2013 Non JBL No NAV OEM stereo to Android auto head unit harness
Discussion in 'Audio & Video' started by Shanet421, Oct 11, 2021.
  1. Oct 14, 2021 at 5:43 AM
    Shanet421
    Shanet421 [OP] (Semi) New Member
    San Diego,CA
    What I have been reading is the 3 SWC wires come from this K3 connector. Pins 6,7,8. Should I try to hot wire from K3 pins to pins 8,13,15 here on aftermarket harness?
    EEB444DE-6932-42FD-95D1-AB8AAC47F21B.jpg 5ACE267F-5148-4257-8FAC-A24ADCB692C6.jpg
  2. Oct 14, 2021 at 5:45 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    U can try it and see.
  3. Oct 14, 2021 at 8:20 PM
    Shanet421
    San Diego,CA
    I can’t seem to find confirmation that those are the correct wires to try but I’m very tempted to give it a go.
  4. Oct 15, 2021 at 3:28 PM
    Shanet421
    San Diego,CA
    SUCCESS!
    That was exactly it from post #31. However I can only program volume up/down & track +\-. The other buttons on the steering wheel will not link a function. I’m pretty happy with just the 4 and I can program any function to them.
    I will add the correct harness links when I order.
    Thanks guys!
    BrandonL812 likes this.
  5. Oct 15, 2021 at 5:02 PM
    BrandonL812
    Brandon
    Glad u made good progress. Really frustrating when the seller dont give you the wring stuff and u have to figure it out on your own.
    Shanet421[OP] likes this.
  6. Oct 15, 2021 at 7:46 PM
    Shanet421
    San Diego,CA
    Here is what I ended up ordering to keep as much of the factory controls as I could going to an android auto head unit.
    Harness to allow some SWC function
    US $3.15 24% Off | FEELDO 1PC 16P Car Head Unit Wire Harness Adapter For Toyota OEM Car Radio Harness With 3-Terminal #FD2771
    https://a.aliexpress.com/_mLWdK3C
    Satellite radio antenna adapter
    https://www.crutchfield.com/p_794SATTO1/iDatalink-ACC-SAT-TO1-sTO1.html
    USB retention adapter
    https://www.crutchfield.com/p_120TOYUSB2/Metra-AX-TOYUSB-2-USB-Port-Cable.html
    AM/FM radio extension cable
    US $1.99 | New 35cm Car Antenna Adapter Vehicle AM / FM Radio Aerial Extension Cable
    https://a.aliexpress.com/_mOxICkE
    It’s about $55 in parts to make the swap.
    hope this helps someone in the future
  7. Oct 31, 2021 at 11:53 AM
    Shanet421
    San Diego,CA
  8. Oct 31, 2021 at 6:11 PM
    BrandonL812
    Brandon
    U got everything up and running the way you like?
  9. Oct 31, 2021 at 8:33 PM
    Shanet421
    San Diego,CA
    I did get everything working. All SWC and OEM usb. Last will be the GPS antenna adaptors.
  10. Dec 9, 2023 at 9:29 AM
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    I'm, in the same boat right now.. I have only Volume and track << >> buttons. What did you buy to make all the buttons work?
  11. Dec 9, 2023 at 11:29 AM
    Shanet421
    San Diego,CA
    To be clear that was all I was able to program as well with my current setup…still functioning well after 2 years and suits my needs for now.
  12. Dec 9, 2023 at 3:52 PM
    1BadTundra
    Clinton
    Too Much to List
    I messaged the seller, they said they will send out the correct harness... We shall see. If I have to settle, thats good enough for me too, but would really like everything to work as intended.
  13. Dec 9, 2023 at 4:01 PM
    Shanet421
    San Diego,CA
    Awesome keep us posted on your findings!
    1BadTundra[QUOTED] likes this.
  14. Dec 11, 2023 at 7:52 AM
    1BadTundra
    Clinton
    Too Much to List
    BTW, any ideas for a more secure fit? I dont feel like the lower part of the unit and the upper part of the HVAC panel are supported at all here.
  15. Dec 18, 2023 at 2:17 PM
    1BadTundra
    Clinton
    Too Much to List
    So I got the new harness today and went right to work. All the harnesses connect, but I only have half the buttons on the wheel... I think i need the Non-JBL CanBus harness. Anyone know this part number? It may solve these issues.
  16. Jan 2, 2024 at 5:32 AM
    1BadTundra
    Clinton
    Too Much to List
    Harness #3 attempt will be here in a day or 2... Still no luck. Shipping from China takes forever.
  17. Jan 3, 2024 at 8:31 AM
    1BadTundra
    Clinton
    Too Much to List
    New harness arrived last night... I went right into it. Now I have Volume +/-, and I have the buttons << >> underneath. But now I lost the phone control, Mode button and voice activate. Not a big deal as I use CarPlay, but still... I have buttons that don't work.
    I just received this from the seller. They are asking me to modify the harness like this,Wire HArness.jpg in one last ditch effort.
  18. Jan 3, 2024 at 10:48 AM
    Shanet421
    San Diego,CA
    You have to be an expert at pulling the dash apart by now!
  19. Jan 3, 2024 at 6:29 PM
    #49
    1BadTundra
    Clinton
    Too Much to List
    That's for damn sure!!! All worth it... I finally have it!!! all steering wheel controls finally work!!
  20. Jan 3, 2024 at 6:41 PM
    #50
    1BadTundra
    Clinton
    Too Much to List
    The wire in your harness that plugs into this clip, and this terminal. In the aftermarket harness, there are 2 browns going into this port. cut them from the white plug, but keep them together. They are getting feedback from this wire in the stock harness. Trust me. It was that damn simple!! Hopefully you have this harness. IMG_2395.jpg IMG_2394.jpg
  21. Jan 3, 2024 at 7:02 PM
    #51
    Shanet421
    San Diego,CA
    So light brown from the truck - dark brown on the aftermarket harness?
  22. Jan 4, 2024 at 5:15 AM
    #52
    1BadTundra
    Clinton
    Too Much to List
    Just the dark brown from the aftermarket harness... You can leave the light brown alone from the truck. I was just showing what it was connected to. But yes, disconnect the dark brown from the aftermarket harness. There should be 2 browns in this one pin. Make sure to connect them together, just get them out of the connector.
  23. Sep 15, 2025 at 8:43 PM
    #53
    loni1127
    loni1127 New Member
    Monday
    Loni
    2011 Tundra
    I'm experiencing the same problem with a new to me 2011 tundra stereo upgrade. Does anyone know where to get the wiring harness? I've ordered and returned 3. All have said plug and play none do.
  24. Sep 15, 2025 at 8:44 PM
    #54
    loni1127
    loni1127 New Member
    Monday
    Loni
    2011 Tundra
