2010 CrewMax Limited “Asphalt Warrior”
Discussion in '2nd Gen Builds (2007-2013)' started by Rube207, Nov 29, 2019.
  1. Mar 2, 2021 at 5:27 AM
    Zero One Actual
    You can shift so much faster and smoother now. The plush leather on your hands is like a warm coconut bath on your finger tips.
  2. Apr 29, 2021 at 1:51 PM
    Krisanna79
    Krisanna79 New Member
    13 crewmax tss 4x4
    how do you like the sway bar?
    Any tips on painting the exterior door handles?
    that gauge cluster is purty.
    love the sequoia lights, I’m planning this swap as well, are the lights brighter than the 2nd gen ones?
  3. Apr 29, 2021 at 5:29 PM
    Rube207
    Rube207 [OP] New Member
    Rob
    Atlanta
    2010 Pyrite Mica Limited CM
    The sway bar is great. I found a used one for $100 on Craigslist, so it felt too good to pass up. Don’t know if I would buy one new, but a lot of people swear by it.
    As along as you sand the texture down smooth, painting the handles was just like any other spray paint job. Spend your time on prep and it will pay off in the end.
    The OEM sequoia headlights are full LED, so not only do they look way better than the original lights, but they are WAY brighter than stock. Night and day difference in light output and they make the truck look better than brand new in my opinion.
    Thanks for the compliments!
    Krisanna79[QUOTED] likes this.
  4. Jun 2, 2021 at 1:06 PM
    wv00097
    wv00097 New Member
    Wes
    AZ > GA
    2011 SR5 TRD OR
    BDS 7 w/ Fox 2.5 OME Dakar leaf pack CB +2 shackles 18x9 Method 308 +18mm 37x12.5 Toyo AT3 TRD intake/exhaust Infinity Kappa w/ Pioneer HU
    Blacked out airbag emblem? Heard that's a tough process to do.
    Love the 2nd gen! Tasteful upgrades too. Love the sequoia headlights.
  5. Jun 2, 2021 at 1:24 PM
    Rube207
    Rob
    Atlanta
    Thanks!
    The blacked out airbag logo wasn’t bad. I masked it and painted in place with light coats.
  6. Jun 2, 2021 at 1:57 PM
    wv00097
    wv00097 New Member
    Wes
    AZ > GA
    2011 SR5 TRD OR
    Lol I guess I should've thought about that. Was reading about disassembling the entire steering wheel and airbag in order to do this... seemed like too much work for me.
    Now I have a new mod for this weekend, thank you sir.
    Rube207[QUOTED][OP] likes this.
  7. Jun 3, 2021 at 5:01 PM
    WVI
    WVI New Member
    @008 Tundra Limited
    Very nice. I really like those Toyota wheel caps!
    Rube207[OP] likes this.
  8. Jan 11, 2022 at 5:45 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Hey @Rube207
    Ordering a few black interior parts soon.
    Wondering what it took to move the tow/haul button to the right knee area?
  9. Jan 11, 2022 at 7:32 PM
    Rube207
    Rob
    Atlanta
    @Shanet421 Hey Shane. Pretty sure the wire was long enough so I just rerouted it and plugged it back in. I really don’t remember it being any trouble at all.
    One thing to keep in mind: not all of the switches fit in all of the locations. They are all keyed differently and only fit in corresponding spots in the dash. Idiot-proofing at the factory I assume. I may have cut the “key” tab off the switch to make it fit where I wanted to, but I don’t recall.
  10. Jan 12, 2022 at 5:18 AM
    Shanet421
    San Diego,CA
    Thanks for that info. Also to triple check the part number for the black instrument cluster bezel is 55410-0C030?
    That and the hvac climate control panel will be next to go black. Last will be the power window switch bezels. I see you painted yours. How are they holding up over time? Do you know if Toyota made these black at the factory?
  11. Jan 12, 2022 at 5:41 AM
    Rube207
    Rob
    Atlanta
    Yes, I’m fairly certain that 55410-0C030 is the correct # for the black instrument cluster surround.
    To my knowledge there are no OEM black window switch bezels. There could be another sequoia part I’m not aware of though. I painted mine with textured black and they are holding up perfectly. Same paint I used on my shifter bezel. Pretty rugged stuff I would say.
  12. Jan 12, 2022 at 6:55 PM
    Shanet421
    San Diego,CA
    Man why does the “grade” cluster bezel cost $100 more then the grey one. You have the black OEM one? How do you like it? Is it easy to keep clean like the grey? Doing it over again would you go a different way? The photos I see online don’t do justice to the real thing I hope.
  13. Jan 13, 2022 at 4:32 AM
    Rube207
    Rob
    Atlanta
    Yeah, I like it a lot more than the grey one. It’s just textured flat black, so it’s nothing special, but I think it looks a lot better. Look back at this post for some pics of mine.
    Another option would be to scuff and paint your stock bezel. You could get a non-textured black bezel this way. The silver gauge trim rings are removable, so you could even leave those silver, or paint them a different contrasting color.
    Shanet421[QUOTED] likes this.
  14. Jan 13, 2022 at 5:21 AM
    Shanet421
    San Diego,CA
    Looking at those pics I seem to like your painted shifter part better then the cluster. In terms of color and sheen. I’m torn as what to do. Paint all these parts and hope for the best at a cost of $100 or so or spring for $500 and get all the pre-finished black OE parts. Plus the $120 reman climate panel. My truck is 4x4 so will also need Control Switch - Toyota (84724-0C020)
    :notsure:
  15. Jan 13, 2022 at 10:41 AM
    Rube207
    Rob
    Atlanta
    Paint it. You can always buy the black stuff later. Plus there’s prob not a ton of resale value on your OE parts.
