  5. Jan 7, 2024 at 1:08 PM
    #1265
    e30cabrio
    Another oddity, no blue smoke until temp is at 1/4.
    Here are the plugs. (in for under 300 miles).
  6. Jan 12, 2024 at 2:56 PM
    #1266
    e30cabrio
    Just began trying to do the leak down test yesterday & my 12 year old compressor died.
    Picked this up today.
    Tucked away.
    AZTundra and M3Tundra-JK like this.
  7. Jan 13, 2024 at 2:17 PM
    #1267
    e30cabrio
    It's official, motor is toast. I'm soooo thrilled.
    Extraction has begun, I'll disassemble it once it is out.
  8. Jan 13, 2024 at 3:23 PM
    #1268
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Well shit, that sucks man...what was the diagnosis of the leak down? Rings?
  9. Jan 13, 2024 at 3:24 PM
    #1269
    e30cabrio
    Starts off awful and drops in real time. Oddly it has excellent power but smokes worse than James Bonds car in Goldfinger
    M3Tundra-JK and farnsrocket like this.
  10. Jan 13, 2024 at 3:32 PM
    #1270
    farnsrocket
    farnsrocket New Member
    Damn! Are you gonna rebuild? Can you get a used motor reasonably priced??
  11. Jan 13, 2024 at 3:35 PM
    #1271
    e30cabrio
    If it is rebuildable I'll rebuild. I have been offered a 99 328 motor, only difference is iron vs mine is an aluminum block.
    Here's the bores...
    I have a cheap boroscope, pictures suck.
    lol
  12. Jan 13, 2024 at 3:39 PM
    #1272
    farnsrocket
    Put an M5 motor in it!!! :D
    M3Tundra-JK and e30cabrio[OP] like this.
  13. Jan 13, 2024 at 3:59 PM
    #1273
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Are the bores scratched? Are those pictures all from the same cylinder? Hard to tell what I'm looking at here, but I've never been good with borescopes. The cross hatch still looks good, no excessive wear that I can see, maybe you got lucky and damage is minimal. If the block, head and crank can be saved, get forged pistons/rods, new bearings, ARP head studs and a quality MLS head gasket. That'll do you for some better boost times!
    Source: I had my ring lands break on piston #4 on my Tacoma and got lucky, only needed a hone and I rebuilt with forged components in my garage.
  14. Jan 13, 2024 at 7:08 PM
    #1274
    e30cabrio
    Want to keep the balance, so no big motor.
    Its different cylinders, and bores look ok to me. I'll know once it is out & apart.
  15. Jan 13, 2024 at 8:19 PM
    #1275
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
  16. Jan 14, 2024 at 8:37 AM
    #1276
    e30cabrio
    With the SC I have more than enough power, I just want a reliable "economical" easy solution, the first choice is simple head work, second bottom end rebuild & valve stem seals/head refresh & finally a good other M52.
    I hope to have it out tomorrow, busy yesterday & today. :(
    M3Tundra-JK likes this.
  17. Jan 15, 2024 at 11:58 AM
    #1277
    e30cabrio
    On the way out.
    armyoffoo likes this.
  18. Jan 15, 2024 at 5:37 PM
    #1278
    e30cabrio
    It's out, I'm freaking dead.
    The clutch, flywheel & pressure plate look very good. I'll be getting a new clutch & pressureplate.
    M3Tundra-JK, AZTundra and armyoffoo like this.
  19. Jan 15, 2024 at 5:53 PM
    #1279
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Good job man! Looking forward to the break down.
    e30cabrio[OP] and AZTundra like this.
  20. Jan 16, 2024 at 4:36 PM
    #1280
    e30cabrio
    Except the Viktor R (they are crap) gasket I see no issues.
  21. Jan 16, 2024 at 6:00 PM
    #1281
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Looks clean to me...was there anything noticeably wrong with the head gasket? Did you find anything with the cylinder head?
  22. Jan 16, 2024 at 6:20 PM
    #1282
    e30cabrio
    Here are a few more, WD 40 in the head to see if it's not sealed.
  23. Jan 17, 2024 at 5:30 AM
    #1283
    e30cabrio
    #5 is not alive. I expected 1&2 to be empty with all the bubbles but no...
  24. Jan 17, 2024 at 5:43 AM
    #1284
    armyoffoo
    armyoffoo Member
    Cypress, TX
    That narrows it down, good work! I was thinking it was something in the head with as clean as the pistons and cylinders looked. Hopefully it is/was the valve seal...and you can focus on the "while you're in there" opportunities :D
  25. Jan 17, 2024 at 3:45 PM
    #1285
    e30cabrio
    Mystery solved. Piston #3 has a crack.
    Looking for M54B30 pistons, rods & a crank, going 3 litre stroker.
  26. Jan 17, 2024 at 3:51 PM
    #1286
    armyoffoo
    armyoffoo Member
    Cypress, TX
    That'll do it! Nice job finding that cracked ring land, can you pick it out? I had the exact same issue on my Tacoma, good excuse for an engine build, considering it could have been much worse.
  27. Jan 17, 2024 at 7:24 PM
    #1287
    e30cabrio
    Builder said he will sell me an S52 which is 3.2 liter for about 1800 more than the 3.0 stroker.
  28. Jan 18, 2024 at 12:14 AM
    #1288
    e30cabrio
    I paid a down payment on the fully rebuilt S52 last night, should have it in 2 weeks.
    Ships like this, freight.
  29. Jan 19, 2024 at 3:48 PM
    #1289
    e30cabrio
    It begins! Tear it down this weekend!
  30. Jan 20, 2024 at 9:19 AM
    #1290
    e30cabrio
    Ready to pressure wash.
    And clean!
    And a bonus!
