2013 Sequoia Limited to TRD FAUX build now with BOOST!
Discussion in 'Sequoia Builds' started by e30cabrio, Apr 19, 2021.
  1. Mar 28, 2023 at 6:17 PM
    #901
    e30cabrio
    e30cabrio [OP] I'm e30cabrio, I'm a modaholic
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    They said anything that needs attention will be done & covered.
    Black@Blue19, sd172 and Fotnot like this.
  2. Mar 29, 2023 at 7:50 AM
    #902
    e30cabrio
    Flying 12+ hours? Must have a huuuuge fuel tank in that plane!
  3. Mar 30, 2023 at 9:30 AM
    #903
    e30cabrio
    Good thing I ordered the fuel line adapter. Shame the fuel rail adapter didn't come yesterday. I ordered a second that is out for delivery, I'll keep whichever shows up first.
  4. Mar 30, 2023 at 1:54 PM
    #904
    e30cabrio
  5. Mar 31, 2023 at 9:32 AM
    #905
    e30cabrio
    Got some really cool hose wrenches!
  6. Mar 31, 2023 at 2:36 PM
    #906
    e30cabrio
  7. Apr 1, 2023 at 12:17 PM
    #907
    e30cabrio
    I'm still lean (over 15) the higher pressure I give, the lower the afr number gets (14-15 at 58) which is as high as this FPR will go.
    I ordered an Aeromotive, from Amazon that said it would deliver today but is not coming until tomorrow.
    The fittings are coming today though :p
  8. Apr 1, 2023 at 4:30 PM
    #908
    e30cabrio
    So I got the hose, installed it and am totally flumoxed, it goes from 58 to 40 @ throttle (I am afraid to go wot as the afrs are up to 16). Why would that happen?
    https://streamable.com/5kc6cs
  9. Apr 2, 2023 at 6:18 PM
    #909
    e30cabrio
    New Aeromotive FPR is in, no pressure change, AFR is a bit better
  10. Apr 3, 2023 at 7:50 PM
    #910
    Behr
    Behr New Member
    2012 Supercharged Sequoia Limited
    Can't seem to find how you did this, is this something built into the head unit? What radar are you using?
  11. Apr 3, 2023 at 7:54 PM
    #911
    e30cabrio
  12. Apr 3, 2023 at 9:04 PM
    #912
    Behr
    Behr New Member
    Damn I just picked up a Sony and the function isn't supported on it. Either way thanks for the info!
  13. Apr 4, 2023 at 5:00 PM
    #913
    e30cabrio
    Dropped the Tree off to get the warranty work done, first time it isn't sleeping at home, they grow up so fast.
    They gave me a '23 Tacoma.
    omgboost likes this.
  14. Apr 5, 2023 at 6:15 AM
    #914
    e30cabrio
    Apparently, Air tags are worthless unless an Apple device, that is online is nearby.
    I have an Air tag in the Tree, It has not updated since 12:43 last night so I looked for ways to refresh it.
    https://www.quora.com/How-do-I-make-the-Apple-AirTag-update-its-location-more-often
    How do I make the Apple AirTag update its location more often?
    You don’t. It helps to understand that AirTags don’t know their location or update their location. Your AirTag periodically sends a unique signal identifying itself. Nearby Apple devices (e.g. an iPhone) receive this signal, roughly guess the direction and distance to the AirTag (without notifying the owner of the iPhone). This device then informs Apple of the location of the AirTag, which updates its location in your iCloud account. You cannot configure the frequency of pings.
    The location is updated both when the device has moved and it has contacted an Apple device that has internet access and location services enabled. if the AirTag is in a remote area it may not come in contact with another device for some time. If it is far from a location with internet access then the device will log the contact and location then update only when it has internet access.
    Luckily my remote start has cellular tracking.
  15. Apr 5, 2023 at 2:02 PM
    #915
    e30cabrio
    Got the first of 2 submersible hoses & direct wire kit for the pump.
    Am I deleting the oem power & ground or splicing these to them?
    Very little documentation with this.
  16. Apr 6, 2023 at 8:19 AM
    #916
    e30cabrio
    Dealer sent a pic of the open head, looks new!
    AZBoatHauler and FrenchToasty like this.
  17. Apr 6, 2023 at 12:32 PM
    #917
    S. Equoia
    S. Equoia New Member
    Ontario, Canada
    2015 Sequoia
    So they are just pulling the timing chain/components forward rather than completely off? I heard that method saves a lot of time if you are not doing any timing components but I wonder how your tensioners are doing?
    I think I have some chain slap on cold days and I'm not sure what I should do as I believe my cam tower seal is also seeping as well as the main crank pully seal at the front of the engine... I definitely can't afford it but I think I need to do the cam tower seals, timing chain kit, and that main crank pully seal and might as well redo the valve covers. Too scared to take it somewhere to have it overlooked and then tell me it's going to cost upwards of $7000 CDN... I just want a lift and a new set of tires :(
  18. Apr 6, 2023 at 3:51 PM
    #918
    Karambit
    Karambit New Member
    2008 Toyota Sequoia Limited
    Hey man, couple questions for you.
