2011 5.7 falling on its face.
Discussion in '2nd Gen Tundras (2007-2013)' started by RogueTundra, Apr 14, 2019 at 4:49 PM.
  1. Apr 15, 2019 at 5:39 AM
    MT Madman
    MT Madman Seasoned Citizen
    Hawk Point MO
    2015 MGM Tundra Limited CM 4x4 Off Road
    Experienced this when I had mud tires on, the rubber would flex on a fast lane change or heavy acceleration, went to Michelin ATs and the problem disappeared. I have Toyos now and they pretty much suck if I take off hard. Just to set it straight, I don't even want to spin my tires on take off. It's like why lose rubber and traction, I want to get up go!
  2. Apr 15, 2019 at 5:46 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    You mentioned Muffler and Intake delete. What Intake did you delete :confused:
    15whtrd likes this.
  3. Apr 15, 2019 at 6:13 AM
    15whtrd
    15whtrd Mr. Blonde
    White 2015 Tundra DC SR5 TRD 4x4 5.7L
    TRD Pro suspension, 2015 TRD Pro headlights, 20% ceramic tinted windows, charcoal filter delete, aFe drop in pro s dry air filter, TRD airflow accelerator, TRD oil fill cap, TRD 18 psi radiator cap, BDX Bullydog tuner, Weathertech floor mats front and rear, rear seat fold down mod, Tyger soft tonneau cover, Linex with uv protection, TRD swaybar, TRD center caps, TRD Pro grille insert, aluminum oil filter canister, Real truck tailgate seal, Pop-n-lock tailgate lock actuator, rear diff breather relocate.
    Yeah what intake? Never heard of that. Sounds like a really bad idea.
  4. Apr 15, 2019 at 6:25 AM
    CMB
    CMB New Member
    Cecil County MD.
    I can attest to that. Just this weekend my TRD CAI tube came loose from the housing and tripped Track-Control, Check Engine and 4Wheel Low lights. Un-hooked Neg battery cable to re-set everything and truck didn't want to start or stay running. Didn't notice it right away but after reading on here about loss of positive vacuum for the engine, I checked it over again and found the separation. I caused it when chickened-out with how tight I clamped the tube on install. Re-attached and clamped tighter+ I'll add clamps when they're delivered today.
    15whtrd likes this.
  5. Apr 15, 2019 at 7:42 AM
    ChargedToyo
    ChargedToyo New Member
    Mario
    2010 Grey
    DAP tune gets rid of the torque management. Definitely helped in those quick take offs obviously not floored but 75-80% throttle with the nannies off it wouldn't stop me flooring from a dead stop. The shifts were quicker and held the rpm longer so you didn't on occasion get the troll death thud.
  6. Apr 15, 2019 at 9:20 AM
    Dr_Al
    Dr_Al New Member
    Al
    Disabling the trac control is worthless unless you disable the stability control. Trac control is only for going in a straight line. As soon as you even slightly turn the steering wheel the stability control kicks in and acts just like the traction control.
  7. Apr 15, 2019 at 9:33 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Pulls out MAF... "HAI GUYZ WUTZ HAPPENZ!???"
    15whtrd likes this.
