2013 Non JBL No NAV OEM stereo to Android auto head unit harness
Discussion in 'Audio & Video' started by Shanet421, Oct 11, 2021.
  1. Oct 11, 2021 at 9:05 AM
    Shanet421
    Shanet421 [OP] (Semi) New Member
    San Diego,CA
    Let me start by saying thanks to @Gravy for sending me this head unit to try out!
    US $93.00 40% Off | 2 Din Android 11 Car Radio For Toyota Tundra Sequoia 2007 2008 2009 2010 2011 2012 2013 Multimedia Player Stereo Navi head unit
    https://a.aliexpress.com/_mO9vZsS
    My truck is a 2013 SR5 without JBL and without factory NAV. Here is a photo of the back of the factory unit and the 6 wire connectors from the truck.
    Here is the new harness that I am using to power the new unit.
    With this harness the unit does power on and all speakers do function. However I can’t get the steering wheel controls to work at all. Am I missing something or should I try a different harness?
    Also there are 4 connectors from the factory stereo that now do not have a place to plug into the new harness.
    There is also 2 connectors from the new harness that do not have a place to plug in.
    Can someone please shed some light on what the functions of the 6 OEM connectors are?
    I do really like the new unit so far but would like it even more if I could keep my steering wheel controls.
    Hoping this tread will help others on the fence about going with an android head unit.
    Thanks in advance for any advice!
  2. Oct 11, 2021 at 9:42 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    You need a steering wheel control interface like a metra axxesss or maestro.
  3. Oct 11, 2021 at 9:49 AM
    Shanet421
    San Diego,CA
  4. Oct 11, 2021 at 9:53 AM
    e30cabrio
    I have never used anything but a mainstream head unit (Pioneer, Kenwood, Alpine etc) Both the Axxess & Maestro need the hu info to flash for your install. It may be possible to use this unit, I have no idea.
    I suggest trying to ask the manufacturer if it is compatible with an interface or for a solution.
    Worst case, you can buy the interface from Crutchfield and return it if it doesn't work.
  5. Oct 11, 2021 at 10:03 AM
    Shanet421
    San Diego,CA
    In the HU settings there is a menu for steering wheel controls to be programmed to do whatever function you wish. The problem is the truck and the HU don’t seem to be speaking the same language.
  6. Oct 11, 2021 at 10:07 AM
    e30cabrio
    I think the thin connector you have nowhere to connect is the steering wheel control, the other is the AM/FM radio antenna. You need an adapter for the antenna.
  7. Oct 11, 2021 at 10:36 AM
    Shanet421
    San Diego,CA
    I believe you are correct on the thin connector. The AM/FM I was able to just plug in the factory wire.
    Now the question is what the 4 coming from the truck are supposed to do?
  8. Oct 11, 2021 at 7:40 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Blue is oem gps. I believe the one to the left of that is your aux input. Other 2 I can't say until I dig into @RainMan_PNW 's awesome wiring schematics.
    If you want to use oem gps antenna with an aftermarket HU: Amazon.com: Adapter for Aftermarket Car Navigation Boxes Connection to OEM GPS Antenna SMA Connector Adapter : Electronics
    Top is rearview camera connector, bottom is a more modern type of antenna connector.
    @Shanet421 I forgot to mention in the texts, with those two pins missing for the harness connector (you can see it in the pics for the manufacturer), there is literally no way for your swc to work, those are the swc signal lines into the HU. So either we get them to send a harness pinned correctly or we repin the one you have using the jbl harness as a donor.
  9. Oct 11, 2021 at 8:13 PM
    Shanet421
    San Diego,CA
    I am almost certain the 16 pin connector I have has wires in all spaces.
  10. Oct 11, 2021 at 8:27 PM
    Gravy
    Yucaipa, California
    Guess I need to dig into the schematics then. Not very motivated at the moment, will do soon.
  11. Oct 11, 2021 at 8:37 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  12. Oct 11, 2021 at 8:55 PM
    Shanet421
    San Diego,CA
    I stumbled upon this
  13. Oct 11, 2021 at 9:48 PM
    Shanet421
    San Diego,CA
    These kinda look a bit off to me
    F9077848-2EC0-4734-9E95-34689611D3C6.jpg 2FA45567-289F-4CC7-B908-35E58E3D346E.jpg
  14. Oct 12, 2021 at 6:40 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Your harness doesnt come with the brown canbus box?
