2013 Sequoia Limited to TRD FAUX build now with BOOST!
Discussion in 'Sequoia Builds' started by e30cabrio, Apr 19, 2021.
  1. Dec 25, 2023 at 4:24 PM
    #1231
    e30cabrio
    e30cabrio [OP] I'm e30cabrio, I'm a modaholic
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Slowly disassembling the interior, all that remains are passenger under dash, dash & carpet.
    Proof of concept on the amp complete.
    armyoffoo likes this.
  2. Dec 26, 2023 at 10:30 AM
    #1232
    e30cabrio
    Dash & rear carpet out, need a break.
    AZTundra likes this.
  3. Dec 26, 2023 at 3:30 PM
    #1233
    e30cabrio
    Turned out the heater core needs to come out to "properly" r&r the rug. No.
    Exhausted, need to figure out the best way to cut the "new" carpet to get it in.
    Had to pull, push, pry & cut the rug out, these were the tools.
    Black@Blue19 and AZTundra like this.
  4. Dec 27, 2023 at 4:31 PM
    #1234
    e30cabrio
    M Roadster hard rubber differential bushing.
  5. Dec 28, 2023 at 8:46 AM
    #1235
    e30cabrio
    This literally kept me up last night worrying that I would not get it in/get the wires where they needed to be.
    Black@Blue19 and armyoffoo like this.
  6. Dec 28, 2023 at 8:50 AM
    #1236
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    That's making me twitch a bit...are all those loose wires from mods?
  7. Dec 28, 2023 at 9:17 AM
    #1237
    e30cabrio
    I added 3 wires, a red for the remote sub amp, brown to get power to the mirror/radar detector & the purple RCA for audio to the amp.
    That is all oem, I had to unwrap the tape to get the seat heaters from behind the seats (on the center console) so I can move them where they belong on the main center panel console under the HVAC.
  8. Dec 28, 2023 at 9:28 AM
    #1238
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Ahh, I figured if it was OEM it would be wrapped, but that explains it.
  9. Dec 28, 2023 at 12:47 PM
    #1239
    e30cabrio
  10. Dec 28, 2023 at 12:50 PM
    #1240
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Now would be the time to add sound deadening material, even if only a little bit. Anything would be an improvement.
    You have put a ton of work into already.
    excuse if you already said sumtin back a piece.
  11. Dec 28, 2023 at 3:55 PM
    #1241
    e30cabrio
    I thought about it but the car is not going to be voluntarily driven with the top up (only if I'm caught in the rain) It's noisy top down & lighter is better.
  12. Dec 29, 2023 at 8:46 AM
    #1242
    e30cabrio
    This was a hassle.
    As I need to run the O2 wire from the motor to the gauge for my PSB-1 I looked for a passthrough, finding nothing, I searched for 20+ minutes, closest I came was a thread on Bimmerforums with derision over asking where the firewall was.
    I am pretty sure had my interior not been gutted I would not have found this, passenger (right) side (US car) it exits behind the aux air pump.
    I also need to run 2 wires to get the oil & water temp data to the gauges.
  13. Dec 29, 2023 at 11:39 AM
    #1243
    e30cabrio
    Dash is in, I was waiting for bulbs that the entire center console has to be disassembled to r&r that just came so progress will resume.
  14. Dec 29, 2023 at 2:28 PM
    #1244
    e30cabrio
    Black@Blue19 and M3Tundra-JK like this.
  15. Dec 30, 2023 at 9:01 PM
    #1245
    e30cabrio
    Rear plastics are in.
  16. Dec 31, 2023 at 3:07 PM
    #1246
    e30cabrio
    Focals for the rear are in.
    M3Tundra-JK and AZTundra like this.
  17. Jan 2, 2024 at 6:50 AM
    #1247
    e30cabrio
    Weekend progress, wiring was not fun & caused delays.
  18. Jan 2, 2024 at 5:11 PM
    #1248
    e30cabrio
    Almost.
  19. Jan 3, 2024 at 6:11 PM
    #1249
    e30cabrio
    Done, very happy.
  20. Jan 3, 2024 at 7:36 PM
    #1250
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Nicely done, looks good!
    e30cabrio[QUOTED][OP] likes this.
  21. Jan 3, 2024 at 8:07 PM
    #1251
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Looks awesome!
  22. Jan 4, 2024 at 5:34 AM
    #1252
    e30cabrio
  23. Jan 4, 2024 at 12:39 PM
    #1253
    e30cabrio
  24. Jan 4, 2024 at 12:49 PM
    #1254
    e30cabrio
    Boost!
  25. Jan 5, 2024 at 5:26 PM
    #1255
    e30cabrio
    This happened today.
  26. Jan 5, 2024 at 6:21 PM
    #1256
    AZTundra
    Paul
    Phoenix, AZ
    Nice! What is the typical or expected psi for that kit?
  27. Jan 5, 2024 at 6:58 PM
    #1257
    e30cabrio
    Spec page says 7 with the 100mm pulley, I have 85mm.
    https://store.activeautowerke.com/products/active-autowerke-bmw-328i-supercharger-kit-level-1-e36
    Rotrex C38-81 Supercharger
    Mounting bracket, pulleys and belt
    6 larger high-flow fuel injectors
    Active Autowerke Air Filter
    Active Autowerke Dyno-Tuned Software
    All mounting hardware, plumbing, hoses and clamps
    Illustrated instruction manual & installation guide
    2 Year Warranty with free tech support
    Performance Specs
    Power 310 BHP @ 6900 rpm
    Torque 0300 ft-lbs @ 5700 rpm
    Boost Level 07.0 psi
  28. Jan 6, 2024 at 9:12 AM
    #1258
    e30cabrio
    Thanks to finally having boost, my 27 year old dipstick tube O ring failed & blew oil onto the cat scaring the crap out of me with billowing blue smoke. I cleaned it up & replaced the O ring.
    So far so good.
  29. Jan 6, 2024 at 4:38 PM
    #1259
    e30cabrio
    Looks like I blew a cylinder.
    Did a compression test and am 10 to 15 lbs lower than before the SC ( was 188-195) on the still good cylinders (175-185) but have 125 on 3. Oil on top of most pistons 3 is the worst.
    M3Tundra-JK likes this.
  30. Jan 6, 2024 at 4:46 PM
    #1260
    AZTundra
    Paul
    Phoenix, AZ
    Damn, that sucks. Sorry to hear that.