    Hows the quality of Xtron products, are you still happy with your purchase and also what did the installation entail? I have kids so I am considering a unit from this brand. I currently have the OEM rear entertainment system installed
    Thank You
  19. Apr 6, 2023 at 4:45 PM
    #919
    e30cabrio
    Except to set it up I haven't really used it, it looks good & works well on the Roku, the internal apps are clunky.
    I like it.
    Picked up the Tree, all well, no new sounds & the parts minus the pump are here, pump says tomorrow.
    Fotnot likes this.
  20. Apr 7, 2023 at 5:09 PM
    #920
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    Don't forget to recheck your fuel pressure before firing it back up, once you get it all back together. Let's keep the conversation here so that we stop mucking up the supercharger thread and running folks off. :D
    e30cabrio[OP] likes this.
  21. Apr 8, 2023 at 7:25 AM
    #921
    e30cabrio
    Rebuilt the pump basket with Gates submersible hose.
  22. Apr 8, 2023 at 8:13 AM
    #922
    e30cabrio
    The paperwork Toyota gave me is near impossible to read, here is what they have on the owner portal. When u/l control arms are replaced does a new alignment need to be done?
    If they did it would it be notated?
    3
    4/2023
    RE SEALED LEFT SIDE CAM HOUSING
    RE SEALED LEFT SIDE CAM HOUSING ~|~P/A LH CAM TOWER RESEAL ~|~ ~|~135759 RESEALED CAM HOUSING LEFT SIDE AS PER APPROVAL
    Customer Pay
    4
    4/2023
    CONTROL ARM, UPPER - RIGHT FRONT
    CONTROL ARM, UPPER - RIGHT FRONT ~|~CONTROL ARM, UPPER - REPLACE (LABOR ONLY) ~|~ ~|~135759 REPLACED RIGHT SIDE UPPER CONTROL ARM AS PER APPROVAL
    Customer Pay
    5
    4/2023
    REPLACED RIGHT FRONT LOWER CONTROL ARM
    REPLACED RIGHT FRONT LOWER CONTROL ARM ~|~CONTROL ARM (LOWER) (BOTH SIDE SIDE) - REPLACE ~|~ ~|~135759 REPLACED RIGHT SIDE LOWER CONTROL ARM AS PER APPROVAL
  23. Apr 8, 2023 at 12:31 PM
    #923
    e30cabrio
    FUCK WALBRO!
    Put it together, not fully sewn up because I have bene burned before. NADA, not even thinking about thinking about running. Thought maybe I swapped the lines, tried to swap them NO! the hardlines are different sizes (learned after wrestling them the fuck off)
    Thought maybe I had the hoses in the basket swapped, NO! Gave it electricity, the Walbro isn't pushing shit, nada NOTHING.
    Wired up the Deatchwerks, tried to start, tried to start, STARTED! RUNS & over 100 fucking PSI (Aerootive maxed out to get to 58ish with the Shitbro.
    DIE Walbro, DIE!
    Also, thans for the Tacoma instructions, they made me feel smart because I bought that transmission jack they are using all on my own.
    This was when I was verifying blue is power & soldering the relay to it.
  24. Apr 9, 2023 at 8:43 AM
    #924
    e30cabrio
    So, yesterday I drove it, it was amazing, for 20 minutes, after I FILLED the tank, pressure dropped to 20lbs.
    Dropped the tank this morning, hose @ the pump pulled off when I opened the basket, I erred on the side of not too tight & lost.
    It's back to having pressure but needs to be buttoned up, I hope for the last time.
  25. Apr 9, 2023 at 9:46 AM
    #925
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    Nice build! Curious to hear your thoughts on the loaner Tacoma coming from a Sequoia.
  26. Apr 9, 2023 at 10:24 AM
    #926
    e30cabrio
    Thanks, it was nice but feels really small. The motor was very buzzy, it was top O the line TRD PRO 4x so the best I assume. I can't imagine owning one.
    Butond up, lost fuel sender GAAAAAAA. I know I connected it but apparently not tightly. Not pulling the tank again today, it is full, I'll fill it in 200 miles if I don't drop it again before.
  27. Apr 9, 2023 at 3:10 PM
    #927
    e30cabrio
    After another drive, my fuel gauge came back. It feels like another truck, so much torque!!!
  28. Apr 10, 2023 at 2:13 PM
    #928
    e30cabrio
    Replacement Aeromotive came, installed an AN6 right angle connector at the fuel rail & ran it to the driver side, and ran the pressure gauge inside.
  29. Apr 10, 2023 at 4:19 PM
    #929
    e30cabrio
    I asked via text several times if they aligned the Tree after r&ring the upper & lower control arms, he finally answered.
    HI sorry just seen the text. So alignment was not part of repair extended wty did not cover . Tech said on road test vehicle did track straight - Chris
    Um, why didn't they ask me if I wanted to pay? Now I have to make an appointment & take it for an alignment :(
  30. Apr 10, 2023 at 6:16 PM
    #930
    armyoffoo
    armyoffoo Member
    Cypress, TX
    If you change your fuel line routing to eliminate the return line, you can clean it up a bit. Currently your return side is using the stock line (23902 in image) connected to the hardline, I would just run a short hose directly from the FPR return barb straight down to that hardline and remove 23902. Also, you might want to get an electronic fuel pressure gauge w/sensor if you want to run it in the cab.
