2013 Sequoia Limited to TRD FAUX build now with BOOST!
Discussion in 'Sequoia Builds' started by e30cabrio, Apr 19, 2021.
  1. Jun 7, 2022 at 7:28 AM
    #541
    e30cabrio
    e30cabrio [OP] I'm e30cabrio, I'm a modaholic
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Second board is in, both read the cluster, I found a guy on UPWORK that is writing the code.
    TRDFerguson and S. Equoia like this.
  2. Jun 17, 2022 at 2:09 PM
    #542
    e30cabrio
    It's a big day! We have interaction between the truck & new cluster. It sees the tach & is getting 4HI & water temp and a few other CAN signals from the truck!
  3. Jun 17, 2022 at 3:41 PM
    #543
    S. Equoia
    S. Equoia New Member
    Ontario, Canada
    2015 Sequoia
    1st of it’s kind!
    e30cabrio[OP] likes this.
  4. Jun 17, 2022 at 5:06 PM
    #544
    e30cabrio
    I'm responsible for spending $$$ & doing a bunch of work but the brain behind it and credit goes to Jeff_5_7 I appreciate him absolutely!
    S. Equoia likes this.
  5. Jun 18, 2022 at 12:43 PM
    #545
    e30cabrio
    This just happened! @Jeff_5_7 is my hero, the truck is in 4HI, ABS & traction will go away when I restart or I may need to reset 0 point calibration. I can't use it yet as my breadboard is dying, I have a permanent board & 5V converter coming from Amazon tomorrow.
    TRDFerguson and Jeff_5_7 like this.
  6. Jun 19, 2022 at 8:21 AM
    #546
    e30cabrio
  7. Jun 21, 2022 at 5:53 PM
    #547
    e30cabrio
    Cluster is in, working at 90% function (have a few false errors)
  8. Jun 22, 2022 at 6:26 AM
    #548
    Diablonyc2
    Diablonyc2 New Member
    Do you envision this can be made plug and play for others (with the purchase of the cluster, bezel, and a custom adapter board)?
    I am colorblind and had "a lot of fun" wiring with Crutchfield my Kenwood radio --- that was "soooo much fun" lol.
    Thanks for all of your work on this!
  9. Jun 22, 2022 at 7:11 AM
    #549
    e30cabrio
    There is no part of this that can be P&P. I had to build the harness that is super color-intensive & some wire colors in the wire diagram were different. Then there is sourcing the parts, it took me almost a year to find a junk yard cluster, new is 5-600 the upper dash, different hazard switch and stop start keyless switch were over 600 (new) the keyless switch is currently just filling the hole.
    Then the hard part: The computer that is doing the translation. First you have to solder it and the CAN together & then need the code which belongs to Jeff_5_7. I'd be looking at a pretty but useless cluster without him.
    Diablonyc2 likes this.
  10. Jun 22, 2022 at 9:04 AM
    #550
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    The potential for a plug and play kit does exist but I would say we are far from that. Everything I and @e30cabrio have working so far is done on prototype boards and patch harnesses. As stated 90% of everything is working but still some bugs to flush out.
    The problem is this is expensive and cost add up quick. Not many wrecked 2018-2021 trucks so clusters are hard to find. Everyone would need a patch harness made with a data converter inline and a coded program to run it. These can be made it would just be time consuming. I think it would be a few hundred $ cost to buy a patch harness with the data conveter in it. It would take me money in parts and several several hours to build each one.
    The "patch harness" would make the cluster operation plug and play, however still some issues. You would need trim pieces for the new cluster to install and look right. Maybe the biggest problem is lack of steering wheel controls to run the display on the new cluster. I have a 2018 steering wheel swap so I do have full function of all display screens. (Looking at options here)
    Other things like new hazzard button and ingtion button on the new trim piece could be addressed but it all adds up slowly. I would say easily $500 for a used cluster and patch harness which would be the main parts. Then more smaller stuff to finailze it all.
    omgboost and Diablonyc2[QUOTED] like this.
  11. Jun 22, 2022 at 9:19 AM
    #551
    JRS
    JRS New Member
    2012 DCLB
    What's the hardware look like? I'm guessing two Teensies, each with a CAN card, for incoming and outgoing. If so, how are they linked - SPI?
    Also, with that many messages to filter and modify, is the uC on the incoming able to keep up? Does the Teensy card support hardware level filtering?
  12. Jun 22, 2022 at 9:27 AM
    #552
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    One Teensy with two CAN channels. It seems to keep up pretty well. I read everything in from the truck on Channel 1, catch the frames I want, modify them and send them out on Channel 2. Additionally I read in everything on Channel 2 and pass it out on Channel 1 (data from cluster to truck). Also have a small function that sends a generated message out from the micontroller at a specifided time interval.
