2011 5.7 falling on its face.
Discussion in '2nd Gen Tundras (2007-2013)' started by RogueTundra, Apr 14, 2019.
  1. Apr 14, 2019 at 4:49 PM
    RogueTundra
    RogueTundra [OP] New Member
    Tyler
    2011 Limited CrewMax
    7" BDS Lift. 35" RBPs. 20x14 Fuel Mavericks. K&N Intake. Muffler delete.
    Ok so sometimes when I leave a red light or floor it to get around someone and just pin it my truck will shift to second gear and fall flat on its face. It will actually slow down with my foot to the floor. It will also flash the traction control light. Even if its fully turned off. It runs good in first but after that nothing. Doesnt always do this though.
    Any ideas what anyone might think it is? Ive searched and havent found much related to this. Any info would help! Thank you.
    Truck is on 35s and has an intake and muffler delete.
  2. Apr 14, 2019 at 5:00 PM
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    2011 Silver Tundra SR5 4WD DC
    DAP Tune, Truxedo ProX15 bed cover, WildPeak AT3s
    Do you actually push the gas pedal to the floor?
  3. Apr 14, 2019 at 5:03 PM
    RogueTundra
    Tyler
    Yes I do. But when it falls on its face I try to pedal it to get it to wake back up and it never does.
  4. Apr 14, 2019 at 5:22 PM
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    hmmm... might try just going 50-75% down on the pedal and see if you get the acceleration you want.
  5. Apr 14, 2019 at 5:24 PM
    RogueTundra
    Tyler
    Its bad. Like I said the traction control light will flash and it will almost completely shut down when its doing this.
  6. Apr 14, 2019 at 5:29 PM
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    Don't ever push the gas pedal to the floor, try only going 50%, maybe 75% to the floor under "hard" acceleration. That's what I'm getting at.
  7. Apr 14, 2019 at 5:30 PM
    Dr_Al
    Dr_Al New Member
    Al
    You are spinning a rear tire and the computer is applying the brakes. Turn off your traction control. But be prepared to replace tires more often as you will be wearing them out.
    Sunnier and 15whtrd like this.
  8. Apr 14, 2019 at 5:32 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Probably just watched dukes of hazard too many times
  9. Apr 14, 2019 at 5:32 PM
    Grumpy Uncle
    Pat
    CO
    Are you hitting the RPM limits? If so that may be the truck doing it's own thing to save itself.
    Black Wolf likes this.
  10. Apr 14, 2019 at 5:34 PM
    sf319
    sf319 New Member
    Utah
    2014 CM Barcelona Red SR5 5.7
    Dash Cam|PowerStop Z36|DIY bed rails|DIY Pop-n-Lock|LED interior
    I noticed this too in my '07 5.7, however if I turn on "Tow/Haul" it seems to be much better behaved. I never realized it was actually spinning a tire until the last couple days with the window down and heard the tires spinning. Stupid Nannies!
    :burnrubber:
  11. Apr 14, 2019 at 5:39 PM
    ardnutoz
    ardnutoz ‍
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    Its probably your trucks steering wheel/ gas pedal actuator inducing the problem. You may get away with it a few times but sooner than later it will stop.
    Try cleaning the maf.
    More times than not its comical to watch people do that since typically they are in a monumental hurry to stop.
    Sundown5oh, Pudge and sf319 like this.
  12. Apr 14, 2019 at 5:51 PM
    RogueTundra
    Tyler
    I know the tires arent spinning. Im not hitting the limiter. I dont even have to be high up in RPM for it to happen. Like I said it runs great in 1st gear always and sometimes will hold WOT just fine up to 80mph. But other times it will shift to second and just shut down. I can do burnouts and it wont apply traction control with it disabled. But even if I do a pull with the TC fully disabled it will fall on its face in second and kick on traction control.
    Im trying to figure out why. Like I said. I can fully disable TC and do a big burnout. But then I could also just hit WOT and it will downshift and completely die out and engage TC EVEN WITH IT DISABLED. Again no tire spin either or rev limiter.
  13. Apr 14, 2019 at 6:02 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    2011 was the first year for the Toyota Trailer Sway Control safety feature. Anyone had any issues related to that that might then show up as sluggish acceleration (or, AKA, cutting spark)?
  14. Apr 14, 2019 at 6:12 PM
    ardnutoz
    ardnutoz ‍
    OZ
    SE-PA
    just keep at it these abuse induced conditions are self diagnosing. ;)
    Grumpy Uncle likes this.
  15. Apr 14, 2019 at 6:15 PM
    Grumpy Uncle
    Pat
    CO
    That's some solid advice right there.