  15. Oct 12, 2021 at 7:03 AM
    Shanet421
    San Diego,CA
    I do have a harness with the brown canbus but none of the white connectors fit my truck
  16. Oct 12, 2021 at 8:31 AM
    BrandonL812
    Brandon
    Can you look at the back of your new radio and see if there are 2 wires, 1 labeled “key1” and “key 2”. Make sure they are connected to each other.
    then try program the buttons again.
  17. Oct 12, 2021 at 9:34 AM
    BrandonL812
    Brandon
    They probably send you the incorrect harness if non of the white connector fit the truck. I would request a new harness with the canbus box. Show them pictures of how it doesn’t fit.
  18. Oct 12, 2021 at 10:13 AM
    Shanet421
    San Diego,CA
    No wires labeled key. Working with the manufacturer has been dicey so far.
  19. Oct 12, 2021 at 10:53 AM
    BrandonL812
    Brandon
    Yeah. That’s not good. Can you return it?
  20. Oct 12, 2021 at 12:13 PM
    Shanet421
    San Diego,CA
    A fellow member loaned it to me to see if I liked it and if it met my needs.
    Currently not meeting the SWC needs
    Every one of those AliExpress android head units specific to 2nd gens say you can keep your SWC. They all take the 16 pin aftermarket terminal. They must have a harness figured out for my model.
  21. Oct 12, 2021 at 12:27 PM
    BrandonL812
    Brandon
    Yeah. Have. But they are resellers. Most of them have no clue what’s going on. i have the joying unit and they are better at providing after sale support.
  22. Oct 12, 2021 at 4:01 PM
    Shanet421
    San Diego,CA
    I just need the correct harness that makes this thing work and keep all the features as advertised.
  23. Oct 12, 2021 at 4:46 PM
    BrandonL812
    Brandon
    Yeah. If u can get the correct harness, you’ll be golden.
  24. Oct 12, 2021 at 5:12 PM
    BrandonL812
    Brandon
    I wonder if the radio’s pin is the same as this harness?
    US $27.13 | SKYFAME 16Pin Car stereo Wire Harness canbus decoder For Lexus GX470 Power cable with canbus box
    https://a.aliexpress.com/_mMii58I
    only need the harness. Possibly use the current canbus.
  25. Oct 12, 2021 at 7:02 PM
    Shanet421
    San Diego,CA
    Very nice find and I’ve been digging!
    You may be on to something and I appreciate the effort.
    I usually only get 1 question per day to the manufacturer answered so gotta make em simple and to the point
  26. Oct 12, 2021 at 7:10 PM
    BrandonL812
    Brandon
    Good luck. Hopefully the manufacturer can do the right thing and help you out. Post back your update. Im curious what they can help you with.
  27. Oct 12, 2021 at 7:24 PM
    Shanet421
    San Diego,CA
    Ya the one you posted is the Hail Mary cover all bases harness but I think I just need 3 - 4 more wires plugged in to get the SWC to work
    BrandonL812 likes this.
  28. Oct 12, 2021 at 7:49 PM
    Shanet421
    San Diego,CA
    Well from these I believe I am dealing with K1 , K2 , K25 , K27.
    The last 20 pin I’m not certain but I think K3 or K4 but can’t confirm that yet.
    Now I gotta find out what the function is of each. Need more wire diagrams.
    EA5BF456-35ED-4313-B3F7-2D5342D45FC3.jpg 40ED3431-BF38-4FEF-ABE5-6746CD360163.jpg 9E5F3D1E-9F48-4487-B6A9-97A246881096.jpg 6C4567AC-F423-4A66-8930-512E944B33E1.jpg
  29. Oct 12, 2021 at 9:44 PM
    Gravy
    Yucaipa, California
    Its looks like the one we want is K25 (small 8pin connector) from what I can tell, haven't found the pinout from the connector itself yet. We need 3 of what looks like 5 pins being used. Pins for SW1, SWG and SW2. Toyota is using wire color labels I'm not used to, so the colors are: Sw1 (LG) light green?, SwG (BR) brown or black/red?, and Sw1 (GR) green or green/red. We need to connect those to the corresponding wires in your harness (connector D(the one I mistook for your cam con)). So the connector is there, its just not matching your trucks connector. Can't hardly blame them after seeing how many connector variations toyota decided to use...
  30. Oct 12, 2021 at 9:51 PM
    Gravy
    Yucaipa, California
    LOL at that harness Brandon linked, that thing is insane, the ultimate toyota harness :p. Canbus decoder is for the JBL victimized trucks. When you get a chance Shane, take/post some pictures of the wires going into your trucks connectors and should be able to sort it out in no time.