  13. Jun 22, 2022 at 9:30 AM
    #553
    JRS
    JRS New Member
    2012 DCLB
    That's awesome. Legitimately surprised. I didn't think a single uC was going to be able to keep up with that much software filtering and 'full-duplex' comm.
    Jeff_5_7 likes this.
  14. Jun 22, 2022 at 9:34 AM
    #554
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Honeslty thinking about cutting it down to one channel only and just injecting new messages into the bus. All of the IDs of the modifided data are "new" so sending it all on the bus, the other ECUs will just ingore it.
    Doing this would be simplier but would have one Bus with ALL messages. For example the cluster would actually see the Old RPM signal and the New RPM signal. It would only react to the new signal since the new address is where it is looking. It would just ingore the old signal
  15. Jun 22, 2022 at 9:39 AM
    #555
    JRS
    JRS New Member
    2012 DCLB
    You'd have to try and characterize the bus load and see if that would increase chances for contention. May not be worth it since the 14s+ have so much more traffic.
    *Edit: forgot this is on a 2.0 model. You'd probably be ok.
  16. Jun 23, 2022 at 6:01 PM
    #556
    e30cabrio
    Directionals/hazards & cruise do not light up, everything else works.
    omgboost, S. Equoia and TRDFerguson like this.
  17. Jun 24, 2022 at 10:14 AM
    #557
    e30cabrio
    This came yesterday, love it!
    Here's the brain behind the cluster, hard to believe it's 600mhz & has a gb of ram!
    omgboost and TRDFerguson like this.
  18. Jun 29, 2022 at 6:41 AM
    #558
    e30cabrio
    Woot! Range & distance plotting are enabled! Jeff is my hero! & thanks to TRDFerguson for giving me access to his '18 to get the data that was needed for this step forward!
  19. Jun 30, 2022 at 5:54 PM
    #559
    e30cabrio
    Last few days have been wiring the steering wheel controls, I bought another in a series of steeringwheels and it came today, it's in great condition but is for a Tacoma so the switch connector does not work.I have a 2020 Sequoia wheel coming tomorrow so that better be the end of that. I gave it the full leather cleaning/rejuvination since it's sitting & waiting for switches.
  20. Jun 30, 2022 at 7:53 PM
    #560
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    How hard is it to change the wheel. I’ve gone to a couple of shops they said it would be extremely expensive to swap
  21. Jun 30, 2022 at 8:07 PM
    #561
    e30cabrio
    As long as you get the right switches it's plug & play, I keep getting Tacoma wheels that have a different clockspring connection.
    The wheels themselves drop right in from 4Runners, Tacomas, Sequoias Tundras etc.
    I'm going to sell two wheels I have, one is in very good condition, the other not so much.
  22. Jul 1, 2022 at 7:44 AM
    #562
    Diablonyc2
    111 degrees outside! I hope the AC is on full blast when you are working on the cluster!
  23. Jul 2, 2022 at 7:18 AM
    #563
    e30cabrio
    That is why I have not finished my air tank & bags & do as much as I can when it's "only" in the high 90s at 4am. It's been humid the last week too which I really hate, if I never go back to Hawaii I'm good with that!
  24. Jul 2, 2022 at 12:11 PM
    #564
    e30cabrio
    Here is the final wheel/switch config.
    It's calculating MPG again from being out, I was hammering it this entire trip, if I was getting more than 7mpg I'd be shocked.
    Love this 2020 Tacoma/4Runner wheel.
  25. Jul 8, 2022 at 12:37 PM
    #565
    S. Equoia
    Ontario, Canada
    2015 Sequoia
    Lemme see!
  26. Jul 8, 2022 at 12:59 PM
    #566
    e30cabrio
    The MPG/Range data?
  27. Jul 8, 2022 at 8:37 PM
    #567
    S. Equoia
    Ontario, Canada
    2015 Sequoia
    No sorry, it seemed like you meant to post a pic of the steering wheel in post #564 but I don’t see a picture.
  28. Jul 9, 2022 at 3:02 AM
    #568
    e30cabrio
    There is a picture in post 564.
    It's this picture.
  29. Jul 9, 2022 at 4:21 AM
    #569
    S. Equoia
    Ontario, Canada
    2015 Sequoia
    I can see it now but not in that post.
    Honestly, amazing job here.
    e30cabrio[OP] and hoof hearted like this.
  30. Jul 9, 2022 at 8:33 PM
    #570
    e30cabrio
    Thanks to Jeff's amazing work cruise function and display is perfect.
    TRDFerguson likes this.