  16. Apr 14, 2019 at 6:17 PM
    RogueTundra
    Tyler
    Starting to feel alot like Pirate4x4 in here lol Yes I use my truck and it gets abused from time to time. But we should all be able to floor our trucks without TC kicking in with NO tire spin and it COMPLETELY DISABLED.
    CaptSpaulding likes this.
  17. Apr 14, 2019 at 6:34 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    NOT if you're the insurance industry.
  18. Apr 14, 2019 at 6:44 PM
    CaptSpaulding
    CaptSpaulding ...ain't nothin but nothin
    Jake
    2010 White DC 4x4
    Without any experience or knowledge of either....could a wheel sensor or ABS sensor be causing the issue? The ABS sensors are very exposed and vulnerable to damage.
    And I agree, if you want to punch it you shouldn't have issues doing so. Ultimately, it's your wallet and your Tundra. I don't often floor it on the streets, but I know I hit WOT often while offroading, and expect my truck to perform as such when I do
    RogueTundra[OP] likes this.
  19. Apr 14, 2019 at 6:53 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    It sounds like your transmission is probably worn out from rough use.
  20. Apr 14, 2019 at 6:54 PM
    RogueTundra
    Tyler
    Thank you! Someone who gets it haha. I have thought about it possibly being a sensor purely because traction control is kicking on when it shouldnt....even when its fully disabled. If it was just falling on its face without TC coming on I might look into fuel delivery. I run Premium too.
  21. Apr 14, 2019 at 6:54 PM
    RogueTundra
    Tyler
    Ive thought this too. Wondering if the trans is slipping and the truck thinks that the tires are slipping when they arent.
  22. Apr 14, 2019 at 7:05 PM
    VTYOTA
    VTYOTA I DECLARE BANKRUPTCY!!
    Howard
    'Merica
    2014 SS CM TRD
    How are you disabling TC? I know in my Gen3 it's a whole process. I'm not sure about a Gen2. You might not be fully disabling it.
  23. Apr 14, 2019 at 7:07 PM
    RogueTundra
    Tyler
    I push the button once. The "auto LSD" light come on. I then push and hold it for about 3 seconds. The "auto LSD" light goes away but then comes back on along with the yellow "trac off" light.
    VTYOTA[QUOTED] likes this.
  24. Apr 14, 2019 at 7:10 PM
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    In my Gen3 I have to hold it again for 3 seconds, then I get a message saying, "Traction Control is Off". So my process is push button, hold for 3 seconds, then hold for 3 seconds again.
    Again, the process I described might be only for a Gen3. Just a thought.
  25. Apr 14, 2019 at 7:36 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Exactly my guess
  26. Apr 14, 2019 at 7:43 PM
    CaptSpaulding
    Jake
    2010 White DC 4x4
    Just ran it by my pops, who is a retired lifetime Chevy mechanic, his first suggestion was the trans as well
  27. Apr 14, 2019 at 7:53 PM
    15whtrd
    15whtrd Mr. Blonde
    How about a zero point calibration. Look into it
    Watt maker, Adam and BTBAKER like this.
  28. Apr 14, 2019 at 9:10 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Pretty sure what you're experiencing is the PCM, Power control module. The computer is anticipating a potential loss of control caused by the hard acceleration. Turning TC off does help but it's not the "cure all." I never experienced this in my '07 or my '10 but my '16 seems to be much more sensitive. I installed a Bully Dog tuner and that pretty much fixed the issue.
    15whtrd likes this.
  29. Apr 14, 2019 at 9:32 PM
    trdprobped17
    trdprobped17 New Member
    Your truck’s power is causing a wheel to spin and the traction control is kicking in. Turning off the traction control will fix it, but, each time you park the truck and start it up, you will have to do the same thing over again. The Bully Dog tuner has the settings where you can permanently disable the traction control. Or you can buy a traction control delete module that someone on here makes and sell.
  30. Apr 15, 2019 at 5:10 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    To me, "falling flat on its face" means sudden loss of engine power and rpm, like cutting fuel or spark. What exactly is happening to engine rpm during this behavior? You have said it isn't hitting the rev limiter, but is that because the engine is not responding to WOT pedal input?
    If the engine rpm isn't responding to WOT, then it's not a slipping transmission. If the engine rpm is not responding, then you have a controls issue (pedal, throttle position sensor, engine speed sensor, etc), or possibly environmental control system haywire. Beyond shotgunning with parts exchange, diagnosing such problems is probably going to require professional help.
    Sunnier likes this.
